vtkQuartileChartRepresentation Class Reference
vtkQuartileChartRepresentation extends to vtkXYChartRepresentation to add support for combining quartile plots. More...
#include <vtkQuartileChartRepresentation.h>
Inheritance diagram for vtkQuartileChartRepresentation:
Collaboration diagram for vtkQuartileChartRepresentation:
typedef vtkXYChartRepresentation Superclass
- Public Types inherited from vtkXYChartRepresentation
typedef vtkChartRepresentation Superclass
- Public Types inherited from vtkChartRepresentation
enum  DesiredOutputPrecision
std::string GetDefaultSeriesLabel (const std::string &tableName, const std::string &columnName) override
 Overridden to format the series name to remove the operation applied e.g. More...
virtual void SetQuartileVisibility (bool)
 When set to true, q1/q3 region is rendered. More...
virtual bool GetQuartileVisibility ()
virtual void SetRangeVisibility (bool)
 When set to true, min/max region is rendered. More...
virtual bool GetRangeVisibility ()
virtual void SetAverageVisibility (bool)
 When set to true, the avg curve is rendered. More...
virtual bool GetAverageVisibility ()
virtual void SetMedianVisibility (bool)
 When set to true, the med curve is rendered. More...
virtual bool GetMedianVisibility ()
virtual void SetMinVisibility (bool)
 When set to true, the min curve is rendered. More...
virtual bool GetMinVisibility ()
virtual void SetMaxVisibility (bool)
 When set to true, the max curve is rendered. More...
virtual bool GetMaxVisibility ()
virtual void SetSumVisibility (bool)
virtual bool GetSumVisibility ()
- Public Member Functions inherited from vtkXYChartRepresentation
void SetVisibility (bool visible) override
 Set visibility of the representation. More...
void SetChartTypeToLine ()
void SetChartTypeToPoints ()
void SetChartTypeToBar ()
void SetChartTypeToStacked ()
void SetChartTypeToBag ()
void SetChartTypeToFunctionalBag ()
void SetChartTypeToArea ()
vtkChartXY * GetChart ()
 Returns the vtkChartXY instance from the view to which this representation is added. More...
void ClearSeriesVisibilities ()
void ClearLineThicknesses ()
void ClearLineStyles ()
void ClearColors ()
void ClearOpacities ()
void ClearAxisCorners ()
void ClearMarkerSizes ()
void ClearMarkerStyles ()
void ClearLabels ()
virtual void SetSelectionColor (double, double, double)
virtual void SetSelectionColor (double [3])
virtual double * GetSelectionColor ()
virtual void GetSelectionColor (double &, double &, double &)
virtual void GetSelectionColor (double [3])
virtual void SetChartType (int)
 Get/Set the chart type, defaults to line chart. More...
virtual int GetChartType ()
virtual void SetXAxisSeriesName (const char *)
 Set the series to use as the X-axis. More...
virtual char * GetXAxisSeriesName ()
virtual void SetUseIndexForXAxis (bool)
 Set whether the index should be used for the x axis. More...
virtual bool GetUseIndexForXAxis ()
void SetSortDataByXAxis (bool val)
 Get/set whether the points in the chart should be sorted by their x-axis value. More...
virtual bool GetSortDataByXAxis ()
void SetSeriesVisibility (const char *seriesname, bool visible)
 Set/Clear the properties for Y series/columns. More...
void SetLineThickness (const char *name, double value)
void SetLineStyle (const char *name, int value)
void SetColor (const char *name, double r, double g, double b)
void SetOpacity (const char *seriesname, double opacity)
void SetAxisCorner (const char *name, int corner)
void SetMarkerStyle (const char *name, int style)
void SetMarkerSize (const char *name, double value)
void SetLabel (const char *name, const char *label)
void SetUseColorMapping (const char *name, bool useColorMapping)
void SetLookupTable (const char *name, vtkScalarsToColors *lut)
const char * GetLabel (const char *name) const
virtual void SetSeriesLabelPrefix (const char *)
 Get/Set the series label prefix. More...
virtual char * GetSeriesLabelPrefix ()
bool Export (vtkAbstractChartExporter *exporter) override
 Called by vtkPVContextView::Export() to export the representation's data to a CSV file. More...
- Public Member Functions inherited from vtkChartRepresentation
void SetSelectionRepresentation (vtkChartSelectionRepresentation *)
 These must only be set during initialization before adding the representation to any views or calling Update(). More...
void MarkModified () override
 This needs to be called on all instances of vtkGeometryRepresentation when the input is modified. More...
void SetCompositeDataSetIndex (unsigned int)
void AddCompositeDataSetIndex (unsigned int)
void ResetCompositeDataSetIndices ()
unsigned int Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) override
 Override because of internal selection representations that need to be initialized as well. More...
virtual bool MapSelectionToInput (vtkSelection *sel)
 This method is called on the client-side by the vtkPVContextView whenever a new selection is made on all the visible representations in that view. More...
virtual bool MapSelectionToView (vtkSelection *sel)
 This is the inverse of MapSelectionToInput(). More...
void SetFieldAssociation (int)
 Set the field association for arrays to use. More...
virtual void SetFlattenTable (int)
 Flatten the table, i.e. More...
virtual int GetFlattenTable ()
virtual bool Export (vtkAbstractChartExporter *vtkNotUsed(exporter))
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkQuartileChartRepresentation * New ()
static vtkQuartileChartRepresentation * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkXYChartRepresentation
static vtkXYChartRepresentation * New ()
static vtkXYChartRepresentation * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkChartRepresentation
static vtkChartRepresentation * New ()
static vtkChartRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkQuartileChartRepresentation ()
 ~vtkQuartileChartRepresentation () override
void PrepareForRendering () override
 This method is called before actual render if this->MTime was modified since the last time this method was called. More...
- Protected Member Functions inherited from vtkXYChartRepresentation
 vtkXYChartRepresentation ()
 ~vtkXYChartRepresentation () override
 Overridden to remove all plots from the view. More...
 Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
vtkSmartPointer< vtkDataObject > TransformTable (vtkSmartPointer< vtkDataObject >) override
 Method to be overridden to apply an operation of the table after it is gathered to the first rank for rendering the chart. More...
- Protected Member Functions inherited from vtkChartRepresentation
 vtkChartRepresentation ()
 ~vtkChartRepresentation () override
vtkTable * GetLocalOutput (bool pre_delivery=false)
 Convenience method to get the first vtkTable from LocalOutput, if any. More...
virtual vtkSmartPointer< vtkDataObject > TransformInputData (vtkDataObject *data)
 Method to be overridden to transform input data. More...
virtual vtkSmartPointer< vtkDataObject > ReduceDataToRoot (vtkDataObject *data)
 Chart representation/views expect that the data is reduced to root node and then passed on the rendering nodes. More...
bool GetLocalOutput (MapOfTables &tables)
 Convenience method to get all vtkTable instances with their associated names. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
bool AverageVisibility
bool HasOnlyOnePoint
bool SumVisibility
bool MaxVisibility
bool MedianVisibility
bool MinVisibility
bool QuartileVisibility
bool RangeVisibility
- Protected Attributes inherited from vtkXYChartRepresentation
vtkInternals * Internals
- Protected Attributes inherited from vtkChartRepresentation
int FieldAssociation
vtkWeakPointer< vtkPVContextView > ContextView
int FlattenTable
vtkSmartPointer< vtkMultiBlockDataSet > LocalOutput
std::set< unsigned int > CompositeIndices
vtkWeakPointer< vtkChartSelectionRepresentation > SelectionRepresentation
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
Friends
class vtkQCRInternals
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Protected Types inherited from vtkChartRepresentation
typedef std::map< std::string, std::pair< vtkSmartPointer< vtkTable >, unsigned int > > MapOfTables
A quartile plot is created by treating multiple input arrays are ranges for area plots. All properties, like color, label etc. are specified collectively.
Definition at line 17 of file vtkQuartileChartRepresentation.h.
Definition at line 21 of file vtkQuartileChartRepresentation.h.
◆ vtkQuartileChartRepresentation()
vtkQuartileChartRepresentation::vtkQuartileChartRepresentation ( )
◆ ~vtkQuartileChartRepresentation()
vtkQuartileChartRepresentation::~vtkQuartileChartRepresentation ( )
static vtkQuartileChartRepresentation* vtkQuartileChartRepresentation::New ( )
virtual const char* vtkQuartileChartRepresentation::GetClassName ( )
Reimplemented from vtkXYChartRepresentation.
static int vtkQuartileChartRepresentation::IsTypeOf ( const char *  type)
virtual int vtkQuartileChartRepresentation::IsA ( const char *  type)
static vtkQuartileChartRepresentation* vtkQuartileChartRepresentation::SafeDownCast ( vtkObject *  o)
void vtkQuartileChartRepresentation::PrintSelf ( ostream &  os,
Reimplemented from vtkChartRepresentation.
◆ GetDefaultSeriesLabel()
std::string vtkQuartileChartRepresentation::GetDefaultSeriesLabel ( const std::string &  tableName,
const std::string &  columnName
a columnName of "min(EQPS)" and "max(EQPS)" both will return "EQPS".
◆ SetQuartileVisibility()
virtual void vtkQuartileChartRepresentation::SetQuartileVisibility ( bool  )
◆ GetQuartileVisibility()
virtual bool vtkQuartileChartRepresentation::GetQuartileVisibility ( )
◆ SetRangeVisibility()
virtual void vtkQuartileChartRepresentation::SetRangeVisibility ( bool  )
◆ GetRangeVisibility()
virtual bool vtkQuartileChartRepresentation::GetRangeVisibility ( )
◆ SetAverageVisibility()
virtual void vtkQuartileChartRepresentation::SetAverageVisibility ( bool  )
◆ GetAverageVisibility()
virtual bool vtkQuartileChartRepresentation::GetAverageVisibility ( )
◆ SetMedianVisibility()
virtual void vtkQuartileChartRepresentation::SetMedianVisibility ( bool  )
◆ GetMedianVisibility()
virtual bool vtkQuartileChartRepresentation::GetMedianVisibility ( )
◆ SetMinVisibility()
virtual void vtkQuartileChartRepresentation::SetMinVisibility ( bool  )
◆ GetMinVisibility()
virtual bool vtkQuartileChartRepresentation::GetMinVisibility ( )
◆ SetMaxVisibility()
virtual void vtkQuartileChartRepresentation::SetMaxVisibility ( bool  )
◆ GetMaxVisibility()
virtual bool vtkQuartileChartRepresentation::GetMaxVisibility ( )
◆ SetSumVisibility()
virtual void vtkQuartileChartRepresentation::SetSumVisibility ( bool  )
◆ GetSumVisibility()
virtual bool vtkQuartileChartRepresentation::GetSumVisibility ( )
◆ PrepareForRendering()
void vtkQuartileChartRepresentation::PrepareForRendering ( )
overrideprotectedvirtual
Subclasses should override to update "appearance" related changes that don't affect data. When this method is called, you're assured that this->ContextView is valid. Note that this method will not be called if this->GetVisibility() returns false, this subclasses should also override SetVisibility() to hide "actors" and such.
◆ vtkQCRInternals
friend class vtkQCRInternals
friend
Definition at line 106 of file vtkQuartileChartRepresentation.h.
◆ AverageVisibility
bool vtkQuartileChartRepresentation::AverageVisibility
Definition at line 91 of file vtkQuartileChartRepresentation.h.
◆ HasOnlyOnePoint
bool vtkQuartileChartRepresentation::HasOnlyOnePoint
Definition at line 92 of file vtkQuartileChartRepresentation.h.
◆ SumVisibility
bool vtkQuartileChartRepresentation::SumVisibility
Definition at line 93 of file vtkQuartileChartRepresentation.h.
◆ MaxVisibility
bool vtkQuartileChartRepresentation::MaxVisibility
Definition at line 94 of file vtkQuartileChartRepresentation.h.
◆ MedianVisibility
bool vtkQuartileChartRepresentation::MedianVisibility
Definition at line 95 of file vtkQuartileChartRepresentation.h.
◆ MinVisibility
bool vtkQuartileChartRepresentation::MinVisibility
Definition at line 96 of file vtkQuartileChartRepresentation.h.
◆ QuartileVisibility
bool vtkQuartileChartRepresentation::QuartileVisibility
Definition at line 97 of file vtkQuartileChartRepresentation.h.
◆ RangeVisibility
bool vtkQuartileChartRepresentation::RangeVisibility
Definition at line 98 of file vtkQuartileChartRepresentation.h.
