Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Friends | List of all members
vtkSMArrayRangeDomain Class Reference
double range domain based on array range More...
#include <vtkSMArrayRangeDomain.h>
Inheritance diagram for vtkSMArrayRangeDomain:
Collaboration diagram for vtkSMArrayRangeDomain:
typedef vtkSMDoubleRangeDomain Superclass
- Public Types inherited from vtkSMDoubleRangeDomain
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
void Update (vtkSMProperty *prop) override
 Updates the range based on the scalar range of the currently selected array. More...
- Public Member Functions inherited from vtkSMDoubleRangeDomain
virtual double GetMinimum (unsigned int idx, int &exists)
 Return a min. More...
virtual double GetMaximum (unsigned int idx, int &exists)
 Return a max. More...
virtual int GetMinimumExists (unsigned int idx)
 Returns if minimum/maximum bound is set for the domain. More...
virtual int GetMaximumExists (unsigned int idx)
virtual double GetMinimum (unsigned int idx)
 Returns the minimum/maximum value, is exists, otherwise 0 is returned. More...
virtual double GetMaximum (unsigned int idx)
virtual int GetResolution ()
 Returns the resolution. More...
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
 Set the value of an element of a property from the animation editor. More...
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
 A vtkSMProperty is often defined with a default value in the XML itself. More...
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMArrayRangeDomain * New ()
static vtkSMArrayRangeDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDoubleRangeDomain
static vtkSMDoubleRangeDomain * New ()
static vtkSMDoubleRangeDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMArrayRangeDomain ()
 ~vtkSMArrayRangeDomain () override
void Update (const char *arrayName, int fieldAssociation, vtkSMSourceProxy *producer, int producerPort, int component=-1)
- Protected Member Functions inherited from vtkSMDoubleRangeDomain
 vtkSMDoubleRangeDomain ()
 ~vtkSMDoubleRangeDomain () override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
virtual int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem)
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void ChildSaveState (vtkPVXMLElement *domainElement)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
Friends
class vtkSMBoundsDomain
class vtkSMRangedTransferFunctionDomain
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
vtkSMArrayRangeDomain is a sub-class of vtkSMDoubleRangeDomain. In it's Update(), it sets min/max values based on the range of an input array. It requires Input (vtkSMProxyProperty) and ArraySelection (vtkSMStringVectorProperty) properties.
See also
vtkSMDoubleRangeDomain vtkSMProxyProperty vtkSMStringVectorProperty
Definition at line 23 of file vtkSMArrayRangeDomain.h.
Definition at line 27 of file vtkSMArrayRangeDomain.h.
◆ vtkSMArrayRangeDomain()
vtkSMArrayRangeDomain::vtkSMArrayRangeDomain ( )
◆ ~vtkSMArrayRangeDomain()
vtkSMArrayRangeDomain::~vtkSMArrayRangeDomain ( )
static vtkSMArrayRangeDomain* vtkSMArrayRangeDomain::New ( )
virtual const char* vtkSMArrayRangeDomain::GetClassName ( )
Reimplemented from vtkSMDoubleRangeDomain.
static int vtkSMArrayRangeDomain::IsTypeOf ( const char *  type)
virtual int vtkSMArrayRangeDomain::IsA ( const char *  type)
static vtkSMArrayRangeDomain* vtkSMArrayRangeDomain::SafeDownCast ( vtkObject *  o)
void vtkSMArrayRangeDomain::PrintSelf ( ostream &  os,
◆ Update() [1/2]
void vtkSMArrayRangeDomain::Update ( vtkSMProperty *  prop)
This requires Input (vtkSMProxyProperty) and ArraySelection (vtkSMStringVectorProperty) properties. Currently, this uses only the first component of the array.
◆ Update() [2/2]
void vtkSMArrayRangeDomain::Update ( const char *  arrayName,
vtkSMSourceProxy *  producer,
int  producerPort,
int  component = -1
◆ vtkSMBoundsDomain
friend class vtkSMBoundsDomain
friend
Definition at line 45 of file vtkSMArrayRangeDomain.h.
◆ vtkSMRangedTransferFunctionDomain
friend class vtkSMRangedTransferFunctionDomain
friend
Definition at line 46 of file vtkSMArrayRangeDomain.h.
