vtkSMRangedTransferFunctionDomain.h
22 #ifndef vtkSMRangedTransferFunctionDomain_h
23 #define vtkSMRangedTransferFunctionDomain_h
24
25 #include "vtkClientServerID.h" // needed for saving animation in batch script
26 #include "vtkRemotingViewsModule.h" //needed for exports
27 #include "vtkSMProxyListDomain.h"
28
29 class vtkSMRangedTransferFunctionDomainInternals;
30
31 class VTKREMOTINGVIEWS_EXPORT vtkSMRangedTransferFunctionDomain : public vtkSMProxyListDomain
32 {
33 public:
36  void PrintSelf(ostream& os, vtkIndent indent) override;
37
43  double GetRangeMinimum(unsigned int idx, int& exists);
50  double GetRangeMaximum(unsigned int idx, int& exists);
51
53
56  bool GetRangeMinimumExists(unsigned int idx);
57  bool GetRangeMaximumExists(unsigned int idx);
59
61
66  double GetRangeMinimum(unsigned int idx)
67  {
68  int not_used;
69  return this->GetRangeMinimum(idx, not_used);
70  }
71  double GetRangeMaximum(unsigned int idx)
72  {
73  int not_used;
74  return this->GetRangeMaximum(idx, not_used);
75  }
77
82  int SetDefaultValues(vtkSMProperty* prop, bool use_unchecked_values) override;
83
84 protected:
87
92  int ReadXMLAttributes(vtkSMProperty* prop, vtkPVXMLElement* element) override;
93
97  void InvokeDomainModifiedEvent();
98
99 private:
101  void operator=(const vtkSMRangedTransferFunctionDomain&) = delete;
102
103  vtkSMRangedTransferFunctionDomainInternals* Internals;
104 };
105
106 #endif
vtkSMRangedTransferFunctionDomain::GetRangeMaximum
Returns the range minimum/maximum value, is exists, otherwise 0 is returned.
Definition: vtkSMRangedTransferFunctionDomain.h:71
vtkSMProxyListDomain::ReadXMLAttributes
int ReadXMLAttributes(vtkSMProperty *prop, vtkPVXMLElement *element) override
vtkSMProperty
Definition: vtkSMProperty.h:144
represents a ranged vtkSMTransferFunctionProxy
Definition: vtkSMRangedTransferFunctionDomain.h:31
union of proxies.
Definition: vtkSMProxyListDomain.h:40
vtkIndent
vtkSMRangedTransferFunctionDomain::GetRangeMinimum
Definition: vtkSMRangedTransferFunctionDomain.h:66
vtkSMProxyListDomain::New
static vtkSMProxyListDomain * New()
vtkPVXMLElement
Definition: vtkPVXMLElement.h:23
vtkClientServerID.h
vtkSMProxyListDomain::PrintSelf
vtkSMProxyListDomain::SetDefaultValues
int SetDefaultValues(vtkSMProperty *prop, bool use_unchecked_values) override
