Classes | Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
vtkSMNewWidgetRepresentationProxyAbstract Class Referenceabstract
Abstract class for proxies for 2D and 3D widgets. More...
#include <vtkSMNewWidgetRepresentationProxyAbstract.h>
Inheritance diagram for vtkSMNewWidgetRepresentationProxyAbstract:
Collaboration diagram for vtkSMNewWidgetRepresentationProxyAbstract:
class  vtkSMWidgetObserver
typedef vtkSMProxy Superclass
bool LinkProperties (vtkSMProxy *controlledProxy, vtkSMPropertyGroup *controlledPropertyGroup)
 Called to link properties from a Widget to controlledProxy i.e. More...
bool UnlinkProperties (vtkSMProxy *controlledProxy)
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMNewWidgetRepresentationProxyAbstract * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMNewWidgetRepresentationProxyAbstract ()
 ~vtkSMNewWidgetRepresentationProxyAbstract () override
virtual void ExecuteEvent (unsigned long event)=0
 Called every time the user interacts with the widget. More...
void ProcessLinkedPropertyEvent (vtkSMProperty *caller, unsigned long event)
 Called everytime a controlled property's unchecked values change. More...
void SetupPropertiesLinks ()
 Setup all links between properties and informations. More...
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkNew< vtkSMWidgetObserver > Observer
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMNewWidgetRepresentationProxyAbstract is an abstract class for proxies representing 2D or 3D widgets. It sets up all the properties link needed so proxies are in sync.
Definition at line 26 of file vtkSMNewWidgetRepresentationProxyAbstract.h.
Definition at line 29 of file vtkSMNewWidgetRepresentationProxyAbstract.h.
◆ vtkSMNewWidgetRepresentationProxyAbstract()
vtkSMNewWidgetRepresentationProxyAbstract::vtkSMNewWidgetRepresentationProxyAbstract ( )
◆ ~vtkSMNewWidgetRepresentationProxyAbstract()
vtkSMNewWidgetRepresentationProxyAbstract::~vtkSMNewWidgetRepresentationProxyAbstract ( )
virtual const char* vtkSMNewWidgetRepresentationProxyAbstract::GetClassName ( )
static int vtkSMNewWidgetRepresentationProxyAbstract::IsTypeOf ( const char *  type)
virtual int vtkSMNewWidgetRepresentationProxyAbstract::IsA ( const char *  type)
static vtkSMNewWidgetRepresentationProxyAbstract* vtkSMNewWidgetRepresentationProxyAbstract::SafeDownCast ( vtkObject *  o)
void vtkSMNewWidgetRepresentationProxyAbstract::PrintSelf ( ostream &  os,
◆ LinkProperties()
bool vtkSMNewWidgetRepresentationProxyAbstract::LinkProperties ( vtkSMProxy *  controlledProxy,
vtkSMPropertyGroup *  controlledPropertyGroup
a proxy whose properties are being manipulated using this Widget. Currently, we only support linking with one controlled proxy at a time. One must call UnlinkProperties() before one can call this method on another controlledProxy. The controlledPropertyGroup is used to determine the mapping between this widget properties and controlledProxy properties.
◆ UnlinkProperties()
bool vtkSMNewWidgetRepresentationProxyAbstract::UnlinkProperties ( vtkSMProxy *  controlledProxy)
◆ ExecuteEvent()
virtual void vtkSMNewWidgetRepresentationProxyAbstract::ExecuteEvent ( unsigned long  event)
protectedpure virtual
This should be override by each subclass.
Implemented in vtkSMScalarBarWidgetRepresentationProxy, vtkSMNewWidgetRepresentationProxy, and vtkSMNew2DWidgetRepresentationProxy.
◆ ProcessLinkedPropertyEvent()
void vtkSMNewWidgetRepresentationProxyAbstract::ProcessLinkedPropertyEvent ( vtkSMProperty *  caller,
unsigned long  event
◆ SetupPropertiesLinks()
void vtkSMNewWidgetRepresentationProxyAbstract::SetupPropertiesLinks ( )
It also update properties information before anything else. Usually called in CreateVTKObject() function.
◆ Observer
vtkNew<vtkSMWidgetObserver> vtkSMNewWidgetRepresentationProxyAbstract::Observer
Definition at line 66 of file vtkSMNewWidgetRepresentationProxyAbstract.h.
