vtkSMOutputPort.h
18 #ifndef vtkSMOutputPort_h
19 #define vtkSMOutputPort_h
20
21 #include "vtkRemotingServerManagerModule.h" //needed for exports
22 #include "vtkSMProxy.h"
23 #include "vtkSmartPointer.h" // needed for vtkSmartPointer
24 #include "vtkWeakPointer.h" // needed for vtkWeakPointer
25
26 #include <map> // needed for std::map
27
28 class vtkCollection;
34 class vtkSMSourceProxy;
35
36 class VTKREMOTINGSERVERMANAGER_EXPORT vtkSMOutputPort : public vtkSMProxy
37 {
38 public:
39  static vtkSMOutputPort* New();
40  vtkTypeMacro(vtkSMOutputPort, vtkSMProxy);
41  void PrintSelf(ostream& os, vtkIndent indent) override;
42
49  virtual vtkPVDataInformation* GetDataInformation();
50
54  vtkPVDataInformation* GetRankDataInformation(int rank);
55
57
68  vtkPVDataInformation* GetSubsetDataInformation(
69  const char* selector, const char* assemblyName = nullptr);
71
76  vtkPVDataInformation* GetSubsetDataInformation(unsigned int compositeIndex);
77
83  virtual vtkPVTemporalDataInformation* GetTemporalDataInformation();
84
88  virtual const char* GetDataClassName();
89
93  virtual vtkPVClassNameInformation* GetClassNameInformation();
94
98  virtual void InvalidateDataInformation();
99
101
104  vtkGetMacro(PortIndex, int);
106
110  vtkSMSourceProxy* GetSourceProxy();
111
113
115  vtkSMSession* GetSession() override;
118 protected:
119  vtkSMOutputPort();
120  ~vtkSMOutputPort() override;
121
125  virtual void GatherClassNameInformation();
126
131  virtual void GatherDataInformation();
132
136  virtual void GatherTemporalDataInformation();
137
138  void SetSourceProxy(vtkSMSourceProxy* src);
139
140  // When set to non-nullptr, GetSourceProxy() returns this rather than the real
141  // source-proxy set using SetSourceProxy(). This provides a mechanism for
142  // vtkSMCompoundSourceProxy to take ownership of ports that don't really
143  // belong to it.
144  void SetCompoundSourceProxy(vtkSMCompoundSourceProxy* src);
145
149  virtual void UpdatePipelineInternal(double time, bool doTime);
150
151  // The index of the port the output is obtained from.
152  vtkSetMacro(PortIndex, int);
153  int PortIndex;
154
157
160
163
166
167  std::map<std::string, std::map<int, vtkSmartPointer<vtkPVDataInformation>>>
169  std::map<int, vtkSmartPointer<vtkPVDataInformation>> RankDataInformations;
170
171 private:
172  vtkSMOutputPort(const vtkSMOutputPort&) = delete;
173  void operator=(const vtkSMOutputPort&) = delete;
174
175  friend class vtkSMSourceProxy;
177  void UpdatePipeline();
178
179  // Update Pipeline with the given timestep request.
180  void UpdatePipeline(double time);
181 };
182
183 #endif
vtkSMSessionProxyManager
Definition: vtkSMSessionProxyManager.h:135
vtkSMOutputPort::DataInformation
vtkPVDataInformation * DataInformation
Definition: vtkSMOutputPort.h:161
vtkSMProxy::New
static vtkSMProxy * New()
vtkSMSessionObject::GetSession
virtual vtkSMSession * GetSession()
Get/Set the session on wihch this object exists.
vtkSMOutputPort::ClassNameInformationValid
int ClassNameInformationValid
Definition: vtkSMOutputPort.h:159
vtkSMOutputPort::DataInformationValid
bool DataInformationValid
Definition: vtkSMOutputPort.h:162
Holds class name.
Definition: vtkPVClassNameInformation.h:18
vtkSMOutputPort::SubsetDataInformations
std::map< std::string, std::map< int, vtkSmartPointer< vtkPVDataInformation > > > SubsetDataInformations
Definition: vtkSMOutputPort.h:168
vtkSMOutputPort::SourceProxy
vtkWeakPointer< vtkSMSourceProxy > SourceProxy
Definition: vtkSMOutputPort.h:155
vtkSMProxy
Definition: vtkSMProxy.h:140
vtkCollection
extends vtkPVDataInformation to gather information across timesteps.
Definition: vtkPVTemporalDataInformation.h:21
vtkSMOutputPort::PortIndex
int PortIndex
Definition: vtkSMOutputPort.h:152
vtkSMSourceProxy
proxy for a VTK source on a server
Definition: vtkSMSourceProxy.h:37
vtkSMOutputPort::TemporalDataInformation
vtkPVTemporalDataInformation * TemporalDataInformation
Definition: vtkSMOutputPort.h:164
vtkPVClassNameInformation * ClassNameInformation
Definition: vtkSMOutputPort.h:158
vtkSMSession
Definition: vtkSMSession.h:22
vtkSMOutputPort::TemporalDataInformationValid
bool TemporalDataInformationValid
Definition: vtkSMOutputPort.h:165
vtkSMProxy::operator=
void operator=(const vtkSMProxy &)=delete
vtkIndent
vtkSmartPointer.h
vtkWeakPointer.h
a proxy excapsulation a pipeline of proxies.
Definition: vtkSMCompoundSourceProxy.h:32
provides meta data about a vtkDataObject subclass.
Definition: vtkPVDataInformation.h:42
vtkSMProxy.h
vtkSMOutputPort::CompoundSourceProxy
vtkWeakPointer< vtkSMCompoundSourceProxy > CompoundSourceProxy
Definition: vtkSMOutputPort.h:156
vtkPVDataAssemblyInformation
fetches vtkDataAssembly from a vtkObject subclass
Definition: vtkPVDataAssemblyInformation.h:20
vtkSMSessionObject::GetSessionProxyManager
virtual vtkSMSessionProxyManager * GetSessionProxyManager()
Return the corresponding ProxyManager if any.
vtkSMSourceProxy::UpdatePipeline
virtual void UpdatePipeline()
Calls Update() on all sources.
vtkSMProxy::PrintSelf
vtkSMOutputPort
reference for an output port of a vtkAlgorithm.
Definition: vtkSMOutputPort.h:36
vtkSMOutputPort::RankDataInformations
std::map< int, vtkSmartPointer< vtkPVDataInformation > > RankDataInformations
Definition: vtkSMOutputPort.h:169
