vtkPVParallelCoordinatesRepresentation Class Reference
vtkPVParallelCoordinatesRepresentation is the vtkChartParallelCoordinates subclass for parallel coordinates representation. More...
#include <vtkPVParallelCoordinatesRepresentation.h>
Inheritance diagram for vtkPVParallelCoordinatesRepresentation:
Collaboration diagram for vtkPVParallelCoordinatesRepresentation:
typedef vtkChartRepresentation Superclass
- Public Types inherited from vtkChartRepresentation
enum  DesiredOutputPrecision
void SetVisibility (bool visible) override
 Set visibility of the representation. More...
vtkChartParallelCoordinates * GetChart ()
 Provides access to the underlying VTK representation. More...
void SetSeriesVisibility (const char *series, bool visibility)
 Set series visibility given its name. More...
void ClearSeriesVisibilities ()
virtual void SetLineThickness (int)
 Sets the line thickness for the plot. More...
virtual void SetLineStyle (int)
 Set the line style for the plot. More...
virtual void SetColor (double, double, double)
 Sets the color to used for the lines in the plot. More...
virtual void SetColor (double [3])
virtual void SetOpacity (double)
 Sets the opacity for the lines in the plot. More...
bool Export (vtkAbstractChartExporter *exporter) override
 Called by vtkPVContextView::Export() to export the representation's data to a CSV file. More...
- Public Member Functions inherited from vtkChartRepresentation
void SetSelectionRepresentation (vtkChartSelectionRepresentation *)
 These must only be set during initialization before adding the representation to any views or calling Update(). More...
void MarkModified () override
 This needs to be called on all instances of vtkGeometryRepresentation when the input is modified. More...
void SetCompositeDataSetIndex (unsigned int)
void AddCompositeDataSetIndex (unsigned int)
void ResetCompositeDataSetIndices ()
unsigned int Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) override
 Override because of internal selection representations that need to be initialized as well. More...
virtual std::string GetDefaultSeriesLabel (const std::string &tableName, const std::string &columnName)
 Method to provide the default name given the name of a table and a column in that table. More...
virtual bool MapSelectionToInput (vtkSelection *sel)
 This method is called on the client-side by the vtkPVContextView whenever a new selection is made on all the visible representations in that view. More...
virtual bool MapSelectionToView (vtkSelection *sel)
 This is the inverse of MapSelectionToInput(). More...
void SetFieldAssociation (int)
 Set the field association for arrays to use. More...
virtual void SetFlattenTable (int)
 Flatten the table, i.e. More...
virtual int GetFlattenTable ()
virtual bool Export (vtkAbstractChartExporter *vtkNotUsed(exporter))
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVParallelCoordinatesRepresentation * New ()
static vtkPVParallelCoordinatesRepresentation * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkChartRepresentation
static vtkChartRepresentation * New ()
static vtkChartRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkPVParallelCoordinatesRepresentation ()
 ~vtkPVParallelCoordinatesRepresentation () override
void PrepareForRendering () override
 Overridden to pass information about changes to series visibility etc. More...
- Protected Member Functions inherited from vtkChartRepresentation
 vtkChartRepresentation ()
 ~vtkChartRepresentation () override
 Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
vtkTable * GetLocalOutput (bool pre_delivery=false)
 Convenience method to get the first vtkTable from LocalOutput, if any. More...
virtual vtkSmartPointer< vtkDataObject > TransformInputData (vtkDataObject *data)
 Method to be overridden to transform input data. More...
virtual vtkSmartPointer< vtkDataObject > ReduceDataToRoot (vtkDataObject *data)
 Chart representation/views expect that the data is reduced to root node and then passed on the rendering nodes. More...
virtual vtkSmartPointer< vtkDataObject > TransformTable (vtkSmartPointer< vtkDataObject > table)
 Method to be overridden to apply an operation of the table after it is gathered to the first rank for rendering the chart. More...
bool GetLocalOutput (MapOfTables &tables)
 Convenience method to get all vtkTable instances with their associated names. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
int LineThickness
int LineStyle
double Color [3]
double Opacity
- Protected Attributes inherited from vtkChartRepresentation
int FieldAssociation
vtkWeakPointer< vtkPVContextView > ContextView
int FlattenTable
vtkSmartPointer< vtkMultiBlockDataSet > LocalOutput
std::set< unsigned int > CompositeIndices
vtkWeakPointer< vtkChartSelectionRepresentation > SelectionRepresentation
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Protected Types inherited from vtkChartRepresentation
typedef std::map< std::string, std::pair< vtkSmartPointer< vtkTable >, unsigned int > > MapOfTables
It exposes API from underlying vtkChartParallelCoordinates.
Definition at line 20 of file vtkPVParallelCoordinatesRepresentation.h.
Definition at line 24 of file vtkPVParallelCoordinatesRepresentation.h.
◆ vtkPVParallelCoordinatesRepresentation()
vtkPVParallelCoordinatesRepresentation::vtkPVParallelCoordinatesRepresentation ( )
◆ ~vtkPVParallelCoordinatesRepresentation()
vtkPVParallelCoordinatesRepresentation::~vtkPVParallelCoordinatesRepresentation ( )
static vtkPVParallelCoordinatesRepresentation* vtkPVParallelCoordinatesRepresentation::New ( )
virtual const char* vtkPVParallelCoordinatesRepresentation::GetClassName ( )
Reimplemented from vtkChartRepresentation.
static int vtkPVParallelCoordinatesRepresentation::IsTypeOf ( const char *  type)
virtual int vtkPVParallelCoordinatesRepresentation::IsA ( const char *  type)
static vtkPVParallelCoordinatesRepresentation* vtkPVParallelCoordinatesRepresentation::SafeDownCast ( vtkObject *  o)
void vtkPVParallelCoordinatesRepresentation::PrintSelf ( ostream &  os,
◆ SetVisibility()
void vtkPVParallelCoordinatesRepresentation::SetVisibility ( bool  visible)
◆ SetSeriesVisibility()
void vtkPVParallelCoordinatesRepresentation::SetSeriesVisibility ( const char *  series,
bool  visibility
The order is currently ignored, but in future we can add support to respect that as in vtkPVPlotMatrixRepresentation.
◆ ClearSeriesVisibilities()
void vtkPVParallelCoordinatesRepresentation::ClearSeriesVisibilities ( )
◆ GetChart()
vtkChartParallelCoordinates* vtkPVParallelCoordinatesRepresentation::GetChart ( )
◆ SetLineThickness()
virtual void vtkPVParallelCoordinatesRepresentation::SetLineThickness ( int  )
◆ SetLineStyle()
virtual void vtkPVParallelCoordinatesRepresentation::SetLineStyle ( int  )
◆ SetColor() [1/2]
virtual void vtkPVParallelCoordinatesRepresentation::SetColor ( double  ,
double  ,
double
◆ SetColor() [2/2]
virtual void vtkPVParallelCoordinatesRepresentation::SetColor ( double  [3])
◆ SetOpacity()
virtual void vtkPVParallelCoordinatesRepresentation::SetOpacity ( double  )
◆ Export()
bool vtkPVParallelCoordinatesRepresentation::Export ( vtkAbstractChartExporter *  exporter)
override
Return false on failure which will call the exporting process to abort and raise an error. Default implementation simply returns false.
◆ PrepareForRendering()
void vtkPVParallelCoordinatesRepresentation::PrepareForRendering ( )
overrideprotectedvirtual
to the plot-matrix.
◆ AddToView()
bool vtkPVParallelCoordinatesRepresentation::AddToView ( vtkView *  view)
◆ RemoveFromView()
bool vtkPVParallelCoordinatesRepresentation::RemoveFromView ( vtkView *  view)
◆ LineThickness
int vtkPVParallelCoordinatesRepresentation::LineThickness
Definition at line 103 of file vtkPVParallelCoordinatesRepresentation.h.
◆ LineStyle
int vtkPVParallelCoordinatesRepresentation::LineStyle
Definition at line 104 of file vtkPVParallelCoordinatesRepresentation.h.
◆ Color
double vtkPVParallelCoordinatesRepresentation::Color[3]
Definition at line 105 of file vtkPVParallelCoordinatesRepresentation.h.
◆ Opacity
double vtkPVParallelCoordinatesRepresentation::Opacity
Definition at line 106 of file vtkPVParallelCoordinatesRepresentation.h.
