pqDisplaySizedImplicitPlanePropertyWidget.h
4 #ifndef pqDisplaySizedImplicitPlanePropertyWidget_h
5 #define pqDisplaySizedImplicitPlanePropertyWidget_h
6
23 class PQAPPLICATIONCOMPONENTS_EXPORT pqDisplaySizedImplicitPlanePropertyWidget
25 {
26  Q_OBJECT
28
29 public:
31  vtkSMProxy* proxy, vtkSMPropertyGroup* smgroup, QWidget* parent = nullptr);
33
37  void apply() override;
38  void reset() override;
40 public Q_SLOTS: // NOLINT(readability-redundant-access-specifiers)
44  void showPlane() { this->setDrawPlane(true); }
45  void hidePlane() { this->setDrawPlane(false); }
46  void setDrawPlane(bool val);
47
51  void setDrawOutlineAndIntersectionEdges(bool val);
52
56  void useXNormal() { this->setNormal(1, 0, 0); }
57
61  void useYNormal() { this->setNormal(0, 1, 0); }
62
66  void useZNormal() { this->setNormal(0, 0, 1); }
67
71  void resetRadiusSize();
72
76  void resetToDataBounds();
77
81  void resetCameraToNormal();
82
86  void useCameraNormal();
87
88 protected Q_SLOTS:
92  void placeWidget() override;
93
94 private Q_SLOTS:
95  void setOrigin(double x, double y, double z);
96  void setNormal(double x, double y, double z);
97
98 private: // NOLINT(readability-redundant-access-specifiers)
100 };
101
102 #endif
pqDisplaySizedImplicitPlanePropertyWidget::hidePlane
void hidePlane()
Definition: pqDisplaySizedImplicitPlanePropertyWidget.h:45
pqDisplaySizedImplicitPlanePropertyWidget::useZNormal
void useZNormal()
Set the widget normal to be along the Z axis.
Definition: pqDisplaySizedImplicitPlanePropertyWidget.h:66
pqDisplaySizedImplicitPlanePropertyWidget::useXNormal
void useXNormal()
Set the widget normal to be along the X axis.
Definition: pqDisplaySizedImplicitPlanePropertyWidget.h:56
pqDisplaySizedImplicitPlanePropertyWidget::useYNormal
void useYNormal()
Set the widget normal to be along the Y axis.
Definition: pqDisplaySizedImplicitPlanePropertyWidget.h:61
vtkSMProxy
Definition: vtkSMProxy.h:140
vtkSMPropertyGroup
Definition: vtkSMPropertyGroup.h:16
pqInteractivePropertyWidget.h
pqPropertyWidget::apply
virtual void apply()
pqInteractivePropertyWidgetAbstract::placeWidget
virtual void placeWidget()=0
Places the interactive widget using current data source information.
pqInteractivePropertyWidget is an abstract pqPropertyWidget subclass designed to serve as the supercl...
Definition: pqInteractivePropertyWidget.h:29
pqDisplaySizedImplicitPlanePropertyWidget is a custom property widget that uses "DisplaySizedImplicit...
Definition: pqDisplaySizedImplicitPlanePropertyWidget.h:23
pqDisplaySizedImplicitPlanePropertyWidget::showPlane
void showPlane()
Slots used to toggle the visibility of the translucent plane.
Definition: pqDisplaySizedImplicitPlanePropertyWidget.h:44
pqInteractivePropertyWidgetAbstract::reset
Overridden to call this->render() to ensure that the widget is redrawn.
