Public Types | Public Member Functions | Static Public Member Functions | Protected Types | Protected Member Functions | List of all members
vtkSMImageExtractWriterProxy Class Reference
extract writer for images or rendering results More...
#include <vtkSMImageExtractWriterProxy.h>
Inheritance diagram for vtkSMImageExtractWriterProxy:
Collaboration diagram for vtkSMImageExtractWriterProxy:
enum  CameraMode { Static = 0, PhiTheta = 1 }
typedef vtkSMExtractWriterProxy Superclass
- Public Types inherited from vtkSMExtractWriterProxy
typedef vtkSMProxy Superclass
bool Write (vtkSMExtractsController *extractor) override
 Implementation for vtkSMExtractWriterProxy API. More...
bool CanExtract (vtkSMProxy *proxy) override
bool IsExtracting (vtkSMProxy *proxy) override
void SetInput (vtkSMProxy *proxy) override
vtkSMProxy * GetInput () override
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMImageExtractWriterProxy * New ()
static vtkSMImageExtractWriterProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMExtractWriterProxy
static vtkSMExtractWriterProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
Protected Types
using SummaryParametersT = vtkSMExtractsController::SummaryParametersT
 vtkSMImageExtractWriterProxy ()
 ~vtkSMImageExtractWriterProxy () override
bool WriteImage (vtkSMExtractsController *extractor, const SummaryParametersT &cameraParams=SummaryParametersT{})
 Save a single image. More...
virtual bool WriteInternal (vtkSMExtractsController *extractor, const SummaryParametersT &params=SummaryParametersT{})
 Called in Write(). More...
virtual const char * GetShortName (const std::string &key) const
 Used to convert a parameter name used in the SummaryParametersT to a shorter version suitable for use in filename. More...
- Protected Member Functions inherited from vtkSMExtractWriterProxy
 vtkSMExtractWriterProxy ()
 ~vtkSMExtractWriterProxy () override
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Static Protected Member Functions inherited from vtkSMExtractWriterProxy
static std::string GenerateExtractsFileName (const std::string &filename, const char *outDir)
 Adds the output directory to the filename, replaces, in case of need, the old string format, and returns the formatted string using vtkPVStringFormatter. More...
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMImageExtractWriterProxy is intended to writing extracts using rendering results from views. Default implementation uses a vtkSMSaveScreenshotProxy provided as a subproxy named "Writer" to handle the image capture.
This can generate images only from vtkSMViewProxy and subclasses.
Definition at line 21 of file vtkSMImageExtractWriterProxy.h.
Definition at line 25 of file vtkSMImageExtractWriterProxy.h.
◆ SummaryParametersT
Definition at line 51 of file vtkSMImageExtractWriterProxy.h.
◆ CameraMode
Enumerator
Static
PhiTheta
Definition at line 39 of file vtkSMImageExtractWriterProxy.h.
◆ vtkSMImageExtractWriterProxy()
vtkSMImageExtractWriterProxy::vtkSMImageExtractWriterProxy ( )
◆ ~vtkSMImageExtractWriterProxy()
vtkSMImageExtractWriterProxy::~vtkSMImageExtractWriterProxy ( )
static vtkSMImageExtractWriterProxy* vtkSMImageExtractWriterProxy::New ( )
virtual const char* vtkSMImageExtractWriterProxy::GetClassName ( )
static int vtkSMImageExtractWriterProxy::IsTypeOf ( const char *  type)
virtual int vtkSMImageExtractWriterProxy::IsA ( const char *  type)
static vtkSMImageExtractWriterProxy* vtkSMImageExtractWriterProxy::SafeDownCast ( vtkObject *  o)
void vtkSMImageExtractWriterProxy::PrintSelf ( ostream &  os,
◆ Write()
bool vtkSMImageExtractWriterProxy::Write ( vtkSMExtractsController *  extractor)
Implements vtkSMExtractWriterProxy.
◆ CanExtract()
bool vtkSMImageExtractWriterProxy::CanExtract ( vtkSMProxy *  proxy)
◆ IsExtracting()
bool vtkSMImageExtractWriterProxy::IsExtracting ( vtkSMProxy *  proxy)
◆ SetInput()
void vtkSMImageExtractWriterProxy::SetInput ( vtkSMProxy *  proxy)
◆ GetInput()
vtkSMProxy* vtkSMImageExtractWriterProxy::GetInput ( )
◆ CreateVTKObjects()
void vtkSMImageExtractWriterProxy::CreateVTKObjects ( )
overrideprotectedvirtual
Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s)
Reimplemented in vtkSMRecolorableImageExtractWriterProxy.
◆ WriteImage()
bool vtkSMImageExtractWriterProxy::WriteImage ( vtkSMExtractsController *  extractor,
const SummaryParametersT &  cameraParams = SummaryParametersT{}
Uses the cameraParams to create a unique filename. The cameraParams are also used when adding an entry to the summary table maintained by the vtkSMExtractsController.
◆ WriteInternal()
virtual bool vtkSMImageExtractWriterProxy::WriteInternal ( vtkSMExtractsController *  extractor,
const SummaryParametersT &  params = SummaryParametersT{}
protectedvirtual
Called in Write().
Intended for subclasses to override to customize image generation
Reimplemented in vtkSMRecolorableImageExtractWriterProxy, and vtkSMCinemaVolumetricImageExtractWriterProxy.
◆ GetShortName()
virtual const char* vtkSMImageExtractWriterProxy::GetShortName ( const std::string &  key) const
protectedvirtual
Reimplemented in vtkSMCinemaVolumetricImageExtractWriterProxy.
