pqPythonManager is a class to facilitate the use of a python interpreter by various paraview GUI components. More...
#include <pqPythonManager.h>
Inherits QObject.
Public Slots | |
| void | executeCode (const QByteArray &code, const QVector< QByteArray > &pre_push={}, const QVector< QByteArray > &post_push={}) |
| Executes the given code. More... | |
| void | executeScript (const QString &filename, vtkTypeUInt32 location=0x10) |
| Executes the given script. More... | |
| void | executeScriptAndRender (const QString &filename, vtkTypeUInt32 location=0x10) |
Same as executeScript() except that is also triggers a render on all views in the application after the script has been processed. More... | |
| void | editMacro (const QString &fileName) |
| Launch python editor to edit the macro. More... | |
| pqPythonManager (QObject *parent=nullptr) | |
| ~pqPythonManager () override | |
| pqPythonMacroSupervisor * | macroSupervisor () const |
| Provides access to the macro supervisor. More... | |
| bool | initializeInterpreter () |
Convienience method to call vtkPythonInterpreter::Initialize(). More... | |
| bool | interpreterIsInitialized () |
| Returns true if the interpreter has been initialized. More... | |
| void | addMacro (const QString &fileName, vtkTypeUInt32 location=0x10) |
| Save the macro in ParaView configuration and update widget automatically. More... | |
| void | updateMacroList () |
| Invalidate the macro list, so the menu/toolbars are updated according to the content of the Macros directories... More... | |
| void | addWidgetForRunMacros (QWidget *widget) |
| Add a widget to be given macro actions. More... | |
| void | addWidgetForEditMacros (QWidget *widget) |
| void | addWidgetForDeleteMacros (QWidget *widget) |
pqPythonManager is slated for deprecation. It's unclear there's a need for such a manager anymore since Python interpreter is globally accessible via vtkPythonInterpreter.
Definition at line 28 of file pqPythonManager.h.
| pqPythonManager::pqPythonManager | ( | QObject * | parent = nullptr | ) |
| pqPythonMacroSupervisor* pqPythonManager::macroSupervisor | ( | ) | const |
| bool pqPythonManager::initializeInterpreter | ( | ) |
| bool pqPythonManager::interpreterIsInitialized | ( | ) |
Same as calling vtkPythonInterpreter::IsInitialized().
| void pqPythonManager::addWidgetForRunMacros | ( | QWidget * | widget | ) |
QActions representing script macros will be added to the widget. This could be a QToolBar, QMenu, or other type of widget.
| void pqPythonManager::addWidgetForEditMacros | ( | QWidget * | widget | ) |
| void pqPythonManager::addWidgetForDeleteMacros | ( | QWidget * | widget | ) |
| void pqPythonManager::addMacro | ( | const QString & | fileName, |
| vtkTypeUInt32 | location = 0x10 |
| void pqPythonManager::updateMacroList | ( | ) |
slot |
If the python interpreter hasn't been initialized yet it will be initialized.
| code | lines of code to execute |
| pre_push | instructions to execute before the code execution |
| post_push | instructions to execute after the code execution |
slot |
slot |
This is used when playing back macros, for example.
slot |
