vtkSMBoundsDomain Class Reference
double range domain based on data set bounds More...
#include <vtkSMBoundsDomain.h>
Inheritance diagram for vtkSMBoundsDomain:
Collaboration diagram for vtkSMBoundsDomain:
enum  Modes {
  NORMAL, MAGNITUDE, ORIENTED_MAGNITUDE, SCALED_EXTENT,
  ARRAY_SCALED_EXTENT, APPROXIMATE_CELL_LENGTH, DATA_BOUNDS, EXTENTS,
  COMPONENT_MAGNITUDE
 SCALED_EXTENT: is used for vtkPVScaleFactorEntry. More...
enum  Axes {
  X_AXIS = 1, Y_AXIS = 2, Z_AXIS = 4, X_AND_Y_AXES = X_AXIS | Y_AXIS,
  Y_AND_Z_AXES = Y_AXIS | Z_AXIS, X_AND_Z_AXES = X_AXIS | Z_AXIS, X_Y_AND_Z_AXES = X_AXIS | Y_AXIS | Z_AXIS
typedef vtkSMDoubleRangeDomain Superclass
- Public Types inherited from vtkSMDoubleRangeDomain
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
void Update (vtkSMProperty *) override
 Update self checking the "unchecked" values of all required properties. More...
virtual double GetScaleFactor ()
virtual int GetAxisFlags ()
int SetDefaultValues (vtkSMProperty *property, bool use_unchecked_values) override
 Overridden to handle APPROXIMATE_CELL_LENGTH. More...
virtual void SetMode (int)
virtual int GetMode ()
- Public Member Functions inherited from vtkSMDoubleRangeDomain
virtual double GetMinimum (unsigned int idx, int &exists)
 Return a min. More...
virtual double GetMaximum (unsigned int idx, int &exists)
 Return a max. More...
virtual int GetMinimumExists (unsigned int idx)
 Returns if minimum/maximum bound is set for the domain. More...
virtual int GetMaximumExists (unsigned int idx)
virtual double GetMinimum (unsigned int idx)
 Returns the minimum/maximum value, is exists, otherwise 0 is returned. More...
virtual double GetMaximum (unsigned int idx)
virtual int GetResolution ()
 Returns the resolution. More...
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
 Set the value of an element of a property from the animation editor. More...
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
 A vtkSMProperty is often defined with a default value in the XML itself. More...
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMBoundsDomain * New ()
static vtkSMBoundsDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDoubleRangeDomain
static vtkSMDoubleRangeDomain * New ()
static vtkSMDoubleRangeDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMBoundsDomain ()
 ~vtkSMBoundsDomain () override
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override
vtkPVDataInformation * GetInputInformation ()
vtkSMIntVectorProperty * GetAxisFlagsInformation ()
bool IsAxisEnabled (int axis)
void SetDomainValues (double bounds[6])
void UpdateOriented ()
- Protected Member Functions inherited from vtkSMDoubleRangeDomain
 vtkSMDoubleRangeDomain ()
 ~vtkSMDoubleRangeDomain () override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void ChildSaveState (vtkPVXMLElement *domainElement)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
int Mode
double ScaleFactor
int AxisFlags
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
vtkSMBoundsDomain extends vtkSMDoubleRangeDomain to add support to determine the valid range for the values based on the dataset bounds. There are several Modes which can be used to control how the range is computed based on the data bounds (defined by the vtkSMBoundsDomain::Modes enum).
To determine the input data bounds, this domain depends on a required property with function Input. The data-information from the source-proxy set as the value for that property is used to determine the bounds.
Supported XML attributes:
Definition at line 59 of file vtkSMBoundsDomain.h.
Definition at line 63 of file vtkSMBoundsDomain.h.
◆ Modes
Enumerator
NORMAL
MAGNITUDE
ORIENTED_MAGNITUDE
SCALED_EXTENT
ARRAY_SCALED_EXTENT
DATA_BOUNDS
EXTENTS
COMPONENT_MAGNITUDE
Definition at line 80 of file vtkSMBoundsDomain.h.
◆ Axes
Enumerator
X_AXIS
Y_AXIS
Z_AXIS
X_AND_Y_AXES
Y_AND_Z_AXES
X_AND_Z_AXES
X_Y_AND_Z_AXES
Definition at line 95 of file vtkSMBoundsDomain.h.
◆ vtkSMBoundsDomain()
vtkSMBoundsDomain::vtkSMBoundsDomain ( )
◆ ~vtkSMBoundsDomain()
vtkSMBoundsDomain::~vtkSMBoundsDomain ( )
static vtkSMBoundsDomain* vtkSMBoundsDomain::New ( )
virtual const char* vtkSMBoundsDomain::GetClassName ( )
Reimplemented from vtkSMDoubleRangeDomain.
static int vtkSMBoundsDomain::IsTypeOf ( const char *  type)
virtual int vtkSMBoundsDomain::IsA ( const char *  type)
static vtkSMBoundsDomain* vtkSMBoundsDomain::SafeDownCast ( vtkObject *  o)
void vtkSMBoundsDomain::PrintSelf ( ostream &  os,
◆ Update()
void vtkSMBoundsDomain::Update ( vtkSMProperty *  )
◆ SetMode()
virtual void vtkSMBoundsDomain::SetMode ( int  )
◆ GetMode()
virtual int vtkSMBoundsDomain::GetMode ( )
◆ GetScaleFactor()
virtual double vtkSMBoundsDomain::GetScaleFactor ( )
◆ GetAxisFlags()
virtual int vtkSMBoundsDomain::GetAxisFlags ( )
◆ SetDefaultValues()
int vtkSMBoundsDomain::SetDefaultValues ( vtkSMProperty *  property,
override
◆ ReadXMLAttributes()
int vtkSMBoundsDomain::ReadXMLAttributes ( vtkSMProperty *  prop,
vtkPVXMLElement *  element
overrideprotectedvirtual
◆ GetInputInformation()
vtkPVDataInformation* vtkSMBoundsDomain::GetInputInformation ( )
◆ GetAxisFlagsInformation()
vtkSMIntVectorProperty* vtkSMBoundsDomain::GetAxisFlagsInformation ( )
◆ IsAxisEnabled()
bool vtkSMBoundsDomain::IsAxisEnabled ( int  axis)
◆ SetDomainValues()
void vtkSMBoundsDomain::SetDomainValues ( double  bounds[6])
◆ UpdateOriented()
void vtkSMBoundsDomain::UpdateOriented ( )
◆ Mode
int vtkSMBoundsDomain::Mode
Definition at line 136 of file vtkSMBoundsDomain.h.
◆ ScaleFactor
double vtkSMBoundsDomain::ScaleFactor
Definition at line 137 of file vtkSMBoundsDomain.h.
◆ AxisFlags
int vtkSMBoundsDomain::AxisFlags
Definition at line 138 of file vtkSMBoundsDomain.h.
