pqCylinderPropertyWidget.h
4 #ifndef pqCylinderPropertyWidget_h
5 #define pqCylinderPropertyWidget_h
6
9 class QWidget;
10
27 class PQAPPLICATIONCOMPONENTS_EXPORT pqCylinderPropertyWidget : public pqInteractivePropertyWidget
28 {
29  Q_OBJECT
31
32 public:
34  vtkSMProxy* proxy, vtkSMPropertyGroup* smgroup, QWidget* parent = nullptr);
35  ~pqCylinderPropertyWidget() override;
36
37 public Q_SLOTS: // NOLINT(readability-redundant-access-specifiers)
41  void useXAxis() { this->setAxis(1, 0, 0); }
42
46  void useYAxis() { this->setAxis(0, 1, 0); }
47
51  void useZAxis() { this->setAxis(0, 0, 1); }
52
56  void resetCameraToAxis();
57
61  void useCameraAxis();
62
63 protected Q_SLOTS:
67  void placeWidget() override;
68
69  void resetBounds();
70
71 private:
72  Q_DISABLE_COPY(pqCylinderPropertyWidget)
73
74  void setAxis(double x, double y, double z);
75  void updateWidget(bool showing_advanced_properties) override;
76
77  pqPropertyLinks WidgetLinks;
78  QWidget* AdvancedPropertyWidgets[2];
79 };
80
81 #endif
pqCylinderPropertyWidget::useZAxis
void useZAxis()
Set the cylinder axis to be along the Z axis.
Definition: pqCylinderPropertyWidget.h:51
pqCylinderPropertyWidget::useYAxis
void useYAxis()
Set the cylinder axis to be along the Y axis.
Definition: pqCylinderPropertyWidget.h:46
pqCylinderPropertyWidget::useXAxis
void useXAxis()
Set the cylinder axis to be along the X axis.
Definition: pqCylinderPropertyWidget.h:41
vtkSMProxy
Definition: vtkSMProxy.h:140
pqPropertyWidget::updateWidget
virtual void updateWidget(bool showing_advanced_properties)
Definition: pqPropertyWidget.h:59
vtkSMPropertyGroup
Definition: vtkSMPropertyGroup.h:16
pqInteractivePropertyWidget.h
pqInteractivePropertyWidgetAbstract::placeWidget
virtual void placeWidget()=0
Places the interactive widget using current data source information.
pqInteractivePropertyWidget is an abstract pqPropertyWidget subclass designed to serve as the supercl...
Definition: pqInteractivePropertyWidget.h:29
pqCylinderPropertyWidget is a custom property widget that uses "ImplicitCylinderWidgetRepresentation"...
Definition: pqCylinderPropertyWidget.h:27
