vtkSMExtractsController Class Reference
controller for extract generation More...
#include <vtkSMExtractsController.h>
Inheritance diagram for vtkSMExtractsController:
Collaboration diagram for vtkSMExtractsController:
const char * GetRealExtractsOutputDirectory () const
 Returns the extract output directory to use. More...
bool Extract (vtkSMProxy *extractor)
 Generate the extract for the current state. More...
bool Extract (vtkSMSessionProxyManager *pxm)
bool Extract ()
bool Extract (vtkCollection *collection)
 Generate extract s for the current state using only the extractors in the collection. More...
bool IsTriggerActivated (vtkSMProxy *extractor)
 Same as IsAnyTriggerActivated except only check the selected extractor's trigger definition. More...
std::vector< vtkSMProxy * > FindExtractors (vtkSMProxy *proxy) const
 Returns a list of extractors associated with the proxy. More...
std::vector< vtkSMProxy * > GetSupportedExtractorPrototypes (vtkSMProxy *proxy) const
 Returns a list of prototype proxies for extractors that can be attached to the given proxy. More...
bool CanExtract (vtkSMProxy *extractor, const std::vector< vtkSMProxy * > &inputs) const
 Returns true is the given extractor (or prototype of the same) can extract the selected set of proxies at the same time. More...
bool CanExtract (vtkSMProxy *extractor, vtkSMProxy *input) const
vtkSMProxy * GetInputForExtractor (vtkSMProxy *extractor) const
 Given an extractor proxy, returns the producer for the extractor, if any. More...
vtkTable * GetSummaryTable () const
 Get access to the summary table generated so far. More...
void ResetSummaryTable ()
 Reset summary table. More...
bool SaveSummaryTable (const std::string &fname, vtkSMSessionProxyManager *pxm)
 Saves summary table to a file. More...
virtual void SetTimeStep (int)
 Information about current time/timestep. More...
virtual int GetTimeStep ()
virtual void SetTime (double)
virtual double GetTime ()
virtual void SetExtractsOutputDirectory (const char *)
 Get/Set the root directory to use for writing extracts. More...
virtual char * GetExtractsOutputDirectory ()
bool IsAnyTriggerActivated (vtkSMSessionProxyManager *pxm)
 Check if any of the extractors registered with the chosen proxy-manager (or active proxy-manager, is none specified) has their trigger activated given the current state of the application and the values for Time and TimeStep set on the controller. More...
bool IsAnyTriggerActivated ()
bool IsAnyTriggerActivated (vtkCollection *collection)
vtkSMProxy * CreateExtractor (vtkSMProxy *proxy, const char *xmlname, const char *registrationName=nullptr) const
 Creates, initializes and registers a new extractor of the chosen type. More...
static vtkSMExtractsController * New ()
static vtkSMExtractsController * SafeDownCast (vtkObject *o)
static bool IsExtractor (vtkSMProxy *extractor, vtkSMProxy *proxy)
 Returns true is the extractor is an extractor for the proxy. More...
static bool IsExtractorEnabled (vtkSMProxy *extractor)
 Returns true of the extractor is enabled. More...
static void SetExtractorEnabled (vtkSMProxy *extractor, bool val)
 Enable/disable an extractor. More...
 vtkSMExtractsController ()
 ~vtkSMExtractsController () override
std::string GetName (vtkSMExtractWriterProxy *writer)
 Returns a friendly name derived from the extract writer. More...
bool CreateExtractsOutputDirectory (vtkSMSessionProxyManager *pxm) const
 These methods are intended to be use by vtkSMExtractWriterProxy and subclasses to ensure chosen output directories are created before attempting to generate extracts. More...
bool CreateDir (const std::string &dname, vtkSMSessionProxyManager *pxm) const
using SummaryParametersT = std::map< std::string, std::string >
 Called by vtkSMExtractWriterProxy subclasses to add an entry to the summary table. More...
bool AddSummaryEntry (vtkSMExtractWriterProxy *writer, const std::string &filename, const SummaryParametersT &params=SummaryParametersT{})
vtkSMExtractsController is a controllers that provides API to handle various aspects of extractors and extract generation mechanisms supported by ParaView.
It provides API to query, create extractors of known types. It also provides API to generate extracts using the defined extractors.
Summary of generated extracts
vtkSMExtractsController generates a summary table for all extracts generated. Each row in this summary table corresponds to an extract generated. Each column provides information about that extract. Filename for the extract is stored in a column named FILE_[type] where [type] is replaced by the extension of the file. Other columns are used to stored named values that characterize the extract.
Currently, this summary table is used to generated a Cinema specification which can be used to explore the generated extracts using Cinema tools (https://cinemascience.github.io/).
Definition at line 45 of file vtkSMExtractsController.h.
Definition at line 49 of file vtkSMExtractsController.h.
◆ SummaryParametersT
Note, this must be called for every extract written out by the extract writer.
Definition at line 203 of file vtkSMExtractsController.h.
◆ vtkSMExtractsController()
vtkSMExtractsController::vtkSMExtractsController ( )
◆ ~vtkSMExtractsController()
vtkSMExtractsController::~vtkSMExtractsController ( )
static vtkSMExtractsController* vtkSMExtractsController::New ( )
virtual const char* vtkSMExtractsController::GetClassName ( )
static int vtkSMExtractsController::IsTypeOf ( const char *  type)
virtual int vtkSMExtractsController::IsA ( const char *  type)
static vtkSMExtractsController* vtkSMExtractsController::SafeDownCast ( vtkObject *  o)
void vtkSMExtractsController::PrintSelf ( ostream &  os,
◆ SetTimeStep()
virtual void vtkSMExtractsController::SetTimeStep ( int  )
This must be set correctly before using Extract to generate extracts.
◆ GetTimeStep()
virtual int vtkSMExtractsController::GetTimeStep ( )
◆ SetTime()
virtual void vtkSMExtractsController::SetTime ( double  )
◆ GetTime()
virtual double vtkSMExtractsController::GetTime ( )
◆ SetExtractsOutputDirectory()
virtual void vtkSMExtractsController::SetExtractsOutputDirectory ( const char *  )
Note
This can be overridden at runtime using environment variable PARAVIEW_OVERRIDE_EXTRACTS_OUTPUT_DIRECTORY. If set, the value specified here ignored and the environment variable is used instead.
◆ GetExtractsOutputDirectory()
virtual char* vtkSMExtractsController::GetExtractsOutputDirectory ( )
Note
◆ GetRealExtractsOutputDirectory()
const char* vtkSMExtractsController::GetRealExtractsOutputDirectory ( ) const
If PARAVIEW_OVERRIDE_EXTRACTS_OUTPUT_DIRECTORY is not set, this will be same as GetExtractsOutputDirectory else this will be the value of the PARAVIEW_OVERRIDE_EXTRACTS_OUTPUT_DIRECTORY environment variable.
◆ Extract() [1/4]
bool vtkSMExtractsController::Extract ( vtkSMProxy *  extractor)
Returns true if extract was generated, false if skipped or failed.
This overload generates extract from the specific extractor.
◆ Extract() [2/4]
bool vtkSMExtractsController::Extract ( vtkSMSessionProxyManager *  pxm)
This overload generates extracts from all extractors registered with the proxy-manager.
◆ Extract() [3/4]
bool vtkSMExtractsController::Extract ( )
This overload locates the active session and then simply calls Extract(vtkSMSessionProxyManager*).
◆ Extract() [4/4]
bool vtkSMExtractsController::Extract ( vtkCollection *  collection)
◆ IsAnyTriggerActivated() [1/3]
bool vtkSMExtractsController::IsAnyTriggerActivated ( vtkSMSessionProxyManager *  pxm)
◆ IsAnyTriggerActivated() [2/3]
bool vtkSMExtractsController::IsAnyTriggerActivated ( )
◆ IsAnyTriggerActivated() [3/3]
bool vtkSMExtractsController::IsAnyTriggerActivated ( vtkCollection *  collection)
◆ IsTriggerActivated()
bool vtkSMExtractsController::IsTriggerActivated ( vtkSMProxy *  extractor)
◆ FindExtractors()
std::vector<vtkSMProxy*> vtkSMExtractsController::FindExtractors ( vtkSMProxy *  proxy) const
◆ GetSupportedExtractorPrototypes()
std::vector<vtkSMProxy*> vtkSMExtractsController::GetSupportedExtractorPrototypes ( vtkSMProxy *  proxy) const
◆ CanExtract() [1/2]
bool vtkSMExtractsController::CanExtract ( vtkSMProxy *  extractor,
const std::vector< vtkSMProxy * > &  inputs
) const
◆ CanExtract() [2/2]
vtkSMProxy *  input
) const
inline
Definition at line 151 of file vtkSMExtractsController.h.
◆ CreateExtractor()
vtkSMProxy* vtkSMExtractsController::CreateExtractor ( vtkSMProxy *  proxy,
const char *  xmlname,
const char *  registrationName = nullptr
) const
◆ IsExtractor()
static bool vtkSMExtractsController::IsExtractor ( vtkSMProxy *  extractor,
vtkSMProxy *  proxy
◆ GetInputForExtractor()
vtkSMProxy* vtkSMExtractsController::GetInputForExtractor ( vtkSMProxy *  extractor) const
May return a vtkSMViewProxy or a vtkSMOutputPort.
◆ GetSummaryTable()
vtkTable* vtkSMExtractsController::GetSummaryTable ( ) const
This will be nullptr until the first extract is generated.
See Summary of generated extracts for information about summary table.
◆ ResetSummaryTable()
void vtkSMExtractsController::ResetSummaryTable ( )
Generally not needed since there is not much use for reusing vtkSMExtractsController, one should just create a new one when needed.
◆ SaveSummaryTable()
bool vtkSMExtractsController::SaveSummaryTable ( const std::string &  fname,
Path is relative to the ExtractsOutputDirectory.
◆ AddSummaryEntry()
bool vtkSMExtractsController::AddSummaryEntry ( vtkSMExtractWriterProxy *  writer,
const std::string &  filename,
const SummaryParametersT &  params = SummaryParametersT{}
◆ IsExtractorEnabled()
static bool vtkSMExtractsController::IsExtractorEnabled ( vtkSMProxy *  extractor)
◆ SetExtractorEnabled()
static void vtkSMExtractsController::SetExtractorEnabled ( vtkSMProxy *  extractor,
bool  val
◆ CreateExtractsOutputDirectory()
bool vtkSMExtractsController::CreateExtractsOutputDirectory ( vtkSMSessionProxyManager *  pxm) const
Return true on success, or false to failed to create writeable directories. Extract writers should not attempt to write any extracts when that happens.
◆ CreateDir()
bool vtkSMExtractsController::CreateDir ( const std::string &  dname,
) const
◆ GetName()
std::string vtkSMExtractsController::GetName ( vtkSMExtractWriterProxy *  writer)
