Classes | Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Member Functions | Protected Attributes | Friends | List of all members
vtkSMProxyManager Class Reference
singleton/facade to vtkSMSessionProxyManager More...
#include <vtkSMProxyManager.h>
Inheritance diagram for vtkSMProxyManager:
Collaboration diagram for vtkSMProxyManager:
struct  LoadStateInformation
struct  ModifiedPropertyInformation
struct  RegisteredProxyInformation
struct  StateChangedInformation
enum  eventId { ActiveSessionChanged = 9753 }
vtkSMSession * GetActiveSession ()
 Returns the current active session. More...
vtkSMSessionProxyManager * GetActiveSessionProxyManager ()
 Convenient method to get the active vtkSMSessionProxyManager. More...
vtkSMSessionProxyManager * GetSessionProxyManager (vtkSMSession *session)
 Return the corresponding vtkSMSessionProxyManager and if any, then create a new one. More...
virtual void SetBlockProxyDefinitionUpdates (bool)
virtual bool GetBlockProxyDefinitionUpdates ()
virtual void BlockProxyDefinitionUpdatesOn ()
virtual void BlockProxyDefinitionUpdatesOff ()
void UpdateProxyDefinitions ()
std::string GetUniqueProxyName (const char *groupname, const char *prefix, bool alwaysAppend=true)
 Given a group, returns a name not already used for proxies registered in the given group. More...
void SetActiveSession (vtkSMSession *session)
 Set the active session. More...
void SetActiveSession (vtkIdType sessionId)
vtkSMProxy * NewProxy (const char *groupName, const char *proxyName, const char *subProxyName=nullptr)
 Calls forwarded to the active vtkSMSessionProxyManager, if any. More...
void RegisterProxy (const char *groupname, const char *name, vtkSMProxy *proxy)
vtkSMProxy * GetProxy (const char *groupname, const char *name)
void UnRegisterProxy (const char *groupname, const char *name, vtkSMProxy *)
const char * GetProxyName (const char *groupname, unsigned int idx)
const char * GetProxyName (const char *groupname, vtkSMProxy *proxy)
void SetUndoStackBuilder (vtkSMUndoStackBuilder *builder)
 Get/Set the undo-stack builder if the application is using undo-redo mechanism to track changes. More...
virtual vtkSMUndoStackBuilder * GetUndoStackBuilder ()
virtual vtkSMPluginManager * GetPluginManager ()
 PluginManager keeps track of plugins loaded on various sessions. More...
virtual vtkSMReaderFactory * GetReaderFactory ()
 Provides access to the reader factory. More...
virtual vtkSMWriterFactory * GetWriterFactory ()
 Provides access to the writer factory. More...
static vtkSMProxyManager * SafeDownCast (vtkObject *o)
static vtkSMProxyManager * GetProxyManager ()
 Provides access to the global ProxyManager. More...
static void Finalize ()
 Free the singleton. More...
static bool IsInitialized ()
 Allow to check if the Singleton has been initialized and has a reference to a valid ProxyManager. More...
static int GetVersionMajor ()
 These methods can be used to obtain the ProxyManager version number. More...
static int GetVersionMinor ()
static int GetVersionPatch ()
static const char * GetParaViewSourceVersion ()
 Returns a string with the format "paraview version x.x.x, Date: YYYY-MM-DD". More...
static vtkSMObject * New ()
 vtkSMProxyManager ()
 ~vtkSMProxyManager () override
void ConnectionsUpdated (vtkObject *, unsigned long, void *)
 Connections updated. More...
 vtkSMObject ()
 ~vtkSMObject () override
static vtkSMProxyManager * New ()
vtkSMUndoStackBuilder * UndoStackBuilder
vtkSMPluginManager * PluginManager
vtkSMReaderFactory * ReaderFactory
vtkSMWriterFactory * WriterFactory
bool BlockProxyDefinitionUpdates
Friends
class vtkSMSessionProxyManager
vtkSMProxyManager is a singleton/facade that creates and manages proxies. It maintains a map of vtkSMSessionProxyManager and delegate all proxy related call to the appropriate one based on the provided session.
See also
vtkSMSessionProxyManager, vtkSMProxyDefinitionManager
Definition at line 35 of file vtkSMProxyManager.h.
Definition at line 38 of file vtkSMProxyManager.h.
◆ eventId
Enumerator
Definition at line 164 of file vtkSMProxyManager.h.
◆ vtkSMProxyManager()
vtkSMProxyManager::vtkSMProxyManager ( )
◆ ~vtkSMProxyManager()
vtkSMProxyManager::~vtkSMProxyManager ( )
virtual const char* vtkSMProxyManager::GetClassName ( )
static int vtkSMProxyManager::IsTypeOf ( const char *  type)
virtual int vtkSMProxyManager::IsA ( const char *  type)
static vtkSMProxyManager* vtkSMProxyManager::SafeDownCast ( vtkObject *  o)
void vtkSMProxyManager::PrintSelf ( ostream &  os,
◆ GetProxyManager()
static vtkSMProxyManager* vtkSMProxyManager::GetProxyManager ( )
◆ Finalize()
static void vtkSMProxyManager::Finalize ( )
Free the singleton.
◆ IsInitialized()
static bool vtkSMProxyManager::IsInitialized ( )
◆ GetVersionMajor()
static int vtkSMProxyManager::GetVersionMajor ( )
Returns the major version number eg. if version is 2.9.1 this method will return 2.
◆ GetVersionMinor()
static int vtkSMProxyManager::GetVersionMinor ( )
Returns the minor version number eg. if version is 2.9.1 this method will return 9.
◆ GetVersionPatch()
static int vtkSMProxyManager::GetVersionPatch ( )
Returns the patch version number eg. if version is 2.9.1 this method will return 1.
◆ GetParaViewSourceVersion()
static const char* vtkSMProxyManager::GetParaViewSourceVersion ( )
◆ GetActiveSession()
vtkSMSession* vtkSMProxyManager::GetActiveSession ( )
If no active session is set, and there's only one registered vtkSMSession with vtkProcessModule, then that session is automatically treated as the active session.
◆ SetActiveSession() [1/2]
void vtkSMProxyManager::SetActiveSession ( vtkSMSession *  session)
It's acceptable to set the active session as nullptr (or 0 in case of sessionId), however GetActiveSession() may automatically pick an active session if none is provided.
◆ SetActiveSession() [2/2]
void vtkSMProxyManager::SetActiveSession ( vtkIdType  sessionId)
◆ GetActiveSessionProxyManager()
vtkSMSessionProxyManager* vtkSMProxyManager::GetActiveSessionProxyManager ( )
If no
◆ GetSessionProxyManager()
vtkSMSessionProxyManager* vtkSMProxyManager::GetSessionProxyManager ( vtkSMSession *  session)
◆ NewProxy()
vtkSMProxy* vtkSMProxyManager::NewProxy ( const char *  groupName,
const char *  proxyName,
const char *  subProxyName = nullptr
Raises errors if no active session manager can be determined (using GetActiveSessionProxyManager()).
◆ RegisterProxy()
void vtkSMProxyManager::RegisterProxy ( const char *  groupname,
const char *  name,
vtkSMProxy *  proxy
◆ GetProxy()
vtkSMProxy* vtkSMProxyManager::GetProxy ( const char *  groupname,
const char *  name
◆ UnRegisterProxy()
void vtkSMProxyManager::UnRegisterProxy ( const char *  groupname,
const char *  name,
vtkSMProxy *
◆ GetProxyName() [1/2]
const char* vtkSMProxyManager::GetProxyName ( const char *  groupname,
unsigned int  idx
◆ GetProxyName() [2/2]
vtkSMProxy *  proxy
◆ SetBlockProxyDefinitionUpdates()
virtual void vtkSMProxyManager::SetBlockProxyDefinitionUpdates ( bool  )
◆ GetBlockProxyDefinitionUpdates()
virtual bool vtkSMProxyManager::GetBlockProxyDefinitionUpdates ( )
◆ BlockProxyDefinitionUpdatesOn()
virtual void vtkSMProxyManager::BlockProxyDefinitionUpdatesOn ( )
◆ BlockProxyDefinitionUpdatesOff()
virtual void vtkSMProxyManager::BlockProxyDefinitionUpdatesOff ( )
◆ UpdateProxyDefinitions()
void vtkSMProxyManager::UpdateProxyDefinitions ( )
◆ SetUndoStackBuilder()
void vtkSMProxyManager::SetUndoStackBuilder ( vtkSMUndoStackBuilder *  builder)
◆ GetUndoStackBuilder()
virtual vtkSMUndoStackBuilder* vtkSMProxyManager::GetUndoStackBuilder ( )
◆ GetPluginManager()
virtual vtkSMPluginManager* vtkSMProxyManager::GetPluginManager ( )
This provides access to the application-wide plugin manager.
◆ GetReaderFactory()
virtual vtkSMReaderFactory* vtkSMProxyManager::GetReaderFactory ( )
Before using the reader factory, it is essential that it's configured correctly.
◆ GetWriterFactory()
virtual vtkSMWriterFactory* vtkSMProxyManager::GetWriterFactory ( )
◆ GetUniqueProxyName()
std::string vtkSMProxyManager::GetUniqueProxyName ( const char *  groupname,
const char *  prefix,
bool  alwaysAppend = true
The prefix is used to come up with a new name. if alwaysAppend is true, then a suffix will always be appended, if not, the prefix may be used directly if possible. If there are multiple vtkSMSessionProxyManager instances in the application, this method tries to find a unique name across all of them.
static vtkSMProxyManager* vtkSMProxyManager::New ( )
staticprotected
◆ ConnectionsUpdated()
void vtkSMProxyManager::ConnectionsUpdated ( vtkObject *  ,
unsigned long  ,
void *
Update the active session accordingly.
◆ vtkSMSessionProxyManager
friend class vtkSMSessionProxyManager
friend
Definition at line 222 of file vtkSMProxyManager.h.
◆ UndoStackBuilder
vtkSMUndoStackBuilder* vtkSMProxyManager::UndoStackBuilder
Definition at line 229 of file vtkSMProxyManager.h.
◆ PluginManager
vtkSMPluginManager* vtkSMProxyManager::PluginManager
Definition at line 230 of file vtkSMProxyManager.h.
◆ ReaderFactory
vtkSMReaderFactory* vtkSMProxyManager::ReaderFactory
Definition at line 231 of file vtkSMProxyManager.h.
◆ WriterFactory
vtkSMWriterFactory* vtkSMProxyManager::WriterFactory
Definition at line 232 of file vtkSMProxyManager.h.
bool vtkSMProxyManager::BlockProxyDefinitionUpdates
Definition at line 234 of file vtkSMProxyManager.h.
