13 #ifndef vtkSMIntVectorProperty_h
14 #define vtkSMIntVectorProperty_h
16 #include "vtkRemotingServerManagerModule.h"
44 int SetElement(
unsigned int idx,
int value);
54 int SetElements(
const int* values);
55 int SetElements(
const int* values,
unsigned int numElems);
63 int SetUncheckedElements(
const int* values);
64 int SetUncheckedElements(
const int* values,
unsigned int numValues);
65 int* GetUnCheckedElements();
74 int SetElements1(
int value0);
82 int SetElements2(
int value0,
int value1);
90 int SetElements3(
int value0,
int value1,
int value2);
95 int AppendElements(
const int* values,
100 int AppendUncheckedElements(
const int* values,
105 int GetElement(
unsigned int idx);
113 int GetUncheckedElement(
unsigned int idx);
120 void SetUncheckedElement(
unsigned int idx,
int value);
142 vtkGetMacro(ArgumentIsArray,
int);
143 vtkSetMacro(ArgumentIsArray,
int);
144 vtkBooleanMacro(ArgumentIsArray,
int);
155 int GetDefaultValue(
int idx);
virtual unsigned int GetNumberOfElements()=0
Returns the size of the vector.
virtual void ReadFrom(const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *)
virtual bool IsValueDefault()
abstract superclass for all vector properties
virtual unsigned int GetNumberOfUncheckedElements()=0
API for setting unchecked element values.
int ReadXMLAttributes(vtkSMProxy *parent, vtkPVXMLElement *element) override
property representing a vector of integers
virtual void SetNumberOfElements(unsigned int num)=0
Sets the size of the vector.
virtual int LoadState(vtkPVXMLElement *element, vtkSMProxyLocator *loader)
Updates state from an XML element.
void ClearUncheckedElements() override=0
virtual void WriteTo(vtkSMMessage *msg)
Let the property write its content into the stream.
virtual void SaveStateValues(vtkPVXMLElement *propertyElement)
void Copy(vtkSMProperty *src) override
Copy all property values.
virtual void SetNumberOfUncheckedElements(unsigned int num)=0
virtual void ResetToXMLDefaults()
For properties that support specifying defaults in XML configuration, this method will reset the prop...
Class used to retrieve a given message state based on its GlobalID.
static vtkSMProperty * New()
