vtkSMPropertyHelper.h
2 // SPDX-FileCopyrightText: Copyright (c) 2007, Sandia Corporation
23 #ifndef vtkSMPropertyHelper_h
24 #define vtkSMPropertyHelper_h
25
26 #include "vtkRemotingServerManagerModule.h" //needed for exports
27 #include "vtkVariant.h" // for vtkVariant
28
29 #include <vector> // for std::vector
30
31 #ifdef INT
32 #undef INT
33 #endif
34 #ifdef DOUBLE
35 #undef DOUBLE
36 #endif
37 #ifdef NONE
38 #undef NONE
39 #endif
40
43 class vtkSMInputProperty;
45 class vtkSMOutputPort;
46 class vtkSMProperty;
47 class vtkSMProxy;
48 class vtkSMProxyProperty;
51
52 class VTKREMOTINGSERVERMANAGER_EXPORT vtkSMPropertyHelper
53 {
54 public:
56
60  vtkSMPropertyHelper(vtkSMProxy* proxy, const char* name, bool quiet = false);
61  vtkSMPropertyHelper(vtkSMProperty* property, bool quiet = false);
64
70  void UpdateValueFromServer();
71
76  void SetNumberOfElements(unsigned int elems);
77
82  unsigned int GetNumberOfElements() const;
83
87  void RemoveAllValues() { this->SetNumberOfElements(0); }
88
92  vtkVariant GetAsVariant(unsigned int index) const;
93
98  template <class T>
99  std::vector<T> GetArray() const;
100
105  template <class T>
106  T GetAs(unsigned int index = 0) const;
107
109
113  void Set(int value) { this->Set(0, value); }
114  void Set(unsigned int index, int value);
115  void Set(const int* values, unsigned int count);
116  void Append(const int* values, unsigned int count);
117  int GetAsInt(unsigned int index = 0) const;
118  unsigned int Get(int* values, unsigned int count = 1) const;
119  std::vector<int> GetIntArray() const;
121
123
127  void Set(double value) { this->Set(0, value); }
128  void Set(unsigned int index, double value);
129  void Set(const double* values, unsigned int count);
130  void Append(const double* values, unsigned int count);
131  double GetAsDouble(unsigned int index = 0) const;
132  unsigned int Get(double* values, unsigned int count = 1) const;
133  std::vector<double> GetDoubleArray() const;
135
136 #if VTK_SIZEOF_ID_TYPE != VTK_SIZEOF_INT
137
142  void Set(vtkIdType value) { this->Set(0, value); }
143  void Set(unsigned int index, vtkIdType value);
144  void Set(const vtkIdType* values, unsigned int count);
145  void Append(const vtkIdType* values, unsigned int count);
146  unsigned int Get(vtkIdType* values, unsigned int count = 1) const;
147 #endif
148  vtkIdType GetAsIdType(unsigned int index = 0) const;
149  std::vector<vtkIdType> GetIdTypeArray() const;
151
153
160  void Set(const char* value) { this->Set(0, value); }
161  void Set(unsigned int index, const char* value);
162  const char* GetAsString(unsigned int index = 0) const;
164
166
171  void Set(vtkSMProxy* value, unsigned int outputport = 0) { this->Set(0, value, outputport); }
172  void Set(unsigned int index, vtkSMProxy* value, unsigned int outputport = 0);
173  void Set(vtkSMProxy** value, unsigned int count, unsigned int* outputports = nullptr);
174  void Add(vtkSMProxy* value, unsigned int outputport = 0);
175  void Remove(vtkSMProxy* value);
176  vtkSMProxy* GetAsProxy(unsigned int index = 0) const;
177  unsigned int GetOutputPort(unsigned int index = 0) const;
178  vtkSMOutputPort* GetAsOutputPort(unsigned int index = 0) const;
180
182
187  void SetStatus(const char* key, int value);
188  int GetStatus(const char* key, int default_value = 0) const;
190
192
197  void SetStatus(const char* key, double* values, int num_values);
198  bool GetStatus(const char* key, double* values, int num_values) const;
200
202
207  void SetStatus(int key, int* values, int num_values);
208  bool GetStatus(int key, int* values, int num_values) const;
210
212
217  void SetStatus(const char* key, const char* value);
218  const char* GetStatus(const char* key, const char* default_value) const;
220
226  void RemoveStatus(const char* key);
227
229
234  void SetStatus(int key, int value);
235  int GetStatus(int key, int default_value = 0) const;
237
239
244  void SetInputArrayToProcess(int fieldAssociation, const char* arrayName);
245  int GetInputArrayAssociation() const;
246  const char* GetInputArrayNameToProcess() const;
248
252  void SetUseUnchecked(bool val) { this->UseUnchecked = val; }
253  bool GetUseUnchecked() const { return this->UseUnchecked; }
254
260  bool Copy(const vtkSMPropertyHelper& source);
261
266  vtkSMPropertyHelper& Modified();
267
268 protected:
269  void setUseUnchecked(bool useUnchecked) { this->UseUnchecked = useUnchecked; }
270
271 private:
272  vtkSMPropertyHelper(const vtkSMPropertyHelper&) = delete;
273  void operator=(const vtkSMPropertyHelper&) = delete;
274  void Initialize(vtkSMProperty* property);
275
276  template <typename T>
277  T GetProperty(unsigned int index) const;
278  template <typename T>
279  std::vector<T> GetPropertyArray() const;
280  template <typename T>
281  unsigned int GetPropertyArray(T* values, unsigned int count = 1) const;
282  template <typename T>
283  void SetProperty(unsigned int index, T value);
284  template <typename T>
285  void SetPropertyArray(const T* values, unsigned int count);
286  void SetPropertyArrayIdType(const vtkIdType* values, unsigned int count);
287  template <typename T>
288  void AppendPropertyArray(const T* values, unsigned int count);
289  template <typename T>
290  bool CopyInternal(const vtkSMPropertyHelper& source);
291
292  enum PType
293  {
294  INT,
295  DOUBLE,
296  IDTYPE,
297  STRING,
298  PROXY,
299  INPUT,
300  NONE
301  };
302
303  bool Quiet;
304  bool UseUnchecked;
305  vtkSMProxy* Proxy;
306  PType Type;
307
308  union {
317  };
318 };
319
320 template <>
321 inline std::vector<int> vtkSMPropertyHelper::GetArray() const
322 {
323  return this->GetIntArray();
324 }
325
326 template <>
327 inline std::vector<double> vtkSMPropertyHelper::GetArray() const
328 {
329  return this->GetDoubleArray();
330 }
331
332 #if VTK_SIZEOF_ID_TYPE != VTK_SIZEOF_INT
333 template <>
334 inline std::vector<vtkIdType> vtkSMPropertyHelper::GetArray() const
335 {
336  return this->GetIdTypeArray();
337 }
338 #endif
339
340 template <>
341 inline int vtkSMPropertyHelper::GetAs(unsigned int index) const
342 {
343  return this->GetAsInt(index);
344 }
345
346 template <>
347 inline double vtkSMPropertyHelper::GetAs(unsigned int index) const
348 {
349  return this->GetAsDouble(index);
350 }
351
352 #if VTK_SIZEOF_ID_TYPE != VTK_SIZEOF_INT
353 template <>
354 inline vtkIdType vtkSMPropertyHelper::GetAs(unsigned int index) const
355 {
356  return this->GetAsIdType(index);
357 }
358 #endif
359
360 #endif
361
362 // VTK-HeaderTest-Exclude: vtkSMPropertyHelper.h
vtkSMPropertyHelper::GetIntArray
std::vector< int > GetIntArray() const
Set/Get methods with int API.
vtkVariant.h
vtkSMPropertyHelper::IdTypeVectorProperty
vtkSMIdTypeVectorProperty * IdTypeVectorProperty
Definition: vtkSMPropertyHelper.h:313
vtkIdType
int vtkIdType
vtkSMVectorProperty
abstract superclass for all vector properties
Definition: vtkSMVectorProperty.h:20
vtkSMPropertyHelper
helper class to get/set property values.
Definition: vtkSMPropertyHelper.h:52
vtkSMPropertyHelper::VectorProperty
vtkSMVectorProperty * VectorProperty
Definition: vtkSMPropertyHelper.h:310
vtkSMPropertyHelper::InputProperty
vtkSMInputProperty * InputProperty
Definition: vtkSMPropertyHelper.h:316
vtkSMPropertyHelper::DoubleVectorProperty
vtkSMDoubleVectorProperty * DoubleVectorProperty
Definition: vtkSMPropertyHelper.h:312
vtkSMIntVectorProperty
property representing a vector of integers
Definition: vtkSMIntVectorProperty.h:21
vtkSMPropertyHelper::SetUseUnchecked
Get/Set whether to use unchecked properties.
Definition: vtkSMPropertyHelper.h:252
vtkSMProperty
Definition: vtkSMProperty.h:144
vtkSMProxy
Definition: vtkSMProxy.h:140
T GetAs(unsigned int index=0) const
Templated method to call GetAsInt(), GetAsDouble(), GetAsIdType() Note, we only provide implementatio...
void Set(vtkSMProxy *value, unsigned int outputport=0)
Set/Get methods for vtkSMProxyProperty or vtkSMInputProperty.
Definition: vtkSMPropertyHelper.h:171
vtkSMPropertyHelper::GetIdTypeArray
std::vector< vtkIdType > GetIdTypeArray() const
vtkSMPropertyHelper::GetAsDouble
double GetAsDouble(unsigned int index=0) const
Set/Get methods with double API.
vtkSMPropertyHelper::GetAsInt
int GetAsInt(unsigned int index=0) const
property representing a vector of doubles
Definition: vtkSMDoubleVectorProperty.h:21
Definition: vtkSMPropertyHelper.h:127
vtkSMPropertyHelper::GetDoubleArray
std::vector< double > GetDoubleArray() const
vtkVariant
vtkSMPropertyHelper::StringVectorProperty
vtkSMStringVectorProperty * StringVectorProperty
Definition: vtkSMPropertyHelper.h:314
vtkSMPropertyHelper::IntVectorProperty
vtkSMIntVectorProperty * IntVectorProperty
Definition: vtkSMPropertyHelper.h:311
std::vector< T > GetArray() const
Templated method to call GetIntArray(), GetDoubleArray(), GetIdTypeArray().
name
name
void Set(int value)
Definition: vtkSMPropertyHelper.h:113
pqTimelineItemRole::PROXY
@ PROXY
Definition: pqTimelineModel.h:18
Definition: vtkSMIdTypeVectorProperty.h:23
vtkSMPropertyHelper::GetUseUnchecked
Definition: vtkSMPropertyHelper.h:253
vtkSMPropertyHelper::GetAsIdType
vtkIdType GetAsIdType(unsigned int index=0) const
vtkSMPropertyHelper::RemoveAllValues
Equivalent to SetNumberOfElements(0).
Definition: vtkSMPropertyHelper.h:87
vtkSMPropertyHelper::ProxyProperty
vtkSMProxyProperty * ProxyProperty
Definition: vtkSMPropertyHelper.h:315
property representing a vector of strings
Definition: vtkSMStringVectorProperty.h:29
vtkSMPropertyHelper::setUseUnchecked
Definition: vtkSMPropertyHelper.h:269
vtkSMProxyProperty
property representing pointer(s) to vtkObject(s)
Definition: vtkSMProxyProperty.h:57
vtkSMPropertyHelper::Property
vtkSMProperty * Property
Definition: vtkSMPropertyHelper.h:309
vtkSMOutputPort
reference for an output port of a vtkAlgorithm.
Definition: vtkSMOutputPort.h:36
void Set(const char *value)
Set/Get methods for vtkSMStringVectorProperty.
Definition: vtkSMPropertyHelper.h:160
vtkSMInputProperty
proxy representing inputs to a filter
Definition: vtkSMInputProperty.h:28
pqTimelineTrack::NONE
@ NONE
Definition: pqTimelineModel.h:41
