vtkPVDataRepresentation Class Reference
vtkPVDataRepresentation adds some ParaView specific API to data representations. More...
#include <vtkPVDataRepresentation.h>
Inheritance diagram for vtkPVDataRepresentation:
Collaboration diagram for vtkPVDataRepresentation:
enum  DesiredOutputPrecision
virtual int ProcessViewRequest (vtkInformationRequestKey *request_type, vtkInformation *inInfo, vtkInformation *outInfo)
virtual void MarkModified ()
virtual void SetVisibility (bool val)
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkAlgorithm * New ()
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
See also
vtkPVDataRepresentationPipeline
Definition at line 23 of file vtkPVDataRepresentation.h.
Definition at line 26 of file vtkPVDataRepresentation.h.
◆ anonymous enum
anonymous enum
Enumerator
SkippedUpdateDataEvent
This event is fired in ProcessViewRequest when REQUEST_UPDATE was requested and the representation needed an update (i.e.
this->GetNeedsUpdate() == true), however was skipped since the data is already cached by the view.
UpdateTimeChangedEvent
Definition at line 200 of file vtkPVDataRepresentation.h.
◆ vtkPVDataRepresentation()
vtkPVDataRepresentation::vtkPVDataRepresentation ( )
◆ ~vtkPVDataRepresentation()
vtkPVDataRepresentation::~vtkPVDataRepresentation ( )
virtual const char* vtkPVDataRepresentation::GetClassName ( )
static int vtkPVDataRepresentation::IsTypeOf ( const char *  type)
virtual int vtkPVDataRepresentation::IsA ( const char *  type)
static vtkPVDataRepresentation* vtkPVDataRepresentation::SafeDownCast ( vtkObject *  o)
void vtkPVDataRepresentation::PrintSelf ( ostream &  os,
◆ ProcessViewRequest()
virtual int vtkPVDataRepresentation::ProcessViewRequest ( vtkInformationRequestKey *  request_type,
vtkInformation *  inInfo,
vtkInformation *  outInfo
◆ MarkModified()
virtual void vtkPVDataRepresentation::MarkModified ( )
This is one of the most important functions.
In VTK pipelines, it's very easy for the pipeline to decide when it needs to re-execute. vtkAlgorithm::Update() can go up the entire pipeline to see if any filters MTime changed (among other things) and if so, it can re-execute the pipeline. However in case of representations, the real input connection may only be present on the data-server nodes. In that case the vtkPVDataRepresentation::RequestData() will only get called on the data-server nodes. That means that representations won't be able to any data-delivery in RequestData(). We'd need some other mechanisms to synchronize data-delivery among processes. To avoid that conundrum, the vtkSMRepresentationProxy calls MarkModified() on all processes whenever any filter in the pipeline is modified. In this method, the vtkPVDataRepresentation subclasses should ensure that they mark all delivery related filters dirty in their RequestData to ensure they execute then next time they are updated. The vtkPVDataRepresentation also uses a special executive which avoids updating the representation unless MarkModified() was called since the last Update(), thus acting as a update-suppressor.
Reimplemented in vtkPolarAxesRepresentation, vtkCompositeRepresentation, vtkPVCompositeOrthographicSliceRepresentation, vtkChartRepresentation, vtkSelectionRepresentation, vtkPVCompositeRepresentation, vtkSpreadSheetRepresentation, and vtkChartSelectionRepresentation.
◆ Initialize()
virtual unsigned int vtkPVDataRepresentation::Initialize ( unsigned int  minIdAvailable,
unsigned int  maxIdAvailable
Initialize the representation with an identifier range so each internal representation can own a unique ID.
If a representation requires more IDs than the set of ids provided, the representation MUST complains by an error or abort explaining how many ids where expected so the number of reserved ids could be easily adjust. Unless noted otherwise, this method must be called before calling any other methods on this class.
Note
CallOnAllProcesses Internally you can pick an id that follow that condition minIdAvailable <= id <= maxIdAvailable Return the minIdAvailable after initialization so that new range could be used
Reimplemented in vtkSelectionRepresentation, vtkPVCompositeRepresentation, vtkChartRepresentation, and vtkPVCompositeOrthographicSliceRepresentation.
◆ GetUniqueIdentifier()
unsigned int vtkPVDataRepresentation::GetUniqueIdentifier ( )
inline
Return 0 if the Initialize() method was not called otherwise a unique ID that will be shared across the processes for that same object.
Definition at line 83 of file vtkPVDataRepresentation.h.
◆ SetVisibility()
virtual void vtkPVDataRepresentation::SetVisibility ( bool  val)
inlinevirtual
◆ GetVisibility()
virtual bool vtkPVDataRepresentation::GetVisibility ( )
Reimplemented in vtkDataLabelRepresentation.
◆ GetRenderedDataObject()
virtual vtkDataObject* vtkPVDataRepresentation::GetRenderedDataObject ( int   vtkNotUsedport)
inlinevirtual
Returns the data object that is rendered from the given input port.
Definition at line 95 of file vtkPVDataRepresentation.h.
◆ SetUpdateTime()
virtual void vtkPVDataRepresentation::SetUpdateTime ( double  time)
◆ GetUpdateTime()
virtual double vtkPVDataRepresentation::GetUpdateTime ( )
◆ GetUpdateTimeValid()
virtual bool vtkPVDataRepresentation::GetUpdateTimeValid ( )
Get whether the UpdateTime is valid.
ResetUpdateTime can be used to clear the UpdateTimeValid flag.
◆ ResetUpdateTime()
void vtkPVDataRepresentation::ResetUpdateTime ( )
◆ SetForcedCacheKey()
virtual void vtkPVDataRepresentation::SetForcedCacheKey ( double  val)
inlinevirtual
Generally, caching is within the purview of the vtkPVView (and subclasses).
However, a representation may choose to override that caching by forcing specific caching parameters. This is primarily intended for views like comparative view that rely on caching to show multiple frames from the same pipeline at a time.
Reimplemented in vtkCompositeRepresentation, vtkPVCompositeRepresentation, and vtkSelectionRepresentation.
Definition at line 125 of file vtkPVDataRepresentation.h.
◆ SetForceUseCache()
virtual void vtkPVDataRepresentation::SetForceUseCache ( bool  val)
inlinevirtual
Definition at line 126 of file vtkPVDataRepresentation.h.
◆ GetForcedCacheKey()
virtual double vtkPVDataRepresentation::GetForcedCacheKey ( )
◆ GetForceUseCache()
virtual bool vtkPVDataRepresentation::GetForceUseCache ( )
◆ GetCacheKey()
double vtkPVDataRepresentation::GetCacheKey ( ) const
Returns the cache-key the representation is currently using.
This takes into consideration whether ForcedCacheKey is to be used.
◆ AddToView()
bool vtkPVDataRepresentation::AddToView ( vtkView *  view)
override
Making these methods public.
When constructing composite representations, we need to call these methods directly on internal representations.
◆ RemoveFromView()
bool vtkPVDataRepresentation::RemoveFromView ( vtkView *  view)
override
◆ GetInternalOutputPort() [1/3]
vtkAlgorithmOutput* vtkPVDataRepresentation::GetInternalOutputPort ( )
inlineoverridevirtual
Retrieves an output port for the input data object at the specified port and connection index.
This may be connected to the representation's internal pipeline. Overridden to use vtkPVTrivialProducer instead of vtkTrivialProducer
Definition at line 152 of file vtkPVDataRepresentation.h.
◆ GetInternalOutputPort() [2/3]
vtkAlgorithmOutput* vtkPVDataRepresentation::GetInternalOutputPort ( int  port)
Definition at line 153 of file vtkPVDataRepresentation.h.
◆ GetInternalOutputPort() [3/3]
vtkAlgorithmOutput* vtkPVDataRepresentation::GetInternalOutputPort ( int  port,
int  conn
◆ GetView()
vtkView* vtkPVDataRepresentation::GetView ( ) const
Provides access to the view.
◆ GetPipelineDataTime()
vtkMTimeType vtkPVDataRepresentation::GetPipelineDataTime ( )
Returns the timestamp when RequestData was executed on the representation.
◆ SetLogName()
virtual void vtkPVDataRepresentation::SetLogName ( const std::string &  name)
inlinevirtual
This is solely intended to simplify debugging and use for any other purpose is vehemently discouraged.
Reimplemented in vtkSelectionRepresentation.
Definition at line 175 of file vtkPVDataRepresentation.h.
◆ GetLogName()
const std::string& vtkPVDataRepresentation::GetLogName ( ) const
inline
Definition at line 176 of file vtkPVDataRepresentation.h.
◆ GetHasTemporalPipeline()
virtual bool vtkPVDataRepresentation::GetHasTemporalPipeline ( )
This flag indicates if the representation is for a temporal pipeline.
If true, then calling SetUpdateTime will result in calling this->MarkModified() i.e. will cause the representation to update on subsequent update request. Otherwise, the subsequent update request will be a no-op (unless the representation ended up calling MarkModified due to other changes i.e. change in input pipeline). HasTemporalPipeline gets set in the first update on the representation, however, only on the data-server side. vtkPVView ensures that the flag is synced up among all ranks at the end of each vtkPVView::Update call.
◆ SetHasTemporalPipeline()
virtual void vtkPVDataRepresentation::SetHasTemporalPipeline ( bool  )
◆ GetNeedsUpdate()
bool vtkPVDataRepresentation::GetNeedsUpdate ( )
Returns true if the representation needs an update.
◆ SetInputConnection()
void vtkPVDataRepresentation::SetInputConnection ( int  port,
vtkAlgorithmOutput *  input
Overridden to ensure that MarkModified is called.
◆ AddInputConnection()
void vtkPVDataRepresentation::AddInputConnection ( int  port,
◆ SetArrayIdNames()
virtual void vtkPVDataRepresentation::SetArrayIdNames ( const char *  vtkNotUsedpointArray,
const char *  vtkNotUsedcellArray
inlinevirtual
Specify the array names used for the selection.
Empty method to be implemented by inheriting classes
Definition at line 226 of file vtkPVDataRepresentation.h.
◆ CreateDefaultExecutive()
vtkExecutive* vtkPVDataRepresentation::CreateDefaultExecutive ( )
overrideprotectedvirtual
Create a default executive.
◆ RequestData()
int vtkPVDataRepresentation::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
◆ RequestUpdateExtent()
int vtkPVDataRepresentation::RequestUpdateExtent ( vtkInformation *  request,
◆ RequestUpdateTime()
int vtkPVDataRepresentation::RequestUpdateTime ( vtkInformation *  ,
◆ UpdateTime
double vtkPVDataRepresentation::UpdateTime
Definition at line 248 of file vtkPVDataRepresentation.h.
◆ UpdateTimeValid
bool vtkPVDataRepresentation::UpdateTimeValid
Definition at line 249 of file vtkPVDataRepresentation.h.
◆ UniqueIdentifier
unsigned int vtkPVDataRepresentation::UniqueIdentifier
Definition at line 250 of file vtkPVDataRepresentation.h.
