vtkOutlineRepresentation Class Reference
representation for outline. More...
#include <vtkOutlineRepresentation.h>
Inheritance diagram for vtkOutlineRepresentation:
Collaboration diagram for vtkOutlineRepresentation:
typedef vtkGeometryRepresentationWithFaces Superclass
- Public Types inherited from vtkGeometryRepresentationWithFaces
enum  RepresentationTypesEx { FOLLOW_FRONTFACE = 400, CULL_BACKFACE = 401, CULL_FRONTFACE = 402 }
typedef vtkGeometryRepresentation Superclass
enum  RepresentationTypes { POINTS = VTK_POINTS, WIREFRAME = VTK_WIREFRAME, SURFACE = VTK_SURFACE, SURFACE_WITH_EDGES = 3 }
enum  DesiredOutputPrecision
void SetRepresentation (const char *) override
 Overload to set representation type using string. More...
void SetUseOutline (int) override
void SetSuppressLOD (bool) override
 Enable/Disable LOD;. More...
void SetPickable (int) override
- Public Member Functions inherited from vtkGeometryRepresentationWithFaces
void SetVisibility (bool val) override
void SetBackfaceAmbientColor (double r, double g, double b)
void SetBackfaceDiffuseColor (double r, double g, double b)
void SetBackfaceOpacity (double val)
virtual void SetBackfaceRepresentation (int)
 Set the backface representation. More...
virtual int GetBackfaceRepresentation ()
vtkDataObject * GetRenderedDataObject (int port) override
virtual void SetNormalArray (const char *val)
 Set the normal array used for smooth shading. More...
virtual void SetTCoordArray (const char *val)
 Set the texture coordinates array used for texture mapping. More...
virtual void SetTangentArray (const char *val)
 Set the tangent coordinates array used for normal mapping. More...
void SetTriangulate (int)
void SetNonlinearSubdivisionLevel (int)
void SetMatchBoundariesIgnoringCellOrder (int)
virtual void SetGenerateFeatureEdges (bool)
void SetComputePointNormals (bool)
void SetSplitting (bool)
void SetFeatureAngle (double)
virtual void SetAmbientColor (double r, double g, double b)
virtual void SetColor (double r, double g, double b)
virtual void SetDiffuseColor (double r, double g, double b)
virtual void SetLighting (bool lighting)
virtual void SetEdgeColor (double r, double g, double b)
virtual void SetInteractiveSelectionColor (double r, double g, double b)
virtual void SetInterpolation (int val)
virtual void SetLineWidth (double val)
virtual void SetOpacity (double val)
virtual void SetEdgeOpacity (double val)
virtual void SetPointSize (double val)
virtual void SetSpecularColor (double r, double g, double b)
virtual void SetSpecularPower (double val)
virtual void SetLuminosity (double val)
virtual void SetRenderPointsAsSpheres (bool)
virtual void SetRenderLinesAsTubes (bool)
virtual void SetRoughness (double val)
virtual void SetMetallic (double val)
virtual void SetEdgeTint (double r, double g, double b)
virtual void SetAnisotropy (double val)
virtual void SetAnisotropyRotation (double val)
virtual void SetBaseIOR (double val)
virtual void SetCoatIOR (double val)
virtual void SetCoatStrength (double val)
virtual void SetCoatRoughness (double val)
virtual void SetCoatNormalScale (double val)
virtual void SetCoatColor (double r, double g, double b)
virtual void SetBaseColorTexture (vtkTexture *tex)
virtual void SetMaterialTexture (vtkTexture *tex)
virtual void SetAnisotropyTexture (vtkTexture *tex)
virtual void SetNormalTexture (vtkTexture *tex)
virtual void SetCoatNormalTexture (vtkTexture *tex)
virtual void SetEmissiveTexture (vtkTexture *tex)
virtual void SetNormalScale (double val)
virtual void SetOcclusionStrength (double val)
virtual void SetEmissiveFactor (double rval, double gval, double bval)
virtual void SetShowTexturesOnBackface (bool)
virtual void SetOrientation (double, double, double)
virtual void SetOrigin (double, double, double)
virtual void SetPosition (double, double, double)
virtual void SetScale (double, double, double)
virtual void SetTexture (vtkTexture *)
virtual void SetUserTransform (const double[16])
virtual void SetFlipTextures (bool)
virtual void SetTextureTransform (vtkTransform *)
virtual vtkTransform * GetTextureTransform ()
virtual void SetRepeatTextures (bool)
virtual bool GetRepeatTextures ()
virtual void SetInterpolateTextures (bool)
virtual bool GetInterpolateTextures ()
virtual void SetUseMipmapTextures (bool)
virtual bool GetUseMipmapTextures ()
virtual void SetInterpolateScalarsBeforeMapping (int val)
virtual void SetLookupTable (vtkScalarsToColors *val)
virtual void SetColorMissingArraysWithNanColor (bool val)
virtual void SetSeamlessU (bool)
virtual void SetSeamlessV (bool)
virtual void SetSelection (vtkSelection *selection)
 Sets the selection used by the mapper. More...
vtkPVLODActor * GetActor ()
 Provides access to the actor used by this representation. More...
const char * GetColorArrayName ()
 Convenience method to get the array name used to scalar color with. More...
virtual void SetMaterial (const char *)
 For OSPRay, choose from among available materials. More...
virtual void SetShaderReplacements (const char *)
 Specify shader replacements using a Json string. More...
void SetArrayIdNames (const char *pointArray, const char *cellArray) override
void SetBlockColorsDistinctValues (int distinctValues)
 Determines the number of distinct values in vtkBlockColors See also vtkPVGeometryFilter. More...
int GetBlockColorsDistinctValues ()
virtual void DisableLightingOn ()
 Disables the lighting on the object. More...
virtual void DisableLightingOff ()
virtual void SetDisableLighting (bool)
virtual bool GetDisableLighting ()
virtual void SetAmbient (double)
 Set the lighting properties of the object. More...
virtual void SetDiffuse (double)
virtual void SetSpecular (double)
virtual double GetAmbient ()
virtual double GetDiffuse ()
virtual double GetSpecular ()
void SetCoordinateShiftScaleMethod (int val)
 Set the shift scale method for the point coordinates see vtkOpenGLVertexBufferObject.h for more information. More...
int GetCoordinateShiftScaleMethod ()
virtual int GetRepresentation ()
 Set the representation type. More...
virtual void SetRequestGhostCellsIfNeeded (bool)
 Representations that use geometry representation as the internal representation should turn this flag off so that we don't end up requesting ghost cells twice. More...
virtual bool GetRequestGhostCellsIfNeeded ()
virtual void RequestGhostCellsIfNeededOn ()
virtual void RequestGhostCellsIfNeededOff ()
virtual void SetMapScalars (int val)
 Sets if scalars are mapped through a color-map or are used directly as colors. More...
virtual void SetStatic (int val)
virtual void SetActiveAssembly (const char *)
 Get/Set the name of the assembly to use for mapping block visibilities, colors and opacities. More...
virtual char * GetActiveAssembly ()
void AddBlockSelector (const char *selector)
 Update list of selectors that determine the selected blocks. More...
void RemoveAllBlockSelectors ()
void SetBlockColor (const char *selector, double r, double g, double b)
 Set the color for a single block. More...
void RemoveAllBlockColors ()
void SetBlockOpacity (const char *selector, double opacity)
 Set the opacity for a single block. More...
void RemoveAllBlockOpacities ()
void SetBlockInterpolateScalarsBeforeMapping (const char *selector, bool interpolate)
 Set if to interpolate scalars before mapping for a single block. More...
void RemoveAllBlockInterpolateScalarsBeforeMappings ()
void SetBlockMapScalars (const char *selector, int val)
 Set the block to map scalars for a single block. More...
void RemoveAllBlockMapScalars ()
void SetBlockArrayName (const char *selector, int assoc, const char *arrayName)
 Set the color array for a single block. More...
void RemoveAllBlockArrayNames ()
void SetBlockLookupTable (vtkScalarsToColors *lut)
 Set the look up table for a single block. More...
void RemoveAllBlockLookupTables ()
virtual void SetEnableScaling (int v)
 For OSPRay controls sizing of implicit spheres (points) and cylinders (lines) More...
virtual void SetScalingArrayName (const char *)
virtual void SetScalingFunction (vtkPiecewiseFunction *pwf)
virtual void SetUseDataPartitions (bool)
 Specify whether or not to redistribute the data. More...
virtual bool GetUseDataPartitions ()
virtual void SetUseShaderReplacements (bool)
 Specify whether or not to shader replacements string must be used. More...
virtual bool GetUseShaderReplacements ()
void SetPlaceHolderDataType (int datatype)
 Set/Get the placeholder data type. More...
virtual int GetPlaceHolderDataType ()
virtual void MarkModified ()
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkOutlineRepresentation * New ()
static vtkOutlineRepresentation * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkGeometryRepresentationWithFaces
static vtkGeometryRepresentationWithFaces * New ()
static vtkGeometryRepresentationWithFaces * SafeDownCast (vtkObject *o)
static vtkGeometryRepresentation * New ()
static vtkGeometryRepresentation * SafeDownCast (vtkObject *o)
static bool GetBounds (vtkDataObject *dataObject, double bounds[6], vtkCompositeDataDisplayAttributes *cdAttributes)
 Convenience method to get bounds from a dataset/composite dataset. More...
static vtkAlgorithm * New ()
 vtkOutlineRepresentation ()
 ~vtkOutlineRepresentation () override
void SetRepresentation (int) override
- Protected Member Functions inherited from vtkGeometryRepresentationWithFaces
 vtkGeometryRepresentationWithFaces ()
 ~vtkGeometryRepresentationWithFaces () override
void SetupDefaults () override
 This method is called in the constructor. More...
void UpdateColoringParameters () override
 Passes on parameters to vtkProperty and vtkMapper. More...
bool NeedsOrderedCompositing () override
 Returns true if this representation has translucent geometry. More...
 vtkGeometryRepresentation ()
 ~vtkGeometryRepresentation () override
 Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
 Overridden to request correct ghost-level to avoid internal surfaces. More...
virtual vtkPVLODActor * GetRenderedProp ()
 Used in ConvertSelection to locate the prop used for actual rendering. More...
void HandleGeometryRepresentationProgress (vtkObject *caller, unsigned long, void *)
void PopulateBlockAttributes (vtkCompositeDataDisplayAttributes *attrs, vtkDataObject *outputData)
 Block attributes in a mapper are referenced to each block through DataObject pointers. More...
void ComputeVisibleDataBounds ()
 Computes the bounds of the visible data based on the block visibilities in the composite data attributes of the mapper. More...
void UpdateShaderReplacements ()
 Update the mapper with the shader replacement strings if feature is enabled. More...
virtual void SetPointArrayToProcess (int p, const char *val)
 Used by SetNormalArray, SetTCoordArray and SetTangentArray. More...
void UpdateGeneralTextureTransform ()
 This is called whenever the texture transformation matrix changes. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Protected Attributes inherited from vtkGeometryRepresentationWithFaces
vtkMapper * BackfaceMapper
vtkMapper * LODBackfaceMapper
vtkPVLODActor * BackfaceActor
vtkProperty * BackfaceProperty
int BackfaceRepresentation
vtkAlgorithm * GeometryFilter
vtkAlgorithm * MultiBlockMaker
vtkGeometryRepresentation_detail::DecimationFilterType * Decimator
vtkPVGeometryFilter * LODOutlineFilter
vtkMapper * Mapper
vtkMapper * LODMapper
vtkPVLODActor * Actor
vtkProperty * Property
char * ActiveAssembly = nullptr
bool RepeatTextures
bool InterpolateTextures
bool UseMipmapTextures
vtkTransform * TextureTransform
double Ambient
double Specular
double Diffuse
int Representation
bool SuppressLOD
bool RequestGhostCellsIfNeeded
double VisibleDataBounds [6]
vtkTimeStamp VisibleDataBoundsTime
vtkPiecewiseFunction * PWF
bool UseDataPartitions
bool UseShaderReplacements
std::string ShaderReplacementsString
bool BlockAttrChanged = false
vtkTimeStamp BlockAttributeTime
bool UpdateBlockAttrLOD = false
int PlaceHolderDataType = VTK_PARTITIONED_DATA_SET_COLLECTION
std::vector< std::string > BlockSelectors
 Configurable through vtkGeometryRepresentation API. More...
std::vector< std::pair< std::string, vtkVector3d > > BlockColors
std::vector< std::pair< std::string, double > > BlockOpacities
std::vector< std::pair< std::string, bool > > BlockInterpolateScalarsBeforeMapping
std::vector< std::pair< std::string, int > > BlockColorModes
std::vector< std::pair< std::string, std::pair< int, std::string > > > BlockArrayNames
std::vector< vtkScalarsToColors * > BlockLookupTables
std::vector< std::pair< std::string, bool > > BlockScalarVisibilities
 Configured internally in vtkGeometryRepresentation. More...
std::vector< std::pair< std::string, bool > > BlockUseLookupTableScalarRanges
std::vector< std::pair< vtkDataObject *, vtkIdType > > BlockFieldDataTupleIds
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
vtkOutlineRepresentation is merely a vtkGeometryRepresentationWithFaces that forces the geometry filter to produce outlines.
Definition at line 17 of file vtkOutlineRepresentation.h.
Definition at line 21 of file vtkOutlineRepresentation.h.
◆ vtkOutlineRepresentation()
vtkOutlineRepresentation::vtkOutlineRepresentation ( )
◆ ~vtkOutlineRepresentation()
vtkOutlineRepresentation::~vtkOutlineRepresentation ( )
static vtkOutlineRepresentation* vtkOutlineRepresentation::New ( )
virtual const char* vtkOutlineRepresentation::GetClassName ( )
static int vtkOutlineRepresentation::IsTypeOf ( const char *  type)
virtual int vtkOutlineRepresentation::IsA ( const char *  type)
static vtkOutlineRepresentation* vtkOutlineRepresentation::SafeDownCast ( vtkObject *  o)
void vtkOutlineRepresentation::PrintSelf ( ostream &  os,
◆ SetRepresentation() [1/2]
void vtkOutlineRepresentation::SetRepresentation ( const char *  )
inlineoverridevirtual
Accepted strings are: "Points", "Wireframe", "Surface" and "Surface With Edges".
Reimplemented from vtkGeometryRepresentation.
Definition at line 24 of file vtkOutlineRepresentation.h.
◆ SetUseOutline()
void vtkOutlineRepresentation::SetUseOutline ( int  )
Definition at line 25 of file vtkOutlineRepresentation.h.
◆ SetSuppressLOD()
void vtkOutlineRepresentation::SetSuppressLOD ( bool  suppress)
Definition at line 26 of file vtkOutlineRepresentation.h.
◆ SetPickable()
void vtkOutlineRepresentation::SetPickable ( int  )
Definition at line 27 of file vtkOutlineRepresentation.h.
◆ SetRepresentation() [2/2]
void vtkOutlineRepresentation::SetRepresentation ( int  )
inlineoverrideprotectedvirtual
This adds VTK_SURFACE_WITH_EDGES to those defined in vtkProperty.
Definition at line 33 of file vtkOutlineRepresentation.h.
