vtkPVRenderView Class Reference
Render View for ParaView. More...
#include <vtkPVRenderView.h>
Inheritance diagram for vtkPVRenderView:
Collaboration diagram for vtkPVRenderView:
enum  InteractionModes {
  INTERACTION_MODE_UNINTIALIZED = -1, INTERACTION_MODE_3D = 0, INTERACTION_MODE_2D, INTERACTION_MODE_SELECTION,
  INTERACTION_MODE_ZOOM, INTERACTION_MODE_POLYGON
enum  { DEFAULT_RENDERER = 0, NON_COMPOSITED_RENDERER = 1 }
 Defines various renderer types. More...
enum  BackgroundMode {
  DEFAULT, GRADIENT, IMAGE, SKYBOX,
  STEREO_SKYBOX
enum  GenericFilmicPresets { Custom = 0, Default = 1, Uncharted2 = 2 }
 Defines tone mapping generic filmic presets. More...
typedef vtkPVView Superclass
- Public Types inherited from vtkPVView
typedef vtkView Superclass
- Public Types inherited from vtkView
virtual vtkRenderer * GetRenderer (int rendererType=DEFAULT_RENDERER)
 Returns the renderer given an int identifying its type. More...
vtkRenderWindowInteractor * GetInteractor ()
 Returns the interactor. More...
virtual void SetupInteractor (vtkRenderWindowInteractor *)
 Set the interactor. More...
void StillRender () override
 Triggers a high-resolution render. More...
void InteractiveRender () override
 Triggers a interactive render. More...
void ConfigureCompressor (const char *configuration)
 Passes the compressor configuration to the client-server synchronizer, if any. More...
virtual void ResetCameraClippingRange ()
 Resets the clipping range. More...
void InvalidateCachedSelection ()
 Invalidates cached selection. More...
void SetMaxClipBounds (double bds[6])
 Used by Cinema to enforce a consistent depth scaling. More...
virtual void SetGridAxes3DActor (vtkPVGridAxes3DActor *)
 Set the vtkPVGridAxes3DActor to use for the view. More...
virtual void SetLegendGridActor (vtkLegendScaleActor *)
 Set the vtkLegendScaleActor to use for the view. More...
virtual void SetCenterAxesVisibility (bool)
 Forwarded to center axes. More...
void SetParallelProjection (int mode)
 Forward to vtkCamera. More...
virtual void SynchronizeGeometryBounds ()
 Synchronizes bounds information on all nodes and reset camera clipping planes. More...
void Update () override
 Overridden to synchronize information among processes whenever data changes. More...
virtual void UpdateLOD ()
 Asks representations to update their LOD geometries. More...
int GetDataDistributionMode (bool low_res)
 Returns the data distribution mode to use. More...
void Deliver (int use_lod, unsigned int size, unsigned int *representation_ids) override
 Called on all processes to request data-delivery for the list of representations. More...
bool GetUseOrderedCompositing ()
 Returns true when ordered compositing is needed on the current group of processes. More...
bool GetRenderEmptyImages ()
 Returns true when the compositor should not use the empty images optimization. More...
void CopyViewUpdateOptions (vtkPVRenderView *otherView)
 Copy internal fields that are used for rendering decision such as remote/local rendering, composite and so on. More...
bool GetOSPRayContinueStreaming ()
 Has OSPRay reached the max frames? More...
void SetOSPRayRendererType (std::string)
 Set the OSPRay renderer to use. More...
virtual void SetMaterialLibrary (vtkPVMaterialLibrary *)
 For OSPRay, set the library of materials. More...
void SetViewTime (double value) override
 Get/Set the time this view is showing. More...
virtual vtkRenderViewBase * GetRenderView ()
void ScaleRendererViewports (const double viewport[4]) override
 Overridden to scale the OrientationWidget appropriately. More...
void SynchronizeMaximumIds (vtkIdType *maxPointId, vtkIdType *maxCellId)
 This is used by vtkPVHardwareSelector to synchronize element ids between all ranks involved in selection. More...
void SetHardwareSelector (vtkPVHardwareSelector *selector)
virtual void SetInteractionMode (int mode)
 Get/Set the interaction mode. More...
virtual int GetInteractionMode ()
void SetSize (int, int) override
 Overridden to call InvalidateCachedSelection() whenever the render window parameters change. More...
void SetPosition (int, int) override
virtual vtkRenderer * GetNonCompositedRenderer ()
 Gets the non-composited renderer for this view. More...
vtkCamera * GetActiveCamera ()
 Get/Set the active camera. More...
virtual void SetActiveCamera (vtkCamera *)
virtual vtkPVInteractorStyle * GetInteractorStyle ()
 Returns the interactor style. More...
void ResetCamera ()
 Resets the active camera using collective prop-bounds. More...
void ResetCamera (double bounds[6])
void ResetCameraScreenSpace (double offsetRatio=0.9)
void ResetCameraScreenSpace (double *bounds, double offsetRatio=0.9)
virtual void SetSuppressRendering (bool)
 SuppressRendering can be used to suppress the render within a StillRender or InteractiveRender. More...
virtual bool GetSuppressRendering ()
virtual void SuppressRenderingOn ()
virtual void SuppressRenderingOff ()
virtual void SetStillRenderImageReductionFactor (int)
 Get/Set the reduction-factor to use when for StillRender(). More...
virtual int GetStillRenderImageReductionFactor ()
virtual void SetInteractiveRenderImageReductionFactor (int)
 Get/Set the reduction-factor to use when for InteractiveRender(). More...
virtual int GetInteractiveRenderImageReductionFactor ()
virtual void SetRemoteRenderingThreshold (double)
 Get/Set the data-size in megabytes above which remote-rendering should be used, if possible. More...
virtual double GetRemoteRenderingThreshold ()
virtual void SetLODRenderingThreshold (double)
 Get/Set the data-size in megabytes above which LOD rendering should be used, if possible. More...
virtual double GetLODRenderingThreshold ()
virtual void SetLODResolution (double)
 Get/Set the LOD resolution. More...
virtual double GetLODResolution ()
virtual void SetUseOutlineForLODRendering (bool)
 When set to true, instead of using simplified geometry for LOD rendering, uses outline, if possible. More...
virtual bool GetUseOutlineForLODRendering ()
void SetUseLightKit (bool enable)
 Enable/Disable light kit. More...
virtual bool GetUseLightKit ()
virtual void UseLightKitOn ()
virtual void UseLightKitOff ()
void StreamingUpdate (const double view_planes[24])
void DeliverStreamedPieces (unsigned int size, unsigned int *representation_ids)
void SelectCells (int region[4], const char *array=nullptr)
 Make a selection. More...
void SelectCells (int region0, int region1, int region2, int region3, const char *array=nullptr)
void SelectPoints (int region[4], const char *array=nullptr)
void SelectPoints (int region0, int region1, int region2, int region3, const char *array=nullptr)
void Select (int field_association, int region[4], const char *array=nullptr)
void SelectPolygonPoints (int *polygon2DArray, vtkIdType arrayLen)
 Make a selection with a polygon. More...
void SelectPolygonCells (int *polygon2DArray, vtkIdType arrayLen)
void SelectPolygon (int field_association, int *polygon2DArray, vtkIdType arrayLen)
virtual vtkSelection * GetLastSelection ()
 Provides access to the last selection. More...
virtual void SetUseInteractiveRenderingForScreenshots (bool)
 Set or get whether capture should be done as StillRender or InteractiveRender when capturing screenshots. More...
virtual void UseInteractiveRenderingForScreenshotsOn ()
virtual void UseInteractiveRenderingForScreenshotsOff ()
virtual bool GetUseInteractiveRenderingForScreenshots ()
virtual bool GetRemoteRenderingAvailable ()
 Returns if remote-rendering is possible on the current group of processes. More...
void RemoteRenderingAvailableOff ()
void NVPipeAvailableOn ()
 Determine if NVPipe is an available compressor option. More...
void NVPipeAvailableOff ()
virtual bool GetUsedLODForLastRender ()
 Returns true if the most recent render used LOD. More...
void SetLockBounds (bool nv)
 Used by Cinema to enforce a consistent viewpoint and depth scaling. More...
virtual bool GetLockBounds ()
int RegisterPropForHardwareSelection (vtkPVDataRepresentation *repr, vtkProp *prop)
 Representations that support hardware (render-buffer based) selection, should register the prop that they use for selection rendering. More...
void UnRegisterPropForHardwareSelection (vtkPVDataRepresentation *repr, vtkProp *prop)
void SetShowAnnotation (bool val)
 Enable/disable showing of annotation for developers. More...
virtual void SetUpdateAnnotation (bool)
void SetAnnotationColor (double r, double g, double b)
 Set color of annotation text for developers. More...
virtual void SetOrientationAxesInteractivity (bool)
 Forwarded to orientation axes widget. More...
virtual void SetOrientationAxesVisibility (bool)
void SetOrientationAxesLabelColor (double r, double g, double b)
void SetOrientationAxesOutlineColor (double r, double g, double b)
void SetOrientationAxesXColor (double r, double g, double b)
void SetOrientationAxesYColor (double r, double g, double b)
void SetOrientationAxesZColor (double r, double g, double b)
void SetOrientationAxesXVisibility (bool vis)
void SetOrientationAxesYVisibility (bool vis)
void SetOrientationAxesZVisibility (bool vis)
void SetOrientationAxesXLabelText (const char *text)
void SetOrientationAxesYLabelText (const char *text)
void SetOrientationAxesZLabelText (const char *text)
void SetCameraOrientationWidgetVisibility (bool visible)
 Forwarded to camera orientation widget. More...
void SetCameraOrientationWidgetSize (int size)
void SetCameraOrientationWidgetPadding (int padding[2])
void SetCameraOrientationWidgetAnchor (int anchor)
virtual void SetCenterOfRotation (double x, double y, double z)
 Forward to vtkPVInteractorStyle instances. More...
virtual void SetRotationFactor (double factor)
void SetKeyLightWarmth (double val)
 Forward to vtkLightKit. More...
void SetKeyLightIntensity (double val)
void SetKeyLightElevation (double val)
void SetKeyLightAzimuth (double val)
void SetFillLightWarmth (double val)
void SetKeyToFillRatio (double val)
void SetFillLightElevation (double val)
void SetFillLightAzimuth (double val)
void SetBackLightWarmth (double val)
void SetKeyToBackRatio (double val)
void SetBackLightElevation (double val)
void SetBackLightAzimuth (double val)
void SetHeadLightWarmth (double val)
void SetKeyToHeadRatio (double val)
void SetMaintainLuminance (int val)
virtual void SetUseHiddenLineRemoval (bool)
 Forward to 3D renderer. More...
virtual void SetUseDepthPeeling (int val)
virtual void SetUseDepthPeelingForVolumes (bool val)
virtual void SetMaximumNumberOfPeels (int val)
virtual void SetBackgroundTexture (vtkTexture *val)
virtual void SetUseRenderViewSettingsForBackground (bool)
 When set, background color and mode will be obtained from vtkPVRenderViewSettings. More...
virtual bool GetUseRenderViewSettingsForBackground ()
virtual void SetBackgroundColorMode (int)
 API for background color selection. More...
virtual void SetBackground (double, double, double)
virtual void SetBackground (double[3])
virtual double * GetBackground ()
virtual void GetBackground (double &, double &, double &)
virtual void GetBackground (double[3])
virtual void SetBackground2 (double, double, double)
virtual void SetBackground2 (double[3])
virtual double * GetBackground2 ()
virtual void GetBackground2 (double &, double &, double &)
virtual void GetBackground2 (double[3])
virtual void SetUseEnvironmentLighting (bool)
virtual void SetEnvironmentalBG (double r, double g, double b)
 Entry point for environmental backgrounds. More...
virtual void SetEnvironmentalBG2 (double r, double g, double b)
virtual void SetEnvironmentalBGTexture (vtkTexture *val)
virtual void SetGradientEnvironmentalBG (int val)
virtual void SetTexturedEnvironmentalBG (int val)
virtual void SetBackgroundMode (int val)
void AddLight (vtkLight *)
 Entry point for dynamic lights. More...
void RemoveLight (vtkLight *)
void SetStereoCapableWindow (int val)
 Forward to vtkRenderWindow. More...
void SetStereoRender (int val)
virtual void SetStereoType (int)
virtual void SetServerStereoType (int)
void SetMultiSamples (int val)
void SetAlphaBitPlanes (int val)
void SetStencilCapable (int val)
virtual void SetCamera2DManipulators (const int manipulators[9])
 Forwarded to vtkPVInteractorStyle if present on local processes. More...
virtual void SetCamera3DManipulators (const int manipulators[9])
void SetCameraManipulators (vtkPVInteractorStyle *style, const int manipulators[9])
virtual void SetReverseMouseWheelZoomDirection (bool reverse)
virtual void SetMouseWheelZoomsToCursor (bool value)
virtual void SetCamera2DMouseWheelMotionFactor (double factor)
virtual void SetCamera3DMouseWheelMotionFactor (double factor)
virtual bool GetUseLODForInteractiveRender ()
 Returns whether the view will use LOD rendering for the next InteractiveRender() call based on the geometry sizes determined by the most recent call to Update(). More...
virtual bool GetUseDistributedRenderingForRender ()
 Returns whether the view will use distributed rendering for the next full-resolution render. More...
virtual bool GetUseDistributedRenderingForLODRender ()
 Returns whether the view will use distributed rendering for the next low-resolution render. More...
virtual vtkTypeUInt32 GetStillRenderProcesses ()
 Returns the processes (vtkPVSession::ServerFlags) that are to be involved in the next StillRender() call based on the decisions made during the most recent Update(). More...
virtual vtkTypeUInt32 GetInteractiveRenderProcesses ()
 Returns the processes (vtkPVSession::ServerFlags) that are to be involved in the next InteractiveRender() call based on the decisions made during the most recent Update() and UpdateLOD(). More...
virtual void SetUseFXAA (bool)
 Enable/disable FXAA antialiasing. More...
virtual bool GetUseFXAA ()
void SetFXAARelativeContrastThreshold (double val)
 FXAA tunable parameters. More...
void SetFXAAHardContrastThreshold (double val)
void SetFXAASubpixelBlendLimit (double val)
void SetFXAASubpixelContrastThreshold (double val)
void SetFXAAUseHighQualityEndpoints (bool val)
void SetFXAAEndpointSearchIterations (int val)
void SetUseToneMapping (bool v)
 Tone Mapping options. More...
virtual bool GetUseToneMapping ()
void SetToneMappingType (int)
void SetExposure (double)
void SetContrast (double)
void SetShoulder (double)
void SetMidIn (double)
void SetMidOut (double)
void SetHdrMax (double)
void SetUseACES (bool)
void SetGenericFilmicPresets (int t)
virtual void SetUseSSAO (bool)
 SSAO options. More...
virtual bool GetUseSSAO ()
virtual void SetUseSSAODefaultPresets (bool)
virtual void SetRadius (double)
virtual void SetKernelSize (int)
virtual void SetBias (double)
virtual void SetBlur (bool)
void AddPropToRenderer (vtkProp *prop)
 Add props directly to the view. More...
void RemovePropFromRenderer (vtkProp *prop)
bool BeginValuePassForRendering (int fieldAssociation, const char *arrayName, int component)
 Experimental API to grab re-colorable images. More...
void EndValuePassForRendering ()
vtkSmartPointer< vtkFloatArray > GrabValuePassResult ()
void CaptureZBuffer ()
 Access to the Z buffer. More...
vtkFloatArray * GetCapturedZBuffer ()
void SetEnableOSPRay (bool)
 Switches between rasterization and ray tracing. More...
bool GetEnableOSPRay ()
void SetShadows (bool)
 Controls whether OSPRay sends casts shadow rays or not. More...
bool GetShadows ()
void SetAmbientOcclusionSamples (int)
 Sets the number of occlusion query rays that OSPRay sends at each intersection. More...
int GetAmbientOcclusionSamples ()
void SetRouletteDepth (int)
 Sets the depth of monte carlo samples on the path tracer. More...
int GetRouletteDepth ()
void SetVolumeAnisotropy (double)
 Set the path tracers volume anisotropy. More...
double GetVolumeAnisotropy ()
void SetSamplesPerPixel (int)
 Set the number of primary rays that OSPRay shoots per pixel. More...
int GetSamplesPerPixel ()
void SetMaxFrames (int)
 Set the number of render passes OSPRay takes to accumulate subsampled color results. More...
int GetMaxFrames ()
void SetDenoise (bool)
 Controls whether to use image denoising to improve appearance. More...
bool GetDenoise ()
void SetLightScale (double)
 Dimish or Amplify all lights in the scene. More...
double GetLightScale ()
void SetBackgroundNorth (double x, double y, double z)
 Control of background orientation for OSPRay. More...
void SetBackgroundEast (double x, double y, double z)
void SetTimeCacheSize (int)
 Set the size of OSPRay's temporal cache. More...
int GetTimeCacheSize ()
- Public Member Functions inherited from vtkPVView
virtual void SetPPI (int)
 Description: Set the screen PPI. More...
virtual int GetPPI ()
virtual bool GetViewTimeValid ()
 Get ViewTimeValid. More...
 Overridden to not call Update() directly on the input representations, instead use ProcessViewRequest() for all vtkPVDataRepresentations. More...
bool InTileDisplayMode ()
 Returns true if the application is currently in tile display mode. More...
bool InCaveDisplayMode ()
 Returns true if the application is currently in cave/immersive display mode. More...
bool GetLocalProcessSupportsInteraction ()
 Returns true if the local process can support interaction. More...
vtkRenderWindow * GetRenderWindow ()
 If this view needs a render window (not all views may use one), this method can be used to get the render window associated with this view on the current process. More...
vtkMTimeType GetUpdateTimeStamp ()
 Provides access to the time when Update() was last called. More...
virtual bool IsCached (vtkPVDataRepresentation *)
 Called in vtkPVDataRepresentation::ProcessViewRequest to check if the representation already has cached data. More...
virtual void ClearCache (vtkPVDataRepresentation *)
 Called by vtkPVDataRepresentation whenever vtkPVDataRepresentation::MarkModified is called. More...
virtual int * GetPosition ()
 Set the position on this view in the multiview configuration. More...
virtual void GetPosition (int &, int &)
virtual void GetPosition (int[2])
virtual int * GetSize ()
 Set the size of this view in the multiview configuration. More...
virtual void GetSize (int &, int &)
virtual void GetSize (int[2])
virtual double GetViewTime ()
virtual void SetCacheKey (double)
 Get/Set the cache key. More...
virtual double GetCacheKey ()
virtual void SetUseCache (bool)
 Get/Set whether caching is enabled. More...
virtual bool GetUseCache ()
virtual void PrepareForScreenshot ()
 These methods are used to setup the view for capturing screen shots. More...
virtual void CleanupAfterScreenshot ()
void SetTileScale (int x, int y)
 When saving screenshots with tiling, these methods get called. More...
void SetTileViewport (double x0, double y0, double x1, double y1)
void SetDeliveryManager (vtkPVDataDeliveryManager *)
 Provides access to data delivery & cache manager for this view. More...
virtual vtkPVDataDeliveryManager * GetDeliveryManager ()
- Public Member Functions inherited from vtkView
vtkView * NewInstance () const
void AddRepresentation (vtkDataRepresentation *rep)
void SetRepresentation (vtkDataRepresentation *rep)
vtkDataRepresentation * AddRepresentationFromInputConnection (vtkAlgorithmOutput *conn)
vtkDataRepresentation * SetRepresentationFromInputConnection (vtkAlgorithmOutput *conn)
vtkDataRepresentation * AddRepresentationFromInput (vtkDataObject *input)
vtkDataRepresentation * SetRepresentationFromInput (vtkDataObject *input)
void RemoveRepresentation (vtkDataRepresentation *rep)
void RemoveRepresentation (vtkAlgorithmOutput *rep)
void RemoveAllRepresentations ()
int GetNumberOfRepresentations ()
vtkDataRepresentation * GetRepresentation (int index=0)
bool IsRepresentationPresent (vtkDataRepresentation *rep)
vtkCommand * GetObserver ()
void RegisterProgress (vtkObject *algorithm, const char *message=NULL)
void UnRegisterProgress (vtkObject *algorithm)
static vtkPVRenderView * New ()
static vtkPVRenderView * SafeDownCast (vtkObject *o)
static vtkInformationIntegerKey * USE_LOD ()
 USE_LOD indicates if LOD is being used for the current render/update. More...
static vtkInformationDoubleKey * LOD_RESOLUTION ()
 Indicates the LOD resolution in REQUEST_UPDATE_LOD() pass. More...
static vtkInformationIntegerKey * USE_OUTLINE_FOR_LOD ()
 Indicates the LOD must use outline if possible in REQUEST_UPDATE_LOD() pass. More...
static vtkInformationIntegerKey * RENDER_EMPTY_IMAGES ()
 Representation can publish this key in their REQUEST_INFORMATION() pass to indicate that the representation needs to disable IceT's empty image optimization. More...
static vtkInformationIntegerKey * NEED_ORDERED_COMPOSITING ()
 Representation can publish this key in their REQUEST_INFORMATION() pass to indicate that the representation needs ordered compositing. More...
static vtkInformationDoubleVectorKey * VIEW_PLANES ()
 Key used to pass meta-data about the view frustum in REQUEST_STREAMING_UPDATE() pass. More...
static vtkInformationRequestKey * REQUEST_STREAMING_UPDATE ()
 Streaming pass request. More...
static vtkInformationRequestKey * REQUEST_PROCESS_STREAMED_PIECE ()
 Pass to relay the streamed "piece" to the representations. More...
static void SetDeliverToAllProcesses (vtkInformation *info, vtkPVDataRepresentation *repr, bool clone)
 Requests the view to deliver the pieces produced by the repr to all processes after a gather to the root node to merge the datasets generated by each process. More...
static void SetDeliverToClientAndRenderingProcesses (vtkInformation *info, vtkPVDataRepresentation *repr, bool deliver_to_client, bool gather_before_delivery, int port=0)
 Requests the view to deliver the data to the client always. More...
static vtkAlgorithmOutput * GetPieceProducer (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
 Convenience methods used by representations to pass represented data. More...
static vtkAlgorithmOutput * GetPieceProducerLOD (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static void SetRedistributionMode (vtkInformation *info, vtkPVDataRepresentation *repr, int mode, int port=0)
static void SetRedistributionModeToSplitBoundaryCells (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static void SetRedistributionModeToDuplicateBoundaryCells (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static void SetRedistributionModeToUniquelyAssignBoundaryCells (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static void SetGeometryBounds (vtkInformation *info, vtkPVDataRepresentation *repr, const double bounds[6], vtkMatrix4x4 *transform=nullptr, int port=0)
static void SetStreamable (vtkInformation *info, vtkPVDataRepresentation *repr, bool streamable)
static void SetNextStreamedPiece (vtkInformation *info, vtkPVDataRepresentation *repr, vtkDataObject *piece)
static vtkDataObject * GetCurrentStreamedPiece (vtkInformation *info, vtkPVDataRepresentation *repr)
static void SetRequiresDistributedRendering (vtkInformation *info, vtkPVDataRepresentation *repr, bool value, bool for_lod=false)
 Some representation only work when remote rendering or local rendering. More...
static void SetRequiresDistributedRenderingLOD (vtkInformation *info, vtkPVDataRepresentation *repr, bool value)
static vtkPVCameraCollection * GetDiscreteCameras (vtkInformation *info, vtkPVDataRepresentation *repr)
 DiscreteCameras are a collection of cameras when specified, forces the view to only interact to a camera in the collection. More...
static void SetDiscreteCameras (vtkInformation *info, vtkPVDataRepresentation *repr, vtkPVCameraCollection *style)
- Static Public Member Functions inherited from vtkPVView
static vtkPVView * SafeDownCast (vtkObject *o)
static void SetEnableStreaming (bool)
static bool GetEnableStreaming ()
static vtkInformationObjectBaseKey * VIEW ()
 Key used to pass the vtkPVView pointer to the representation during any of the view passes such as REQUEST_UPDATE(), REQUEST_UPDATE_LOD(), REQUEST_RENDER(), etc. More...
static vtkInformationRequestKey * REQUEST_UPDATE ()
 This is a Update-Data pass. More...
static vtkInformationRequestKey * REQUEST_UPDATE_LOD ()
 This is a Update-LOD-Data pass. More...
static vtkInformationRequestKey * REQUEST_RENDER ()
 This is a render pass. More...
static void SetPiece (vtkInformation *info, vtkPVDataRepresentation *repr, vtkDataObject *data, unsigned long trueSize=0, int port=0)
static vtkDataObject * GetPiece (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static vtkDataObject * GetDeliveredPiece (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static void SetPieceLOD (vtkInformation *info, vtkPVDataRepresentation *repr, vtkDataObject *data, unsigned long trueSize=0, int port=0)
static vtkDataObject * GetPieceLOD (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static vtkDataObject * GetDeliveredPieceLOD (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0)
static void SetUseGenericOpenGLRenderWindow (bool val)
 Use this to indicate that the process should use vtkGenericOpenGLRenderWindow rather than vtkRenderWindow when creating an new render window. More...
static bool GetUseGenericOpenGLRenderWindow ()
- Static Public Member Functions inherited from vtkView
static vtkView * New ()
static vtkView * SafeDownCast (vtkObjectBase *o)
 vtkPVRenderView ()
 ~vtkPVRenderView () override
virtual void Render (bool interactive, bool skip_rendering)
 Actual render method. More...
virtual void AboutToRenderOnLocalProcess (bool interactive)
 Called just before the local process renders. More...
bool ShouldUseDistributedRendering (double geometry_size, bool using_lod)
 Returns true if distributed rendering should be used based on the geometry size. More...
bool ShouldUseLODRendering (double geometry)
 Returns true if LOD rendering should be used based on the geometry size. More...
bool IsProcessRenderingGeometriesForCompositing (bool using_distributed_rendering)
 Returns true if the local process is invovled in rendering composited geometry i.e. More...
void SetLastSelection (vtkSelection *)
 Set the last selection object. More...
virtual void UpdateCenterAxes ()
 UpdateCenterAxes(). More...
bool GetLocalProcessDoesRendering (bool using_distributed_rendering)
 Returns true if the local process is doing to do actual render or displaying an image in a viewport. More...
bool TestCollaborationCounter ()
 In multi-clients mode, ensures that all processes are in the same "state" as far as the view is concerned. More...
void SynchronizeForCollaboration ()
 Synchronizes remote-rendering related parameters for collaborative rendering in multi-clients mode. More...
virtual void BuildAnnotationText (ostream &str)
 Method to build annotation text to annotate the view with runtime information. More...
virtual bool PrepareSelect (int fieldAssociation, const char *array=nullptr)
 Prepare for selection. More...
virtual void PostSelect (vtkSelection *sel, const char *array=nullptr)
 Post process after selection. More...
virtual void UpdateBackground (vtkRenderer *renderer=nullptr)
 Updates background color. More...
void ConfigureTexture (vtkTexture *texture)
 Configure texture based on scalar type. More...
virtual void SetupAndSetRenderer (vtkRenderer *ren)
 Set the 3D renderer to use within the render view. More...
virtual unsigned int GetSynchronizationCounter ()
 SynchronizationCounter is used in multi-clients mode to ensure that the views on two different clients are in the same state as the server side. More...
virtual bool GetMakingSelection ()
 Returns true is currently generating a selection. More...
- Protected Member Functions inherited from vtkPVView
 vtkPVView (bool create_render_window=true)
 ~vtkPVView () override
vtkRenderWindow * NewRenderWindow ()
 Subclasses should use this method to create new render windows instead of directly creating a new one. More...
void SetRenderWindow (vtkRenderWindow *)
 Subclasses can use this method to set the render window created for this view. More...
void AllReduce (const vtkBoundingBox &source, vtkBoundingBox &dest)
 Reduce bounding box between all participating processes. More...
void AllReduce (vtkTypeUInt64 source, vtkTypeUInt64 &dest, int operation, bool skip_data_server=false)
 Reduce between all participating processes using the operation (vtkCommunicator::StandardOperations) specified. More...
vtkPVSession * GetSession ()
virtual bool GetInCaptureScreenshot ()
 Flag set to true between calls to PrepareForScreenshot and CleanupAfterScreenshot. More...
void SynchronizeRepresentationTemporalPipelineStates ()
 Called in Update() to sync HasTemporalPipeline flags between representations on all processes. More...
void AddRepresentationInternal (vtkDataRepresentation *rep) override
 Overridden to assign IDs to each representation. More...
void RemoveRepresentationInternal (vtkDataRepresentation *rep) override
int CallProcessViewRequest (vtkInformationRequestKey *passType, vtkInformation *request, vtkInformationVector *reply)
 Subclasses can use this method to trigger a pass on all representations. More...
- Protected Member Functions inherited from vtkView
 vtkView ()
 ~vtkView ()
virtual vtkDataRepresentation * CreateDefaultRepresentation (vtkAlgorithmOutput *conn)
virtual void AddRepresentationInternal (vtkDataRepresentation *vtkNotUsed(rep))
virtual void RemoveRepresentationInternal (vtkDataRepresentation *vtkNotUsed(rep))
virtual void SetReuseSingleRepresentation (bool)
virtual bool GetReuseSingleRepresentation ()
virtual void ReuseSingleRepresentationOn ()
virtual void ReuseSingleRepresentationOff ()
vtkLightKit * LightKit
vtkRenderViewBase * RenderView
vtkRenderer * NonCompositedRenderer
vtkPVSynchronizedRenderer * SynchronizedRenderers
vtkSmartPointer< vtkRenderWindowInteractor > Interactor
vtkInteractorStyleRubberBand3D * RubberBandStyle
vtkInteractorStyleRubberBandZoom * RubberBandZoom
vtkInteractorStyleDrawPolygon * PolygonStyle
vtkPVCenterAxesActor * CenterAxes
vtkPVAxesWidget * OrientationWidget
vtkSmartPointer< vtkPVHardwareSelector > Selector
vtkSelection * LastSelection
vtkSmartPointer< vtkPVGridAxes3DActor > GridAxes3DActor
vtkSmartPointer< vtkLegendScaleActor > LegendGridActor
vtkNew< vtkSkybox > Skybox
vtkNew< vtkCameraOrientationWidget > CameraOrientationWidget
int StillRenderImageReductionFactor
int InteractiveRenderImageReductionFactor
int InteractionMode
bool ShowAnnotation
bool UpdateAnnotation
bool SuppressRendering
vtkPVInteractorStyle * TwoDInteractorStyle
vtkPVInteractorStyle * ThreeDInteractorStyle
bool ReverseMouseWheelZoomDirection = false
vtkPVInteractorStyle * InteractorStyle
vtkWeakPointer< vtkPVCameraCollection > DiscreteCameras
unsigned int SynchronizationCounter
double RemoteRenderingThreshold
double LODRenderingThreshold
vtkBoundingBox GeometryBounds
bool UseInteractiveRenderingForScreenshots
bool NeedsOrderedCompositing
bool RenderEmptyImages
bool UseFXAA
vtkNew< vtkFXAAOptions > FXAAOptions
bool UseToneMapping
bool UseSSAO
bool UseSSAODefaultPresets
double Radius
int KernelSize
double Bias
bool Blur
double LODResolution
bool UseLightKit
bool UsedLODForLastRender
bool UseLODForInteractiveRender
bool UseOutlineForLODRendering
bool UseDistributedRenderingForRender
bool UseDistributedRenderingForLODRender
vtkTypeUInt32 StillRenderProcesses
vtkTypeUInt32 InteractiveRenderProcesses
vtkTimeStamp PriorityQueueBuildTimeStamp
 Keeps track of the time when the priority-queue for streaming was generated. More...
bool LockBounds
- Protected Attributes inherited from vtkPVView
double ViewTime
double CacheKey
bool UseCache
int Size [2]
int Position [2]
int PPI
vtkTimeStamp UpdateTimeStamp
 Keeps track of the time when vtkPVRenderView::Update() was called. More...
vtkInformation * RequestInformation
 These are passed as arguments to vtkDataRepresentation::ProcessViewRequest(). More...
vtkInformationVector * ReplyInformationVector
- Protected Attributes inherited from vtkView
bool ReuseSingleRepresentation
double LastRepresentationVisibleBounds [6]
 Compute and reduce the visible bounds of the provided representation. More...
double * ComputeVisibleBounds (vtkPVDataRepresentation *pvrepr) VTK_SIZEHINT(6)
enum  { USE_BOUNDS_FOR_REDISTRIBUTION = 0x01, DATA_IS_REDISTRIBUTABLE = 0x02, USE_DATA_FOR_LOAD_BALANCING = 0x40 }
 OrderedCompositingConfiguration lets representations indicate to the view how the representation participates in data-redistribution necessary when ordered-compositing is being used. More...
static void SetOrderedCompositingConfiguration (vtkInformation *info, vtkPVDataRepresentation *repr, int config, const double *bounds=nullptr, int port=0)
static void SetForceDataDistributionMode (vtkInformation *info, int flag)
 This is an temporary/experimental option and may be removed without notice. More...
bool IsForceDataDistributionModeSet () const
int GetForceDataDistributionMode () const
- Static Protected Member Functions inherited from vtkPVView
static vtkPVDataDeliveryManager * GetDeliveryManager (vtkInformation *info)
vtkRenderView equivalent that is specialized for ParaView. vtkRenderView handles polygonal rendering for ParaView in all the different modes of operation. vtkPVRenderView instance must be created on all involved processes. vtkPVRenderView uses the information about what process it has been created on to decide what part of the "rendering" happens on the process.
Definition at line 64 of file vtkPVRenderView.h.
Definition at line 69 of file vtkPVRenderView.h.
◆ InteractionModes
Enumerator
INTERACTION_MODE_3D
INTERACTION_MODE_2D
Definition at line 72 of file vtkPVRenderView.h.
◆ anonymous enum
anonymous enum
Enumerator
DEFAULT_RENDERER
Definition at line 119 of file vtkPVRenderView.h.
◆ anonymous enum
anonymous enum
These flags are meant to be combined together using bit-wise-OR.
If not specified, default is 0 i.e. the representation data will be left untouched. Except for trivial representations or representations that have their full rendering geometry available on all rendering ranks, this is not recommended.
DATA_IS_REDISTRIBUTABLE indicates that the view may redistribute the rendering data from this representation as needed. This is typical for representation rendering poly-data or unstructured grids.
USE_DATA_FOR_LOAD_BALANCING indicates that when building a sortable distribution for the data, it should use this representation data. If not set, the representation will not contribute to the algorithm that builds the kd-tree used to split data across rendering ranks.
USE_BOUNDS_FOR_REDISTRIBUTION may be used when the data is too heavy to move (i.e DATA_IS_REDISTRIBUTABLE is not true) and is already split across ranks in a sortable fashion. In that case, this indicates the view must use the spatial partitioning of this representation's data and move other data accordingly. This flag cannot be combined with DATA_IS_REDISTRIBUTABLE or USE_BOUNDS_FOR_REDISTRIBUTION.
Enumerator
Definition at line 499 of file vtkPVRenderView.h.
◆ BackgroundMode
Enumerator
DEFAULT
GRADIENT
SKYBOX
STEREO_SKYBOX
Definition at line 703 of file vtkPVRenderView.h.
◆ GenericFilmicPresets
Enumerator
Custom
Default
Uncharted2
Definition at line 894 of file vtkPVRenderView.h.
◆ vtkPVRenderView()
vtkPVRenderView::vtkPVRenderView ( )
◆ ~vtkPVRenderView()
vtkPVRenderView::~vtkPVRenderView ( )
static vtkPVRenderView* vtkPVRenderView::New ( )
virtual const char* vtkPVRenderView::GetClassName ( )
static int vtkPVRenderView::IsTypeOf ( const char *  type)
virtual int vtkPVRenderView::IsA ( const char *  type)
static vtkPVRenderView* vtkPVRenderView::SafeDownCast ( vtkObject *  o)
void vtkPVRenderView::PrintSelf ( ostream &  os,
Reimplemented from vtkView.
Reimplemented in vtkPVRenderViewWithEDL.
◆ SetInteractionMode()
virtual void vtkPVRenderView::SetInteractionMode ( int  mode)
Default is INTERACTION_MODE_3D. If INTERACTION_MODE_SELECTION is selected, then whenever the user drags and creates a selection region, this class will fire a vtkCommand::SelectionChangedEvent event with the selection region as the argument.
Note
CallOnAllProcesses
this must be called on all processes, however it will have any effect only the driver processes i.e. the process with the interactor.
Reimplemented in vtkPVOrthographicSliceView.
◆ GetInteractionMode()
virtual int vtkPVRenderView::GetInteractionMode ( )
Note
CallOnAllProcesses
◆ SetSize()
void vtkPVRenderView::SetSize ( int  ,
int
Reimplemented from vtkPVView.
◆ SetPosition()
void vtkPVRenderView::SetPosition ( int  ,
int
◆ GetNonCompositedRenderer()
virtual vtkRenderer* vtkPVRenderView::GetNonCompositedRenderer ( )
This is typically used for labels, 2D annotations etc.
Note
CallOnAllProcesses
◆ GetRenderer()
virtual vtkRenderer* vtkPVRenderView::GetRenderer ( int  rendererType = DEFAULT_RENDERER)
  • DEFAULT_RENDERER: returns the 3D renderer.
  • NON_COMPOSITED_RENDERER: returns the NonCompositedRenderer.
◆ GetActiveCamera()
vtkCamera* vtkPVRenderView::GetActiveCamera ( )
The active camera is set on both the composited and non-composited renderer.
◆ SetActiveCamera()
virtual void vtkPVRenderView::SetActiveCamera ( vtkCamera *  )
◆ GetInteractor()
vtkRenderWindowInteractor* vtkPVRenderView::GetInteractor ( )
◆ SetupInteractor()
virtual void vtkPVRenderView::SetupInteractor ( vtkRenderWindowInteractor *  )
Set the interactor.
Client applications must set the interactor to enable interactivity. Note this method will also change the interactor styles set on the interactor.
◆ GetInteractorStyle()
virtual vtkPVInteractorStyle* vtkPVRenderView::GetInteractorStyle ( )
◆ ResetCamera() [1/2]
void vtkPVRenderView::ResetCamera ( )
OffsetRatio can be used to add a zoom offset.
Note
CallOnAllProcesses
◆ ResetCamera() [2/2]
void vtkPVRenderView::ResetCamera ( double  bounds[6])
Note
CallOnAllProcesses
◆ ResetCameraScreenSpace() [1/2]
void vtkPVRenderView::ResetCameraScreenSpace ( double  offsetRatio = 0.9)
Note
CallOnAllProcesses
◆ ResetCameraScreenSpace() [2/2]
void vtkPVRenderView::ResetCameraScreenSpace ( double *  bounds,
Note
CallOnAllProcesses
◆ ComputeVisibleBounds()
double* vtkPVRenderView::ComputeVisibleBounds ( vtkPVDataRepresentation *  pvrepr)
Uses LastRepresentationVisibleBounds to store the result until the next call.
Note
CallOnAllProcesses
◆ StillRender()
void vtkPVRenderView::StillRender ( )
Note
Can be called on processes involved in rendering i.e those returned by this->GetStillRenderProcesses().
Implements vtkPVView.
◆ InteractiveRender()
void vtkPVRenderView::InteractiveRender ( )
Based on the settings on the view, this may result in a low-resolution rendering or a simplified geometry rendering.
Note
Can be called on processes involved in rendering i.e those returned by this->GetInteractiveRenderProcesses().
◆ SetSuppressRendering()
virtual void vtkPVRenderView::SetSuppressRendering ( bool  )
This is useful in cases where you want the representations mappers to be setup for rendering and have their data ready but not actually do the render. For example if you want to export the scene but not render it you must turn on SuppressRendering and then call StillRender
◆ GetSuppressRendering()
virtual bool vtkPVRenderView::GetSuppressRendering ( )
◆ SuppressRenderingOn()
virtual void vtkPVRenderView::SuppressRenderingOn ( )
◆ SuppressRenderingOff()
virtual void vtkPVRenderView::SuppressRenderingOff ( )
◆ SetStillRenderImageReductionFactor()
virtual void vtkPVRenderView::SetStillRenderImageReductionFactor ( int  )
This is typically set to 1, but in some cases with terrible connectivity or really large displays, one may want to use a sub-sampled image even for StillRender(). This is set it number of pixels to be sub-sampled by. Note that image reduction factors have no effect when in built-in mode.
Note
CallOnAllProcesses
◆ GetStillRenderImageReductionFactor()
virtual int vtkPVRenderView::GetStillRenderImageReductionFactor ( )
Note
CallOnAllProcesses
◆ SetInteractiveRenderImageReductionFactor()
virtual void vtkPVRenderView::SetInteractiveRenderImageReductionFactor ( int  )
Note
CallOnAllProcesses
◆ GetInteractiveRenderImageReductionFactor()
virtual int vtkPVRenderView::GetInteractiveRenderImageReductionFactor ( )
Note
CallOnAllProcesses
◆ SetRemoteRenderingThreshold()
virtual void vtkPVRenderView::SetRemoteRenderingThreshold ( double  )
Note
CallOnAllProcesses
◆ GetRemoteRenderingThreshold()
virtual double vtkPVRenderView::GetRemoteRenderingThreshold ( )
Note
CallOnAllProcesses
◆ SetLODRenderingThreshold()
virtual void vtkPVRenderView::SetLODRenderingThreshold ( double  )
Note
CallOnAllProcesses
◆ GetLODRenderingThreshold()
virtual double vtkPVRenderView::GetLODRenderingThreshold ( )
Note
CallOnAllProcesses
◆ SetLODResolution()
virtual void vtkPVRenderView::SetLODResolution ( double  )
This affects the size of the grid used for quadric clustering, for example. 1.0 implies maximum resolution while 0 implies minimum resolution.
Note
CallOnAllProcesses
◆ GetLODResolution()
virtual double vtkPVRenderView::GetLODResolution ( )
Note
CallOnAllProcesses
◆ SetUseOutlineForLODRendering()
virtual void vtkPVRenderView::SetUseOutlineForLODRendering ( bool  )
Note that not all representations support this mode and hence one may still see non-outline data being rendering when this flag is ON and LOD is being used.
◆ GetUseOutlineForLODRendering()
virtual bool vtkPVRenderView::GetUseOutlineForLODRendering ( )
◆ ConfigureCompressor()
void vtkPVRenderView::ConfigureCompressor ( const char *  configuration)
This affects the image compression used to relay images back to the client. See vtkPVClientServerSynchronizedRenderers::ConfigureCompressor() for details.
Note
CallOnAllProcesses
◆ ResetCameraClippingRange()
virtual void vtkPVRenderView::ResetCameraClippingRange ( )
One does not need to call this directly ever. It is called periodically by the vtkRenderer to reset the camera range.
◆ SetUseLightKit()
void vtkPVRenderView::SetUseLightKit ( bool  enable)
Note
CallOnAllProcesses
◆ GetUseLightKit()
virtual bool vtkPVRenderView::GetUseLightKit ( )
Note
CallOnAllProcesses
◆ UseLightKitOn()
virtual void vtkPVRenderView::UseLightKitOn ( )
Note
CallOnAllProcesses
◆ UseLightKitOff()
virtual void vtkPVRenderView::UseLightKitOff ( )
Note
CallOnAllProcesses
◆ StreamingUpdate()
void vtkPVRenderView::StreamingUpdate ( const double  view_planes[24])
◆ DeliverStreamedPieces()
void vtkPVRenderView::DeliverStreamedPieces ( unsigned int  size,
unsigned int *  representation_ids
◆ USE_LOD()
static vtkInformationIntegerKey* vtkPVRenderView::USE_LOD ( )
◆ LOD_RESOLUTION()
static vtkInformationDoubleKey* vtkPVRenderView::LOD_RESOLUTION ( )
◆ USE_OUTLINE_FOR_LOD()
static vtkInformationIntegerKey* vtkPVRenderView::USE_OUTLINE_FOR_LOD ( )
◆ RENDER_EMPTY_IMAGES()
static vtkInformationIntegerKey* vtkPVRenderView::RENDER_EMPTY_IMAGES ( )
This is typically only needed if a painter will make use of MPI global collective communications.
◆ NEED_ORDERED_COMPOSITING()
static vtkInformationIntegerKey* vtkPVRenderView::NEED_ORDERED_COMPOSITING ( )
◆ VIEW_PLANES()
static vtkInformationDoubleVectorKey* vtkPVRenderView::VIEW_PLANES ( )
The value is a double vector with exactly 24 values.
◆ REQUEST_STREAMING_UPDATE()
static vtkInformationRequestKey* vtkPVRenderView::REQUEST_STREAMING_UPDATE ( )
◆ REQUEST_PROCESS_STREAMED_PIECE()
static vtkInformationRequestKey* vtkPVRenderView::REQUEST_PROCESS_STREAMED_PIECE ( )
◆ SelectCells() [1/2]
void vtkPVRenderView::SelectCells ( int  region[4],
const char *  array = nullptr
Make a selection.
This will result in setting up of this->LastSelection which can be accessed using GetLastSelection().
Note
This method is called on call rendering processes and client (or driver). Thus, if doing client only rendering, this shouldn't be called on server nodes.
◆ SelectCells() [2/2]
void vtkPVRenderView::SelectCells ( int  region0,
int  region1,
int  region2,
int  region3,
inline
Make a selection.
Note
Definition at line 366 of file vtkPVRenderView.h.
◆ SelectPoints() [1/2]
void vtkPVRenderView::SelectPoints ( int  region[4],
Make a selection.
Note
◆ SelectPoints() [2/2]
void vtkPVRenderView::SelectPoints ( int  region0,
int  region1,
int  region2,
int  region3,
inline
Make a selection.
Note
Definition at line 372 of file vtkPVRenderView.h.
◆ Select()
void vtkPVRenderView::Select ( int  field_association,
int  region[4],
Make a selection.
Note
◆ SelectPolygonPoints()
void vtkPVRenderView::SelectPolygonPoints ( int *  polygon2DArray,
vtkIdType  arrayLen
The polygon2DArray should contain the polygon points in display units of (x, y) tuples, and arrayLen is the total length of polygon2DArray. This will result in setting up of this->LastSelection which can be accessed using GetLastSelection().
Note
◆ SelectPolygonCells()
void vtkPVRenderView::SelectPolygonCells ( int *  polygon2DArray,
vtkIdType  arrayLen
Note
◆ SelectPolygon()
void vtkPVRenderView::SelectPolygon ( int  field_association,
vtkIdType  arrayLen
Note
◆ GetLastSelection()
virtual vtkSelection* vtkPVRenderView::GetLastSelection ( )
This is valid only on the client or driver node displaying the composited result.
◆ SetUseInteractiveRenderingForScreenshots()
virtual void vtkPVRenderView::SetUseInteractiveRenderingForScreenshots ( bool  )
◆ UseInteractiveRenderingForScreenshotsOn()
virtual void vtkPVRenderView::UseInteractiveRenderingForScreenshotsOn ( )
◆ UseInteractiveRenderingForScreenshotsOff()
virtual void vtkPVRenderView::UseInteractiveRenderingForScreenshotsOff ( )
◆ GetUseInteractiveRenderingForScreenshots()
virtual bool vtkPVRenderView::GetUseInteractiveRenderingForScreenshots ( )
◆ GetRemoteRenderingAvailable()
virtual bool vtkPVRenderView::GetRemoteRenderingAvailable ( )
◆ RemoteRenderingAvailableOff()
void vtkPVRenderView::RemoteRenderingAvailableOff ( )
inline
Definition at line 419 of file vtkPVRenderView.h.
◆ NVPipeAvailableOn()
void vtkPVRenderView::NVPipeAvailableOn ( )
◆ NVPipeAvailableOff()
void vtkPVRenderView::NVPipeAvailableOff ( )
◆ GetUsedLODForLastRender()
virtual bool vtkPVRenderView::GetUsedLODForLastRender ( )
◆ InvalidateCachedSelection()
void vtkPVRenderView::InvalidateCachedSelection ( )
Called explicitly when view proxy thinks the cache may have become obsolete.
Note
CallOnAllProcesses
◆ GetPieceProducer()
static vtkAlgorithmOutput* vtkPVRenderView::GetPieceProducer ( vtkInformation *  info,
vtkPVDataRepresentation *  repr,
int  port = 0
If trueSize is non-zero, then that's the size used in making decisions about LOD/remote rendering etc and not the actual size of the dataset.
◆ GetPieceProducerLOD()
static vtkAlgorithmOutput* vtkPVRenderView::GetPieceProducerLOD ( vtkInformation *  info,
int  port = 0
◆ SetRedistributionMode()
static void vtkPVRenderView::SetRedistributionMode ( vtkInformation *  info,
int  mode,
int  port = 0
◆ SetRedistributionModeToSplitBoundaryCells()
static void vtkPVRenderView::SetRedistributionModeToSplitBoundaryCells ( vtkInformation *  info,
int  port = 0
◆ SetRedistributionModeToDuplicateBoundaryCells()
static void vtkPVRenderView::SetRedistributionModeToDuplicateBoundaryCells ( vtkInformation *  info,
int  port = 0
◆ SetRedistributionModeToUniquelyAssignBoundaryCells()
static void vtkPVRenderView::SetRedistributionModeToUniquelyAssignBoundaryCells ( vtkInformation *  info,
int  port = 0
◆ SetGeometryBounds()
static void vtkPVRenderView::SetGeometryBounds ( vtkInformation *  info,
vtkMatrix4x4 *  transform = nullptr,
int  port = 0
◆ SetStreamable()
static void vtkPVRenderView::SetStreamable ( vtkInformation *  info,
bool  streamable
◆ SetNextStreamedPiece()
static void vtkPVRenderView::SetNextStreamedPiece ( vtkInformation *  info,
vtkDataObject *  piece
◆ GetCurrentStreamedPiece()
static vtkDataObject* vtkPVRenderView::GetCurrentStreamedPiece ( vtkInformation *  info,
◆ SetOrderedCompositingConfiguration()
static void vtkPVRenderView::SetOrderedCompositingConfiguration ( vtkInformation *  info,
int  config,
const double *  bounds = nullptr,
int  port = 0
◆ SetMaxClipBounds()
void vtkPVRenderView::SetMaxClipBounds ( double  bds[6])
Called with the global (visible and invisible) bounds at start of export.
◆ SetLockBounds()
void vtkPVRenderView::SetLockBounds ( bool  nv)
Prevents ParaView from changing depth scaling over course of an export.
◆ GetLockBounds()
virtual bool vtkPVRenderView::GetLockBounds ( )
◆ SetDeliverToAllProcesses()
static void vtkPVRenderView::SetDeliverToAllProcesses ( vtkInformation *  info,
bool  clone
◆ SetDeliverToClientAndRenderingProcesses()
static void vtkPVRenderView::SetDeliverToClientAndRenderingProcesses ( vtkInformation *  info,
int  port = 0
This is essential for representation that render in the non-composited views e.g. the text-source representation. If SetDeliverToAllProcesses() is true, this is redundant. gather_before_delivery can be used to indicate if the data on the server-nodes must be gathered to the root node before shipping to the client. If gather_before_delivery is false, only the data from the root node will be sent to the client without any parallel communication.
◆ SetRequiresDistributedRendering()
static void vtkPVRenderView::SetRequiresDistributedRendering ( vtkInformation *  info,
bool  value,
bool  for_lod = false
Use this method in REQUEST_UPDATE() pass to tell the view if the representation requires a particular mode. Note, only use this to "require" a remote or local render. value == true indicates that the representation requires distributed rendering, value == false indicates the representation can only render property on the client or root node.
◆ SetRequiresDistributedRenderingLOD()
static void vtkPVRenderView::SetRequiresDistributedRenderingLOD ( vtkInformation *  info,
bool  value
inlinestatic
Definition at line 556 of file vtkPVRenderView.h.
◆ SetForceDataDistributionMode()
static void vtkPVRenderView::SetForceDataDistributionMode ( vtkInformation *  info,
int  flag
This is intended to be used within some experimental representations that require that all data being moved around uses a specific mode rather than the one automatically determined based on the process type. Set flag to -1 to clear. The flag is cleared in every vtkPVRenderView::Update() call, hence a representation must set it in vtkPVView::REQUEST_UPDATE() pass if needed each time. Also note, if the value it set to non-negative and is not equal to vtkMPIMoveData::PASS_THROUGH, ordered compositing will also be disabled.
◆ IsForceDataDistributionModeSet()
bool vtkPVRenderView::IsForceDataDistributionModeSet ( ) const
inline
Definition at line 577 of file vtkPVRenderView.h.
◆ GetForceDataDistributionMode()
int vtkPVRenderView::GetForceDataDistributionMode ( ) const
inline
Definition at line 578 of file vtkPVRenderView.h.
◆ RegisterPropForHardwareSelection()
int vtkPVRenderView::RegisterPropForHardwareSelection ( vtkPVDataRepresentation *  repr,
vtkProp *  prop
They can do that in the vtkPVDataRepresentation::AddToView() implementation.
◆ UnRegisterPropForHardwareSelection()
void vtkPVRenderView::UnRegisterPropForHardwareSelection ( vtkPVDataRepresentation *  repr,
vtkProp *  prop
◆ SetShowAnnotation()
void vtkPVRenderView::SetShowAnnotation ( bool  val)
◆ SetUpdateAnnotation()
virtual void vtkPVRenderView::SetUpdateAnnotation ( bool  )
◆ SetAnnotationColor()
void vtkPVRenderView::SetAnnotationColor ( double  r,
double  g,
double  b
◆ SetGridAxes3DActor()
virtual void vtkPVRenderView::SetGridAxes3DActor ( vtkPVGridAxes3DActor *  )
◆ SetLegendGridActor()
virtual void vtkPVRenderView::SetLegendGridActor ( vtkLegendScaleActor *  )
◆ SetOrientationAxesInteractivity()
virtual void vtkPVRenderView::SetOrientationAxesInteractivity ( bool  )
◆ SetOrientationAxesVisibility()
virtual void vtkPVRenderView::SetOrientationAxesVisibility ( bool  )
◆ SetOrientationAxesLabelColor()
void vtkPVRenderView::SetOrientationAxesLabelColor ( double  r,
double  g,
double  b
◆ SetOrientationAxesOutlineColor()
void vtkPVRenderView::SetOrientationAxesOutlineColor ( double  r,
double  g,
double  b
◆ SetOrientationAxesXColor()
void vtkPVRenderView::SetOrientationAxesXColor ( double  r,
double  g,
double  b
◆ SetOrientationAxesYColor()
void vtkPVRenderView::SetOrientationAxesYColor ( double  r,
double  g,
double  b
◆ SetOrientationAxesZColor()
void vtkPVRenderView::SetOrientationAxesZColor ( double  r,
double  g,
double  b
◆ SetOrientationAxesXVisibility()
void vtkPVRenderView::SetOrientationAxesXVisibility ( bool  vis)
◆ SetOrientationAxesYVisibility()
void vtkPVRenderView::SetOrientationAxesYVisibility ( bool  vis)
◆ SetOrientationAxesZVisibility()
void vtkPVRenderView::SetOrientationAxesZVisibility ( bool  vis)
◆ SetOrientationAxesXLabelText()
void vtkPVRenderView::SetOrientationAxesXLabelText ( const char *  text)
◆ SetOrientationAxesYLabelText()
void vtkPVRenderView::SetOrientationAxesYLabelText ( const char *  text)
◆ SetOrientationAxesZLabelText()
void vtkPVRenderView::SetOrientationAxesZLabelText ( const char *  text)
◆ SetCameraOrientationWidgetVisibility()
void vtkPVRenderView::SetCameraOrientationWidgetVisibility ( bool  visible)
◆ SetCameraOrientationWidgetSize()
void vtkPVRenderView::SetCameraOrientationWidgetSize ( int  size)
◆ SetCameraOrientationWidgetPadding()
void vtkPVRenderView::SetCameraOrientationWidgetPadding ( int  padding[2])
◆ SetCameraOrientationWidgetAnchor()
void vtkPVRenderView::SetCameraOrientationWidgetAnchor ( int  anchor)
◆ SetCenterAxesVisibility()
virtual void vtkPVRenderView::SetCenterAxesVisibility ( bool  )
◆ SetCenterOfRotation()
virtual void vtkPVRenderView::SetCenterOfRotation ( double  x,
double  y,
double  z
◆ SetRotationFactor()
virtual void vtkPVRenderView::SetRotationFactor ( double  factor)
◆ SetKeyLightWarmth()
void vtkPVRenderView::SetKeyLightWarmth ( double  val)
◆ SetKeyLightIntensity()
void vtkPVRenderView::SetKeyLightIntensity ( double  val)
◆ SetKeyLightElevation()
void vtkPVRenderView::SetKeyLightElevation ( double  val)
◆ SetKeyLightAzimuth()
void vtkPVRenderView::SetKeyLightAzimuth ( double  val)
◆ SetFillLightWarmth()
void vtkPVRenderView::SetFillLightWarmth ( double  val)
◆ SetKeyToFillRatio()
void vtkPVRenderView::SetKeyToFillRatio ( double  val)
◆ SetFillLightElevation()
void vtkPVRenderView::SetFillLightElevation ( double  val)
◆ SetFillLightAzimuth()
void vtkPVRenderView::SetFillLightAzimuth ( double  val)
◆ SetBackLightWarmth()
void vtkPVRenderView::SetBackLightWarmth ( double  val)
◆ SetKeyToBackRatio()
void vtkPVRenderView::SetKeyToBackRatio ( double  val)
◆ SetBackLightElevation()
void vtkPVRenderView::SetBackLightElevation ( double  val)
◆ SetBackLightAzimuth()
void vtkPVRenderView::SetBackLightAzimuth ( double  val)
◆ SetHeadLightWarmth()
void vtkPVRenderView::SetHeadLightWarmth ( double  val)
◆ SetKeyToHeadRatio()
void vtkPVRenderView::SetKeyToHeadRatio ( double  val)
◆ SetMaintainLuminance()
void vtkPVRenderView::SetMaintainLuminance ( int  val)
◆ SetUseHiddenLineRemoval()
virtual void vtkPVRenderView::SetUseHiddenLineRemoval ( bool  )
◆ SetUseDepthPeeling()
virtual void vtkPVRenderView::SetUseDepthPeeling ( int  val)
◆ SetUseDepthPeelingForVolumes()
virtual void vtkPVRenderView::SetUseDepthPeelingForVolumes ( bool  val)
◆ SetMaximumNumberOfPeels()
virtual void vtkPVRenderView::SetMaximumNumberOfPeels ( int  val)
◆ SetBackgroundTexture()
virtual void vtkPVRenderView::SetBackgroundTexture ( vtkTexture *  val)
◆ SetUseRenderViewSettingsForBackground()
virtual void vtkPVRenderView::SetUseRenderViewSettingsForBackground ( bool  )
◆ GetUseRenderViewSettingsForBackground()
virtual bool vtkPVRenderView::GetUseRenderViewSettingsForBackground ( )
◆ SetBackgroundColorMode()
virtual void vtkPVRenderView::SetBackgroundColorMode ( int  )
See also
BackgroundMode
◆ SetBackground() [1/2]
virtual void vtkPVRenderView::SetBackground ( double  ,
double  ,
double
See also
BackgroundMode
◆ SetBackground() [2/2]
virtual void vtkPVRenderView::SetBackground ( double  [3])
See also
BackgroundMode
◆ GetBackground() [1/3]
virtual double* vtkPVRenderView::GetBackground ( )
See also
BackgroundMode
◆ GetBackground() [2/3]
virtual void vtkPVRenderView::GetBackground ( double &  ,
double &  ,
double &
See also
BackgroundMode
◆ GetBackground() [3/3]
virtual void vtkPVRenderView::GetBackground ( double  [3])
See also
BackgroundMode
◆ SetBackground2() [1/2]
virtual void vtkPVRenderView::SetBackground2 ( double  ,
double  ,
double
See also
BackgroundMode
◆ SetBackground2() [2/2]
virtual void vtkPVRenderView::SetBackground2 ( double  [3])
See also
BackgroundMode
◆ GetBackground2() [1/3]
virtual double* vtkPVRenderView::GetBackground2 ( )
See also
BackgroundMode
◆ GetBackground2() [2/3]
virtual void vtkPVRenderView::GetBackground2 ( double &  ,
double &  ,
double &
See also
BackgroundMode
◆ GetBackground2() [3/3]
virtual void vtkPVRenderView::GetBackground2 ( double  [3])
See also
BackgroundMode
◆ SetUseEnvironmentLighting()
virtual void vtkPVRenderView::SetUseEnvironmentLighting ( bool  )
See also
BackgroundMode
◆ SetEnvironmentalBG()
virtual void vtkPVRenderView::SetEnvironmentalBG ( double  r,
double  g,
double  b
◆ SetEnvironmentalBG2()
virtual void vtkPVRenderView::SetEnvironmentalBG2 ( double  r,
double  g,
double  b
◆ SetEnvironmentalBGTexture()
virtual void vtkPVRenderView::SetEnvironmentalBGTexture ( vtkTexture *  val)
◆ SetGradientEnvironmentalBG()
virtual void vtkPVRenderView::SetGradientEnvironmentalBG ( int  val)
◆ SetTexturedEnvironmentalBG()
virtual void vtkPVRenderView::SetTexturedEnvironmentalBG ( int  val)
◆ SetBackgroundMode()
virtual void vtkPVRenderView::SetBackgroundMode ( int  val)
◆ AddLight()
void vtkPVRenderView::AddLight ( vtkLight *  )
◆ RemoveLight()
void vtkPVRenderView::RemoveLight ( vtkLight *  )
◆ SetStereoCapableWindow()
void vtkPVRenderView::SetStereoCapableWindow ( int  val)
◆ SetStereoRender()
void vtkPVRenderView::SetStereoRender ( int  val)
◆ SetStereoType()
virtual void vtkPVRenderView::SetStereoType ( int  )
◆ SetServerStereoType()
virtual void vtkPVRenderView::SetServerStereoType ( int  )
◆ SetMultiSamples()
void vtkPVRenderView::SetMultiSamples ( int  val)
◆ SetAlphaBitPlanes()
void vtkPVRenderView::SetAlphaBitPlanes ( int  val)
◆ SetStencilCapable()
void vtkPVRenderView::SetStencilCapable ( int  val)
◆ SetParallelProjection()
void vtkPVRenderView::SetParallelProjection ( int  mode)
◆ SetCamera2DManipulators()
virtual void vtkPVRenderView::SetCamera2DManipulators ( const int  manipulators[9])
◆ SetCamera3DManipulators()
virtual void vtkPVRenderView::SetCamera3DManipulators ( const int  manipulators[9])
◆ SetCameraManipulators()
void vtkPVRenderView::SetCameraManipulators ( vtkPVInteractorStyle *  style,
◆ SetReverseMouseWheelZoomDirection()
virtual void vtkPVRenderView::SetReverseMouseWheelZoomDirection ( bool  reverse)
◆ SetMouseWheelZoomsToCursor()
virtual void vtkPVRenderView::SetMouseWheelZoomsToCursor ( bool  value)
◆ SetCamera2DMouseWheelMotionFactor()
virtual void vtkPVRenderView::SetCamera2DMouseWheelMotionFactor ( double  factor)
◆ SetCamera3DMouseWheelMotionFactor()
virtual void vtkPVRenderView::SetCamera3DMouseWheelMotionFactor ( double  factor)
◆ SynchronizeGeometryBounds()
virtual void vtkPVRenderView::SynchronizeGeometryBounds ( )
Note
CallOnAllProcesses
◆ Update()
void vtkPVRenderView::Update ( )
The vtkSMViewProxy ensures that this method is called only when something has changed on the view-proxy or one of its representations or their inputs. Hence it's okay to do some extra inter-process communication here.
◆ UpdateLOD()
virtual void vtkPVRenderView::UpdateLOD ( )
◆ GetUseLODForInteractiveRender()
virtual bool vtkPVRenderView::GetUseLODForInteractiveRender ( )
◆ GetUseDistributedRenderingForRender()
virtual bool vtkPVRenderView::GetUseDistributedRenderingForRender ( )
This uses the full resolution geometry sizes as determined by the most recent call to Update.
◆ GetUseDistributedRenderingForLODRender()
virtual bool vtkPVRenderView::GetUseDistributedRenderingForLODRender ( )
This uses the low-resolution (or LOD) geometry sizes as determined by the most recent call to UpdateLOD.
◆ GetStillRenderProcesses()
virtual vtkTypeUInt32 vtkPVRenderView::GetStillRenderProcesses ( )
◆ GetInteractiveRenderProcesses()
virtual vtkTypeUInt32 vtkPVRenderView::GetInteractiveRenderProcesses ( )
◆ GetDataDistributionMode()
int vtkPVRenderView::GetDataDistributionMode ( bool  low_res)
◆ Deliver()
void vtkPVRenderView::Deliver ( int  use_lod,
unsigned int  size,
Note this method has to be called on all processes or it may lead to deadlock.
◆ GetUseOrderedCompositing()
bool vtkPVRenderView::GetUseOrderedCompositing ( )
Note that unlike most other functions, this may return different values on different processes e.g.
  • always false on client and dataserver
  • true on pvserver or renderserver if opacity < 1 or volume present, else false
◆ GetRenderEmptyImages()
bool vtkPVRenderView::GetRenderEmptyImages ( )
◆ SetUseFXAA()
virtual void vtkPVRenderView::SetUseFXAA ( bool  )
◆ GetUseFXAA()
virtual bool vtkPVRenderView::GetUseFXAA ( )
◆ SetFXAARelativeContrastThreshold()
void vtkPVRenderView::SetFXAARelativeContrastThreshold ( double  val)
See vtkFXAAOptions for details.
◆ SetFXAAHardContrastThreshold()
void vtkPVRenderView::SetFXAAHardContrastThreshold ( double  val)
◆ SetFXAASubpixelBlendLimit()
void vtkPVRenderView::SetFXAASubpixelBlendLimit ( double  val)
◆ SetFXAASubpixelContrastThreshold()
void vtkPVRenderView::SetFXAASubpixelContrastThreshold ( double  val)
◆ SetFXAAUseHighQualityEndpoints()
void vtkPVRenderView::SetFXAAUseHighQualityEndpoints ( bool  val)
◆ SetFXAAEndpointSearchIterations()
void vtkPVRenderView::SetFXAAEndpointSearchIterations ( int  val)
◆ SetUseToneMapping()
void vtkPVRenderView::SetUseToneMapping ( bool  v)
◆ GetUseToneMapping()
virtual bool vtkPVRenderView::GetUseToneMapping ( )
◆ SetToneMappingType()
void vtkPVRenderView::SetToneMappingType ( int  )
◆ SetExposure()
void vtkPVRenderView::SetExposure ( double  )
◆ SetContrast()
void vtkPVRenderView::SetContrast ( double  )
◆ SetShoulder()
void vtkPVRenderView::SetShoulder ( double  )
◆ SetMidIn()
void vtkPVRenderView::SetMidIn ( double  )
◆ SetMidOut()
void vtkPVRenderView::SetMidOut ( double  )
◆ SetHdrMax()
void vtkPVRenderView::SetHdrMax ( double  )
◆ SetUseACES()
void vtkPVRenderView::SetUseACES ( bool  )
◆ SetGenericFilmicPresets()
void vtkPVRenderView::SetGenericFilmicPresets ( int  t)
◆ SetUseSSAO()
virtual void vtkPVRenderView::SetUseSSAO ( bool  )
SSAO options.
◆ GetUseSSAO()
virtual bool vtkPVRenderView::GetUseSSAO ( )
SSAO options.
◆ SetUseSSAODefaultPresets()
virtual void vtkPVRenderView::SetUseSSAODefaultPresets ( bool  )
SSAO options.
◆ SetRadius()
virtual void vtkPVRenderView::SetRadius ( double  )
SSAO options.
◆ SetKernelSize()
virtual void vtkPVRenderView::SetKernelSize ( int  )
SSAO options.
◆ SetBias()
virtual void vtkPVRenderView::SetBias ( double  )
SSAO options.
◆ SetBlur()
virtual void vtkPVRenderView::SetBlur ( bool  )
SSAO options.
◆ CopyViewUpdateOptions()
void vtkPVRenderView::CopyViewUpdateOptions ( vtkPVRenderView *  otherView)
This method was introduced for the quad view so internal views could use the decision that were made in the main view.
◆ AddPropToRenderer()
void vtkPVRenderView::AddPropToRenderer ( vtkProp *  prop)
◆ RemovePropFromRenderer()
void vtkPVRenderView::RemovePropFromRenderer ( vtkProp *  prop)
◆ BeginValuePassForRendering()
bool vtkPVRenderView::BeginValuePassForRendering ( int  fieldAssociation,
const char *  arrayName,
int  component
Between BeginValuePassForRendering and EndValuePassForRendering calls, all renders will end up using vtkValuePass for rendering instead of the standard rendering passes that generate results on screen.
GrabValuePassResult must be called between BeginValuePassForRendering and EndValuePassForRendering. Returns the vtkFloatArray grabbed by vtkValuePass.
This API is not intended for remote-rendering use-cases. Thus only supported in client-only and pvbatch (or in situ) cases. That's the reason why we are exposing this directly on the vtkPVRenderView rather accessing it via a proxy.
◆ EndValuePassForRendering()
void vtkPVRenderView::EndValuePassForRendering ( )
◆ GrabValuePassResult()
vtkSmartPointer<vtkFloatArray> vtkPVRenderView::GrabValuePassResult ( )
◆ CaptureZBuffer()
void vtkPVRenderView::CaptureZBuffer ( )
◆ GetCapturedZBuffer()
vtkFloatArray* vtkPVRenderView::GetCapturedZBuffer ( )
◆ SetEnableOSPRay()
void vtkPVRenderView::SetEnableOSPRay ( bool  )
◆ GetEnableOSPRay()
bool vtkPVRenderView::GetEnableOSPRay ( )
◆ SetShadows()
void vtkPVRenderView::SetShadows ( bool  )
◆ GetShadows()
bool vtkPVRenderView::GetShadows ( )
◆ SetAmbientOcclusionSamples()
void vtkPVRenderView::SetAmbientOcclusionSamples ( int  )
◆ GetAmbientOcclusionSamples()
int vtkPVRenderView::GetAmbientOcclusionSamples ( )
◆ SetRouletteDepth()
void vtkPVRenderView::SetRouletteDepth ( int  )
◆ GetRouletteDepth()
int vtkPVRenderView::GetRouletteDepth ( )
◆ SetVolumeAnisotropy()
void vtkPVRenderView::SetVolumeAnisotropy ( double  )
◆ GetVolumeAnisotropy()
double vtkPVRenderView::GetVolumeAnisotropy ( )
◆ SetSamplesPerPixel()
void vtkPVRenderView::SetSamplesPerPixel ( int  )
◆ GetSamplesPerPixel()
int vtkPVRenderView::GetSamplesPerPixel ( )
◆ SetMaxFrames()
void vtkPVRenderView::SetMaxFrames ( int  )
◆ GetMaxFrames()
int vtkPVRenderView::GetMaxFrames ( )
◆ GetOSPRayContinueStreaming()
bool vtkPVRenderView::GetOSPRayContinueStreaming ( )
Has OSPRay reached the max frames?
◆ SetDenoise()
void vtkPVRenderView::SetDenoise ( bool  )
◆ GetDenoise()
bool vtkPVRenderView::GetDenoise ( )
◆ SetLightScale()
void vtkPVRenderView::SetLightScale ( double  )
◆ GetLightScale()
double vtkPVRenderView::GetLightScale ( )
◆ SetOSPRayRendererType()
void vtkPVRenderView::SetOSPRayRendererType ( std::string  )
Set the OSPRay renderer to use.
May be either scivis (default) or pathtracer.
◆ SetBackgroundNorth()
void vtkPVRenderView::SetBackgroundNorth ( double  x,
double  y,
double  z
◆ SetBackgroundEast()
void vtkPVRenderView::SetBackgroundEast ( double  x,
double  y,
double  z
◆ SetMaterialLibrary()
virtual void vtkPVRenderView::SetMaterialLibrary ( vtkPVMaterialLibrary *  )
For OSPRay, set the library of materials.
◆ SetViewTime()
void vtkPVRenderView::SetViewTime ( double  value)
Get/Set the time this view is showing.
Note
CallOnAllProcesses
◆ SetTimeCacheSize()
void vtkPVRenderView::SetTimeCacheSize ( int  )
◆ GetTimeCacheSize()
int vtkPVRenderView::GetTimeCacheSize ( )
◆ GetDiscreteCameras()
static vtkPVCameraCollection* vtkPVRenderView::GetDiscreteCameras ( vtkInformation *  info,
In vtkPVView::REQUEST_UPDATE() pass, representations may request the view to use discrete cameras by providing a vtkPVCameraCollection to the view. Since multiple representations may be visible in the view, it's up to the representations how to handle multiple representations providing different styles.
When set, on each render, vtkPVRenderView will try to update the current camera to match a camera in the collection. During interacting, however, the snapping to a camera in the collection is only done when the snapped to camera is different from the previous. This avoids side effects on camera manipulators that simply update existing camera positions during interaction.
Note
Since this is supposed to set in vtkPVView::REQUEST_UPDATE(), it is unset before the pass is triggered.
Warning
This is a new/experimental feature that was added to support viewing of Cinema databases in ParaView. As the support for Cinema in ParaView improve, this is likely to change.
◆ SetDiscreteCameras()
static void vtkPVRenderView::SetDiscreteCameras ( vtkInformation *  info,
vtkPVCameraCollection *  style
Note
Warning
◆ GetRenderView()
virtual vtkRenderViewBase* vtkPVRenderView::GetRenderView ( )
◆ ScaleRendererViewports()
void vtkPVRenderView::ScaleRendererViewports ( const double  viewport[4])
Overridden to scale the OrientationWidget appropriately.
◆ SynchronizeMaximumIds()
void vtkPVRenderView::SynchronizeMaximumIds ( vtkIdType *  maxPointId,
vtkIdType *  maxCellId
This is used by vtkPVHardwareSelector to synchronize element ids between all ranks involved in selection.
◆ SetHardwareSelector()
void vtkPVRenderView::SetHardwareSelector ( vtkPVHardwareSelector *  selector)
◆ Render()
virtual void vtkPVRenderView::Render ( bool  interactive,
bool  skip_rendering
protectedvirtual
◆ AboutToRenderOnLocalProcess()
virtual void vtkPVRenderView::AboutToRenderOnLocalProcess ( bool  interactive)
inlineprotectedvirtual
This is only called on the nodes where the rendering is going to happen.
Reimplemented in vtkPVOrthographicSliceView, and vtkPVMultiSliceView.
Definition at line 1134 of file vtkPVRenderView.h.
◆ ShouldUseDistributedRendering()
bool vtkPVRenderView::ShouldUseDistributedRendering ( double  geometry_size,
bool  using_lod
using_lod will be true if this method is called to determine distributed rendering status for renders using lower LOD i.e when called in UpdateLOD().
◆ ShouldUseLODRendering()
bool vtkPVRenderView::ShouldUseLODRendering ( double  geometry)
◆ IsProcessRenderingGeometriesForCompositing()
bool vtkPVRenderView::IsProcessRenderingGeometriesForCompositing ( bool  using_distributed_rendering)
geometry rendered in view that is composited together.
◆ SetLastSelection()
void vtkPVRenderView::SetLastSelection ( vtkSelection *  )
◆ UpdateCenterAxes()
virtual void vtkPVRenderView::UpdateCenterAxes ( )
protectedvirtual
UpdateCenterAxes().
Updates CenterAxes's scale and position.
◆ GetLocalProcessDoesRendering()
bool vtkPVRenderView::GetLocalProcessDoesRendering ( bool  using_distributed_rendering)
◆ TestCollaborationCounter()
bool vtkPVRenderView::TestCollaborationCounter ( )
Returns false if that's not the case.
◆ SynchronizeForCollaboration()
void vtkPVRenderView::SynchronizeForCollaboration ( )
◆ BuildAnnotationText()
virtual void vtkPVRenderView::BuildAnnotationText ( ostream &  str)
protectedvirtual
◆ GetSynchronizationCounter()
virtual unsigned int vtkPVRenderView::GetSynchronizationCounter ( )
protectedvirtual
◆ GetMakingSelection()
virtual bool vtkPVRenderView::GetMakingSelection ( )
protectedvirtual
◆ PrepareSelect()
virtual bool vtkPVRenderView::PrepareSelect ( int  fieldAssociation,
protectedvirtual
Returns false if it is currently generating a selection.
◆ PostSelect()
virtual void vtkPVRenderView::PostSelect ( vtkSelection *  sel,
protectedvirtual
◆ UpdateBackground()
virtual void vtkPVRenderView::UpdateBackground ( vtkRenderer *  renderer = nullptr)
protectedvirtual
If no renderer is specified, then the default renderer returned by GetRenderer is used.
◆ ConfigureTexture()
void vtkPVRenderView::ConfigureTexture ( vtkTexture *  texture)
◆ SetupAndSetRenderer()
virtual void vtkPVRenderView::SetupAndSetRenderer ( vtkRenderer *  ren)
protectedvirtual
This function modifies the input renderer in order to be usable by the render view.
◆ LastRepresentationVisibleBounds
double vtkPVRenderView::LastRepresentationVisibleBounds[6]
Note
CallOnAllProcesses
Definition at line 182 of file vtkPVRenderView.h.
◆ LightKit
vtkLightKit* vtkPVRenderView::LightKit
Definition at line 1234 of file vtkPVRenderView.h.
◆ RenderView
vtkRenderViewBase* vtkPVRenderView::RenderView
Definition at line 1235 of file vtkPVRenderView.h.
◆ NonCompositedRenderer
vtkRenderer* vtkPVRenderView::NonCompositedRenderer
Definition at line 1236 of file vtkPVRenderView.h.
◆ SynchronizedRenderers
vtkPVSynchronizedRenderer* vtkPVRenderView::SynchronizedRenderers
Definition at line 1237 of file vtkPVRenderView.h.
◆ Interactor
vtkSmartPointer<vtkRenderWindowInteractor> vtkPVRenderView::Interactor
Definition at line 1238 of file vtkPVRenderView.h.
◆ RubberBandStyle
vtkInteractorStyleRubberBand3D* vtkPVRenderView::RubberBandStyle
Definition at line 1239 of file vtkPVRenderView.h.
◆ RubberBandZoom
vtkInteractorStyleRubberBandZoom* vtkPVRenderView::RubberBandZoom
Definition at line 1240 of file vtkPVRenderView.h.
◆ PolygonStyle
vtkInteractorStyleDrawPolygon* vtkPVRenderView::PolygonStyle
Definition at line 1241 of file vtkPVRenderView.h.
◆ CenterAxes
vtkPVCenterAxesActor* vtkPVRenderView::CenterAxes
Definition at line 1242 of file vtkPVRenderView.h.
◆ OrientationWidget
vtkPVAxesWidget* vtkPVRenderView::OrientationWidget
Definition at line 1243 of file vtkPVRenderView.h.
◆ Selector
vtkSmartPointer<vtkPVHardwareSelector> vtkPVRenderView::Selector
Definition at line 1244 of file vtkPVRenderView.h.
◆ LastSelection
vtkSelection* vtkPVRenderView::LastSelection
Definition at line 1245 of file vtkPVRenderView.h.
◆ GridAxes3DActor
vtkSmartPointer<vtkPVGridAxes3DActor> vtkPVRenderView::GridAxes3DActor
Definition at line 1246 of file vtkPVRenderView.h.
◆ LegendGridActor
vtkSmartPointer<vtkLegendScaleActor> vtkPVRenderView::LegendGridActor
Definition at line 1247 of file vtkPVRenderView.h.
◆ Skybox
vtkNew<vtkSkybox> vtkPVRenderView::Skybox
Definition at line 1248 of file vtkPVRenderView.h.
◆ CameraOrientationWidget
vtkNew<vtkCameraOrientationWidget> vtkPVRenderView::CameraOrientationWidget
Definition at line 1249 of file vtkPVRenderView.h.
◆ StillRenderImageReductionFactor
int vtkPVRenderView::StillRenderImageReductionFactor
Definition at line 1251 of file vtkPVRenderView.h.
◆ InteractiveRenderImageReductionFactor
int vtkPVRenderView::InteractiveRenderImageReductionFactor
Definition at line 1252 of file vtkPVRenderView.h.
◆ InteractionMode
int vtkPVRenderView::InteractionMode
Definition at line 1253 of file vtkPVRenderView.h.
◆ ShowAnnotation
bool vtkPVRenderView::ShowAnnotation
Definition at line 1254 of file vtkPVRenderView.h.
◆ UpdateAnnotation
bool vtkPVRenderView::UpdateAnnotation
Definition at line 1255 of file vtkPVRenderView.h.
◆ SuppressRendering
bool vtkPVRenderView::SuppressRendering
Definition at line 1264 of file vtkPVRenderView.h.
◆ TwoDInteractorStyle
vtkPVInteractorStyle* vtkPVRenderView::TwoDInteractorStyle
Definition at line 1267 of file vtkPVRenderView.h.
◆ ThreeDInteractorStyle
vtkPVInteractorStyle* vtkPVRenderView::ThreeDInteractorStyle
Definition at line 1268 of file vtkPVRenderView.h.
◆ ReverseMouseWheelZoomDirection
bool vtkPVRenderView::ReverseMouseWheelZoomDirection = false
Definition at line 1270 of file vtkPVRenderView.h.
◆ InteractorStyle
vtkPVInteractorStyle* vtkPVRenderView::InteractorStyle
Definition at line 1273 of file vtkPVRenderView.h.
◆ DiscreteCameras
vtkWeakPointer<vtkPVCameraCollection> vtkPVRenderView::DiscreteCameras
Definition at line 1275 of file vtkPVRenderView.h.
◆ SynchronizationCounter
unsigned int vtkPVRenderView::SynchronizationCounter
Definition at line 1279 of file vtkPVRenderView.h.
◆ RemoteRenderingThreshold
double vtkPVRenderView::RemoteRenderingThreshold
Definition at line 1282 of file vtkPVRenderView.h.
◆ LODRenderingThreshold
double vtkPVRenderView::LODRenderingThreshold
Definition at line 1283 of file vtkPVRenderView.h.
◆ GeometryBounds
vtkBoundingBox vtkPVRenderView::GeometryBounds
Definition at line 1284 of file vtkPVRenderView.h.
bool vtkPVRenderView::UseInteractiveRenderingForScreenshots
Definition at line 1286 of file vtkPVRenderView.h.
◆ NeedsOrderedCompositing
bool vtkPVRenderView::NeedsOrderedCompositing
Definition at line 1287 of file vtkPVRenderView.h.
◆ RenderEmptyImages
bool vtkPVRenderView::RenderEmptyImages
Definition at line 1288 of file vtkPVRenderView.h.
◆ UseFXAA
bool vtkPVRenderView::UseFXAA
Definition at line 1290 of file vtkPVRenderView.h.
◆ FXAAOptions
vtkNew<vtkFXAAOptions> vtkPVRenderView::FXAAOptions
Definition at line 1291 of file vtkPVRenderView.h.
◆ UseToneMapping
bool vtkPVRenderView::UseToneMapping
Definition at line 1293 of file vtkPVRenderView.h.
◆ UseSSAO
bool vtkPVRenderView::UseSSAO
Definition at line 1295 of file vtkPVRenderView.h.
◆ UseSSAODefaultPresets
bool vtkPVRenderView::UseSSAODefaultPresets
Definition at line 1296 of file vtkPVRenderView.h.
◆ Radius
double vtkPVRenderView::Radius
Definition at line 1297 of file vtkPVRenderView.h.
◆ KernelSize
int vtkPVRenderView::KernelSize
Definition at line 1298 of file vtkPVRenderView.h.
◆ Bias
double vtkPVRenderView::Bias
Definition at line 1299 of file vtkPVRenderView.h.
◆ Blur
bool vtkPVRenderView::Blur
Definition at line 1300 of file vtkPVRenderView.h.
◆ LODResolution
double vtkPVRenderView::LODResolution
Definition at line 1302 of file vtkPVRenderView.h.
◆ UseLightKit
bool vtkPVRenderView::UseLightKit
Definition at line 1303 of file vtkPVRenderView.h.
◆ UsedLODForLastRender
bool vtkPVRenderView::UsedLODForLastRender
Definition at line 1305 of file vtkPVRenderView.h.
◆ UseLODForInteractiveRender
bool vtkPVRenderView::UseLODForInteractiveRender
Definition at line 1306 of file vtkPVRenderView.h.
◆ UseOutlineForLODRendering
bool vtkPVRenderView::UseOutlineForLODRendering
Definition at line 1307 of file vtkPVRenderView.h.
◆ UseDistributedRenderingForRender
bool vtkPVRenderView::UseDistributedRenderingForRender
Definition at line 1308 of file vtkPVRenderView.h.
◆ UseDistributedRenderingForLODRender
bool vtkPVRenderView::UseDistributedRenderingForLODRender
Definition at line 1309 of file vtkPVRenderView.h.
◆ StillRenderProcesses
vtkTypeUInt32 vtkPVRenderView::StillRenderProcesses
Definition at line 1311 of file vtkPVRenderView.h.
◆ InteractiveRenderProcesses
vtkTypeUInt32 vtkPVRenderView::InteractiveRenderProcesses
Definition at line 1312 of file vtkPVRenderView.h.
◆ PriorityQueueBuildTimeStamp
vtkTimeStamp vtkPVRenderView::PriorityQueueBuildTimeStamp
Definition at line 1318 of file vtkPVRenderView.h.
◆ LockBounds
bool vtkPVRenderView::LockBounds
Definition at line 1320 of file vtkPVRenderView.h.
