13 #ifndef vtkSMIdTypeVectorProperty_h
14 #define vtkSMIdTypeVectorProperty_h
16 #include "vtkRemotingServerManagerModule.h"
46 int SetElement(
unsigned int idx,
vtkIdType value);
57 int SetElements(
const vtkIdType* values,
unsigned int numValues);
64 int SetUncheckedElements(
const vtkIdType* values);
65 int SetUncheckedElements(
95 int AppendElements(
100 int AppendUncheckedElements(
113 vtkIdType GetUncheckedElement(
unsigned int idx);
120 void SetUncheckedElement(
unsigned int idx,
vtkIdType value);
133 const std::vector<vtkIdType>& GetElements()
const;
134 const std::vector<vtkIdType>& GetUncheckedElements()
const;
150 vtkGetMacro(ArgumentIsArray,
int);
151 vtkSetMacro(ArgumentIsArray,
int);
152 vtkBooleanMacro(ArgumentIsArray,
int);
207 vtkInternals* Internals;
virtual unsigned int GetNumberOfElements()=0
Returns the size of the vector.
virtual void ReadFrom(const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *)
abstract superclass for all vector properties
virtual unsigned int GetNumberOfUncheckedElements()=0
API for setting unchecked element values.
int ReadXMLAttributes(vtkSMProxy *parent, vtkPVXMLElement *element) override
virtual void SetNumberOfElements(unsigned int num)=0
Sets the size of the vector.
virtual int LoadState(vtkPVXMLElement *element, vtkSMProxyLocator *loader)
Updates state from an XML element.
void ClearUncheckedElements() override=0
virtual void WriteTo(vtkSMMessage *msg)
Let the property write its content into the stream.
virtual void SaveStateValues(vtkPVXMLElement *propertyElement)
void Copy(vtkSMProperty *src) override
Copy all property values.
virtual void SetNumberOfUncheckedElements(unsigned int num)=0
property representing a vector of integers
virtual void ResetToXMLDefaults()
For properties that support specifying defaults in XML configuration, this method will reset the prop...
Class used to retrieve a given message state based on its GlobalID.
static vtkSMProperty * New()
