Public Slots | Signals | Public Member Functions | Static Public Member Functions | Protected Member Functions | List of all members
pqObjectBuilder Class Reference
pqObjectBuilder is loosely based on the Builder design pattern. More...
#include <pqObjectBuilder.h>
Inherits QObject.
Public Slots
void abortPendingConnections ()
 Closes any open connections for reverse-connection. More...
Signals
void finishedAddingServer (pqServer *server)
 Emitted after a new server connection is created. More...
void sourceCreated (pqPipelineSource *)
 Fired on successful completion of createSource(). More...
void filterCreated (pqPipelineSource *)
 Fired on successful completion of createFilter(). More...
void readerCreated (pqPipelineSource *, const QString &filename)
 Fired on successful completion of createReader(). More...
void readerCreated (pqPipelineSource *, const QStringList &filename)
void aboutToCreateView (pqServer *server)
 fired before attempting to create a view. More...
void viewCreated (pqView *)
 Fired on successful completion of createView(). More...
void dataRepresentationCreated (pqDataRepresentation *)
 Fired on successful completion of createDataRepresentation(). More...
void proxyCreated (pqProxy *)
 Fired on successful completion of any method that creates a pqProxy or subclass including createDataRepresentation, createView, createFilter, createSource, createReader etc. More...
void proxyCreated (vtkSMProxy *)
 Fired on successful completion of createProxy(). More...
void destroying (pqView *view)
 Fired when destroy(pqView*) is called. More...
void destroying (pqRepresentation *display)
 Fired when destroy(pqRepresentation*) is called. More...
void destroying (pqPipelineSource *source)
 Fired when destroy(pqPipelineSource*) is called. More...
void destroying (pqProxy *proxy)
 Fired when destroy(pqProxy*) is called. More...
 pqObjectBuilder (QObject *parent=nullptr)
 ~pqObjectBuilder () override
void removeServer (pqServer *server)
 Destroy a server connection. More...
pqServer * resetServer (pqServer *server)
 Resets the server by destroying the old pqServer instance and creating a new one while keeping the same underlying session alive. More...
virtual pqPipelineSource * createSource (const QString &sm_group, const QString &sm_name, pqServer *server)
 Creates a source of the given server manager group (sm_group) and name (sm_name) on the given server. More...
virtual pqPipelineSource * createFilter (const QString &group, const QString &name, QMap< QString, QList< pqOutputPort * >> namedInputs, pqServer *server)
 Creates a filter with the given Server Manager group (sm_group) and name (sm_name). More...
virtual pqPipelineSource * createFilter (const QString &group, const QString &name, pqPipelineSource *input, int output_port=0)
 Convenience method that takes a single input source. More...
virtual pqPipelineSource * createReader (const QString &sm_group, const QString &sm_name, const QStringList &files, pqServer *server)
 Creates a reader of the given server manager group (sm_group) and name (sm_name) on the given server. More...
virtual pqView * createView (const QString &type, pqServer *server)
 Creates a new view module of the given type on the given server. More...
virtual void destroy (pqView *view)
 Destroys the view module. More...
virtual void addToLayout (pqView *view, pqProxy *layout=nullptr)
 Assigns the view to the layout. More...
virtual pqDataRepresentation * createDataRepresentation (pqOutputPort *source, pqView *view, const QString &representationType="")
 Creates a representation to show the data from the given output port of a source in the given view. More...
virtual vtkSMProxy * createProxy (const QString &sm_group, const QString &sm_name, pqServer *server, const QString &reg_group)
 Convenience method to create a proxy of any type on the given server. More...
virtual void destroy (pqRepresentation *repr)
 Destroys the data display. More...
virtual void destroy (pqPipelineSource *source)
 Destroys a source/filter. More...
virtual void destroy (pqAnimationCue *cue)
 Destroys an animation cue and all keyframe objects, if any in that cue. More...
virtual void destroy (pqProxy *proxy)
 Convenience method, simply unregisters the Server Manager proxy which the pqProxy represents. More...
virtual void destroySources (pqServer *server=nullptr)
 Destroy all sources/filters on a server. More...
virtual void destroyLookupTables (pqServer *server=nullptr)
 Destroy all lookup tables and scalar bars associated with them. More...
virtual void destroyPipelineProxies (pqServer *server=nullptr)
 Destroys all proxies that are involved in pipelines i.e. More...
virtual void destroyAllProxies (pqServer *server)
 This method unregisters all proxies on the given server. More...
bool waitingForConnection () const
 Returns true while pqObjectBuilder is in createServer() call. More...
bool forceWaitingForConnection (bool force)
 Set ForceWaitingForConnection When set to true, WaitingForConnection() will always return true When set to false, no effect. More...
pqServer * createServer (const pqServerResource &resource, int connectionTimeout=60)
 Create a server connection give a server resource. More...
pqServer * createServer (const pqServerResource &resource, int connectionTimeout, vtkNetworkAccessManager::ConnectionResult &result)
static QString getFileNamePropertyName (vtkSMProxy *)
 This is a convenience method to return the name of the property on the proxy, if any, which can be used to set the filename. More...
virtual void destroyProxyInternal (pqProxy *proxy)
 Unregisters a proxy. More...
It is used to create as well as destroy complex objects such as views, displays, sources etc. Since most of the public API is virtual, it is possible for custom applications to subclass pqObjectBuilder to provide their own implementation for creation/ destroying these objects. The application layer accesses the ObjectBuilder through the pqApplicationCore singleton. NOTE: pqObjectBuilder replaces the previously supported pqPipelineBuilder. Unlike pqPipelineBuilder, this class no longer deals with undo/redo stack. The application layer components that use the ObjectBuilder are supposed to bother about the undo stack i.e. call begin/end on the undo stack before/after calling creation/destruction method on the ObjectBuilder.
Definition at line 42 of file pqObjectBuilder.h.
◆ pqObjectBuilder()
pqObjectBuilder::pqObjectBuilder ( QObject *  parent = nullptr)
◆ ~pqObjectBuilder()
pqObjectBuilder::~pqObjectBuilder ( )
override
◆ createServer() [1/2]
pqServer* pqObjectBuilder::createServer ( const pqServerResource &  resource,
int  connectionTimeout = 60
inline
By default, this method does not create a new connection if one already exists. Also it disconnects from any existing server connection before connecting to a new one. This behavior can be changed by setting MultipleConnectionsSupport to true. In that case this will always try to connect the server using the details specified in the resource irrespective if the server is already connected or any other server connections exists and will wait for timeout seconds for direct connection. 0 means no retry, -1 means infinite retries. Calling this method while waiting for a previous server connection to be established raises errors. The result arg provide information about the failure or sucess of the connection, see vtkNetworkAccessManager::ConnectionResult for possible values.
Definition at line 67 of file pqObjectBuilder.h.
◆ createServer() [2/2]
vtkNetworkAccessManager::ConnectionResult &  result
◆ removeServer()
void pqObjectBuilder::removeServer ( pqServer *  server)
◆ resetServer()
pqServer* pqObjectBuilder::resetServer ( pqServer *  server)
◆ createSource()
virtual pqPipelineSource* pqObjectBuilder::createSource ( const QString &  sm_group,
const QString &  sm_name,
pqServer *  server
On success, returns the pqPipelineSource for the created proxy.
◆ createFilter() [1/2]
virtual pqPipelineSource* pqObjectBuilder::createFilter ( const QString &  group,
const QString &  name,
pqServer *  server
If the filter accepts multiple inputs, all the inputs provided in the list are set as input, instead only the first one is set as the input. All inputs must be on the same server.
◆ createFilter() [2/2]
pqPipelineSource *  input,
int  output_port = 0
◆ createReader()
virtual pqPipelineSource* pqObjectBuilder::createReader ( const QString &  sm_group,
const QStringList &  files,
pqServer *  server
◆ createView()
virtual pqView* pqObjectBuilder::createView ( const QString &  type,
pqServer *  server
◆ destroy() [1/5]
virtual void pqObjectBuilder::destroy ( pqView *  view)
This destroys the view module as well as all the displays in the view module.
◆ addToLayout()
virtual void pqObjectBuilder::addToLayout ( pqView *  view,
pqProxy *  layout = nullptr
If layout is nullptr, this method will use an arbitrary layout on the same server as the view, if any, or create a new layout and assign the view to it.
◆ createDataRepresentation()
virtual pqDataRepresentation* pqObjectBuilder::createDataRepresentation ( pqOutputPort *  source,
pqView *  view,
const QString &  representationType = ""
◆ createProxy()
virtual vtkSMProxy* pqObjectBuilder::createProxy ( const QString &  sm_group,
pqServer *  server,
const QString &  reg_group
One can alternatively use the vtkSMProxyManager to create new proxies directly. This method additionally set the connection ID on the new proxy. If reg_name is empty, then a new name is assigned.
◆ destroy() [2/5]
virtual void pqObjectBuilder::destroy ( pqRepresentation *  repr)
It will remove the display from any view modules it is added to and then unregister it.
◆ destroy() [3/5]
virtual void pqObjectBuilder::destroy ( pqPipelineSource *  source)
Removing a source involves the following:
◆ destroy() [4/5]
virtual void pqObjectBuilder::destroy ( pqAnimationCue *  cue)
◆ destroy() [5/5]
virtual void pqObjectBuilder::destroy ( pqProxy *  proxy)
◆ destroySources()
virtual void pqObjectBuilder::destroySources ( pqServer *  server = nullptr)
◆ destroyLookupTables()
virtual void pqObjectBuilder::destroyLookupTables ( pqServer *  server = nullptr)
◆ destroyPipelineProxies()
virtual void pqObjectBuilder::destroyPipelineProxies ( pqServer *  server = nullptr)
simply calls destroySources(), destroyLookupTables().
◆ destroyAllProxies()
virtual void pqObjectBuilder::destroyAllProxies ( pqServer *  server)
This is usually done in anticipate of a disconnect or starting afresh.
◆ getFileNamePropertyName()
static QString pqObjectBuilder::getFileNamePropertyName ( vtkSMProxy *  )
If no such property exists, this returns a null string. If there are more than 1 properties with FileListDomain, then it looks at the Hints for the proxy for the XML of the form <DefaultFileNameProperty name="<propertyname>" /> and uses that property otherwise simply returns the first one encountered.
◆ waitingForConnection()
bool pqObjectBuilder::waitingForConnection ( ) const
inline
Definition at line 215 of file pqObjectBuilder.h.
◆ forceWaitingForConnection()
bool pqObjectBuilder::forceWaitingForConnection ( bool  force)
Returns the previous state
◆ abortPendingConnections
void pqObjectBuilder::abortPendingConnections ( )
slot
◆ finishedAddingServer
void pqObjectBuilder::finishedAddingServer ( pqServer *  server)
signal
◆ sourceCreated
void pqObjectBuilder::sourceCreated ( pqPipelineSource *  )
signal
Remember that this signal is fired only when the creation of the object is requested by the GUI. It wont be triggered when the python client creates the source or when state is loaded or on undo/redo.
◆ filterCreated
void pqObjectBuilder::filterCreated ( pqPipelineSource *  )
signal
◆ readerCreated [1/2]
void pqObjectBuilder::readerCreated ( pqPipelineSource *  ,
const QString &  filename
signal
◆ readerCreated [2/2]
const QStringList &  filename
signal
◆ aboutToCreateView
void pqObjectBuilder::aboutToCreateView ( pqServer *  server)
signal
◆ viewCreated
void pqObjectBuilder::viewCreated ( pqView *  )
signal
◆ dataRepresentationCreated
void pqObjectBuilder::dataRepresentationCreated ( pqDataRepresentation *  )
signal
◆ proxyCreated [1/2]
void pqObjectBuilder::proxyCreated ( pqProxy *  )
signal
◆ proxyCreated [2/2]
void pqObjectBuilder::proxyCreated ( vtkSMProxy *  )
signal
◆ destroying [1/4]
void pqObjectBuilder::destroying ( pqView *  view)
signal
This signal is fired before the process for destruction of the object begins. Remember that this signal is fired only when the destruction of the object is requested by the GUI. It wont be triggered when the python client unregisters the source or when state is loaded or on undo/redo.
◆ destroying [2/4]
void pqObjectBuilder::destroying ( pqRepresentation *  display)
signal
◆ destroying [3/4]
void pqObjectBuilder::destroying ( pqPipelineSource *  source)
signal
◆ destroying [4/4]
void pqObjectBuilder::destroying ( pqProxy *  proxy)
signal
◆ destroyProxyInternal()
virtual void pqObjectBuilder::destroyProxyInternal ( pqProxy *  proxy)
protectedvirtual
