vtkImageVolumeRepresentation Class Reference
representation for showing image datasets as a volume. More...
#include <vtkImageVolumeRepresentation.h>
Inheritance diagram for vtkImageVolumeRepresentation:
Collaboration diagram for vtkImageVolumeRepresentation:
typedef vtkVolumeRepresentation Superclass
- Public Types inherited from vtkVolumeRepresentation
enum  DesiredOutputPrecision
void SetAmbient (double)
void SetDiffuse (double)
void SetSpecular (double)
void SetSpecularPower (double)
void SetShade (bool)
void SetAnisotropy (float)
void SetSliceFunction (vtkImplicitFunction *slice)
void SetRequestedRenderMode (int)
void SetBlendMode (int)
void SetCropping (int)
void SetGlobalIlluminationReach (float)
void SetVolumetricScatteringBlending (float)
void SetUseTransfer2D (bool)
void SetUseGradientForTransfer2D (bool)
void SelectColorArray2 (int, int, int, int, const char *name)
void SelectColorArray2Component (int component)
void SetTransferFunction2D (vtkPVTransferFunction2D *transfer2d)
void SetIsosurfaceValue (int i, double value)
 Methods to set isosurface values. More...
void SetNumberOfIsosurfaces (int number)
virtual void SetCroppingOrigin (double, double, double)
 Get/Set the cropping origin. More...
virtual void SetCroppingOrigin (double [3])
virtual double * GetCroppingOrigin ()
virtual void GetCroppingOrigin (double &, double &, double &)
virtual void GetCroppingOrigin (double [3])
virtual void SetCroppingScale (double, double, double)
 Get/Set the cropping scale. More...
virtual void SetCroppingScale (double [3])
virtual double * GetCroppingScale ()
virtual void GetCroppingScale (double &, double &, double &)
virtual void GetCroppingScale (double [3])
- Public Member Functions inherited from vtkVolumeRepresentation
void SetVisibility (bool val) override
void SetOrientation (double, double, double)
void SetOrigin (double, double, double)
void SetPickable (int val)
void SetPosition (double, double, double)
void SetScale (double, double, double)
void SetInterpolationType (int val)
void SetColor (vtkColorTransferFunction *lut)
void SetScalarOpacity (vtkPiecewiseFunction *pwf)
void SetScalarOpacityUnitDistance (double val)
void SetMapScalars (bool)
void SetMultiComponentsMapping (bool)
void SetUseSeparateOpacityArray (bool)
void SelectOpacityArray (int, int, int, int, const char *name)
void SelectOpacityArrayComponent (int component)
vtkPVLODVolume * GetActor ()
 Provides access to the actor used by this representation. More...
virtual void MarkModified ()
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkImageVolumeRepresentation * New ()
static vtkImageVolumeRepresentation * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkVolumeRepresentation
static vtkVolumeRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkImageVolumeRepresentation ()
 ~vtkImageVolumeRepresentation () override
virtual void UpdateMapperParameters ()
 Passes on parameters to the active volume mapper. More...
virtual vtkPVLODVolume * GetRenderedProp ()
 Used in ConvertSelection to locate the rendered prop. More...
- Protected Member Functions inherited from vtkVolumeRepresentation
 vtkVolumeRepresentation ()
 ~vtkVolumeRepresentation () override
bool AppendOpacityComponent (vtkDataSet *dataset)
 Appends a designated opacity component to a scalar array used for color/opacity mapping. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkSmartPointer< vtkDataObject > Cache
vtkSmartPointer< vtkVolumeMapper > VolumeMapper
vtkNew< vtkPolyDataMapper > OutlineMapper
int WholeExtent [6] = { 0, -1, 0, -1, 0, -1 }
double CroppingOrigin [3] = { 0, 0, 0 }
double CroppingScale [3] = { 1, 1, 1 }
bool UseTransfer2D = false
bool UseGradientForTransfer2D = true
vtkPVTransferFunction2D * TransferFunction2D = nullptr
int ColorArray2FieldAssociation = -1
int ColorArray2Component = -1
std::string ColorArray2Name
- Protected Attributes inherited from vtkVolumeRepresentation
vtkNew< vtkVolumeProperty > Property
vtkSmartPointer< vtkPVLODVolume > Actor
vtkNew< vtkOutlineSource > OutlineSource
unsigned long DataSize = 0
double DataBounds [6]
bool MapScalars = true
bool MultiComponentsMapping = false
bool UseSeparateOpacityArray = false
std::string OpacityArrayName
int OpacityArrayFieldAssociation = -1
int OpacityArrayComponent = -1
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkImageVolumeRepresentation is a representation for volume rendering vtkImageData. Unlike other data-representations used by ParaView, this representation does not support delivery to client (or render server) nodes. In those configurations, it merely delivers a outline for the image to the client and render-server and those nodes simply render the outline.
vtkImageVolumeRepresentation has a few caveats:
  1. It only supports vtkImageData and vtkPartitionedDataSet comprising of vtkImageData. In case of latter, any partition not a vtkImageData will be silently skipped.
  2. In distributed mode, bounds on each rank as assumed to be non-overlapping.
Definition at line 47 of file vtkImageVolumeRepresentation.h.
Definition at line 51 of file vtkImageVolumeRepresentation.h.
◆ vtkImageVolumeRepresentation()
vtkImageVolumeRepresentation::vtkImageVolumeRepresentation ( )
◆ ~vtkImageVolumeRepresentation()
vtkImageVolumeRepresentation::~vtkImageVolumeRepresentation ( )
static vtkImageVolumeRepresentation* vtkImageVolumeRepresentation::New ( )
virtual const char* vtkImageVolumeRepresentation::GetClassName ( )
Reimplemented from vtkVolumeRepresentation.
static int vtkImageVolumeRepresentation::IsTypeOf ( const char *  type)
virtual int vtkImageVolumeRepresentation::IsA ( const char *  type)
static vtkImageVolumeRepresentation* vtkImageVolumeRepresentation::SafeDownCast ( vtkObject *  o)
void vtkImageVolumeRepresentation::PrintSelf ( ostream &  os,
◆ ProcessViewRequest()
int vtkImageVolumeRepresentation::ProcessViewRequest ( vtkInformationRequestKey *  request_type,
vtkInformation *  inInfo,
vtkInformation *  outInfo
◆ SetAmbient()
void vtkImageVolumeRepresentation::SetAmbient ( double  )
◆ SetDiffuse()
void vtkImageVolumeRepresentation::SetDiffuse ( double  )
◆ SetSpecular()
void vtkImageVolumeRepresentation::SetSpecular ( double  )
◆ SetSpecularPower()
void vtkImageVolumeRepresentation::SetSpecularPower ( double  )
◆ SetShade()
void vtkImageVolumeRepresentation::SetShade ( bool  )
◆ SetAnisotropy()
void vtkImageVolumeRepresentation::SetAnisotropy ( float  )
◆ SetSliceFunction()
void vtkImageVolumeRepresentation::SetSliceFunction ( vtkImplicitFunction *  slice)
◆ SetIsosurfaceValue()
void vtkImageVolumeRepresentation::SetIsosurfaceValue ( int  i,
double  value
◆ SetNumberOfIsosurfaces()
void vtkImageVolumeRepresentation::SetNumberOfIsosurfaces ( int  number)
◆ SetRequestedRenderMode()
void vtkImageVolumeRepresentation::SetRequestedRenderMode ( int  )
◆ SetBlendMode()
void vtkImageVolumeRepresentation::SetBlendMode ( int  )
◆ SetCropping()
void vtkImageVolumeRepresentation::SetCropping ( int  )
◆ SetGlobalIlluminationReach()
void vtkImageVolumeRepresentation::SetGlobalIlluminationReach ( float  )
◆ SetVolumetricScatteringBlending()
void vtkImageVolumeRepresentation::SetVolumetricScatteringBlending ( float  )
◆ SetCroppingOrigin() [1/2]
virtual void vtkImageVolumeRepresentation::SetCroppingOrigin ( double  ,
double  ,
double
◆ SetCroppingOrigin() [2/2]
virtual void vtkImageVolumeRepresentation::SetCroppingOrigin ( double  [3])
◆ GetCroppingOrigin() [1/3]
virtual double* vtkImageVolumeRepresentation::GetCroppingOrigin ( )
◆ GetCroppingOrigin() [2/3]
virtual void vtkImageVolumeRepresentation::GetCroppingOrigin ( double &  ,
double &  ,
double &
◆ GetCroppingOrigin() [3/3]
virtual void vtkImageVolumeRepresentation::GetCroppingOrigin ( double  [3])
◆ SetCroppingScale() [1/2]
virtual void vtkImageVolumeRepresentation::SetCroppingScale ( double  ,
double  ,
double
◆ SetCroppingScale() [2/2]
virtual void vtkImageVolumeRepresentation::SetCroppingScale ( double  [3])
◆ GetCroppingScale() [1/3]
virtual double* vtkImageVolumeRepresentation::GetCroppingScale ( )
◆ GetCroppingScale() [2/3]
virtual void vtkImageVolumeRepresentation::GetCroppingScale ( double &  ,
double &  ,
double &
◆ GetCroppingScale() [3/3]
virtual void vtkImageVolumeRepresentation::GetCroppingScale ( double  [3])
◆ SetUseTransfer2D()
void vtkImageVolumeRepresentation::SetUseTransfer2D ( bool  )
◆ SetUseGradientForTransfer2D()
void vtkImageVolumeRepresentation::SetUseGradientForTransfer2D ( bool  )
◆ SelectColorArray2()
void vtkImageVolumeRepresentation::SelectColorArray2 ( int  ,
int  ,
int  ,
int  ,
const char *  name
◆ SelectColorArray2Component()
void vtkImageVolumeRepresentation::SelectColorArray2Component ( int  component)
◆ SetTransferFunction2D()
void vtkImageVolumeRepresentation::SetTransferFunction2D ( vtkPVTransferFunction2D *  transfer2d)
◆ FillInputPortInformation()
int vtkImageVolumeRepresentation::FillInputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
Fill input port information.
◆ RequestData()
int vtkImageVolumeRepresentation::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
◆ AddToView()
bool vtkImageVolumeRepresentation::AddToView ( vtkView *  view)
◆ RemoveFromView()
bool vtkImageVolumeRepresentation::RemoveFromView ( vtkView *  view)
◆ UpdateMapperParameters()
virtual void vtkImageVolumeRepresentation::UpdateMapperParameters ( )
protectedvirtual
◆ GetRenderedProp()
virtual vtkPVLODVolume* vtkImageVolumeRepresentation::GetRenderedProp ( )
inlineprotectedvirtual
Definition at line 146 of file vtkImageVolumeRepresentation.h.
◆ Cache
vtkSmartPointer<vtkDataObject> vtkImageVolumeRepresentation::Cache
◆ VolumeMapper
vtkSmartPointer<vtkVolumeMapper> vtkImageVolumeRepresentation::VolumeMapper
Definition at line 149 of file vtkImageVolumeRepresentation.h.
◆ OutlineMapper
vtkNew<vtkPolyDataMapper> vtkImageVolumeRepresentation::OutlineMapper
Definition at line 151 of file vtkImageVolumeRepresentation.h.
◆ WholeExtent
int vtkImageVolumeRepresentation::WholeExtent[6] = { 0, -1, 0, -1, 0, -1 }
Definition at line 153 of file vtkImageVolumeRepresentation.h.
◆ CroppingOrigin
double vtkImageVolumeRepresentation::CroppingOrigin[3] = { 0, 0, 0 }
Definition at line 154 of file vtkImageVolumeRepresentation.h.
◆ CroppingScale
double vtkImageVolumeRepresentation::CroppingScale[3] = { 1, 1, 1 }
Definition at line 155 of file vtkImageVolumeRepresentation.h.
◆ UseTransfer2D
bool vtkImageVolumeRepresentation::UseTransfer2D = false
Definition at line 158 of file vtkImageVolumeRepresentation.h.
◆ UseGradientForTransfer2D
bool vtkImageVolumeRepresentation::UseGradientForTransfer2D = true
Definition at line 159 of file vtkImageVolumeRepresentation.h.
◆ TransferFunction2D
vtkPVTransferFunction2D* vtkImageVolumeRepresentation::TransferFunction2D = nullptr
Definition at line 160 of file vtkImageVolumeRepresentation.h.
◆ ColorArray2FieldAssociation
int vtkImageVolumeRepresentation::ColorArray2FieldAssociation = -1
Definition at line 161 of file vtkImageVolumeRepresentation.h.
◆ ColorArray2Component
int vtkImageVolumeRepresentation::ColorArray2Component = -1
Definition at line 162 of file vtkImageVolumeRepresentation.h.
◆ ColorArray2Name
std::string vtkImageVolumeRepresentation::ColorArray2Name
Definition at line 163 of file vtkImageVolumeRepresentation.h.
