vtkImageSliceRepresentation Class Reference
representation for showing slices from a vtkImageData. More...
#include <vtkImageSliceRepresentation.h>
Inheritance diagram for vtkImageSliceRepresentation:
Collaboration diagram for vtkImageSliceRepresentation:
enum  { XY_PLANE = VTK_XY_PLANE, YZ_PLANE = VTK_YZ_PLANE, XZ_PLANE = VTK_XZ_PLANE }
enum  DesiredOutputPrecision
void SetVisibility (bool val) override
void SetOrientation (double, double, double)
void SetOrigin (double, double, double)
void SetPickable (int val)
void SetPosition (double, double, double)
void SetScale (double, double, double)
void SetOpacity (double val)
void SetLookupTable (vtkScalarsToColors *val)
void SetMapScalars (int val)
void SetUseXYPlane (int val)
vtkPVLODActor * GetActor ()
 Provides access to the actor used by this representation. More...
void SetInputArrayToProcess (int idx, int port, int connection, int fieldAssociation, const char *name) override
 Set the input data arrays that this algorithm will process. More...
void SetInputArrayToProcess (int idx, int port, int connection, int fieldAssociation, int fieldAttributeType) override
void SetInputArrayToProcess (int idx, vtkInformation *info) override
void SetInputArrayToProcess (int idx, int port, int connection, const char *fieldAssociation, const char *attributeTypeorName) override
virtual void SetSlice (unsigned int)
 Get set the slice number to extract. More...
virtual unsigned int GetSlice ()
virtual void SetSliceMode (int)
 Get/Set the direction in which to slice a 3D input data. More...
virtual int GetSliceMode ()
virtual void MarkModified ()
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkImageSliceRepresentation * New ()
static vtkImageSliceRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkImageSliceRepresentation ()
 ~vtkImageSliceRepresentation () override
void UpdateSliceData (vtkInformationVector **)
 Extract the slice. More...
 Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
int SliceMode
unsigned int Slice
vtkPVImageSliceMapper * SliceMapper
vtkPVLODActor * Actor
vtkNew< vtkImageData > SliceData
double WholeBounds [6]
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkImageSliceRepresentation is a representation for showing slices from an image dataset. Currently, it does not support composite datasets, however, we should be able to add such a support in future.
Definition at line 26 of file vtkImageSliceRepresentation.h.
Definition at line 30 of file vtkImageSliceRepresentation.h.
◆ anonymous enum
anonymous enum
Enumerator
XY_PLANE
YZ_PLANE
XZ_PLANE
Definition at line 82 of file vtkImageSliceRepresentation.h.
◆ vtkImageSliceRepresentation()
vtkImageSliceRepresentation::vtkImageSliceRepresentation ( )
◆ ~vtkImageSliceRepresentation()
vtkImageSliceRepresentation::~vtkImageSliceRepresentation ( )
static vtkImageSliceRepresentation* vtkImageSliceRepresentation::New ( )
virtual const char* vtkImageSliceRepresentation::GetClassName ( )
static int vtkImageSliceRepresentation::IsTypeOf ( const char *  type)
virtual int vtkImageSliceRepresentation::IsA ( const char *  type)
static vtkImageSliceRepresentation* vtkImageSliceRepresentation::SafeDownCast ( vtkObject *  o)
void vtkImageSliceRepresentation::PrintSelf ( ostream &  os,
◆ SetInputArrayToProcess() [1/4]
void vtkImageSliceRepresentation::SetInputArrayToProcess ( int  idx,
int  port,
int  connection,
const char *  name
Overridden to pass the array selection to the mapper.
◆ SetInputArrayToProcess() [2/4]
int  port,
int  connection,
inlineoverridevirtual
Definition at line 40 of file vtkImageSliceRepresentation.h.
◆ SetInputArrayToProcess() [3/4]
vtkInformation *  info
Definition at line 46 of file vtkImageSliceRepresentation.h.
◆ SetInputArrayToProcess() [4/4]
int  port,
int  connection,
const char *  fieldAssociation,
const char *  attributeTypeorName
Definition at line 50 of file vtkImageSliceRepresentation.h.
◆ ProcessViewRequest()
int vtkImageSliceRepresentation::ProcessViewRequest ( vtkInformationRequestKey *  request_type,
vtkInformation *  inInfo,
vtkInformation *  outInfo
◆ SetVisibility()
void vtkImageSliceRepresentation::SetVisibility ( bool  val)
When the visibility of representation of false, all view passes are ignored. Overridden to propagate to the active representation.
◆ SetSlice()
virtual void vtkImageSliceRepresentation::SetSlice ( unsigned  int)
◆ GetSlice()
virtual unsigned int vtkImageSliceRepresentation::GetSlice ( )
◆ SetSliceMode()
virtual void vtkImageSliceRepresentation::SetSliceMode ( int  )
◆ GetSliceMode()
virtual int vtkImageSliceRepresentation::GetSliceMode ( )
◆ SetOrientation()
void vtkImageSliceRepresentation::SetOrientation ( double  ,
double  ,
double
◆ SetOrigin()
void vtkImageSliceRepresentation::SetOrigin ( double  ,
double  ,
double
◆ SetPickable()
void vtkImageSliceRepresentation::SetPickable ( int  val)
◆ SetPosition()
void vtkImageSliceRepresentation::SetPosition ( double  ,
double  ,
double
◆ SetScale()
void vtkImageSliceRepresentation::SetScale ( double  ,
double  ,
double
◆ SetOpacity()
void vtkImageSliceRepresentation::SetOpacity ( double  val)
◆ SetLookupTable()
void vtkImageSliceRepresentation::SetLookupTable ( vtkScalarsToColors *  val)
◆ SetMapScalars()
void vtkImageSliceRepresentation::SetMapScalars ( int  val)
◆ SetUseXYPlane()
void vtkImageSliceRepresentation::SetUseXYPlane ( int  val)
◆ GetActor()
vtkPVLODActor* vtkImageSliceRepresentation::GetActor ( )
inline
Definition at line 118 of file vtkImageSliceRepresentation.h.
◆ UpdateSliceData()
void vtkImageSliceRepresentation::UpdateSliceData ( vtkInformationVector **  )
Extract the slice.
◆ FillInputPortInformation()
int vtkImageSliceRepresentation::FillInputPortInformation ( int  port,
overrideprotectedvirtual
Fill input port information.
◆ RequestData()
int vtkImageSliceRepresentation::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
Since most representations are "meta-filters" (i.e. filters containing other filters), you should create shallow copies of your input before connecting to the internal pipeline. The convenience method GetInternalOutputPort will create a cached shallow copy of a specified input for you. The related helper functions GetInternalAnnotationOutputPort, GetInternalSelectionOutputPort should be used to obtain a selection or annotation port whose selections are localized for a particular input data object.
◆ AddToView()
bool vtkImageSliceRepresentation::AddToView ( vtkView *  view)
◆ RemoveFromView()
bool vtkImageSliceRepresentation::RemoveFromView ( vtkView *  view)
◆ SliceMode
int vtkImageSliceRepresentation::SliceMode
Definition at line 160 of file vtkImageSliceRepresentation.h.
◆ Slice
unsigned int vtkImageSliceRepresentation::Slice
Definition at line 161 of file vtkImageSliceRepresentation.h.
◆ SliceMapper
vtkPVImageSliceMapper* vtkImageSliceRepresentation::SliceMapper
Definition at line 163 of file vtkImageSliceRepresentation.h.
◆ Actor
vtkPVLODActor* vtkImageSliceRepresentation::Actor
Definition at line 164 of file vtkImageSliceRepresentation.h.
◆ SliceData
vtkNew<vtkImageData> vtkImageSliceRepresentation::SliceData
Definition at line 165 of file vtkImageSliceRepresentation.h.
◆ WholeBounds
double vtkImageSliceRepresentation::WholeBounds[6]
Definition at line 169 of file vtkImageSliceRepresentation.h.
