Public Types | Signals | Public Member Functions | Protected Slots | Protected Member Functions | List of all members
pqPluginManager Class Reference
pqPluginManager works with vtkSMPluginManager to keep track for plugins loaded/available. More...
#include <pqPluginManager.h>
Inherits QObject.
enum  LoadStatus { LOADED, NOTLOADED, ALREADYLOADED }
Signals
void pluginsUpdated ()
 notification when plugin has been loaded. More...
void requiredPluginsNotLoaded (pqServer *)
 notification that the plugins on the client and server are mismatched. More...
 pqPluginManager (QObject *p=nullptr)
 ~pqPluginManager () override
void loadPluginsFromSettings ()
 Called during application initialization to load plugins from settings. More...
LoadStatus loadExtension (pqServer *session, const QString &lib, QString *errorMsg=nullptr, bool remote=true)
 attempt to load an extension on a server if server is nullptr, extension will be loaded on client side return status on success, if NOTLOADED was returned, the error is reported If errorMsg is non-nullptr, then errors are not reported, but the error message is put in the errorMsg string More...
void loadExtensions (pqServer *)
 attempt to load all available plugins on a server, or client plugins if nullptr More...
vtkPVPluginsInformation * loadedExtensions (pqServer *session, bool remote)
 return all the plugins loaded on a session. More...
QStringList pluginPaths (pqServer *session, bool remote)
 Return all the paths that plugins will be searched for. More...
void hidePlugin (const QString &lib, bool remote)
 simply adds the plugin to the ignore list, so when this class tries to serialize the plugin information, it skips the indicated plugin. More...
bool isHidden (const QString &lib, bool remote)
bool verifyPlugins (pqServer *session)
 ensures that plugins required on client and server are present on both. More...
Protected Slots
void loadPluginsFromSettings (pqServer *)
 attempts to load the configuration for plugins for the particular server. More...
void onServerConnected (pqServer *)
void onServerDisconnected (pqServer *)
void updatePluginLists ()
void initialize (vtkSMPluginManager *)
It also ensures that when a new session is created, the default plugin-configuration-xmls are parsed on all processes involved to ensure that auto-load plugins are loaded. It preserves the information about plugins loaded across ParaView sessions in settings so that users can easily load previously loaded plugins.
pqPluginManager can work with multiple sessions. It maintains internal data-structures for different sessions.
Definition at line 28 of file pqPluginManager.h.
◆ LoadStatus
Enumerator
LOADED
NOTLOADED
ALREADYLOADED
Definition at line 46 of file pqPluginManager.h.
◆ pqPluginManager()
pqPluginManager::pqPluginManager ( QObject *  p = nullptr)
◆ ~pqPluginManager()
pqPluginManager::~pqPluginManager ( )
override
◆ loadPluginsFromSettings() [1/2]
void pqPluginManager::loadPluginsFromSettings ( )
This only loads "local" plugins. pqApplicationCore calls this method explicitly after the essential components of the core have been initialized. This ensures that any plugins being loaded during startup of application have the environment setup correctly.
◆ loadExtension()
LoadStatus pqPluginManager::loadExtension ( pqServer *  session,
const QString &  lib,
QString *  errorMsg = nullptr,
bool  remote = true
◆ loadExtensions()
void pqPluginManager::loadExtensions ( pqServer *  )
◆ loadedExtensions()
vtkPVPluginsInformation* pqPluginManager::loadedExtensions ( pqServer *  session,
bool  remote
This will either returns the plugins information for local processes or server-process (for remote sessions) based on the state of remote.
◆ pluginPaths()
QStringList pqPluginManager::pluginPaths ( pqServer *  session,
bool  remote
◆ hidePlugin()
void pqPluginManager::hidePlugin ( const QString &  lib,
bool  remote
◆ isHidden()
bool pqPluginManager::isHidden ( const QString &  lib,
bool  remote
◆ verifyPlugins()
bool pqPluginManager::verifyPlugins ( pqServer *  session)
Fires requiredPluginsNotLoaded() signal if any mismatch is found. Returns true is all plugin requirements are satisfied, else returns false.
◆ pluginsUpdated
void pqPluginManager::pluginsUpdated ( )
signal
◆ requiredPluginsNotLoaded
void pqPluginManager::requiredPluginsNotLoaded ( pqServer *  )
signal
◆ initialize()
void pqPluginManager::initialize ( vtkSMPluginManager *  )
◆ loadPluginsFromSettings [2/2]
void pqPluginManager::loadPluginsFromSettings ( pqServer *  )
protectedslot
◆ onServerConnected
void pqPluginManager::onServerConnected ( pqServer *  )
protectedslot
◆ onServerDisconnected
void pqPluginManager::onServerDisconnected ( pqServer *  )
protectedslot
◆ updatePluginLists
void pqPluginManager::updatePluginLists ( )
protectedslot
