Public Member Functions | Protected Member Functions | List of all members
pqInteractiveProperty2DWidget Class Reference
pqInteractiveProperty2DWidget is an abstract pqInteractivePropertyWidgetAbstract subclass designed to serve as the superclass for all pqInteractivePropertyWidgetAbstract types that have interactive widget (also called 2D Widgets) associated with them. More...
#include <pqInteractiveProperty2DWidget.h>
Inheritance diagram for pqInteractiveProperty2DWidget:
Collaboration diagram for pqInteractiveProperty2DWidget:
 pqInteractiveProperty2DWidget (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqInteractiveProperty2DWidget () override
vtkSMNew2DWidgetRepresentationProxy * widgetProxy () const
 Returns the proxy for the interactive 2D widget. More...
- Public Member Functions inherited from pqInteractivePropertyWidgetAbstract
 pqInteractivePropertyWidgetAbstract (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqInteractivePropertyWidgetAbstract () override
void reset () override
 Overridden to call this->render() to ensure that the widget is redrawn. More...
void setView (pqView *view) override
 Overridden to show the widget proxy in the new view. More...
bool isWidgetVisible () const
 Returns the interactive widget's visibility. More...
vtkSMProxy * dataSource () const
 Returns the data source. More...
vtkBoundingBox dataBounds (bool visibleOnly=false) const
 Returns bounds from the dataSource, if possible. More...
vtkSMPropertyGroup * propertyGroup () const
 Returns the vtkSMPropertyGroup pass to the constructor. More...
void hideEvent (QHideEvent *) override
 Overriden in order to hide the VTK widget. More...
void showEvent (QShowEvent *) override
 Overriden in order to show the VTK widget. More...
void select () override
 In these methods, we show/hide the widget since the interactive widget is not supposed to be visible except when the panel is "active" or "selected". More...
void deselect () override
void selectPort (int portIndex) final
 ~pqPropertyWidget () override
virtual void apply ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
bool isSelected () const
vtkSMNewWidgetRepresentationProxyAbstract * internalWidgetProxy () final
 Get the internal instance of the widget proxy. More...
- Protected Member Functions inherited from pqInteractivePropertyWidgetAbstract
void setupConnections (vtkSMNewWidgetRepresentationProxyAbstract *widget, vtkSMPropertyGroup *smgroup, vtkSMProxy *smproxy)
 Setup all the links and events for the given widget and SM property group. More...
void setupUserObserver (vtkSMProxy *smproxy)
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
- Public Slots inherited from pqInteractivePropertyWidgetAbstract
virtual void setWidgetVisible (bool val)
 Toggle the interactive widget's visibility. More...
void setDataSource (vtkSMProxy *dataSource)
 DataSource is used by interactive widgets to determine now to place the widget in the view e.g. More...
- Signals inherited from pqInteractivePropertyWidgetAbstract
void widgetVisibilityToggled (bool)
 Fired whenever setWidgetVisible() changes the widget's visibility. More...
void widgetVisibilityUpdated (bool)
 Fired whenever the widgets visibility is updated for whatever reason, be it because the panel was selected/deselected or the view changed, etc. More...
void startInteraction ()
 Fired by the underlying interactive widget representation proxy, for each respective events. More...
void interaction ()
void endInteraction ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
- Protected Slots inherited from pqInteractivePropertyWidgetAbstract
virtual void placeWidget ()=0
 Places the interactive widget using current data source information. More...
void render ()
 Safe call render on the view. More...
virtual void updateWidgetVisibility ()
 This method is called to update the state of Visibility and Enabled properties on the widget based on the state of isWidgetVisible(), isSelected() and the active view. More...
- Protected Attributes inherited from pqInteractivePropertyWidgetAbstract
bool VisibleState = true
bool WidgetVisibility = false
int LinkedPortIndex = -1
- Properties inherited from pqInteractivePropertyWidgetAbstract
pqSMProxy dataSource
pqInteractiveProperty2DWidget is intended to provide a Qt widget (along with an interactive widget in the active view) for controlling properties on the proxy identified by a vtkSMPropertyGroup passed to the constructor. Subclasses are free to determine which interactive widget to create and how to setup the UI for it.
pqInteractiveProperty2DWidget is basically the same as pqInteractivePropertyWidget but use vtkSMNew2DWidgetRepresentationProxy instead vtkSMNewWidgetRepresentationProxy
Definition at line 31 of file pqInteractiveProperty2DWidget.h.
◆ pqInteractiveProperty2DWidget()
pqInteractiveProperty2DWidget::pqInteractiveProperty2DWidget ( const char *  widget_smgroup,
const char *  widget_smname,
vtkSMProxy *  proxy,
QWidget *  parent = nullptr
◆ ~pqInteractiveProperty2DWidget()
pqInteractiveProperty2DWidget::~pqInteractiveProperty2DWidget ( )
override
◆ widgetProxy()
vtkSMNew2DWidgetRepresentationProxy* pqInteractiveProperty2DWidget::widgetProxy ( ) const
inline
Definition at line 45 of file pqInteractiveProperty2DWidget.h.
◆ internalWidgetProxy()
vtkSMNewWidgetRepresentationProxyAbstract* pqInteractiveProperty2DWidget::internalWidgetProxy ( )
inlinefinalprotectedvirtual
Implements pqInteractivePropertyWidgetAbstract.
Definition at line 51 of file pqInteractiveProperty2DWidget.h.
