vtkSMStringVectorProperty.h
17 #ifndef vtkSMStringVectorProperty_h
18 #define vtkSMStringVectorProperty_h
20 #include "vtkRemotingServerManagerModule.h" //needed for exports
21 #include "vtkSMVectorProperty.h"
22
23 #include <string> // needed for std::string
24 #include <vector> // needed for std::vector
25
26 class vtkStringList;
27 class vtkSMStateLocator;
28
29 class VTKREMOTINGSERVERMANAGER_EXPORT vtkSMStringVectorProperty : public vtkSMVectorProperty
30 {
31 public:
34  void PrintSelf(ostream& os, vtkIndent indent) override;
35
39  unsigned int GetNumberOfElements() override;
40
45  void SetNumberOfElements(unsigned int num) override;
46
52  int SetElement(unsigned int idx, const char* value);
53
57  int SetElements(const char* values[], unsigned int count);
58
60
63  int SetElements(vtkStringList* newvalue);
64  int SetElements(const std::vector<std::string>& newvalue);
66
68
71  int SetUncheckedElements(const char* values[], unsigned int count);
72  int SetUncheckedElements(const std::vector<std::string>& newvalue);
74
78  int AppendElements(const std::vector<std::string>& newvalue);
79
83  int AppendUncheckedElements(const std::vector<std::string>& newvalue);
84
88  void GetElements(vtkStringList* list);
89
91
94  const std::vector<std::string>& GetElements() const;
95  const std::vector<std::string>& GetUncheckedElements() const;
97
101  const char* GetElement(unsigned int idx);
102
107  unsigned int GetElementIndex(const char* value, int& exists);
108
110
118  void SetElementType(unsigned int idx, int type);
119  int GetElementType(unsigned int idx);
121
128  const char* GetUncheckedElement(unsigned int idx);
129
135  void SetUncheckedElement(unsigned int idx, const char* value);
136
138
141  void GetUncheckedElements(vtkStringList* list);
142  int SetUncheckedElements(vtkStringList* list);
144
150  unsigned int GetNumberOfUncheckedElements() override;
151
153  {
156  STRING
157  };
158
162  void Copy(vtkSMProperty* src) override;
163
167  const char* GetDefaultValue(int idx);
168
169  void ClearUncheckedElements() override;
170
171  bool IsValueDefault() override;
172
178  void ResetToXMLDefaults() override;
179
180 protected:
182  ~vtkSMStringVectorProperty() override;
183
189  void SetNumberOfUncheckedElements(unsigned int num) override;
190
199  int ReadXMLAttributes(vtkSMProxy* parent, vtkPVXMLElement* element) override;
200
204  void WriteTo(vtkSMMessage*) override;
205
209  void ReadFrom(const vtkSMMessage*, int msg_offset, vtkSMProxyLocator*) override;
210
214  int LoadState(vtkPVXMLElement* element, vtkSMProxyLocator* loader) override;
215
216  // Save concrete property values into the XML state property declaration
217  void SaveStateValues(vtkPVXMLElement* propElement) override;
218
219 private:
221  void operator=(const vtkSMStringVectorProperty&) = delete;
222
223  class vtkInternals;
224  vtkInternals* Internals;
225 };
226
227 #endif
vtkSMVectorProperty::PrintSelf
vtkSMVectorProperty::GetNumberOfElements
virtual unsigned int GetNumberOfElements()=0
Returns the size of the vector.
vtkSMProperty::ReadFrom
virtual void ReadFrom(const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *)
Definition: vtkSMProperty.h:555
vtkSMProperty::IsValueDefault
virtual bool IsValueDefault()
Definition: vtkSMProperty.h:510
vtkSMVectorProperty
abstract superclass for all vector properties
Definition: vtkSMVectorProperty.h:20
vtkSMVectorProperty::GetNumberOfUncheckedElements
virtual unsigned int GetNumberOfUncheckedElements()=0
API for setting unchecked element values.
vtkSMStringVectorProperty::ElementTypes
ElementTypes
Definition: vtkSMStringVectorProperty.h:152
vtkSMVectorProperty::ReadXMLAttributes
int ReadXMLAttributes(vtkSMProxy *parent, vtkPVXMLElement *element) override
vtkSMStringVectorProperty::DOUBLE
@ DOUBLE
Definition: vtkSMStringVectorProperty.h:155
vtkSMVectorProperty::SetNumberOfElements
virtual void SetNumberOfElements(unsigned int num)=0
Sets the size of the vector.
vtkSMProperty
Definition: vtkSMProperty.h:144
vtkSMProperty::LoadState
virtual int LoadState(vtkPVXMLElement *element, vtkSMProxyLocator *loader)
Updates state from an XML element.
vtkSMVectorProperty::ClearUncheckedElements
void ClearUncheckedElements() override=0
vtkSMProxy
Definition: vtkSMProxy.h:140
vtkSMProperty::WriteTo
virtual void WriteTo(vtkSMMessage *msg)
Let the property write its content into the stream.
vtkSMProperty::SaveStateValues
virtual void SaveStateValues(vtkPVXMLElement *propertyElement)
vtkIndent
vtkSMVectorProperty::Copy
void Copy(vtkSMProperty *src) override
Copy all property values.
vtkSMVectorProperty::SetNumberOfUncheckedElements
virtual void SetNumberOfUncheckedElements(unsigned int num)=0
vtkSMMessage
vtkStringList
Manages allocation and freeing for a string list.
Definition: vtkStringList.h:18
vtkSMStringVectorProperty::INT
@ INT
Definition: vtkSMStringVectorProperty.h:154
vtkPVXMLElement
Definition: vtkPVXMLElement.h:23
vtkSMProperty::ResetToXMLDefaults
virtual void ResetToXMLDefaults()
For properties that support specifying defaults in XML configuration, this method will reset the prop...
Definition: vtkSMProperty.h:415
property representing a vector of strings
Definition: vtkSMStringVectorProperty.h:29
vtkSMProxyLocator
Definition: vtkSMProxyLocator.h:24
vtkSMStateLocator
Class used to retrieve a given message state based on its GlobalID.
Definition: vtkSMStateLocator.h:23
vtkSMProperty::New
static vtkSMProperty * New()
