vtkPVRepresentedArrayListSettings Class Reference
singleton used to filter out undesired data attribute from the representation. More...
#include <vtkPVRepresentedArrayListSettings.h>
Inheritance diagram for vtkPVRepresentedArrayListSettings:
Collaboration diagram for vtkPVRepresentedArrayListSettings:
virtual bool ShouldUseMagnitudeMode (int ncomp) const
 Check if the array mode for this number of components should be the magnitude mode or not. More...
virtual void SetNumberOfFilterExpressions (int n)
 Set/get the number of filter expressions. More...
virtual int GetNumberOfFilterExpressions ()
virtual void SetFilterExpression (int i, const char *expression)
 Set/get the filter expression at index i. More...
virtual const char * GetFilterExpression (int i)
virtual void SetComputeArrayMagnitude (bool)
 Setters to control whether ParaView should allow the user to display the gradient of a given multi-component field. More...
virtual void SetArrayMagnitudeException (int idx, int ncomp)
virtual void SetNumberOfArrayMagnitudeExceptions (int nexceptions)
virtual void SetNumberOfChartsDefaultXAxis (int n)
 ChartsDefaultXAxis is the list of array names that will be selected by default as the X axis when displaying some data in charts. More...
virtual int GetNumberOfChartsDefaultXAxis () const
virtual void SetChartsDefaultXAxis (int i, const char *expression)
virtual const char * GetChartsDefaultXAxis (int i) const
virtual const std::vector< std::string > & GetAllChartsDefaultXAxis () const
virtual void SetNumberOfChartsHiddenAttributes (int n)
 ChartsHiddenAttributes is a list of regex that controls whether or not array should be visible by defaults in a chart. More...
virtual int GetNumberOfChartsHiddenAttributes () const
virtual void SetChartsHiddenAttributes (int i, const char *expression)
virtual const std::vector< vtksys::RegularExpression > & GetAllChartsHiddenAttributes () const
virtual bool GetSeriesVisibilityDefault (const char *name) const
virtual void SetNumberOfExcludedNameFilters (int n)
virtual int GetNumberOfExcludedNameFilters ()
virtual void SetExcludedNameFilter (int i, const char *expression)
virtual const char * GetExcludedNameFilter (int i)
vtkStringArray * GetAllNameFilters ()
static vtkPVRepresentedArrayListSettings * New ()
static vtkPVRepresentedArrayListSettings * SafeDownCast (vtkObject *o)
static vtkPVRepresentedArrayListSettings * GetInstance ()
 Access the singleton. More...
 vtkPVRepresentedArrayListSettings ()
 ~vtkPVRepresentedArrayListSettings () override
Currently represent the "Represented Attributes" section of ParaView settings.
vtkPVRepresentedArrayListSettings is a singleton used to keep track of a list of regular expressions that filter out arrays in a RepresentedArrayList domain, and contains other settings controlling which array should be visible in which situation.
All calls to vtkPVRepresentedArrayListSettings::New() returns a reference to the singleton instance.
Definition at line 37 of file vtkPVRepresentedArrayListSettings.h.
Definition at line 41 of file vtkPVRepresentedArrayListSettings.h.
◆ vtkPVRepresentedArrayListSettings()
vtkPVRepresentedArrayListSettings::vtkPVRepresentedArrayListSettings ( )
◆ ~vtkPVRepresentedArrayListSettings()
vtkPVRepresentedArrayListSettings::~vtkPVRepresentedArrayListSettings ( )
static vtkPVRepresentedArrayListSettings* vtkPVRepresentedArrayListSettings::New ( )
virtual const char* vtkPVRepresentedArrayListSettings::GetClassName ( )
static int vtkPVRepresentedArrayListSettings::IsTypeOf ( const char *  type)
virtual int vtkPVRepresentedArrayListSettings::IsA ( const char *  type)
static vtkPVRepresentedArrayListSettings* vtkPVRepresentedArrayListSettings::SafeDownCast ( vtkObject *  o)
void vtkPVRepresentedArrayListSettings::PrintSelf ( ostream &  os,
◆ GetInstance()
static vtkPVRepresentedArrayListSettings* vtkPVRepresentedArrayListSettings::GetInstance ( )
◆ SetNumberOfFilterExpressions()
virtual void vtkPVRepresentedArrayListSettings::SetNumberOfFilterExpressions ( int  n)
◆ GetNumberOfFilterExpressions()
virtual int vtkPVRepresentedArrayListSettings::GetNumberOfFilterExpressions ( )
◆ SetFilterExpression()
virtual void vtkPVRepresentedArrayListSettings::SetFilterExpression ( int  i,
const char *  expression
If the index is outside the valid range, this call is a noop.
◆ GetFilterExpression()
virtual const char* vtkPVRepresentedArrayListSettings::GetFilterExpression ( int  i)
◆ SetComputeArrayMagnitude()
virtual void vtkPVRepresentedArrayListSettings::SetComputeArrayMagnitude ( bool  )
If ComputeArrayMagnitude is true then ParaView will always compute the magnitude. Otherwise it will not.
ArrayMagnitudeExceptions is the list of exceptions and will behave differently depending on the value of ComputeArrayMagnitude. If ComputeArrayMagnitude is false then the list describes the number of components for which ParaView will still compute the magnitude. Else the list describe the number of components for which ParaView will not compute the magnitude.
See also
◆ SetArrayMagnitudeException()
virtual void vtkPVRepresentedArrayListSettings::SetArrayMagnitudeException ( int  idx,
int  ncomp
See also
◆ SetNumberOfArrayMagnitudeExceptions()
virtual void vtkPVRepresentedArrayListSettings::SetNumberOfArrayMagnitudeExceptions ( int  nexceptions)
See also
◆ ShouldUseMagnitudeMode()
virtual bool vtkPVRepresentedArrayListSettings::ShouldUseMagnitudeMode ( int  ncomp) const
This will internally use the informations given by ComputeArrayMagnitude and ArrayMagnitudeExceptions.
See also
◆ SetNumberOfChartsDefaultXAxis()
virtual void vtkPVRepresentedArrayListSettings::SetNumberOfChartsDefaultXAxis ( int  n)
◆ GetNumberOfChartsDefaultXAxis()
virtual int vtkPVRepresentedArrayListSettings::GetNumberOfChartsDefaultXAxis ( ) const
◆ SetChartsDefaultXAxis()
virtual void vtkPVRepresentedArrayListSettings::SetChartsDefaultXAxis ( int  i,
◆ GetChartsDefaultXAxis()
virtual const char* vtkPVRepresentedArrayListSettings::GetChartsDefaultXAxis ( int  i) const
◆ GetAllChartsDefaultXAxis()
virtual const std::vector<std::string>& vtkPVRepresentedArrayListSettings::GetAllChartsDefaultXAxis ( ) const
◆ SetNumberOfChartsHiddenAttributes()
virtual void vtkPVRepresentedArrayListSettings::SetNumberOfChartsHiddenAttributes ( int  n)
If the name of the array matches one of the regex then it will be hidden by defaults, otherwise it will be visible.
See GetSeriesVisibilityDefault to evaluate the default visibility of a given array name.
◆ GetNumberOfChartsHiddenAttributes()
virtual int vtkPVRepresentedArrayListSettings::GetNumberOfChartsHiddenAttributes ( ) const
◆ SetChartsHiddenAttributes()
virtual void vtkPVRepresentedArrayListSettings::SetChartsHiddenAttributes ( int  i,
◆ GetAllChartsHiddenAttributes()
virtual const std::vector<vtksys::RegularExpression>& vtkPVRepresentedArrayListSettings::GetAllChartsHiddenAttributes ( ) const
◆ GetSeriesVisibilityDefault()
virtual bool vtkPVRepresentedArrayListSettings::GetSeriesVisibilityDefault ( const char *  name) const
◆ SetNumberOfExcludedNameFilters()
virtual void vtkPVRepresentedArrayListSettings::SetNumberOfExcludedNameFilters ( int  n)
Deprecated:
All following settings has been moved from this class to vtkPVIOSettings.
◆ GetNumberOfExcludedNameFilters()
virtual int vtkPVRepresentedArrayListSettings::GetNumberOfExcludedNameFilters ( )
Deprecated:
◆ SetExcludedNameFilter()
virtual void vtkPVRepresentedArrayListSettings::SetExcludedNameFilter ( int  i,
Deprecated:
◆ GetExcludedNameFilter()
virtual const char* vtkPVRepresentedArrayListSettings::GetExcludedNameFilter ( int  i)
Deprecated:
◆ GetAllNameFilters()
vtkStringArray* vtkPVRepresentedArrayListSettings::GetAllNameFilters ( )
Deprecated:
