vtkSMRecolorableImageExtractWriterProxy Class Reference
extractor for recolorable images. More...
#include <vtkSMRecolorableImageExtractWriterProxy.h>
Inheritance diagram for vtkSMRecolorableImageExtractWriterProxy:
Collaboration diagram for vtkSMRecolorableImageExtractWriterProxy:
typedef vtkSMImageExtractWriterProxy Superclass
- Public Types inherited from vtkSMImageExtractWriterProxy
enum  CameraMode { Static = 0, PhiTheta = 1 }
typedef vtkSMExtractWriterProxy Superclass
- Public Types inherited from vtkSMExtractWriterProxy
typedef vtkSMProxy Superclass
- Public Member Functions inherited from vtkSMImageExtractWriterProxy
bool Write (vtkSMExtractsController *extractor) override
 Implementation for vtkSMExtractWriterProxy API. More...
bool CanExtract (vtkSMProxy *proxy) override
bool IsExtracting (vtkSMProxy *proxy) override
void SetInput (vtkSMProxy *proxy) override
vtkSMProxy * GetInput () override
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMRecolorableImageExtractWriterProxy * New ()
static vtkSMRecolorableImageExtractWriterProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMImageExtractWriterProxy
static vtkSMImageExtractWriterProxy * New ()
static vtkSMImageExtractWriterProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMExtractWriterProxy
static vtkSMExtractWriterProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMRecolorableImageExtractWriterProxy ()
 ~vtkSMRecolorableImageExtractWriterProxy () override
bool WriteInternal (vtkSMExtractsController *extractor, const SummaryParametersT &params=SummaryParametersT{}) override
 Called in Write(). More...
- Protected Member Functions inherited from vtkSMImageExtractWriterProxy
 vtkSMImageExtractWriterProxy ()
 ~vtkSMImageExtractWriterProxy () override
bool WriteImage (vtkSMExtractsController *extractor, const SummaryParametersT &cameraParams=SummaryParametersT{})
 Save a single image. More...
virtual const char * GetShortName (const std::string &key) const
 Used to convert a parameter name used in the SummaryParametersT to a shorter version suitable for use in filename. More...
- Protected Member Functions inherited from vtkSMExtractWriterProxy
 vtkSMExtractWriterProxy ()
 ~vtkSMExtractWriterProxy () override
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Types inherited from vtkSMImageExtractWriterProxy
using SummaryParametersT = vtkSMExtractsController::SummaryParametersT
- Static Protected Member Functions inherited from vtkSMExtractWriterProxy
static std::string GenerateExtractsFileName (const std::string &filename, const char *outDir)
 Adds the output directory to the filename, replaces, in case of need, the old string format, and returns the formatted string using vtkPVStringFormatter. More...
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMRecolorableImageExtractWriterProxy is an extractors that saves out recolorable images instead of standard PNGs from views. Recolorable images are obtained from vtkPVRenderView by rendering and capturing the raw data array values instead of mapping them through a lookup table. The implementation uses vtkValuePass.
Currently, this is only supported in client-only (builtin) and parallel pvbatch (or insitu) modes. Any client-server configuration is not supported.
Definition at line 22 of file vtkSMRecolorableImageExtractWriterProxy.h.
Definition at line 27 of file vtkSMRecolorableImageExtractWriterProxy.h.
◆ vtkSMRecolorableImageExtractWriterProxy()
vtkSMRecolorableImageExtractWriterProxy::vtkSMRecolorableImageExtractWriterProxy ( )
◆ ~vtkSMRecolorableImageExtractWriterProxy()
vtkSMRecolorableImageExtractWriterProxy::~vtkSMRecolorableImageExtractWriterProxy ( )
static vtkSMRecolorableImageExtractWriterProxy* vtkSMRecolorableImageExtractWriterProxy::New ( )
virtual const char* vtkSMRecolorableImageExtractWriterProxy::GetClassName ( )
Reimplemented from vtkSMImageExtractWriterProxy.
static int vtkSMRecolorableImageExtractWriterProxy::IsTypeOf ( const char *  type)
virtual int vtkSMRecolorableImageExtractWriterProxy::IsA ( const char *  type)
static vtkSMRecolorableImageExtractWriterProxy* vtkSMRecolorableImageExtractWriterProxy::SafeDownCast ( vtkObject *  o)
void vtkSMRecolorableImageExtractWriterProxy::PrintSelf ( ostream &  os,
◆ CreateVTKObjects()
void vtkSMRecolorableImageExtractWriterProxy::CreateVTKObjects ( )
Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s)
◆ WriteInternal()
bool vtkSMRecolorableImageExtractWriterProxy::WriteInternal ( vtkSMExtractsController *  extractor,
const SummaryParametersT &  params = SummaryParametersT{}
overrideprotectedvirtual
Called in Write().
Intended for subclasses to override to customize image generation
