Classes | Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | List of all members
vtkPVStringFormatter Class Reference
Utility class used for string formatting. More...
#include <vtkPVStringFormatter.h>
Inheritance diagram for vtkPVStringFormatter:
Collaboration diagram for vtkPVStringFormatter:
class  TraceScope
 This subclass should ONLY be used to enable automatic push/pop of argument scopes in the same scope of code. More...
static vtkPVStringFormatter * New ()
static vtkPVStringFormatter * SafeDownCast (vtkObject *o)
template<typename... Args>
static void PushScope (Args &&... args)
 Pushes arguments using fmt::arg(name, arg) to add a new scope to the scope stack. More...
static void PushScope (const char *scopeName, Args &&... args)
 Pushes arguments using a scope name and arguments in the form of fmt::arg(name, arg) to add a new scope to the scope stack. More...
static void PopScope ()
 Pops the top scope of the scope stack. More...
static std::string Format (const std::string &formattableString)
 Given a formattable string, use the top scope of the argument stack, and return the formatted string. More...
 vtkPVStringFormatter ()
 ~vtkPVStringFormatter () override
vtkPVStringFormatter is a utility class that defines the API for formatting strings using a stack of argument scopes. Scopes can be created by defining arguments using the fmt library. A string will always be formatted using the top argument scope in the scope stack.
Definition at line 33 of file vtkPVStringFormatter.h.
Definition at line 37 of file vtkPVStringFormatter.h.
◆ vtkPVStringFormatter()
vtkPVStringFormatter::vtkPVStringFormatter ( )
◆ ~vtkPVStringFormatter()
vtkPVStringFormatter::~vtkPVStringFormatter ( )
static vtkPVStringFormatter* vtkPVStringFormatter::New ( )
virtual const char* vtkPVStringFormatter::GetClassName ( )
static int vtkPVStringFormatter::IsTypeOf ( const char *  type)
virtual int vtkPVStringFormatter::IsA ( const char *  type)
static vtkPVStringFormatter* vtkPVStringFormatter::SafeDownCast ( vtkObject *  o)
void vtkPVStringFormatter::PrintSelf ( ostream &  os,
◆ PushScope() [1/2]
static void vtkPVStringFormatter::PushScope ( Args &&...  args)
inlinestatic
The new scope has as a baseline the top scope of the scope stack.
Definition at line 67 of file vtkPVStringFormatter.h.
◆ PushScope() [2/2]
static void vtkPVStringFormatter::PushScope ( const char *  scopeName,
Args &&...  args
inlinestatic
E.g. if PushScope("TEST", fmt::arg("test1", test)) is used then the scope the scope will have the following arguments: TEST_test1 and test1, The new scope has as a baseline the top scope of the scope stack.
Note
If you want to call this function, scope name MUST be const char*, otherwise the implementation of this function without the scope name will be invoked.
Definition at line 94 of file vtkPVStringFormatter.h.
◆ PopScope()
static void vtkPVStringFormatter::PopScope ( )
◆ Format()
static std::string vtkPVStringFormatter::Format ( const std::string &  formattableString)
