Public Slots | Signals | Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
pqPVApplicationCore Class Reference
pqPVApplicationCore is the application code used by ParaView-based applications that use more of ParaView's functionality than that provided by pqApplicationCore such as the the selection manager, animation manager etc. More...
#include <pqPVApplicationCore.h>
Inheritance diagram for pqPVApplicationCore:
Collaboration diagram for pqPVApplicationCore:
Public Slots
void applyPipeline ()
 A useful slot to trigger an apply on the pipeline. More...
void quickLaunch ()
 Pops-up the quick launch dialog. More...
void startSearch ()
 Pops-up the search dialog if the focused widget is QAsbstractItemView type. More...
- Public Slots inherited from pqApplicationCore
void prepareForQuit ()
 Applications calls this to ensure that any cleanup is performed correctly. More...
void quit ()
 Calls QCoreApplication::quit(). More...
void updateAvailableReadersAndWriters ()
 Update the available readers and writers using the factories. More...
void render ()
 Renders all windows. More...
void loadConfiguration (const QString &filename)
 Load configuration xml. More...
void loadConfigurationXML (const char *xmldata)
Signals
void aboutToShowQuickLaunch ()
 Emitted whenever the quickLaunch dialog is about to show. More...
void triggerApply ()
- Signals inherited from pqApplicationCore
void aboutToWriteState (QString filename)
 Fired before a state file, either python or XML, is written. More...
void aboutToReadState (QString filename)
 Fired before a state file, either python or XML, is read. More...
void aboutToLoadState (vtkPVXMLElement *root)
 Fired before a state xml is being loaded. More...
void stateLoaded (vtkPVXMLElement *root, vtkSMProxyLocator *locator)
 Fired when a state file is loaded successfully. More...
void stateSaved (vtkPVXMLElement *root)
 Fired to save state xml. More...
void undoStackChanged (pqUndoStack *)
 Fired when the undo stack is set. More...
void loadXML (vtkPVXMLElement *)
 Fired on loadConfiguration(). More...
void forceFilterMenuRefresh ()
 Fired when the filter menu state needs to be manually updated. More...
void updateMasterEnableState (bool)
 Fired when master changed. More...
void clientEnvironmentDone ()
 Fired when the ParaView Client infrastructure has completed setting up the environment. More...
 pqPVApplicationCore (int &argc, char **argv, vtkCLIOptions *options=nullptr, bool addStandardArgs=true, QObject *parent=nullptr)
 ~pqPVApplicationCore () override
pqSelectionManager * selectionManager () const
 Provides access to the selection manager. More...
pqAnimationManager * animationManager () const
 Provides access to the animation manager. More...
pqTestUtility * testUtility () override
 Provides access to the test utility. More...
pqPythonManager * pythonManager () const
 Provides access to the python manager. More...
virtual void registerForQuicklaunch (QWidget *)
 ParaView provides a mechanism to trigger menu actions using a quick-launch dialog. More...
void loadStateFromPythonFile (const QString &filename, pqServer *server, vtkTypeUInt32 location=0x10)
- Public Member Functions inherited from pqApplicationCore
 pqApplicationCore (int &argc, char **argv, vtkCLIOptions *options=nullptr, bool addStandardArgs=true, QObject *parent=nullptr)
 Initializes the ParaView application engine. More...
pqObjectBuilder * getObjectBuilder () const
 Get the Object Builder. More...
void setUndoStack (pqUndoStack *stack)
 Set/Get the application's central undo stack. More...
pqUndoStack * getUndoStack () const
void registerManager (const QString &function, QObject *manager)
 Custom Applications may need use various "managers" All such manager can be registered with the pqApplicationCore so that that can be used by other components of the application. More...
QObject * manager (const QString &function)
 Returns a manager for a particular function, if any. More...
void unRegisterManager (const QString &function)
 Unregisters a manager for a particular function, if any. More...
QHelpEngine * helpEngine ()
 provides access to the help engine. More...
void registerDocumentation (const QString &filename)
 QHelpEngine doesn't like filenames in resource space. More...
pqServerManagerObserver * getServerManagerObserver ()
 ServerManagerObserver observer the vtkSMProxyManager for changes to the server manager and fires signals on certain actions such as registeration/unregistration of proxies etc. More...
pqServerManagerModel * getServerManagerModel () const
 ServerManagerModel is the representation of the ServerManager using pqServerManagerModelItem subclasses. More...
pqInterfaceTracker * interfaceTracker () const
 Locates the interface tracker for the application. More...
pqLinksModel * getLinksModel () const
 pqLinksModel is the model used to keep track of proxy/property links maintained by vtkSMProxyManager. More...
pqMainWindowEventManager * getMainWindowEventManager () const
 pqMainWindowManager manages signals called for main window events. More...
pqPluginManager * getPluginManager () const
 pqPluginManager manages all functionality associated with loading plugins. More...
pqProgressManager * getProgressManager () const
 ProgressManager is the manager that streamlines progress. More...
pqRecentlyUsedResourcesList & recentlyUsedResources ()
 Returns the set of recently-used resources i.e. More...
pqServerConfigurationCollection & serverConfigurations ()
 Returns the collection of server configurations known. More...
pqSettings * settings ()
 Get the application settings. More...
void clearSettings ()
 Clears the settings. More...
vtkPVXMLElement * saveState ()
 Save the ServerManager state to a XML element. More...
bool saveState (const QString &filename, vtkTypeUInt32 location=0x10)
 Save the ServerManager state to a file. More...
void loadState (vtkPVXMLElement *root, pqServer *server, vtkSMStateLoader *loader=nullptr)
 Loads the ServerManager state. More...
void loadState (const char *filename, pqServer *server, vtkSMStateLoader *loader=nullptr)
 Load state xml from a file. More...
void loadStateFromString (const char *xmlcontents, pqServer *server, vtkSMStateLoader *loader=nullptr)
 Loads state from an in-memory buffer. More...
void clearViewsForLoadingState (pqServer *server)
void loadStateIncremental (vtkPVXMLElement *root, pqServer *server, vtkSMStateLoader *loader=nullptr)
 Same as loadState() except that it doesn't clear the current visualization state. More...
void loadStateIncremental (const QString &filename, pqServer *server, vtkSMStateLoader *loader=nullptr)
void setLoadingState (bool value)
 Set the loading state flag. More...
bool isLoadingState ()
 Check to see if its in the process of loading a state Reliance on this flag is chimerical since we cannot set this ivar when state file is being loaded from python shell. More...
pqServer * getActiveServer () const
 returns the active server is any. More...
QString getTranslationsPathFromInterfaceLanguage (QString prefix, QString locale)
 returns a path to a directory containing a translation binary file located in a path specified by the PV_TRANSLATIONS_DIR environment variable or in the resources directory. More...
QTranslator * getQtTranslations (QString prefix, QString locale)
 returns a QTranslator with a loaded qm file. More...
QString getInterfaceLanguage ()
 returns interface language in use in a locale code form. More...
 ~pqApplicationCore () override
 Destructor. More...
void _paraview_client_environment_complete ()
 INTERNAL. More...
static pqPVApplicationCore * instance ()
 Returns the pqPVApplicationCore instance. More...
- Static Public Member Functions inherited from pqApplicationCore
static pqApplicationCore * instance ()
bool eventFilter (QObject *obj, QEvent *event) override
 Override event filter in order to catch file association mechanism. More...
QPointer< pqSelectionManager > SelectionManager
QPointer< pqAnimationManager > AnimationManager
pqPythonManager * PythonManager
QList< QPointer< QWidget > > QuickLaunchMenus
- Protected Attributes inherited from pqApplicationCore
bool LoadingState
pqLinksModel * LinksModel
pqObjectBuilder * ObjectBuilder
pqInterfaceTracker * InterfaceTracker
pqMainWindowEventManager * MainWindowEventManager
pqPluginManager * PluginManager
pqProgressManager * ProgressManager
pqServerManagerModel * ServerManagerModel
pqServerManagerObserver * ServerManagerObserver
pqUndoStack * UndoStack
pqRecentlyUsedResourcesList * RecentlyUsedResourcesList
pqServerConfigurationCollection * ServerConfigurations
pqSettings * Settings
QHelpEngine * HelpEngine
QPointer< pqTestUtility > TestUtility
- Protected Slots inherited from pqApplicationCore
void onStateLoaded (vtkPVXMLElement *root, vtkSMProxyLocator *locator)
void onStateSaved (vtkPVXMLElement *root)
void onHelpEngineWarning (const QString &)
Definition at line 25 of file pqPVApplicationCore.h.
◆ pqPVApplicationCore()
pqPVApplicationCore::pqPVApplicationCore ( int &  argc,
char **  argv,
vtkCLIOptions *  options = nullptr,
bool  addStandardArgs = true,
QObject *  parent = nullptr
◆ ~pqPVApplicationCore()
pqPVApplicationCore::~pqPVApplicationCore ( )
override
◆ instance()
static pqPVApplicationCore* pqPVApplicationCore::instance ( )
inlinestatic
If no pqPVApplicationCore has been created then return nullptr.
Definition at line 39 of file pqPVApplicationCore.h.
◆ selectionManager()
pqSelectionManager* pqPVApplicationCore::selectionManager ( ) const
Selection manager provides access to the ParaView wide data selection mechanism. This must not be confused with the active-object selection.
◆ animationManager()
pqAnimationManager* pqPVApplicationCore::animationManager ( ) const
Animation manager helps with the
◆ testUtility()
pqTestUtility* pqPVApplicationCore::testUtility ( )
Reimplemented from pqApplicationCore.
◆ pythonManager()
pqPythonManager* pqPVApplicationCore::pythonManager ( ) const
This is non-nullptr only when paraview is compiled with python support i.e. PARAVIEW_USE_PYTHON is ON.
◆ registerForQuicklaunch()
virtual void pqPVApplicationCore::registerForQuicklaunch ( QWidget *  )
Applications can register menus action from which should be launch-able from the quick-launch dialog. Typical candidates are the sources menu, filters menu etc.
◆ loadStateFromPythonFile()
void pqPVApplicationCore::loadStateFromPythonFile ( const QString &  filename,
pqServer *  server,
vtkTypeUInt32  location = 0x10
◆ applyPipeline
void pqPVApplicationCore::applyPipeline ( )
slot
This is just emitting a signal usually caught by a pqApplyBehavior.
◆ quickLaunch
void pqPVApplicationCore::quickLaunch ( )
slot
◆ startSearch
void pqPVApplicationCore::startSearch ( )
slot
◆ aboutToShowQuickLaunch
void pqPVApplicationCore::aboutToShowQuickLaunch ( )
signal
This can be used to update the menu items (QActions) that will be shown in the quick-launch dialog.
◆ triggerApply
void pqPVApplicationCore::triggerApply ( )
signal
◆ eventFilter()
bool pqPVApplicationCore::eventFilter ( QObject *  obj,
QEvent *  event
◆ SelectionManager
QPointer<pqSelectionManager> pqPVApplicationCore::SelectionManager
Definition at line 113 of file pqPVApplicationCore.h.
◆ AnimationManager
QPointer<pqAnimationManager> pqPVApplicationCore::AnimationManager
Definition at line 114 of file pqPVApplicationCore.h.
◆ PythonManager
pqPythonManager* pqPVApplicationCore::PythonManager
Definition at line 116 of file pqPVApplicationCore.h.
◆ QuickLaunchMenus
QList<QPointer<QWidget> > pqPVApplicationCore::QuickLaunchMenus
Definition at line 117 of file pqPVApplicationCore.h.
