Public Slots | Signals | Public Member Functions | Protected Slots | Protected Member Functions | Protected Attributes | List of all members
pqProgressManager Class Reference
pqProgressManager is progress manager. More...
#include <pqProgressManager.h>
Inherits QObject.
Public Slots
void setProgress (const QString &message, int progress)
 Update progress. More...
void setEnableProgress (bool)
 Enables progress. More...
void beginProgress ()
 Convenience slots that simply call setEnableProgress(). More...
void endProgress ()
void setEnableAbort (bool)
 Enables abort. More...
void triggerAbort ()
 fires abort(). More...
bool unblockEvents (bool val)
 While progress is enabled, pqProgressManager blocks key/mouse events, except for objects added using addNonBlockableObject. More...
Signals
void abort ()
 Emitted to trigger an abort. More...
void progress (const QString &message, int progress)
void enableProgress (bool)
void enableAbort (bool)
void progressStartEvent ()
void progressEndEvent ()
 pqProgressManager (QObject *parent=nullptr)
 ~pqProgressManager () override
void lockProgress (QObject *object)
 Locks progress to respond to progress signals set by the object alone. More...
void unlockProgress (QObject *object)
 Releases the progress lock. More...
bool isLocked () const
 Returns if the progress is currently locked by any object. More...
void addNonBlockableObject (QObject *o)
 When progress is enabled, the manager eats all mouse and key events fired except for those objects which are in the non-blockable list. More...
void removeNonBlockableObject (QObject *o)
const QList< QPointer< QObject > > & nonBlockableObjects () const
 Returns the list of non-blockable objects. More...
Protected Slots
void onStartProgress ()
 callbacks for signals fired from vtkProcessModule. More...
void onEndProgress ()
void onProgress (vtkObject *)
void onServerAdded (pqServer *)
bool eventFilter (QObject *obj, QEvent *event) override
 Filter QApplication events. More...
QPointer< QObject > Lock
QList< QPointer< QObject > > NonBlockableObjects
int ProgressCount
bool InUpdate
bool EnableProgress
bool ReadyEnableProgress
bool UnblockEvents
It centralizes progress raising/ handling. Provides ability for any object to lock progress so that only progress fired by itself will be notified to the rest of the world. Also, when progress is enabled, it disables handling of mouse/key events except on those objects in the NonBlockableObjects list.
Definition at line 21 of file pqProgressManager.h.
◆ pqProgressManager()
pqProgressManager::pqProgressManager ( QObject *  parent = nullptr)
◆ ~pqProgressManager()
pqProgressManager::~pqProgressManager ( )
override
◆ lockProgress()
void pqProgressManager::lockProgress ( QObject *  object)
All signals sent by other objects are ignored until Unlock is called.
◆ unlockProgress()
void pqProgressManager::unlockProgress ( QObject *  object)
◆ isLocked()
bool pqProgressManager::isLocked ( ) const
◆ addNonBlockableObject()
void pqProgressManager::addNonBlockableObject ( QObject *  o)
inline
This is the API to add/remove non-blockable objects.
Definition at line 49 of file pqProgressManager.h.
◆ removeNonBlockableObject()
void pqProgressManager::removeNonBlockableObject ( QObject *  o)
inline
Definition at line 50 of file pqProgressManager.h.
◆ nonBlockableObjects()
const QList<QPointer<QObject> >& pqProgressManager::nonBlockableObjects ( ) const
inline
Definition at line 55 of file pqProgressManager.h.
◆ eventFilter()
bool pqProgressManager::eventFilter ( QObject *  obj,
QEvent *  event
◆ setProgress
void pqProgressManager::setProgress ( const QString &  message,
int  progress
slot
Update progress.
The progress must be enbled by calling enableProgress(true) before calling this method for the progress to be updated.
◆ setEnableProgress
void pqProgressManager::setEnableProgress ( bool  )
slot
Enables progress.
◆ beginProgress
void pqProgressManager::beginProgress ( )
inlineslot
Definition at line 79 of file pqProgressManager.h.
◆ endProgress
void pqProgressManager::endProgress ( )
inlineslot
Definition at line 80 of file pqProgressManager.h.
◆ setEnableAbort
void pqProgressManager::setEnableAbort ( bool  )
slot
Enables abort.
◆ triggerAbort
void pqProgressManager::triggerAbort ( )
slot
fires abort().
Must be called by the GUI that triggers abort.
◆ unblockEvents
bool pqProgressManager::unblockEvents ( bool  val)
slot
Sometimes it's not possible to add objects explicitly and we may want to temporarily skip blocking of events. This methods can be used for that e.g.
bool prev = progressManager->unblockEvents(true);
QMessageBox::question(....);
progressManager->unblockEvents(prev);
Returns
previous value.
◆ abort
void pqProgressManager::abort ( )
signal
◆ progress
void pqProgressManager::progress ( const QString &  message,
int  progress
signal
◆ enableProgress
void pqProgressManager::enableProgress ( bool  )
signal
◆ enableAbort
void pqProgressManager::enableAbort ( bool  )
signal
◆ progressStartEvent
void pqProgressManager::progressStartEvent ( )
signal
◆ progressEndEvent
void pqProgressManager::progressEndEvent ( )
signal
◆ onStartProgress
void pqProgressManager::onStartProgress ( )
protectedslot
◆ onEndProgress
void pqProgressManager::onEndProgress ( )
protectedslot
◆ onProgress
void pqProgressManager::onProgress ( vtkObject *  )
protectedslot
◆ onServerAdded
void pqProgressManager::onServerAdded ( pqServer *  )
protectedslot
◆ Lock
QPointer<QObject> pqProgressManager::Lock
Definition at line 133 of file pqProgressManager.h.
◆ NonBlockableObjects
QList<QPointer<QObject> > pqProgressManager::NonBlockableObjects
Definition at line 134 of file pqProgressManager.h.
◆ ProgressCount
int pqProgressManager::ProgressCount
Definition at line 135 of file pqProgressManager.h.
◆ InUpdate
bool pqProgressManager::InUpdate
Definition at line 136 of file pqProgressManager.h.
◆ EnableProgress
bool pqProgressManager::EnableProgress
Definition at line 138 of file pqProgressManager.h.
◆ ReadyEnableProgress
bool pqProgressManager::ReadyEnableProgress
Definition at line 139 of file pqProgressManager.h.
◆ UnblockEvents
bool pqProgressManager::UnblockEvents
Definition at line 140 of file pqProgressManager.h.
