Signals | Public Member Functions | Static Public Member Functions | Protected Slots | Protected Member Functions | List of all members
pqApplyBehavior Class Reference
#include <pqApplyBehavior.h>
Inherits QObject.
Signals
void triggerApply ()
 pqApplyBehavior (QObject *parent=nullptr)
 ~pqApplyBehavior () override
void registerPanel (pqPropertiesPanel *panel)
 Register/unregister pqPropertiesPanel instances to monitor. More...
void unregisterPanel (pqPropertiesPanel *panel)
static void hideInputIfRequired (pqPipelineFilter *filter, pqView *view)
Protected Slots
virtual void applied (pqPropertiesPanel *panel, pqProxy *proxy)
virtual void applied (pqPropertiesPanel *panel=nullptr)
virtual void showData (pqPipelineSource *source, pqView *view)
pqApplyBehavior collects the logic that needs to happen after the user hits "Apply" on the pqPropertiesPanel. Since "Apply" is an important concept in ParaView application, it gets its own behavior so applications can customize it, if needed.
pqApplyBehavior can work with or without registered pqPropertiesPanel. One could still manually register any pqPropertiesPanel instance(s). pqParaViewBehaviors does that automatically for pqPropertiesPanel instances available during the startup.
This behavior is also responsible for managing the AutoApply mechanism with is controllable using vtkPVGeneralSettings
Definition at line 32 of file pqApplyBehavior.h.
◆ pqApplyBehavior()
pqApplyBehavior::pqApplyBehavior ( QObject *  parent = nullptr)
◆ ~pqApplyBehavior()
pqApplyBehavior::~pqApplyBehavior ( )
override
◆ registerPanel()
void pqApplyBehavior::registerPanel ( pqPropertiesPanel *  panel)
◆ unregisterPanel()
void pqApplyBehavior::unregisterPanel ( pqPropertiesPanel *  panel)
◆ hideInputIfRequired()
static void pqApplyBehavior::hideInputIfRequired ( pqPipelineFilter *  filter,
pqView *  view
◆ triggerApply
void pqApplyBehavior::triggerApply ( )
signal
◆ applied [1/2]
virtual void pqApplyBehavior::applied ( pqPropertiesPanel *  panel,
pqProxy *  proxy
protectedvirtualslot
◆ applied [2/2]
virtual void pqApplyBehavior::applied ( pqPropertiesPanel *  panel = nullptr)
◆ showData()
virtual void pqApplyBehavior::showData ( pqPipelineSource *  source,
pqView *  view
protectedvirtual
