Public Types | Public Member Functions | Static Public Member Functions | Protected Types | Protected Member Functions | Protected Attributes | List of all members
vtkChartRepresentation Class Reference
vtkChartRepresentation is the base representation for charting representations. More...
#include <vtkChartRepresentation.h>
Inheritance diagram for vtkChartRepresentation:
Collaboration diagram for vtkChartRepresentation:
enum  DesiredOutputPrecision
void SetSelectionRepresentation (vtkChartSelectionRepresentation *)
 These must only be set during initialization before adding the representation to any views or calling Update(). More...
void SetVisibility (bool visible) override
 Set visibility of the representation. More...
void MarkModified () override
 This needs to be called on all instances of vtkGeometryRepresentation when the input is modified. More...
void SetCompositeDataSetIndex (unsigned int)
void AddCompositeDataSetIndex (unsigned int)
void ResetCompositeDataSetIndices ()
unsigned int Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) override
 Override because of internal selection representations that need to be initialized as well. More...
virtual std::string GetDefaultSeriesLabel (const std::string &tableName, const std::string &columnName)
 Method to provide the default name given the name of a table and a column in that table. More...
virtual bool MapSelectionToInput (vtkSelection *sel)
 This method is called on the client-side by the vtkPVContextView whenever a new selection is made on all the visible representations in that view. More...
virtual bool MapSelectionToView (vtkSelection *sel)
 This is the inverse of MapSelectionToInput(). More...
void SetFieldAssociation (int)
 Set the field association for arrays to use. More...
virtual void SetFlattenTable (int)
 Flatten the table, i.e. More...
virtual int GetFlattenTable ()
virtual bool Export (vtkAbstractChartExporter *vtkNotUsed(exporter))
 Called by vtkPVContextView::Export() to export the representation's data to a CSV file. More...
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkChartRepresentation * New ()
static vtkChartRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
Protected Types
typedef std::map< std::string, std::pair< vtkSmartPointer< vtkTable >, unsigned int > > MapOfTables
 vtkChartRepresentation ()
 ~vtkChartRepresentation () override
virtual void PrepareForRendering ()
 This method is called before actual render if this->MTime was modified since the last time this method was called. More...
 Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
vtkTable * GetLocalOutput (bool pre_delivery=false)
 Convenience method to get the first vtkTable from LocalOutput, if any. More...
virtual vtkSmartPointer< vtkDataObject > TransformInputData (vtkDataObject *data)
 Method to be overridden to transform input data. More...
virtual vtkSmartPointer< vtkDataObject > ReduceDataToRoot (vtkDataObject *data)
 Chart representation/views expect that the data is reduced to root node and then passed on the rendering nodes. More...
virtual vtkSmartPointer< vtkDataObject > TransformTable (vtkSmartPointer< vtkDataObject > table)
 Method to be overridden to apply an operation of the table after it is gathered to the first rank for rendering the chart. More...
bool GetLocalOutput (MapOfTables &tables)
 Convenience method to get all vtkTable instances with their associated names. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
int FieldAssociation
vtkWeakPointer< vtkPVContextView > ContextView
int FlattenTable
vtkSmartPointer< vtkMultiBlockDataSet > LocalOutput
std::set< unsigned int > CompositeIndices
vtkWeakPointer< vtkChartSelectionRepresentation > SelectionRepresentation
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
Currently, ParaView's charting views are client-side only views that render only on the client side. That being the case, when running in client-server mode or in parallel, the data-delivery mode is fixed. Hence, unlike representations for 3D views, this representation delivers the data in RequestData() itself. This makes it possible for client code to call UpdatePipeline() on the representation proxy and then access the delivered vtkTable on the client.
Definition at line 35 of file vtkChartRepresentation.h.
Definition at line 39 of file vtkChartRepresentation.h.
◆ MapOfTables
typedef std::map<std::string, std::pair<vtkSmartPointer<vtkTable>, unsigned int> > vtkChartRepresentation::MapOfTables
Definition at line 226 of file vtkChartRepresentation.h.
◆ vtkChartRepresentation()
vtkChartRepresentation::vtkChartRepresentation ( )
◆ ~vtkChartRepresentation()
vtkChartRepresentation::~vtkChartRepresentation ( )
static vtkChartRepresentation* vtkChartRepresentation::New ( )
virtual const char* vtkChartRepresentation::GetClassName ( )
static int vtkChartRepresentation::IsTypeOf ( const char *  type)
virtual int vtkChartRepresentation::IsA ( const char *  type)
static vtkChartRepresentation* vtkChartRepresentation::SafeDownCast ( vtkObject *  o)
void vtkChartRepresentation::PrintSelf ( ostream &  os,
◆ SetSelectionRepresentation()
void vtkChartRepresentation::SetSelectionRepresentation ( vtkChartSelectionRepresentation *  )
◆ SetVisibility()
void vtkChartRepresentation::SetVisibility ( bool  visible)
◆ MarkModified()
void vtkChartRepresentation::MarkModified ( )
This is essential since the geometry filter does not have any real-input on the client side which messes with the Update requests.
◆ SetFieldAssociation()
void vtkChartRepresentation::SetFieldAssociation ( int  )
When changed, this will call MarkModified().
◆ GetFieldAssociation()
virtual int vtkChartRepresentation::GetFieldAssociation ( )
◆ SetCompositeDataSetIndex()
void vtkChartRepresentation::SetCompositeDataSetIndex ( unsigned  int)
◆ AddCompositeDataSetIndex()
void vtkChartRepresentation::AddCompositeDataSetIndex ( unsigned  int)
◆ ResetCompositeDataSetIndices()
void vtkChartRepresentation::ResetCompositeDataSetIndices ( )
◆ Initialize()
unsigned int vtkChartRepresentation::Initialize ( unsigned int  minIdAvailable,
◆ ProcessViewRequest()
int vtkChartRepresentation::ProcessViewRequest ( vtkInformationRequestKey *  request_type,
vtkInformation *  inInfo,
vtkInformation *  outInfo
This is typically called by the vtkView to request meta-data from the representations or ask them to perform certain tasks e.g. PrepareForRendering. Overridden to handle REQUEST_RENDER() to call PrepareForRendering.
Reimplemented in vtkXYChartRepresentation.
◆ GetDefaultSeriesLabel()
virtual std::string vtkChartRepresentation::GetDefaultSeriesLabel ( const std::string &  tableName,
const std::string &  columnName
When overriding this method, ensure that the implementation does not depend on the instance being initialized or have valid data. This method is called on the client-side when filling up the domains for the properties.
Reimplemented in vtkQuartileChartRepresentation.
◆ SetFlattenTable()
virtual void vtkChartRepresentation::SetFlattenTable ( int  )
split any multicomponent columns into separate components.
◆ GetFlattenTable()
virtual int vtkChartRepresentation::GetFlattenTable ( )
◆ MapSelectionToInput()
virtual bool vtkChartRepresentation::MapSelectionToInput ( vtkSelection *  sel)
The goal of this method is allow the representations to transform the selection created in the view (which is an id-based selection based on the vtkTable that is fed into the vtkChart) to an appropriate selection based on the data going into the representation. Return false if the selection is not applicable to this representation or the conversion cannot be made. Default implementation simply ensures that the FieldType on the selection nodes is set to match up with the FieldAssociation on the representation.
Reimplemented in vtkPVHistogramChartRepresentation.
◆ MapSelectionToView()
virtual bool vtkChartRepresentation::MapSelectionToView ( vtkSelection *  sel)
In this case, we are converting the selection defined on the input for the representation to a selection that corresponds to elements being rendered in the view. The default implementation checks removes vtkSelectionNode items in sel that don't have the FieldType that matches this->FieldAssociation. Similar to MapSelectionToInput(), this method is expected to transform the sel in place and return false is the selection is not applicable to this representation or the conversion cannot be made.
◆ Export()
virtual bool vtkChartRepresentation::Export ( vtkAbstractChartExporter *  vtkNotUsedexporter)
inlinevirtual
Return false on failure which will call the exporting process to abort and raise an error. Default implementation simply returns false.
Definition at line 146 of file vtkChartRepresentation.h.
◆ FillInputPortInformation()
int vtkChartRepresentation::FillInputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
Fill input port information.
◆ PrepareForRendering()
virtual void vtkChartRepresentation::PrepareForRendering ( )
inlineprotectedvirtual
Subclasses should override to update "appearance" related changes that don't affect data. When this method is called, you're assured that this->ContextView is valid. Note that this method will not be called if this->GetVisibility() returns false, this subclasses should also override SetVisibility() to hide "actors" and such.
Reimplemented in vtkXYChartRepresentation, vtkPVPlotMatrixRepresentation, vtkPVHistogramChartRepresentation, vtkQuartileChartRepresentation, vtkPVParallelCoordinatesRepresentation, vtkPVBoxChartRepresentation, and vtkPVImageChartRepresentation.
Definition at line 167 of file vtkChartRepresentation.h.
◆ RequestData()
int vtkChartRepresentation::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
Since most representations are "meta-filters" (i.e. filters containing other filters), you should create shallow copies of your input before connecting to the internal pipeline. The convenience method GetInternalOutputPort will create a cached shallow copy of a specified input for you. The related helper functions GetInternalAnnotationOutputPort, GetInternalSelectionOutputPort should be used to obtain a selection or annotation port whose selections are localized for a particular input data object.
◆ AddToView()
bool vtkChartRepresentation::AddToView ( vtkView *  view)
◆ RemoveFromView()
bool vtkChartRepresentation::RemoveFromView ( vtkView *  view)
◆ GetLocalOutput() [1/2]
vtkTable* vtkChartRepresentation::GetLocalOutput ( bool  pre_delivery = false)
If pre_delivery is true (default is false), then the data from most-recent REQUEST_UPDATE pass is used otherwise the delivered data object from most recent REQUEST_RENDER pass is used.
◆ TransformInputData()
virtual vtkSmartPointer<vtkDataObject> vtkChartRepresentation::TransformInputData ( vtkDataObject *  data)
protectedvirtual
The default implementation just returns the data object provided in parameter.
◆ ReduceDataToRoot()
virtual vtkSmartPointer<vtkDataObject> vtkChartRepresentation::ReduceDataToRoot ( vtkDataObject *  data)
protectedvirtual
This method may be overridden to customize the reduction. The default implementation uses vtkBlockDeliveryPreprocessor to convert to tables and then use vtkPVMergeTablesMultiBlock as the reduction algorithm.
Reimplemented in vtkPVImageChartRepresentation.
◆ TransformTable()
virtual vtkSmartPointer<vtkDataObject> vtkChartRepresentation::TransformTable ( vtkSmartPointer< vtkDataObject >  table)
protectedvirtual
This allows subclasses to operate on the final table. The default implementation just returns the input.
◆ GetLocalOutput() [2/2]
bool vtkChartRepresentation::GetLocalOutput ( MapOfTables &  tables)
◆ FieldAssociation
int vtkChartRepresentation::FieldAssociation
Definition at line 233 of file vtkChartRepresentation.h.
◆ ContextView
vtkWeakPointer<vtkPVContextView> vtkChartRepresentation::ContextView
Definition at line 234 of file vtkChartRepresentation.h.
◆ FlattenTable
int vtkChartRepresentation::FlattenTable
Definition at line 235 of file vtkChartRepresentation.h.
◆ LocalOutput
vtkSmartPointer<vtkMultiBlockDataSet> vtkChartRepresentation::LocalOutput
Definition at line 237 of file vtkChartRepresentation.h.
◆ CompositeIndices
std::set<unsigned int> vtkChartRepresentation::CompositeIndices
Definition at line 238 of file vtkChartRepresentation.h.
◆ SelectionRepresentation
vtkWeakPointer<vtkChartSelectionRepresentation> vtkChartRepresentation::SelectionRepresentation
Definition at line 240 of file vtkChartRepresentation.h.
