vtkSMSaveScreenshotProxy Class Reference
proxy to help with saving screenshots for views More...
#include <vtkSMSaveScreenshotProxy.h>
Inheritance diagram for vtkSMSaveScreenshotProxy:
Collaboration diagram for vtkSMSaveScreenshotProxy:
typedef vtkSMProxy Superclass
bool WriteImage (const char *filename, vtkTypeUInt32 location=vtkPVSession::CLIENT, vtkPVXMLElement *stateXMLRoot=nullptr)
 Capture image. More...
vtkSmartPointer< vtkImageData > CaptureImage ()
 Capture the rendered image but doesn't save it out to any file. More...
virtual void UpdateDefaultsAndVisibilities (const char *filename)
 Updates default property values for saving the given file. More...
std::string GetFileFormatFilters ()
 Convenience method to derive a QFileDialog friendly format string for extensions supported by this proxy. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMSaveScreenshotProxy * New ()
static vtkSMSaveScreenshotProxy * SafeDownCast (vtkObject *o)
static vtkSmartPointer< vtkImageData > CaptureImage (vtkSMViewProxy *view, const vtkVector2i &size)
 This method can be used to capture an image for a view for a specific resolution using default options. More...
static vtkSmartPointer< vtkImageData > CaptureImage (vtkSMViewLayoutProxy *view, const vtkVector2i &size)
 This method can be used to capture an image for a layout for a specific resolution using default options. More...
static vtkVector2i GetScaleFactorsAndSize (const vtkVector2i &targetSize, vtkVector2i &size, bool *approximate=nullptr)
 Compute scale factors and new size for target resolution. More...
static int ComputeMagnification (const vtkVector2i &targetSize, vtkVector2i &size)
 Compute a single magnification factor to reach targetSize using a box that fits within size. More...
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMSaveScreenshotProxy ()
 ~vtkSMSaveScreenshotProxy () override
std::pair< vtkSmartPointer< vtkImageData >, vtkSmartPointer< vtkImageData > > CapturePreppedImages ()
 When StereoMode is set to VTK_STEREO_EMULATE, both eyes are captures. More...
virtual bool Prepare ()
 Prepares for saving an image. More...
virtual bool Cleanup ()
 This restores the state after the screenshot saving. More...
vtkSMViewLayoutProxy * GetLayout ()
vtkSMViewProxy * GetView ()
vtkSMProxy * GetFormatProxy (const std::string &filename)
 Select the format proxy to match the given extension. More...
std::string GetStereoFileName (const std::string &filename, bool left)
 Adds a stereo filename suffix to the given filename. More...
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
class vtkSMRecolorableImageExtractWriterProxy
virtual void SetUseFloatingPointBuffers (bool)
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMSaveScreenshotProxy is used to capture images from views or layouts. It encapsulates the logic to generate screen shot of any arbitrary size independent of the application window size.
The properties on this proxy provide various options that user can configure when saving images/screenshots. Once those properties are setup, one calls vtkSMSaveScreenshotProxy::WriteImage or vtkSMSaveScreenshotProxy::CaptureImage.
Definition at line 32 of file vtkSMSaveScreenshotProxy.h.
Definition at line 36 of file vtkSMSaveScreenshotProxy.h.
◆ vtkSMSaveScreenshotProxy()
vtkSMSaveScreenshotProxy::vtkSMSaveScreenshotProxy ( )
◆ ~vtkSMSaveScreenshotProxy()
vtkSMSaveScreenshotProxy::~vtkSMSaveScreenshotProxy ( )
static vtkSMSaveScreenshotProxy* vtkSMSaveScreenshotProxy::New ( )
virtual const char* vtkSMSaveScreenshotProxy::GetClassName ( )
Reimplemented in vtkSMSaveAnimationProxy.
static int vtkSMSaveScreenshotProxy::IsTypeOf ( const char *  type)
virtual int vtkSMSaveScreenshotProxy::IsA ( const char *  type)
static vtkSMSaveScreenshotProxy* vtkSMSaveScreenshotProxy::SafeDownCast ( vtkObject *  o)
void vtkSMSaveScreenshotProxy::PrintSelf ( ostream &  os,
◆ WriteImage()
bool vtkSMSaveScreenshotProxy::WriteImage ( const char *  filename,
vtkTypeUInt32  location = vtkPVSession::CLIENT,
vtkPVXMLElement *  stateXMLRoot = nullptr
Capture image.
You can specify the location at which to write the image. Currently supported values are vtkPVSession::CLIENT, vtkPVSession::DATA_SERVER or vtkPVSession::DATA_SERVER_ROOT. Selecting vtkPVSession::DATA_SERVER is same as vtkPVSession::DATA_SERVER_ROOT since the images are only written on root node. You can also specify the xml root of a state file to embed in the image.
Note: embedding state as metadata is supported only for PNG files.
◆ CaptureImage() [1/3]
vtkSmartPointer<vtkImageData> vtkSMSaveScreenshotProxy::CaptureImage ( )
◆ UpdateDefaultsAndVisibilities()
virtual void vtkSMSaveScreenshotProxy::UpdateDefaultsAndVisibilities ( const char *  filename)
◆ CaptureImage() [2/3]
static vtkSmartPointer<vtkImageData> vtkSMSaveScreenshotProxy::CaptureImage ( vtkSMViewProxy *  view,
const vtkVector2i &  size
This is provided as a convenience method to quickly capture images from a view.
◆ CaptureImage() [3/3]
static vtkSmartPointer<vtkImageData> vtkSMSaveScreenshotProxy::CaptureImage ( vtkSMViewLayoutProxy *  view,
This is provided as a convenience method to quickly capture images from a layout.
◆ GetScaleFactorsAndSize()
static vtkVector2i vtkSMSaveScreenshotProxy::GetScaleFactorsAndSize ( const vtkVector2i &  targetSize,
vtkVector2i &  size,
bool *  approximate = nullptr
This determines integral scale factors (in X and Y) to get a box of size of targetSize from a box of maximum size specified by size. If approximate is non-null, then it is set to true when there no way to do that (e.g. one of the components of the targetSize is prime and doesn't match size).
On success, returns the scale factors and modifies size such that size * scaleFactors == targetSize is possible. If not, size * scaleFactors < targetSize and approximate if non-null, is set to true.
◆ ComputeMagnification()
static int vtkSMSaveScreenshotProxy::ComputeMagnification ( const vtkVector2i &  targetSize,
vtkVector2i &  size
This implementation is inaccurate and may not give target resolution correctly. Hence GetScaleFactorsAndSize should be preferred. This method is useful when the interest is in preserving the target aspect ratio as closely as possible than reaching the target size.
◆ GetFileFormatFilters()
std::string vtkSMSaveScreenshotProxy::GetFileFormatFilters ( )
◆ CapturePreppedImages()
std::pair<vtkSmartPointer<vtkImageData>, vtkSmartPointer<vtkImageData> > vtkSMSaveScreenshotProxy::CapturePreppedImages ( )
In that case, this method may be used to return images for each of the eyes.
◆ Prepare()
virtual bool vtkSMSaveScreenshotProxy::Prepare ( )
protectedvirtual
This will do any changes to view properties necessary for saving appropriate image(s).
◆ Cleanup()
virtual bool vtkSMSaveScreenshotProxy::Cleanup ( )
protectedvirtual
◆ GetLayout()
vtkSMViewLayoutProxy* vtkSMSaveScreenshotProxy::GetLayout ( )
◆ GetView()
vtkSMViewProxy* vtkSMSaveScreenshotProxy::GetView ( )
◆ GetFormatProxy()
vtkSMProxy* vtkSMSaveScreenshotProxy::GetFormatProxy ( const std::string &  filename)
In otherwords, this changes the "Format" proxy-property to have the writer proxy from the domain that supports the given filename.
◆ GetStereoFileName()
std::string vtkSMSaveScreenshotProxy::GetStereoFileName ( const std::string &  filename,
bool  left
◆ SetUseFloatingPointBuffers()
virtual void vtkSMSaveScreenshotProxy::SetUseFloatingPointBuffers ( bool  )
protectedvirtual
◆ vtkSMRecolorableImageExtractWriterProxy
Definition at line 147 of file vtkSMSaveScreenshotProxy.h.
