Signals | Public Member Functions | Static Public Member Functions | Protected Slots | List of all members
pqServerManagerModel Class Reference
pqServerManagerModel is the model for the Server Manager. More...
#include <pqServerManagerModel.h>
Inherits QObject.
Signals
void preServerAdded (pqServer *)
 Signals emitted when a new pqServer object is created. More...
void serverAdded (pqServer *)
void serverReady (pqServer *)
 Signals emitted when a new pqServer object is properly initialized. More...
void preServerRemoved (pqServer *)
 Signals emitted when a pqServer instance is being destroyed. More...
void serverRemoved (pqServer *)
void aboutToRemoveServer (pqServer *server)
 Fired when beginRemoveServer is called. More...
void finishedRemovingServer ()
 Fired when endRemoveServer is called. More...
void preItemAdded (pqServerManagerModelItem *)
 Signals emitted when any pqServerManagerModelItem subclass is created. More...
void itemAdded (pqServerManagerModelItem *)
void preItemRemoved (pqServerManagerModelItem *)
 Signals emitted when any new pqServerManagerModelItem subclass is being destroyed. More...
void itemRemoved (pqServerManagerModelItem *)
void preProxyAdded (pqProxy *)
void proxyAdded (pqProxy *)
void preProxyRemoved (pqProxy *)
void proxyRemoved (pqProxy *)
void preSourceAdded (pqPipelineSource *source)
 Signals emitted when a source/filter is created. More...
void sourceAdded (pqPipelineSource *source)
void preSourceRemoved (pqPipelineSource *)
 Signals emitted when a source/filter is destroyed. More...
void sourceRemoved (pqPipelineSource *)
void preViewAdded (pqView *view)
 Signals emitted when a view is created. More...
void viewAdded (pqView *view)
void preViewRemoved (pqView *)
 Signals emitted when a view is destroyed. More...
void viewRemoved (pqView *)
void preRepresentationAdded (pqRepresentation *rep)
 Signals emitted when a representation is created. More...
void representationAdded (pqRepresentation *rep)
void preRepresentationRemoved (pqRepresentation *)
 Signals emitted when a representation is destroyed. More...
void representationRemoved (pqRepresentation *)
void nameChanged (pqServerManagerModelItem *item)
 Fired when the name of an item changes. More...
void modifiedStateChanged (pqServerManagerModelItem *item)
 Fired when the state of the model item changes. More...
void connectionAdded (pqPipelineSource *source, pqPipelineSource *consumer, int srcOutputPort)
 Fired when a connection between two pqPipelineSources is created. More...
void preConnectionAdded (pqPipelineSource *source, pqPipelineSource *consumer, int srcOutputPort)
void connectionRemoved (pqPipelineSource *source, pqPipelineSource *consumer, int srcOutputPort)
 Fired when a connection between tow pqPipelineSources is broken. More...
void preConnectionRemoved (pqPipelineSource *source, pqPipelineSource *consumer, int srcOutputPort)
void dataUpdated (pqPipelineSource *)
 Fired when a source indicates that data was updated i.e. More...
void preExtractorAdded (pqExtractor *)
 Signals figured for pqExtractor. More...
void extractorAdded (pqExtractor *)
void preExtractorRemoved (pqExtractor *)
void extractorRemoved (pqExtractor *)
void connectionAdded (pqServerManagerModelItem *source, pqExtractor *consumer)
 Signals fired to notify changes to extractor connections. More...
void connectionRemoved (pqServerManagerModelItem *source, pqExtractor *consumer)
 pqServerManagerModel (pqServerManagerObserver *observer, QObject *parent=nullptr)
 Constructor: observer :- instance of pqServerManagerObserver observing the server manager. More...
 ~pqServerManagerModel () override
pqServer * findServer (vtkIdType cid) const
 Given a session Id, returns the pqServer instance for that session, if any. More...
pqServer * findServer (vtkSession *) const
 Given a vtkSession*, returns the pqServer instance for that session, if any. More...
pqServer * findServer (vtkSMSession *) const
pqServer * findServer (const pqServerResource &resource) const
 Given a server resource, locates the pqServer instance for it, if any. More...
pqServer * findServer (const QString &name) const
 Given a server name, locates the pqServer instance with this name, if any. More...
void beginRemoveServer (pqServer *server)
 Book end events for removing a server. More...
void endRemoveServer ()
void setActiveResource (const pqServerResource &resource)
 This method to called by any code that's requesting ServerManager to create a new connection (viz. More...
template<class T >
T findItem (vtkSMProxy *proxy) const
 Given a proxy, locates a pqServerManagerModelItem subclass for the given proxy. More...
template<class T >
T findItem (vtkTypeUInt32 id) const
 Given the global id for a proxy, locates a pqServerManagerModelItem subclass for the proxy. More...
template<class T >
QList< T > findItems () const
 Returns a list of pqServerManagerModelItem of the given type. More...
template<class T >
int getNumberOfItems () const
 Returns the number of items of the given type. More...
template<class T >
T getItemAtIndex (int index) const
 Returns the item of the given type and the given index. More...
template<class T >
QList< T > findItems (pqServer *server) const
 Same as findItems<T>() except that this returns only those items that are on the indicated server. More...
template<class T >
T findItem (const QString &name) const
 Returns an item with the given name. More...
static void findItemsHelper (const pqServerManagerModel *model, const QMetaObject &mo, QList< void * > *list, pqServer *server=nullptr)
 Internal method. More...
static pqServerManagerModelItem * findItemHelper (const pqServerManagerModel *model, const QMetaObject &mo, vtkSMProxy *proxy)
static pqServerManagerModelItem * findItemHelper (const pqServerManagerModel *model, const QMetaObject &mo, vtkTypeUInt32 id)
static pqServerManagerModelItem * findItemHelper (const pqServerManagerModel *model, const QMetaObject &mo, const QString &name)
Protected Slots
virtual void onProxyRegistered (const QString &group, const QString &name, vtkSMProxy *proxy)
 Called when a proxy is registered. More...
virtual void onProxyUnRegistered (const QString &group, const QString &name, vtkSMProxy *proxy)
 Called when a proxy is unregistered. More...
virtual void onConnectionCreated (vtkIdType id)
 Called when a new server connection is created. More...
virtual void onConnectionClosed (vtkIdType id)
 Called when a server connection is closed. More...
virtual void onStateLoaded (vtkPVXMLElement *, vtkSMProxyLocator *)
 Called when state file is loaded. More...
All the pipelines in the Server Manager need a GUI representation to obtain additional information about their connections etc. This class collects that. This is merely representation of all the information available in the Server Manager in a more GUI friendly way. Simplicity is the key here.
Definition at line 52 of file pqServerManagerModel.h.
◆ pqServerManagerModel()
pqServerManagerModel::pqServerManagerModel ( pqServerManagerObserver *  observer,
QObject *  parent = nullptr
◆ ~pqServerManagerModel()
pqServerManagerModel::~pqServerManagerModel ( )
override
◆ findServer() [1/5]
pqServer* pqServerManagerModel::findServer ( vtkIdType  cid) const
◆ findServer() [2/5]
pqServer* pqServerManagerModel::findServer ( vtkSession *  ) const
◆ findServer() [3/5]
pqServer* pqServerManagerModel::findServer ( vtkSMSession *  ) const
◆ findServer() [4/5]
pqServer* pqServerManagerModel::findServer ( const pqServerResource &  resource) const
◆ findServer() [5/5]
pqServer* pqServerManagerModel::findServer ( const QString &  name) const
◆ beginRemoveServer()
void pqServerManagerModel::beginRemoveServer ( pqServer *  server)
◆ endRemoveServer()
void pqServerManagerModel::endRemoveServer ( )
◆ setActiveResource()
void pqServerManagerModel::setActiveResource ( const pqServerResource &  resource)
pqObjectBuilder) to set the resource to be used for the newly create pqServer instance. The active resource is automatically cleared one a new pqServer instance is created. Refer to pqObjectBuilder::createServer for details.
◆ findItem() [1/3]
template<class T >
T pqServerManagerModel::findItem ( vtkSMProxy *  proxy) const
inline
Definition at line 109 of file pqServerManagerModel.h.
◆ findItem() [2/3]
template<class T >
T pqServerManagerModel::findItem ( vtkTypeUInt32  id) const
inline
Definition at line 119 of file pqServerManagerModel.h.
◆ findItems() [1/2]
template<class T >
QList<T> pqServerManagerModel::findItems ( ) const
inline
Definition at line 128 of file pqServerManagerModel.h.
◆ getNumberOfItems()
template<class T >
int pqServerManagerModel::getNumberOfItems ( ) const
inline
Definition at line 137 of file pqServerManagerModel.h.
◆ getItemAtIndex()
template<class T >
T pqServerManagerModel::getItemAtIndex ( int  index) const
inline
The index is determined by collecting all the items of the given type in a list (findItems()).
Definition at line 148 of file pqServerManagerModel.h.
◆ findItems() [2/2]
template<class T >
QList<T> pqServerManagerModel::findItems ( pqServer *  server) const
inline
If server == 0, then all items are returned.
Definition at line 158 of file pqServerManagerModel.h.
◆ findItem() [3/3]
template<class T >
T pqServerManagerModel::findItem ( const QString &  name) const
inline
The type can be pqProxy subclass, since these are the ones that can have a name. Note that since names need not be unique, using this method is not recommended. This is provided for backwards compatibility alone.
Definition at line 170 of file pqServerManagerModel.h.
◆ findItemsHelper()
static void pqServerManagerModel::findItemsHelper ( const pqServerManagerModel *  model,
const QMetaObject &  mo,
QList< void * > *  list,
pqServer *  server = nullptr
Internal method.
◆ findItemHelper() [1/3]
static pqServerManagerModelItem* pqServerManagerModel::findItemHelper ( const pqServerManagerModel *  model,
vtkSMProxy *  proxy
Internal method.
◆ findItemHelper() [2/3]
vtkTypeUInt32  id
Internal method.
◆ findItemHelper() [3/3]
Internal method.
◆ preServerAdded
void pqServerManagerModel::preServerAdded ( pqServer *  )
signal
◆ serverAdded
void pqServerManagerModel::serverAdded ( pqServer *  )
signal
◆ serverReady
void pqServerManagerModel::serverReady ( pqServer *  )
signal
This happen just before serverAdded() but should not be used by user. serverAdded() should be the signal to bind against unless you need to be notified before the serverAdded() like the plugin loader do.
◆ preServerRemoved
void pqServerManagerModel::preServerRemoved ( pqServer *  )
signal
◆ serverRemoved
void pqServerManagerModel::serverRemoved ( pqServer *  )
signal
◆ aboutToRemoveServer
void pqServerManagerModel::aboutToRemoveServer ( pqServer *  server)
signal
◆ finishedRemovingServer
void pqServerManagerModel::finishedRemovingServer ( )
signal
◆ preItemAdded
void pqServerManagerModel::preItemAdded ( pqServerManagerModelItem *  )
signal
◆ itemAdded
void pqServerManagerModel::itemAdded ( pqServerManagerModelItem *  )
signal
◆ preItemRemoved
void pqServerManagerModel::preItemRemoved ( pqServerManagerModelItem *  )
signal
◆ itemRemoved
void pqServerManagerModel::itemRemoved ( pqServerManagerModelItem *  )
signal
◆ preProxyAdded
void pqServerManagerModel::preProxyAdded ( pqProxy *  )
signal
◆ proxyAdded
void pqServerManagerModel::proxyAdded ( pqProxy *  )
signal
◆ preProxyRemoved
void pqServerManagerModel::preProxyRemoved ( pqProxy *  )
signal
◆ proxyRemoved
void pqServerManagerModel::proxyRemoved ( pqProxy *  )
signal
◆ preSourceAdded
void pqServerManagerModel::preSourceAdded ( pqPipelineSource *  source)
signal
◆ sourceAdded
void pqServerManagerModel::sourceAdded ( pqPipelineSource *  source)
signal
◆ preSourceRemoved
void pqServerManagerModel::preSourceRemoved ( pqPipelineSource *  )
signal
◆ sourceRemoved
void pqServerManagerModel::sourceRemoved ( pqPipelineSource *  )
signal
◆ preViewAdded
void pqServerManagerModel::preViewAdded ( pqView *  view)
signal
◆ viewAdded
void pqServerManagerModel::viewAdded ( pqView *  view)
signal
◆ preViewRemoved
void pqServerManagerModel::preViewRemoved ( pqView *  )
signal
◆ viewRemoved
void pqServerManagerModel::viewRemoved ( pqView *  )
signal
◆ preRepresentationAdded
void pqServerManagerModel::preRepresentationAdded ( pqRepresentation *  rep)
signal
◆ representationAdded
void pqServerManagerModel::representationAdded ( pqRepresentation *  rep)
signal
◆ preRepresentationRemoved
void pqServerManagerModel::preRepresentationRemoved ( pqRepresentation *  )
signal
◆ representationRemoved
void pqServerManagerModel::representationRemoved ( pqRepresentation *  )
signal
◆ preExtractorAdded
void pqServerManagerModel::preExtractorAdded ( pqExtractor *  )
signal
◆ extractorAdded
void pqServerManagerModel::extractorAdded ( pqExtractor *  )
signal
◆ preExtractorRemoved
void pqServerManagerModel::preExtractorRemoved ( pqExtractor *  )
signal
◆ extractorRemoved
void pqServerManagerModel::extractorRemoved ( pqExtractor *  )
signal
◆ nameChanged
void pqServerManagerModel::nameChanged ( pqServerManagerModelItem *  item)
signal
◆ modifiedStateChanged
void pqServerManagerModel::modifiedStateChanged ( pqServerManagerModelItem *  item)
signal
◆ connectionAdded [1/2]
void pqServerManagerModel::connectionAdded ( pqPipelineSource *  source,
pqPipelineSource *  consumer,
int  srcOutputPort
signal
◆ preConnectionAdded
void pqServerManagerModel::preConnectionAdded ( pqPipelineSource *  source,
int  srcOutputPort
signal
◆ connectionRemoved [1/2]
void pqServerManagerModel::connectionRemoved ( pqPipelineSource *  source,
int  srcOutputPort
signal
◆ preConnectionRemoved
void pqServerManagerModel::preConnectionRemoved ( pqPipelineSource *  source,
int  srcOutputPort
signal
◆ connectionAdded [2/2]
void pqServerManagerModel::connectionAdded ( pqServerManagerModelItem *  source,
pqExtractor *  consumer
signal
◆ connectionRemoved [2/2]
void pqServerManagerModel::connectionRemoved ( pqServerManagerModelItem *  source,
signal
◆ dataUpdated
void pqServerManagerModel::dataUpdated ( pqPipelineSource *  )
signal
the pipeline was updated.
◆ onProxyRegistered
virtual void pqServerManagerModel::onProxyRegistered ( const QString &  group,
const QString &  name,
vtkSMProxy *  proxy
protectedvirtualslot
◆ onProxyUnRegistered
virtual void pqServerManagerModel::onProxyUnRegistered ( const QString &  group,
vtkSMProxy *  proxy
◆ onConnectionCreated
virtual void pqServerManagerModel::onConnectionCreated ( vtkIdType  id)
◆ onConnectionClosed
virtual void pqServerManagerModel::onConnectionClosed ( vtkIdType  id)
◆ onStateLoaded
virtual void pqServerManagerModel::onStateLoaded ( vtkPVXMLElement *  ,
vtkSMProxyLocator *
We need to discover "helper proxies" and set up the associations accordingly.
