vtkSMRangedTransferFunctionDomain Class Reference
represents a ranged vtkSMTransferFunctionProxy More...
#include <vtkSMRangedTransferFunctionDomain.h>
Inheritance diagram for vtkSMRangedTransferFunctionDomain:
Collaboration diagram for vtkSMRangedTransferFunctionDomain:
typedef vtkSMProxyListDomain Superclass
- Public Types inherited from vtkSMProxyListDomain
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
double GetRangeMinimum (unsigned int idx, int &exists)
 Return a range min. More...
double GetRangeMaximum (unsigned int idx, int &exists)
 Return a range max. More...
int SetDefaultValues (vtkSMProperty *prop, bool use_unchecked_values) override
 If prop is a vtkSMProxyProperty containing a vtkSMTransferFunctionProxy this set its range based on this domain min and max values. More...
bool GetRangeMinimumExists (unsigned int idx)
 Returns if range minimum/maximum bound is set for the domain. More...
bool GetRangeMaximumExists (unsigned int idx)
double GetRangeMinimum (unsigned int idx)
 Returns the range minimum/maximum value, is exists, otherwise 0 is returned. More...
double GetRangeMaximum (unsigned int idx)
- Public Member Functions inherited from vtkSMProxyListDomain
const std::vector< ProxyType > & GetProxyTypes () const
 Returns a vector of proxy types for the proxies in the domain. More...
unsigned int GetNumberOfProxyTypes ()
 Returns the number of proxies in the domain. More...
const char * GetProxyGroup (unsigned int index)
 Returns the xml group name for the proxy at a given index. More...
const char * GetProxyName (unsigned int index)
 Returns the xml type name for the proxy at a given index. More...
const char * GetProxyName (vtkSMProxy *proxy)
 If the proxy is part of the domain, then this returns the name used for the proxy in the domain. More...
vtkSMProxy * GetProxyWithName (const char *pname)
 Inverse of GetProxyName, returns the first proxy with the given name. More...
int IsInDomain (vtkSMProperty *property) override
 This always returns true. More...
void AddProxy (vtkSMProxy *)
 Add a proxy to the domain. More...
bool HasProxy (vtkSMProxy *)
 Returns if the proxy is present in the domain. More...
unsigned int GetNumberOfProxies ()
 Get number of proxies in the domain. More...
vtkSMProxy * GetProxy (unsigned int index)
 Get proxy at a given index. More...
vtkSMProxy * FindProxy (const char *xmlgroup, const char *xmlname)
 Find a proxy in the domain of the given group and type. More...
int RemoveProxy (vtkSMProxy *proxy)
 Removes the first occurrence of the proxy in the domain. More...
int RemoveProxy (unsigned int index)
 Removes the proxy at the given index. More...
void CreateProxies (vtkSMSessionProxyManager *pxm)
 Creates and populates the domain with the proxy-types. More...
 A vtkSMProperty is often defined with a default value in the XML itself. More...
void SetLogName (const char *prefix)
 Sets log name for each of the proxy in the domain using the prefix provided. More...
virtual void SetDefaultIndex (unsigned int)
 Set and Get the default proxy index. More...
virtual unsigned int GetDefaultIndex ()
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void Update (vtkSMProperty *requestingProperty)
 Update self based on the "unchecked" values of all required properties. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
 Set the value of an element of a property from the animation editor. More...
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMRangedTransferFunctionDomain * New ()
static vtkSMRangedTransferFunctionDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMProxyListDomain
static vtkSMProxyListDomain * New ()
static vtkSMProxyListDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMRangedTransferFunctionDomain ()
 ~vtkSMRangedTransferFunctionDomain () override
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override
void InvokeDomainModifiedEvent ()
 Callback to invoke DomainModified event. More...
- Protected Member Functions inherited from vtkSMProxyListDomain
 vtkSMProxyListDomain ()
 ~vtkSMProxyListDomain () override
void AddProxy (const char *group, const char *name)
 Adds a proxy type, used by ReadXMLAttributes(). More...
void ChildSaveState (vtkPVXMLElement *propertyElement) override
 Save state for this domain. More...
int LoadState (vtkPVXMLElement *domainElement, vtkSMProxyLocator *loader) override
void SetProxies (vtkSMProxy **proxies, unsigned int count)
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMProxyListDomain
unsigned int DefaultIndex = 0
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
This domain represent a single vtkSMTransferFunctionProxy with a range defined by a vtkSMArrayRangeDomain used internally.
Example usage :
<RangedTransferFunctionDomain name="domain">
<RequiredProperties>
<Property function="Input" name="Input" />
<Property function="ArraySelection" name="OpacityArray" />
<Property function="ComponentSelection" name="OpacityArrayComponent" />
</RequiredProperties>
</RangedTransferFunctionDomain>
Definition at line 31 of file vtkSMRangedTransferFunctionDomain.h.
Definition at line 35 of file vtkSMRangedTransferFunctionDomain.h.
◆ vtkSMRangedTransferFunctionDomain()
vtkSMRangedTransferFunctionDomain::vtkSMRangedTransferFunctionDomain ( )
◆ ~vtkSMRangedTransferFunctionDomain()
vtkSMRangedTransferFunctionDomain::~vtkSMRangedTransferFunctionDomain ( )
static vtkSMRangedTransferFunctionDomain* vtkSMRangedTransferFunctionDomain::New ( )
virtual const char* vtkSMRangedTransferFunctionDomain::GetClassName ( )
Reimplemented from vtkSMProxyListDomain.
static int vtkSMRangedTransferFunctionDomain::IsTypeOf ( const char *  type)
virtual int vtkSMRangedTransferFunctionDomain::IsA ( const char *  type)
static vtkSMRangedTransferFunctionDomain* vtkSMRangedTransferFunctionDomain::SafeDownCast ( vtkObject *  o)
void vtkSMRangedTransferFunctionDomain::PrintSelf ( ostream &  os,
◆ GetRangeMinimum() [1/2]
double vtkSMRangedTransferFunctionDomain::GetRangeMinimum ( unsigned int  idx,
int &  exists
Return a range min.
value if it exists. If the min. exists exists is set to 1. Otherwise, it is set to 0. An unspecified min. is equivalent to -inf
◆ GetRangeMaximum() [1/2]
double vtkSMRangedTransferFunctionDomain::GetRangeMaximum ( unsigned int  idx,
int &  exists
Return a range max.
value if it exists. If the max. exists exists is set to 1. Otherwise, it is set to 0. An unspecified max. is equivalent to +inf
◆ GetRangeMinimumExists()
bool vtkSMRangedTransferFunctionDomain::GetRangeMinimumExists ( unsigned int  idx)
◆ GetRangeMaximumExists()
bool vtkSMRangedTransferFunctionDomain::GetRangeMaximumExists ( unsigned int  idx)
◆ GetRangeMinimum() [2/2]
double vtkSMRangedTransferFunctionDomain::GetRangeMinimum ( unsigned int  idx)
inline
Use GetMaximumExists() GetMaximumExists() to make sure that the bound is set.
Definition at line 66 of file vtkSMRangedTransferFunctionDomain.h.
◆ GetRangeMaximum() [2/2]
double vtkSMRangedTransferFunctionDomain::GetRangeMaximum ( unsigned int  idx)
inline
Definition at line 71 of file vtkSMRangedTransferFunctionDomain.h.
◆ SetDefaultValues()
int vtkSMRangedTransferFunctionDomain::SetDefaultValues ( vtkSMProperty *  prop,
override
◆ ReadXMLAttributes()
int vtkSMRangedTransferFunctionDomain::ReadXMLAttributes ( vtkSMProperty *  prop,
vtkPVXMLElement *  element
overrideprotectedvirtual
◆ InvokeDomainModifiedEvent()
void vtkSMRangedTransferFunctionDomain::InvokeDomainModifiedEvent ( )
