vtkGeometryRepresentation Class Reference
representation for showing any datasets as external shell of polygons. More...
#include <vtkGeometryRepresentation.h>
Inheritance diagram for vtkGeometryRepresentation:
Collaboration diagram for vtkGeometryRepresentation:
enum  RepresentationTypes { POINTS = VTK_POINTS, WIREFRAME = VTK_WIREFRAME, SURFACE = VTK_SURFACE, SURFACE_WITH_EDGES = 3 }
enum  DesiredOutputPrecision
void SetVisibility (bool val) override
virtual void SetSuppressLOD (bool suppress)
 Enable/Disable LOD;. More...
virtual void SetRepresentation (const char *)
 Overload to set representation type using string. More...
vtkDataObject * GetRenderedDataObject (int port) override
virtual void SetNormalArray (const char *val)
 Set the normal array used for smooth shading. More...
virtual void SetTCoordArray (const char *val)
 Set the texture coordinates array used for texture mapping. More...
virtual void SetTangentArray (const char *val)
 Set the tangent coordinates array used for normal mapping. More...
virtual void SetUseOutline (int)
void SetTriangulate (int)
void SetNonlinearSubdivisionLevel (int)
void SetMatchBoundariesIgnoringCellOrder (int)
virtual void SetGenerateFeatureEdges (bool)
void SetComputePointNormals (bool)
void SetSplitting (bool)
void SetFeatureAngle (double)
virtual void SetAmbientColor (double r, double g, double b)
virtual void SetColor (double r, double g, double b)
virtual void SetDiffuseColor (double r, double g, double b)
virtual void SetLighting (bool lighting)
virtual void SetEdgeColor (double r, double g, double b)
virtual void SetInteractiveSelectionColor (double r, double g, double b)
virtual void SetInterpolation (int val)
virtual void SetLineWidth (double val)
virtual void SetOpacity (double val)
virtual void SetEdgeOpacity (double val)
virtual void SetPointSize (double val)
virtual void SetSpecularColor (double r, double g, double b)
virtual void SetSpecularPower (double val)
virtual void SetLuminosity (double val)
virtual void SetRenderPointsAsSpheres (bool)
virtual void SetRenderLinesAsTubes (bool)
virtual void SetRoughness (double val)
virtual void SetMetallic (double val)
virtual void SetEdgeTint (double r, double g, double b)
virtual void SetAnisotropy (double val)
virtual void SetAnisotropyRotation (double val)
virtual void SetBaseIOR (double val)
virtual void SetCoatIOR (double val)
virtual void SetCoatStrength (double val)
virtual void SetCoatRoughness (double val)
virtual void SetCoatNormalScale (double val)
virtual void SetCoatColor (double r, double g, double b)
virtual void SetBaseColorTexture (vtkTexture *tex)
virtual void SetMaterialTexture (vtkTexture *tex)
virtual void SetAnisotropyTexture (vtkTexture *tex)
virtual void SetNormalTexture (vtkTexture *tex)
virtual void SetCoatNormalTexture (vtkTexture *tex)
virtual void SetEmissiveTexture (vtkTexture *tex)
virtual void SetNormalScale (double val)
virtual void SetOcclusionStrength (double val)
virtual void SetEmissiveFactor (double rval, double gval, double bval)
virtual void SetShowTexturesOnBackface (bool)
virtual void SetOrientation (double, double, double)
virtual void SetOrigin (double, double, double)
virtual void SetPickable (int val)
virtual void SetPosition (double, double, double)
virtual void SetScale (double, double, double)
virtual void SetTexture (vtkTexture *)
virtual void SetUserTransform (const double[16])
virtual void SetFlipTextures (bool)
virtual void SetTextureTransform (vtkTransform *)
virtual vtkTransform * GetTextureTransform ()
virtual void SetRepeatTextures (bool)
virtual bool GetRepeatTextures ()
virtual void SetInterpolateTextures (bool)
virtual bool GetInterpolateTextures ()
virtual void SetUseMipmapTextures (bool)
virtual bool GetUseMipmapTextures ()
virtual void SetInterpolateScalarsBeforeMapping (int val)
virtual void SetLookupTable (vtkScalarsToColors *val)
virtual void SetColorMissingArraysWithNanColor (bool val)
virtual void SetSeamlessU (bool)
virtual void SetSeamlessV (bool)
virtual void SetSelection (vtkSelection *selection)
 Sets the selection used by the mapper. More...
vtkPVLODActor * GetActor ()
 Provides access to the actor used by this representation. More...
const char * GetColorArrayName ()
 Convenience method to get the array name used to scalar color with. More...
virtual void SetMaterial (const char *)
 For OSPRay, choose from among available materials. More...
virtual void SetShaderReplacements (const char *)
 Specify shader replacements using a Json string. More...
void SetArrayIdNames (const char *pointArray, const char *cellArray) override
void SetBlockColorsDistinctValues (int distinctValues)
 Determines the number of distinct values in vtkBlockColors See also vtkPVGeometryFilter. More...
int GetBlockColorsDistinctValues ()
virtual void DisableLightingOn ()
 Disables the lighting on the object. More...
virtual void DisableLightingOff ()
virtual void SetDisableLighting (bool)
virtual bool GetDisableLighting ()
virtual void SetAmbient (double)
 Set the lighting properties of the object. More...
virtual void SetDiffuse (double)
virtual void SetSpecular (double)
virtual double GetAmbient ()
virtual double GetDiffuse ()
virtual double GetSpecular ()
void SetCoordinateShiftScaleMethod (int val)
 Set the shift scale method for the point coordinates see vtkOpenGLVertexBufferObject.h for more information. More...
int GetCoordinateShiftScaleMethod ()
virtual void SetRepresentation (int)
 Set the representation type. More...
virtual int GetRepresentation ()
virtual void SetRequestGhostCellsIfNeeded (bool)
 Representations that use geometry representation as the internal representation should turn this flag off so that we don't end up requesting ghost cells twice. More...
virtual bool GetRequestGhostCellsIfNeeded ()
virtual void RequestGhostCellsIfNeededOn ()
virtual void RequestGhostCellsIfNeededOff ()
virtual void SetMapScalars (int val)
 Sets if scalars are mapped through a color-map or are used directly as colors. More...
virtual void SetStatic (int val)
virtual void SetActiveAssembly (const char *)
 Get/Set the name of the assembly to use for mapping block visibilities, colors and opacities. More...
virtual char * GetActiveAssembly ()
void AddBlockSelector (const char *selector)
 Update list of selectors that determine the selected blocks. More...
void RemoveAllBlockSelectors ()
void SetBlockColor (const char *selector, double r, double g, double b)
 Set the color for a single block. More...
void RemoveAllBlockColors ()
void SetBlockOpacity (const char *selector, double opacity)
 Set the opacity for a single block. More...
void RemoveAllBlockOpacities ()
void SetBlockInterpolateScalarsBeforeMapping (const char *selector, bool interpolate)
 Set if to interpolate scalars before mapping for a single block. More...
void RemoveAllBlockInterpolateScalarsBeforeMappings ()
void SetBlockMapScalars (const char *selector, int val)
 Set the block to map scalars for a single block. More...
void RemoveAllBlockMapScalars ()
void SetBlockArrayName (const char *selector, int assoc, const char *arrayName)
 Set the color array for a single block. More...
void RemoveAllBlockArrayNames ()
void SetBlockLookupTable (vtkScalarsToColors *lut)
 Set the look up table for a single block. More...
void RemoveAllBlockLookupTables ()
virtual void SetEnableScaling (int v)
 For OSPRay controls sizing of implicit spheres (points) and cylinders (lines) More...
virtual void SetScalingArrayName (const char *)
virtual void SetScalingFunction (vtkPiecewiseFunction *pwf)
virtual void SetUseDataPartitions (bool)
 Specify whether or not to redistribute the data. More...
virtual bool GetUseDataPartitions ()
virtual void SetUseShaderReplacements (bool)
 Specify whether or not to shader replacements string must be used. More...
virtual bool GetUseShaderReplacements ()
void SetPlaceHolderDataType (int datatype)
 Set/Get the placeholder data type. More...
virtual int GetPlaceHolderDataType ()
virtual void MarkModified ()
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkGeometryRepresentation * New ()
static vtkGeometryRepresentation * SafeDownCast (vtkObject *o)
static bool GetBounds (vtkDataObject *dataObject, double bounds[6], vtkCompositeDataDisplayAttributes *cdAttributes)
 Convenience method to get bounds from a dataset/composite dataset. More...
static vtkAlgorithm * New ()
 vtkGeometryRepresentation ()
 ~vtkGeometryRepresentation () override
virtual void SetupDefaults ()
 This method is called in the constructor. More...
 Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
 Overridden to request correct ghost-level to avoid internal surfaces. More...
virtual void UpdateColoringParameters ()
 Passes on parameters to vtkProperty and vtkMapper. More...
virtual vtkPVLODActor * GetRenderedProp ()
 Used in ConvertSelection to locate the prop used for actual rendering. More...
void HandleGeometryRepresentationProgress (vtkObject *caller, unsigned long, void *)
void PopulateBlockAttributes (vtkCompositeDataDisplayAttributes *attrs, vtkDataObject *outputData)
 Block attributes in a mapper are referenced to each block through DataObject pointers. More...
void ComputeVisibleDataBounds ()
 Computes the bounds of the visible data based on the block visibilities in the composite data attributes of the mapper. More...
void UpdateShaderReplacements ()
 Update the mapper with the shader replacement strings if feature is enabled. More...
virtual bool NeedsOrderedCompositing ()
 Returns true if this representation has translucent geometry. More...
virtual void SetPointArrayToProcess (int p, const char *val)
 Used by SetNormalArray, SetTCoordArray and SetTangentArray. More...
void UpdateGeneralTextureTransform ()
 This is called whenever the texture transformation matrix changes. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkAlgorithm * GeometryFilter
vtkAlgorithm * MultiBlockMaker
vtkGeometryRepresentation_detail::DecimationFilterType * Decimator
vtkPVGeometryFilter * LODOutlineFilter
vtkMapper * Mapper
vtkMapper * LODMapper
vtkPVLODActor * Actor
vtkProperty * Property
char * ActiveAssembly = nullptr
bool RepeatTextures
bool InterpolateTextures
bool UseMipmapTextures
vtkTransform * TextureTransform
double Ambient
double Specular
double Diffuse
int Representation
bool SuppressLOD
bool RequestGhostCellsIfNeeded
double VisibleDataBounds [6]
vtkTimeStamp VisibleDataBoundsTime
vtkPiecewiseFunction * PWF
bool UseDataPartitions
bool UseShaderReplacements
std::string ShaderReplacementsString
bool BlockAttrChanged = false
vtkTimeStamp BlockAttributeTime
bool UpdateBlockAttrLOD = false
int PlaceHolderDataType = VTK_PARTITIONED_DATA_SET_COLLECTION
std::vector< std::string > BlockSelectors
 Configurable through vtkGeometryRepresentation API. More...
std::vector< std::pair< std::string, vtkVector3d > > BlockColors
std::vector< std::pair< std::string, double > > BlockOpacities
std::vector< std::pair< std::string, bool > > BlockInterpolateScalarsBeforeMapping
std::vector< std::pair< std::string, int > > BlockColorModes
std::vector< std::pair< std::string, std::pair< int, std::string > > > BlockArrayNames
std::vector< vtkScalarsToColors * > BlockLookupTables
std::vector< std::pair< std::string, bool > > BlockScalarVisibilities
 Configured internally in vtkGeometryRepresentation. More...
std::vector< std::pair< std::string, bool > > BlockUseLookupTableScalarRanges
std::vector< std::pair< vtkDataObject *, vtkIdType > > BlockFieldDataTupleIds
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkGeometryRepresentation is a representation for showing polygon geometry. It handles non-polygonal datasets by extracting external surfaces. One can use this representation to show surface/wireframe/points/surface-with-edges.
The addition of a transformation matrix was supported by CEA/DIF Commissariat a l'Energie Atomique, Centre DAM Ile-De-France, Arpajon, France.
Definition at line 46 of file vtkGeometryRepresentation.h.
Definition at line 51 of file vtkGeometryRepresentation.h.
◆ RepresentationTypes
Enumerator
POINTS
WIREFRAME
SURFACE
SURFACE_WITH_EDGES
Definition at line 109 of file vtkGeometryRepresentation.h.
◆ vtkGeometryRepresentation()
vtkGeometryRepresentation::vtkGeometryRepresentation ( )
◆ ~vtkGeometryRepresentation()
vtkGeometryRepresentation::~vtkGeometryRepresentation ( )
static vtkGeometryRepresentation* vtkGeometryRepresentation::New ( )
virtual const char* vtkGeometryRepresentation::GetClassName ( )
static int vtkGeometryRepresentation::IsTypeOf ( const char *  type)
virtual int vtkGeometryRepresentation::IsA ( const char *  type)
static vtkGeometryRepresentation* vtkGeometryRepresentation::SafeDownCast ( vtkObject *  o)
void vtkGeometryRepresentation::PrintSelf ( ostream &  os,
◆ ProcessViewRequest()
int vtkGeometryRepresentation::ProcessViewRequest ( vtkInformationRequestKey *  request_type,
vtkInformation *  inInfo,
vtkInformation *  outInfo
Reimplemented in vtkGeometryRepresentationWithFaces, vtkGlyph3DRepresentation, vtkSurfaceLICRepresentation, and vtkGeometrySliceRepresentation.
◆ SetVisibility()
void vtkGeometryRepresentation::SetVisibility ( bool  val)
When the visibility of representation of false, all view passes are ignored.
Reimplemented in vtkGlyph3DRepresentation, and vtkGeometryRepresentationWithFaces.
◆ SetBlockColorsDistinctValues()
void vtkGeometryRepresentation::SetBlockColorsDistinctValues ( int  distinctValues)
◆ GetBlockColorsDistinctValues()
int vtkGeometryRepresentation::GetBlockColorsDistinctValues ( )
◆ SetSuppressLOD()
virtual void vtkGeometryRepresentation::SetSuppressLOD ( bool  suppress)
inlinevirtual
Reimplemented in vtkFeatureEdgesRepresentation, and vtkOutlineRepresentation.
Definition at line 81 of file vtkGeometryRepresentation.h.
◆ DisableLightingOn()
virtual void vtkGeometryRepresentation::DisableLightingOn ( )
It only displays the Diffuse component of the lighting color of the object.
◆ DisableLightingOff()
virtual void vtkGeometryRepresentation::DisableLightingOff ( )
◆ SetDisableLighting()
virtual void vtkGeometryRepresentation::SetDisableLighting ( bool  )
◆ GetDisableLighting()
virtual bool vtkGeometryRepresentation::GetDisableLighting ( )
◆ SetAmbient()
virtual void vtkGeometryRepresentation::SetAmbient ( double  )
vtkGeometryRepresentation overrides these based of the following conditions:
  • When Representation is wireframe or points, it disables diffuse or specular.
  • When scalar coloring is employed, it disabled specular.
◆ SetDiffuse()
virtual void vtkGeometryRepresentation::SetDiffuse ( double  )
◆ SetSpecular()
virtual void vtkGeometryRepresentation::SetSpecular ( double  )
◆ GetAmbient()
virtual double vtkGeometryRepresentation::GetAmbient ( )
◆ GetDiffuse()
virtual double vtkGeometryRepresentation::GetDiffuse ( )
◆ GetSpecular()
virtual double vtkGeometryRepresentation::GetSpecular ( )
◆ SetCoordinateShiftScaleMethod()
void vtkGeometryRepresentation::SetCoordinateShiftScaleMethod ( int  val)
◆ GetCoordinateShiftScaleMethod()
int vtkGeometryRepresentation::GetCoordinateShiftScaleMethod ( )
◆ SetRepresentation() [1/2]
virtual void vtkGeometryRepresentation::SetRepresentation ( int  )
This adds VTK_SURFACE_WITH_EDGES to those defined in vtkProperty.
◆ GetRepresentation()
virtual int vtkGeometryRepresentation::GetRepresentation ( )
◆ SetRepresentation() [2/2]
virtual void vtkGeometryRepresentation::SetRepresentation ( const char *  )
Accepted strings are: "Points", "Wireframe", "Surface" and "Surface With Edges".
◆ GetRenderedDataObject()
vtkDataObject* vtkGeometryRepresentation::GetRenderedDataObject ( int  port)
override
Returns the data object that is rendered from the given input port.
◆ SetRequestGhostCellsIfNeeded()
virtual void vtkGeometryRepresentation::SetRequestGhostCellsIfNeeded ( bool  )
◆ GetRequestGhostCellsIfNeeded()
virtual bool vtkGeometryRepresentation::GetRequestGhostCellsIfNeeded ( )
◆ RequestGhostCellsIfNeededOn()
virtual void vtkGeometryRepresentation::RequestGhostCellsIfNeededOn ( )
◆ RequestGhostCellsIfNeededOff()
virtual void vtkGeometryRepresentation::RequestGhostCellsIfNeededOff ( )
◆ SetNormalArray()
virtual void vtkGeometryRepresentation::SetNormalArray ( const char *  val)
It must be a three components array.
◆ SetTCoordArray()
virtual void vtkGeometryRepresentation::SetTCoordArray ( const char *  val)
It must be a two components array.
◆ SetTangentArray()
virtual void vtkGeometryRepresentation::SetTangentArray ( const char *  val)
◆ SetUseOutline()
virtual void vtkGeometryRepresentation::SetUseOutline ( int  )
◆ SetTriangulate()
void vtkGeometryRepresentation::SetTriangulate ( int  )
◆ SetNonlinearSubdivisionLevel()
void vtkGeometryRepresentation::SetNonlinearSubdivisionLevel ( int  )
◆ SetMatchBoundariesIgnoringCellOrder()
void vtkGeometryRepresentation::SetMatchBoundariesIgnoringCellOrder ( int  )
◆ SetGenerateFeatureEdges()
virtual void vtkGeometryRepresentation::SetGenerateFeatureEdges ( bool  )
Reimplemented in vtkFeatureEdgesRepresentation.
◆ SetComputePointNormals()
void vtkGeometryRepresentation::SetComputePointNormals ( bool  )
◆ SetSplitting()
void vtkGeometryRepresentation::SetSplitting ( bool  )
◆ SetFeatureAngle()
void vtkGeometryRepresentation::SetFeatureAngle ( double  )
◆ SetAmbientColor()
virtual void vtkGeometryRepresentation::SetAmbientColor ( double  r,
double  g,
double  b
◆ SetColor()
virtual void vtkGeometryRepresentation::SetColor ( double  r,
double  g,
double  b
◆ SetDiffuseColor()
virtual void vtkGeometryRepresentation::SetDiffuseColor ( double  r,
double  g,
double  b
◆ SetLighting()
virtual void vtkGeometryRepresentation::SetLighting ( bool  lighting)
◆ SetEdgeColor()
virtual void vtkGeometryRepresentation::SetEdgeColor ( double  r,
double  g,
double  b
◆ SetInteractiveSelectionColor()
virtual void vtkGeometryRepresentation::SetInteractiveSelectionColor ( double  r,
double  g,
double  b
◆ SetInterpolation()
virtual void vtkGeometryRepresentation::SetInterpolation ( int  val)
◆ SetLineWidth()
virtual void vtkGeometryRepresentation::SetLineWidth ( double  val)
◆ SetOpacity()
virtual void vtkGeometryRepresentation::SetOpacity ( double  val)
◆ SetEdgeOpacity()
virtual void vtkGeometryRepresentation::SetEdgeOpacity ( double  val)
◆ SetPointSize()
virtual void vtkGeometryRepresentation::SetPointSize ( double  val)
◆ SetSpecularColor()
virtual void vtkGeometryRepresentation::SetSpecularColor ( double  r,
double  g,
double  b
◆ SetSpecularPower()
virtual void vtkGeometryRepresentation::SetSpecularPower ( double  val)
◆ SetLuminosity()
virtual void vtkGeometryRepresentation::SetLuminosity ( double  val)
◆ SetRenderPointsAsSpheres()
virtual void vtkGeometryRepresentation::SetRenderPointsAsSpheres ( bool  )
◆ SetRenderLinesAsTubes()
virtual void vtkGeometryRepresentation::SetRenderLinesAsTubes ( bool  )
◆ SetRoughness()
virtual void vtkGeometryRepresentation::SetRoughness ( double  val)
◆ SetMetallic()
virtual void vtkGeometryRepresentation::SetMetallic ( double  val)
◆ SetEdgeTint()
virtual void vtkGeometryRepresentation::SetEdgeTint ( double  r,
double  g,
double  b
◆ SetAnisotropy()
virtual void vtkGeometryRepresentation::SetAnisotropy ( double  val)
◆ SetAnisotropyRotation()
virtual void vtkGeometryRepresentation::SetAnisotropyRotation ( double  val)
◆ SetBaseIOR()
virtual void vtkGeometryRepresentation::SetBaseIOR ( double  val)
◆ SetCoatIOR()
virtual void vtkGeometryRepresentation::SetCoatIOR ( double  val)
◆ SetCoatStrength()
virtual void vtkGeometryRepresentation::SetCoatStrength ( double  val)
◆ SetCoatRoughness()
virtual void vtkGeometryRepresentation::SetCoatRoughness ( double  val)
◆ SetCoatNormalScale()
virtual void vtkGeometryRepresentation::SetCoatNormalScale ( double  val)
◆ SetCoatColor()
virtual void vtkGeometryRepresentation::SetCoatColor ( double  r,
double  g,
double  b
◆ SetBaseColorTexture()
virtual void vtkGeometryRepresentation::SetBaseColorTexture ( vtkTexture *  tex)
◆ SetMaterialTexture()
virtual void vtkGeometryRepresentation::SetMaterialTexture ( vtkTexture *  tex)
◆ SetAnisotropyTexture()
virtual void vtkGeometryRepresentation::SetAnisotropyTexture ( vtkTexture *  tex)
◆ SetNormalTexture()
virtual void vtkGeometryRepresentation::SetNormalTexture ( vtkTexture *  tex)
◆ SetCoatNormalTexture()
virtual void vtkGeometryRepresentation::SetCoatNormalTexture ( vtkTexture *  tex)
◆ SetEmissiveTexture()
virtual void vtkGeometryRepresentation::SetEmissiveTexture ( vtkTexture *  tex)
◆ SetNormalScale()
virtual void vtkGeometryRepresentation::SetNormalScale ( double  val)
◆ SetOcclusionStrength()
virtual void vtkGeometryRepresentation::SetOcclusionStrength ( double  val)
◆ SetEmissiveFactor()
virtual void vtkGeometryRepresentation::SetEmissiveFactor ( double  rval,
double  gval,
double  bval
◆ SetShowTexturesOnBackface()
virtual void vtkGeometryRepresentation::SetShowTexturesOnBackface ( bool  )
◆ SetOrientation()
virtual void vtkGeometryRepresentation::SetOrientation ( double  ,
double  ,
double
Reimplemented in vtkGlyph3DRepresentation.
◆ SetOrigin()
virtual void vtkGeometryRepresentation::SetOrigin ( double  ,
double  ,
double
◆ SetPickable()
virtual void vtkGeometryRepresentation::SetPickable ( int  val)
◆ SetPosition()
virtual void vtkGeometryRepresentation::SetPosition ( double  ,
double  ,
double
◆ SetScale()
virtual void vtkGeometryRepresentation::SetScale ( double  ,
double  ,
double
◆ SetTexture()
virtual void vtkGeometryRepresentation::SetTexture ( vtkTexture *  )
◆ SetUserTransform()
virtual void vtkGeometryRepresentation::SetUserTransform ( const double  [16])
◆ SetFlipTextures()
virtual void vtkGeometryRepresentation::SetFlipTextures ( bool  )
◆ SetTextureTransform()
virtual void vtkGeometryRepresentation::SetTextureTransform ( vtkTransform *  )
◆ GetTextureTransform()
virtual vtkTransform* vtkGeometryRepresentation::GetTextureTransform ( )
◆ SetRepeatTextures()
virtual void vtkGeometryRepresentation::SetRepeatTextures ( bool  )
◆ GetRepeatTextures()
virtual bool vtkGeometryRepresentation::GetRepeatTextures ( )
◆ SetInterpolateTextures()
virtual void vtkGeometryRepresentation::SetInterpolateTextures ( bool  )
◆ GetInterpolateTextures()
virtual bool vtkGeometryRepresentation::GetInterpolateTextures ( )
◆ SetUseMipmapTextures()
virtual void vtkGeometryRepresentation::SetUseMipmapTextures ( bool  )
◆ GetUseMipmapTextures()
virtual bool vtkGeometryRepresentation::GetUseMipmapTextures ( )
◆ SetInterpolateScalarsBeforeMapping()
virtual void vtkGeometryRepresentation::SetInterpolateScalarsBeforeMapping ( int  val)
◆ SetLookupTable()
virtual void vtkGeometryRepresentation::SetLookupTable ( vtkScalarsToColors *  val)
◆ SetColorMissingArraysWithNanColor()
virtual void vtkGeometryRepresentation::SetColorMissingArraysWithNanColor ( bool  val)
◆ SetSeamlessU()
virtual void vtkGeometryRepresentation::SetSeamlessU ( bool  )
◆ SetSeamlessV()
virtual void vtkGeometryRepresentation::SetSeamlessV ( bool  )
◆ SetMapScalars()
virtual void vtkGeometryRepresentation::SetMapScalars ( int  val)
0 maps to VTK_COLOR_MODE_DIRECT_SCALARS 1 maps to VTK_COLOR_MODE_MAP_SCALARS
See also
vtkScalarsToColors::MapScalars
◆ SetStatic()
virtual void vtkGeometryRepresentation::SetStatic ( int  val)
See also
◆ SetSelection()
virtual void vtkGeometryRepresentation::SetSelection ( vtkSelection *  selection)
◆ GetActor()
vtkPVLODActor* vtkGeometryRepresentation::GetActor ( )
inline
Definition at line 276 of file vtkGeometryRepresentation.h.
◆ SetActiveAssembly()
virtual void vtkGeometryRepresentation::SetActiveAssembly ( const char *  )
The default is Hierarchy.
◆ GetActiveAssembly()
virtual char* vtkGeometryRepresentation::GetActiveAssembly ( )
◆ AddBlockSelector()
void vtkGeometryRepresentation::AddBlockSelector ( const char *  selector)
◆ RemoveAllBlockSelectors()
void vtkGeometryRepresentation::RemoveAllBlockSelectors ( )
◆ SetBlockColor()
void vtkGeometryRepresentation::SetBlockColor ( const char *  selector,
double  r,
double  g,
double  b
◆ RemoveAllBlockColors()
void vtkGeometryRepresentation::RemoveAllBlockColors ( )
◆ SetBlockOpacity()
void vtkGeometryRepresentation::SetBlockOpacity ( const char *  selector,
double  opacity
◆ RemoveAllBlockOpacities()
void vtkGeometryRepresentation::RemoveAllBlockOpacities ( )
◆ SetBlockInterpolateScalarsBeforeMapping()
void vtkGeometryRepresentation::SetBlockInterpolateScalarsBeforeMapping ( const char *  selector,
bool  interpolate
◆ RemoveAllBlockInterpolateScalarsBeforeMappings()
void vtkGeometryRepresentation::RemoveAllBlockInterpolateScalarsBeforeMappings ( )
◆ SetBlockMapScalars()
void vtkGeometryRepresentation::SetBlockMapScalars ( const char *  selector,
int  val
Note: Similar to SetMapScalars, but for blocks.
◆ RemoveAllBlockMapScalars()
void vtkGeometryRepresentation::RemoveAllBlockMapScalars ( )
◆ SetBlockArrayName()
void vtkGeometryRepresentation::SetBlockArrayName ( const char *  selector,
int  assoc,
const char *  arrayName
◆ RemoveAllBlockArrayNames()
void vtkGeometryRepresentation::RemoveAllBlockArrayNames ( )
◆ SetBlockLookupTable()
void vtkGeometryRepresentation::SetBlockLookupTable ( vtkScalarsToColors *  lut)
Note: we need two methods because we can't wrap a string and a vtkObject using either vtkSMStringVectorProperty or vtkSMProxyProperty.
◆ RemoveAllBlockLookupTables()
void vtkGeometryRepresentation::RemoveAllBlockLookupTables ( )
◆ GetColorArrayName()
const char* vtkGeometryRepresentation::GetColorArrayName ( )
◆ GetBounds()
static bool vtkGeometryRepresentation::GetBounds ( vtkDataObject *  dataObject,
double  bounds[6],
vtkCompositeDataDisplayAttributes *  cdAttributes
If a vtkCompositeDataDisplayAttributes cdAttributes is provided and if the input data dataObject is vtkCompositeDataSet, only visible blocks of the data will be used to compute the bounds. Returns true if valid bounds were computed.
◆ SetEnableScaling()
virtual void vtkGeometryRepresentation::SetEnableScaling ( int  v)
◆ SetScalingArrayName()
virtual void vtkGeometryRepresentation::SetScalingArrayName ( const char *  )
◆ SetScalingFunction()
virtual void vtkGeometryRepresentation::SetScalingFunction ( vtkPiecewiseFunction *  pwf)
◆ SetMaterial()
virtual void vtkGeometryRepresentation::SetMaterial ( const char *  )
◆ SetUseDataPartitions()
virtual void vtkGeometryRepresentation::SetUseDataPartitions ( bool  )
The default is false since that is the only way in general to guarantee correct rendering. Can set to true if all rendered data sets are based on the same data partitioning in order to save on the data redistribution.
◆ GetUseDataPartitions()
virtual bool vtkGeometryRepresentation::GetUseDataPartitions ( )
◆ SetUseShaderReplacements()
virtual void vtkGeometryRepresentation::SetUseShaderReplacements ( bool  )
◆ GetUseShaderReplacements()
virtual bool vtkGeometryRepresentation::GetUseShaderReplacements ( )
◆ SetShaderReplacements()
virtual void vtkGeometryRepresentation::SetShaderReplacements ( const char *  )
Please refer to the XML definition of the property for details about the expected Json string format.
◆ SetArrayIdNames()
void vtkGeometryRepresentation::SetArrayIdNames ( const char *  pointArray,
const char *  cellArray
override
Specify the array names used for the selection.
Use nullptr to use default ones. ("vtkOriginalPointIds" and "vtkOriginalCellIds")
◆ SetPlaceHolderDataType()
void vtkGeometryRepresentation::SetPlaceHolderDataType ( int  datatype)
This value is set by the proxy and is needed to ensure that the client knows the type of the input that lives on the server.
In the past, we were always creating a placeholder of type vtkMultiBlockDataSet when no input was available on the client. This is no longer valid because vtkPVGeometryFilter can now generate also vtkPartitionedDataSetCollection.
This can be potentially removed in the future once vtkMultiBlockDataSet is deprecated.
◆ GetPlaceHolderDataType()
virtual int vtkGeometryRepresentation::GetPlaceHolderDataType ( )
◆ SetupDefaults()
virtual void vtkGeometryRepresentation::SetupDefaults ( )
protectedvirtual
If the subclasses override any of the iVar vtkObject's of this class e.g. the Mappers, GeometryFilter etc., they should call this method again in their constructor. It must be totally safe to call this method repeatedly.
Reimplemented in vtkGlyph3DRepresentation, vtkCellGridRepresentation, vtkGeometryRepresentationWithFaces, and vtkGeometrySliceRepresentation.
◆ FillInputPortInformation()
int vtkGeometryRepresentation::FillInputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
Fill input port information.
◆ RequestData()
int vtkGeometryRepresentation::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
Since most representations are "meta-filters" (i.e. filters containing other filters), you should create shallow copies of your input before connecting to the internal pipeline. The convenience method GetInternalOutputPort will create a cached shallow copy of a specified input for you. The related helper functions GetInternalAnnotationOutputPort, GetInternalSelectionOutputPort should be used to obtain a selection or annotation port whose selections are localized for a particular input data object.
Reimplemented in vtkGlyph3DRepresentation, and vtkGeometrySliceRepresentation.
◆ RequestUpdateExtent()
int vtkGeometryRepresentation::RequestUpdateExtent ( vtkInformation *  request,
◆ AddToView()
bool vtkGeometryRepresentation::AddToView ( vtkView *  view)
◆ RemoveFromView()
bool vtkGeometryRepresentation::RemoveFromView ( vtkView *  view)
◆ UpdateColoringParameters()
virtual void vtkGeometryRepresentation::UpdateColoringParameters ( )
protectedvirtual
◆ GetRenderedProp()
virtual vtkPVLODActor* vtkGeometryRepresentation::GetRenderedProp ( )
inlineprotectedvirtual
Definition at line 486 of file vtkGeometryRepresentation.h.
◆ HandleGeometryRepresentationProgress()
void vtkGeometryRepresentation::HandleGeometryRepresentationProgress ( vtkObject *  caller,
unsigned  long,
void *
◆ PopulateBlockAttributes()
void vtkGeometryRepresentation::PopulateBlockAttributes ( vtkCompositeDataDisplayAttributes *  attrs,
vtkDataObject *  outputData
Since DataObjects may change after updating the pipeline, this class maintains an additional map using the flat-index as a key. This method updates the mapper's attributes with those cached in this representation; This is done after the data has updated (multi-block nodes change after an update).
◆ ComputeVisibleDataBounds()
void vtkGeometryRepresentation::ComputeVisibleDataBounds ( )
◆ UpdateShaderReplacements()
void vtkGeometryRepresentation::UpdateShaderReplacements ( )
◆ NeedsOrderedCompositing()
virtual bool vtkGeometryRepresentation::NeedsOrderedCompositing ( )
protectedvirtual
Unlike vtkActor::HasTranslucentPolygonalGeometry which cannot be called in Update, this method can be called in Update i.e. before the mapper has all the data to decide if it is doing translucent rendering.
Reimplemented in vtkCellGridRepresentation, and vtkGeometryRepresentationWithFaces.
◆ SetPointArrayToProcess()
virtual void vtkGeometryRepresentation::SetPointArrayToProcess ( int  p,
const char *  val
protectedvirtual
◆ UpdateGeneralTextureTransform()
void vtkGeometryRepresentation::UpdateGeneralTextureTransform ( )
◆ GeometryFilter
vtkAlgorithm* vtkGeometryRepresentation::GeometryFilter
Definition at line 529 of file vtkGeometryRepresentation.h.
◆ MultiBlockMaker
vtkAlgorithm* vtkGeometryRepresentation::MultiBlockMaker
Definition at line 530 of file vtkGeometryRepresentation.h.
◆ Decimator
vtkGeometryRepresentation_detail::DecimationFilterType* vtkGeometryRepresentation::Decimator
Definition at line 531 of file vtkGeometryRepresentation.h.
◆ LODOutlineFilter
vtkPVGeometryFilter* vtkGeometryRepresentation::LODOutlineFilter
Definition at line 532 of file vtkGeometryRepresentation.h.
◆ Mapper
vtkMapper* vtkGeometryRepresentation::Mapper
Definition at line 534 of file vtkGeometryRepresentation.h.
◆ LODMapper
vtkMapper* vtkGeometryRepresentation::LODMapper
Definition at line 535 of file vtkGeometryRepresentation.h.
◆ Actor
vtkPVLODActor* vtkGeometryRepresentation::Actor
Definition at line 536 of file vtkGeometryRepresentation.h.
◆ Property
vtkProperty* vtkGeometryRepresentation::Property
Definition at line 537 of file vtkGeometryRepresentation.h.
◆ ActiveAssembly
char* vtkGeometryRepresentation::ActiveAssembly = nullptr
Definition at line 539 of file vtkGeometryRepresentation.h.
◆ RepeatTextures
bool vtkGeometryRepresentation::RepeatTextures
Definition at line 540 of file vtkGeometryRepresentation.h.
◆ InterpolateTextures
bool vtkGeometryRepresentation::InterpolateTextures
Definition at line 541 of file vtkGeometryRepresentation.h.
◆ UseMipmapTextures
bool vtkGeometryRepresentation::UseMipmapTextures
Definition at line 542 of file vtkGeometryRepresentation.h.
◆ TextureTransform
vtkTransform* vtkGeometryRepresentation::TextureTransform
Definition at line 543 of file vtkGeometryRepresentation.h.
◆ Ambient
double vtkGeometryRepresentation::Ambient
Definition at line 544 of file vtkGeometryRepresentation.h.
◆ Specular
double vtkGeometryRepresentation::Specular
Definition at line 545 of file vtkGeometryRepresentation.h.
◆ Diffuse
double vtkGeometryRepresentation::Diffuse
Definition at line 546 of file vtkGeometryRepresentation.h.
◆ Representation
int vtkGeometryRepresentation::Representation
Definition at line 547 of file vtkGeometryRepresentation.h.
◆ SuppressLOD
bool vtkGeometryRepresentation::SuppressLOD
Definition at line 548 of file vtkGeometryRepresentation.h.
bool vtkGeometryRepresentation::RequestGhostCellsIfNeeded
Definition at line 549 of file vtkGeometryRepresentation.h.
◆ VisibleDataBounds
double vtkGeometryRepresentation::VisibleDataBounds[6]
Definition at line 550 of file vtkGeometryRepresentation.h.
◆ VisibleDataBoundsTime
vtkTimeStamp vtkGeometryRepresentation::VisibleDataBoundsTime
Definition at line 552 of file vtkGeometryRepresentation.h.
◆ PWF
vtkPiecewiseFunction* vtkGeometryRepresentation::PWF
Definition at line 554 of file vtkGeometryRepresentation.h.
◆ UseDataPartitions
bool vtkGeometryRepresentation::UseDataPartitions
Definition at line 556 of file vtkGeometryRepresentation.h.
◆ UseShaderReplacements
bool vtkGeometryRepresentation::UseShaderReplacements
Definition at line 558 of file vtkGeometryRepresentation.h.
◆ ShaderReplacementsString
std::string vtkGeometryRepresentation::ShaderReplacementsString
Definition at line 559 of file vtkGeometryRepresentation.h.
◆ BlockAttrChanged
bool vtkGeometryRepresentation::BlockAttrChanged = false
Definition at line 561 of file vtkGeometryRepresentation.h.
◆ BlockAttributeTime
vtkTimeStamp vtkGeometryRepresentation::BlockAttributeTime
Definition at line 562 of file vtkGeometryRepresentation.h.
◆ UpdateBlockAttrLOD
bool vtkGeometryRepresentation::UpdateBlockAttrLOD = false
Definition at line 563 of file vtkGeometryRepresentation.h.
◆ PlaceHolderDataType
int vtkGeometryRepresentation::PlaceHolderDataType = VTK_PARTITIONED_DATA_SET_COLLECTION
Definition at line 566 of file vtkGeometryRepresentation.h.
◆ BlockSelectors
std::vector<std::string> vtkGeometryRepresentation::BlockSelectors
Definition at line 575 of file vtkGeometryRepresentation.h.
◆ BlockColors
std::vector<std::pair<std::string, vtkVector3d> > vtkGeometryRepresentation::BlockColors
Definition at line 576 of file vtkGeometryRepresentation.h.
◆ BlockOpacities
std::vector<std::pair<std::string, double> > vtkGeometryRepresentation::BlockOpacities
Definition at line 577 of file vtkGeometryRepresentation.h.
◆ BlockInterpolateScalarsBeforeMapping
std::vector<std::pair<std::string, bool> > vtkGeometryRepresentation::BlockInterpolateScalarsBeforeMapping
Definition at line 578 of file vtkGeometryRepresentation.h.
◆ BlockColorModes
std::vector<std::pair<std::string, int> > vtkGeometryRepresentation::BlockColorModes
Definition at line 579 of file vtkGeometryRepresentation.h.
◆ BlockArrayNames
std::vector<std::pair<std::string, std::pair<int , std::string> > > vtkGeometryRepresentation::BlockArrayNames
Definition at line 580 of file vtkGeometryRepresentation.h.
◆ BlockLookupTables
std::vector<vtkScalarsToColors*> vtkGeometryRepresentation::BlockLookupTables
Definition at line 581 of file vtkGeometryRepresentation.h.
◆ BlockScalarVisibilities
std::vector<std::pair<std::string, bool> > vtkGeometryRepresentation::BlockScalarVisibilities
Definition at line 587 of file vtkGeometryRepresentation.h.
◆ BlockUseLookupTableScalarRanges
std::vector<std::pair<std::string, bool> > vtkGeometryRepresentation::BlockUseLookupTableScalarRanges
Definition at line 588 of file vtkGeometryRepresentation.h.
◆ BlockFieldDataTupleIds
std::vector<std::pair<vtkDataObject*, vtkIdType> > vtkGeometryRepresentation::BlockFieldDataTupleIds
Definition at line 589 of file vtkGeometryRepresentation.h.
