48 #ifndef vtkSMProxyProperty_h
49 #define vtkSMProxyProperty_h
51 #include "vtkRemotingServerManagerModule.h"
67 static void EnableProxyCreation();
68 static void DisableProxyCreation();
69 static bool CanCreateProxy();
82 virtual void SetProxy(
unsigned int idx,
vtkSMProxy* proxy);
84 virtual void RemoveAllProxies();
90 virtual void SetProxies(
unsigned int numElements,
vtkSMProxy* proxies[]);
109 virtual void AddUncheckedProxy(
vtkSMProxy* proxy);
110 virtual void SetUncheckedProxy(
unsigned int idx,
vtkSMProxy* proxy);
116 virtual void RemoveAllUncheckedProxies();
122 unsigned int GetNumberOfProxies();
127 unsigned int GetNumberOfUncheckedProxies();
133 void SetNumberOfProxies(
unsigned int count);
134 void SetNumberOfUncheckedProxies(
145 vtkSMProxy* GetUncheckedProxy(
unsigned int idx);
virtual void ReadFrom(const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *)
virtual bool IsValueDefault()
virtual void UpdateAllInputs()
Update all proxies referred by this property (if any).
virtual int ReadXMLAttributes(vtkSMProxy *parent, vtkPVXMLElement *element)
virtual int LoadState(vtkPVXMLElement *element, vtkSMProxyLocator *loader)
Updates state from an XML element.
virtual void WriteTo(vtkSMMessage *msg)
Let the property write its content into the stream.
void ClearUncheckedElements() override
Use this method to clear unchecked values set of this property.
void OnUpdateDataEvent()
Called when a producer fires the vtkCommand::UpdateDataEvent.
vtkPPInternals * PPInternals
virtual void SaveStateValues(vtkPVXMLElement *propertyElement)
This class is used by vtkSMProxyProperty to keep track of the proxies.
void UpdateDomains()
Calls Update() on all domains contained by the property as well as all dependent domains.
virtual void ResetToXMLDefaults()
For properties that support specifying defaults in XML configuration, this method will reset the prop...
virtual void Copy(vtkSMProperty *src)
Copy all property values.
static bool CreateProxyAllowed
property representing pointer(s) to vtkObject(s)
Class used to retrieve a given message state based on its GlobalID.
static vtkSMProperty * New()
