vtkPVHistogramChartRepresentation Class Reference
representation for "Histogram View". More...
#include <vtkPVHistogramChartRepresentation.h>
Inheritance diagram for vtkPVHistogramChartRepresentation:
Collaboration diagram for vtkPVHistogramChartRepresentation:
typedef vtkXYChartRepresentation Superclass
- Public Types inherited from vtkXYChartRepresentation
typedef vtkChartRepresentation Superclass
- Public Types inherited from vtkChartRepresentation
enum  DesiredOutputPrecision
void SetHistogramColor (double r, double g, double b)
 Sets the color for the histograms. More...
void SetUseColorMapping (bool colorMapping)
 Sets the histogram to be color mapped by the scalar. More...
void SetLookupTable (vtkScalarsToColors *lut)
 Sets the lookup table that is used for color mapping by the scalar. More...
void SetHistogramLineStyle (int style)
 Set the line style for the histogram. More...
vtkSmartPointer< vtkDataObject > TransformInputData (vtkDataObject *data) override
 Method to be overridden to transform input data to a vtkTable. More...
bool MapSelectionToInput (vtkSelection *) override
 Overridden to transform id-based selection produced by the histogram view to a threshold-based selection. More...
bool MapSelectionToView (vtkSelection *sel) override
 Inverse of MapSelectionToInput(). More...
void SetComponent (int)
 Controls which input data component should be binned, for input arrays with more-than-one component. More...
int GetComponent ()
void SetBinCount (int)
 Controls the number of bins N in the output histogram data. More...
int GetBinCount ()
void SetCenterBinsAroundMinAndMax (bool)
 Get/Set if first and last bins must be centered around the min and max data. More...
bool GetCenterBinsAroundMinAndMax ()
void SetCustomBinRanges (double min, double max)
 Get/Set custom bin ranges to use. More...
double * GetCustomBinRanges ()
void SetUseCustomBinRanges (bool)
 When set to true, CustomBinRanges will be used instead of using the full range for the selected array. More...
bool GetUseCustomBinRanges ()
void SetInputArrayToProcess (int idx, int port, int connection, int fieldAssociation, const char *name) override
 Overload the vtkAlgorithm method to update after the change. More...
- Public Member Functions inherited from vtkXYChartRepresentation
void SetVisibility (bool visible) override
 Set visibility of the representation. More...
void SetChartTypeToLine ()
void SetChartTypeToPoints ()
void SetChartTypeToBar ()
void SetChartTypeToStacked ()
void SetChartTypeToBag ()
void SetChartTypeToFunctionalBag ()
void SetChartTypeToArea ()
vtkChartXY * GetChart ()
 Returns the vtkChartXY instance from the view to which this representation is added. More...
void ClearSeriesVisibilities ()
void ClearLineThicknesses ()
void ClearLineStyles ()
void ClearColors ()
void ClearOpacities ()
void ClearAxisCorners ()
void ClearMarkerSizes ()
void ClearMarkerStyles ()
void ClearLabels ()
virtual void SetSelectionColor (double, double, double)
virtual void SetSelectionColor (double [3])
virtual double * GetSelectionColor ()
virtual void GetSelectionColor (double &, double &, double &)
virtual void GetSelectionColor (double [3])
virtual void SetChartType (int)
 Get/Set the chart type, defaults to line chart. More...
virtual int GetChartType ()
virtual void SetXAxisSeriesName (const char *)
 Set the series to use as the X-axis. More...
virtual char * GetXAxisSeriesName ()
virtual void SetUseIndexForXAxis (bool)
 Set whether the index should be used for the x axis. More...
virtual bool GetUseIndexForXAxis ()
void SetSortDataByXAxis (bool val)
 Get/set whether the points in the chart should be sorted by their x-axis value. More...
virtual bool GetSortDataByXAxis ()
void SetSeriesVisibility (const char *seriesname, bool visible)
 Set/Clear the properties for Y series/columns. More...
void SetLineThickness (const char *name, double value)
void SetLineStyle (const char *name, int value)
void SetColor (const char *name, double r, double g, double b)
void SetOpacity (const char *seriesname, double opacity)
void SetAxisCorner (const char *name, int corner)
void SetMarkerStyle (const char *name, int style)
void SetMarkerSize (const char *name, double value)
void SetLabel (const char *name, const char *label)
void SetUseColorMapping (const char *name, bool useColorMapping)
void SetLookupTable (const char *name, vtkScalarsToColors *lut)
const char * GetLabel (const char *name) const
virtual void SetSeriesLabelPrefix (const char *)
 Get/Set the series label prefix. More...
virtual char * GetSeriesLabelPrefix ()
bool Export (vtkAbstractChartExporter *exporter) override
 Called by vtkPVContextView::Export() to export the representation's data to a CSV file. More...
- Public Member Functions inherited from vtkChartRepresentation
void SetSelectionRepresentation (vtkChartSelectionRepresentation *)
 These must only be set during initialization before adding the representation to any views or calling Update(). More...
void MarkModified () override
 This needs to be called on all instances of vtkGeometryRepresentation when the input is modified. More...
void SetCompositeDataSetIndex (unsigned int)
void AddCompositeDataSetIndex (unsigned int)
void ResetCompositeDataSetIndices ()
unsigned int Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) override
 Override because of internal selection representations that need to be initialized as well. More...
virtual std::string GetDefaultSeriesLabel (const std::string &tableName, const std::string &columnName)
 Method to provide the default name given the name of a table and a column in that table. More...
void SetFieldAssociation (int)
 Set the field association for arrays to use. More...
virtual void SetFlattenTable (int)
 Flatten the table, i.e. More...
virtual int GetFlattenTable ()
virtual bool Export (vtkAbstractChartExporter *vtkNotUsed(exporter))
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVHistogramChartRepresentation * New ()
static vtkPVHistogramChartRepresentation * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkXYChartRepresentation
static vtkXYChartRepresentation * New ()
static vtkXYChartRepresentation * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkChartRepresentation
static vtkChartRepresentation * New ()
static vtkChartRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkPVHistogramChartRepresentation ()
 ~vtkPVHistogramChartRepresentation () override
void PrepareForRendering () override
 This method is called before actual render if this->MTime was modified since the last time this method was called. More...
- Protected Member Functions inherited from vtkXYChartRepresentation
 vtkXYChartRepresentation ()
 ~vtkXYChartRepresentation () override
 Overridden to remove all plots from the view. More...
 Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
vtkSmartPointer< vtkDataObject > TransformTable (vtkSmartPointer< vtkDataObject >) override
 Method to be overridden to apply an operation of the table after it is gathered to the first rank for rendering the chart. More...
- Protected Member Functions inherited from vtkChartRepresentation
 vtkChartRepresentation ()
 ~vtkChartRepresentation () override
vtkTable * GetLocalOutput (bool pre_delivery=false)
 Convenience method to get the first vtkTable from LocalOutput, if any. More...
virtual vtkSmartPointer< vtkDataObject > ReduceDataToRoot (vtkDataObject *data)
 Chart representation/views expect that the data is reduced to root node and then passed on the rendering nodes. More...
bool GetLocalOutput (MapOfTables &tables)
 Convenience method to get all vtkTable instances with their associated names. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkPExtractHistogram * ExtractHistogram
- Protected Attributes inherited from vtkXYChartRepresentation
vtkInternals * Internals
- Protected Attributes inherited from vtkChartRepresentation
int FieldAssociation
vtkWeakPointer< vtkPVContextView > ContextView
int FlattenTable
vtkSmartPointer< vtkMultiBlockDataSet > LocalOutput
std::set< unsigned int > CompositeIndices
vtkWeakPointer< vtkChartSelectionRepresentation > SelectionRepresentation
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Protected Types inherited from vtkChartRepresentation
typedef std::map< std::string, std::pair< vtkSmartPointer< vtkTable >, unsigned int > > MapOfTables
vtkPVHistogramChartRepresentation is the vtkPVDataRepresentation subclass for showing an data in the "Histogram View". The representation pipeline extracts histogram from the input dataset and then shows that in the view.
Definition at line 23 of file vtkPVHistogramChartRepresentation.h.
Definition at line 27 of file vtkPVHistogramChartRepresentation.h.
◆ vtkPVHistogramChartRepresentation()
vtkPVHistogramChartRepresentation::vtkPVHistogramChartRepresentation ( )
◆ ~vtkPVHistogramChartRepresentation()
vtkPVHistogramChartRepresentation::~vtkPVHistogramChartRepresentation ( )
static vtkPVHistogramChartRepresentation* vtkPVHistogramChartRepresentation::New ( )
virtual const char* vtkPVHistogramChartRepresentation::GetClassName ( )
Reimplemented from vtkXYChartRepresentation.
static int vtkPVHistogramChartRepresentation::IsTypeOf ( const char *  type)
virtual int vtkPVHistogramChartRepresentation::IsA ( const char *  type)
static vtkPVHistogramChartRepresentation* vtkPVHistogramChartRepresentation::SafeDownCast ( vtkObject *  o)
void vtkPVHistogramChartRepresentation::PrintSelf ( ostream &  os,
Reimplemented from vtkChartRepresentation.
◆ SetComponent()
void vtkPVHistogramChartRepresentation::SetComponent ( int  )
◆ GetComponent()
int vtkPVHistogramChartRepresentation::GetComponent ( )
◆ SetBinCount()
void vtkPVHistogramChartRepresentation::SetBinCount ( int  )
◆ GetBinCount()
int vtkPVHistogramChartRepresentation::GetBinCount ( )
◆ SetCenterBinsAroundMinAndMax()
void vtkPVHistogramChartRepresentation::SetCenterBinsAroundMinAndMax ( bool  )
This is only used when UseCustomBinRanges is set to false. Default is false.
◆ GetCenterBinsAroundMinAndMax()
bool vtkPVHistogramChartRepresentation::GetCenterBinsAroundMinAndMax ( )
◆ SetCustomBinRanges()
void vtkPVHistogramChartRepresentation::SetCustomBinRanges ( double  min,
double  max
These are used only when UseCustomBinRanges is set to true.
◆ GetCustomBinRanges()
double* vtkPVHistogramChartRepresentation::GetCustomBinRanges ( )
◆ SetUseCustomBinRanges()
void vtkPVHistogramChartRepresentation::SetUseCustomBinRanges ( bool  )
By default, set to false.
◆ GetUseCustomBinRanges()
bool vtkPVHistogramChartRepresentation::GetUseCustomBinRanges ( )
◆ SetHistogramColor()
void vtkPVHistogramChartRepresentation::SetHistogramColor ( double  r,
double  g,
double  b
◆ SetUseColorMapping()
void vtkPVHistogramChartRepresentation::SetUseColorMapping ( bool  colorMapping)
◆ SetLookupTable()
void vtkPVHistogramChartRepresentation::SetLookupTable ( vtkScalarsToColors *  lut)
◆ SetHistogramLineStyle()
void vtkPVHistogramChartRepresentation::SetHistogramLineStyle ( int  style)
◆ TransformInputData()
vtkSmartPointer<vtkDataObject> vtkPVHistogramChartRepresentation::TransformInputData ( vtkDataObject *  data)
◆ SetInputArrayToProcess()
void vtkPVHistogramChartRepresentation::SetInputArrayToProcess ( int  idx,
int  port,
int  connection,
const char *  name
◆ MapSelectionToInput()
bool vtkPVHistogramChartRepresentation::MapSelectionToInput ( vtkSelection *  )
◆ MapSelectionToView()
bool vtkPVHistogramChartRepresentation::MapSelectionToView ( vtkSelection *  sel)
◆ PrepareForRendering()
void vtkPVHistogramChartRepresentation::PrepareForRendering ( )
overrideprotectedvirtual
Subclasses should override to update "appearance" related changes that don't affect data. When this method is called, you're assured that this->ContextView is valid. Note that this method will not be called if this->GetVisibility() returns false, this subclasses should also override SetVisibility() to hide "actors" and such.
◆ ExtractHistogram
vtkPExtractHistogram* vtkPVHistogramChartRepresentation::ExtractHistogram
Definition at line 126 of file vtkPVHistogramChartRepresentation.h.
