vtkSMNew2DWidgetRepresentationProxy Class Reference
proxy for 2D widgets and their representations in ParaView. More...
#include <vtkSMNew2DWidgetRepresentationProxy.h>
Inheritance diagram for vtkSMNew2DWidgetRepresentationProxy:
Collaboration diagram for vtkSMNew2DWidgetRepresentationProxy:
typedef vtkSMNewWidgetRepresentationProxyAbstract Superclass
- Public Types inherited from vtkSMNewWidgetRepresentationProxyAbstract
typedef vtkSMProxy Superclass
virtual vtkSMProxy * GetContextItemProxy ()
 Get Representation Proxy. More...
- Public Member Functions inherited from vtkSMNewWidgetRepresentationProxyAbstract
bool LinkProperties (vtkSMProxy *controlledProxy, vtkSMPropertyGroup *controlledPropertyGroup)
 Called to link properties from a Widget to controlledProxy i.e. More...
bool UnlinkProperties (vtkSMProxy *controlledProxy)
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMNew2DWidgetRepresentationProxy * New ()
static vtkSMNew2DWidgetRepresentationProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMNewWidgetRepresentationProxyAbstract
static vtkSMNewWidgetRepresentationProxyAbstract * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMNew2DWidgetRepresentationProxy ()
 ~vtkSMNew2DWidgetRepresentationProxy () override
void ExecuteEvent (unsigned long event) override
 Called every time the user interacts with the widget. More...
 Overridden from vtkSMProxy to call BeginCreateVTKObjects() and EndCreateVTKObjects(). More...
- Protected Member Functions inherited from vtkSMNewWidgetRepresentationProxyAbstract
 vtkSMNewWidgetRepresentationProxyAbstract ()
 ~vtkSMNewWidgetRepresentationProxyAbstract () override
void ProcessLinkedPropertyEvent (vtkSMProperty *caller, unsigned long event)
 Called everytime a controlled property's unchecked values change. More...
void SetupPropertiesLinks ()
 Setup all links between properties and informations. More...
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkWeakPointer< vtkContextItem > ContextItem
vtkSMProxy * ContextItemProxy = nullptr
- Protected Attributes inherited from vtkSMNewWidgetRepresentationProxyAbstract
vtkNew< vtkSMWidgetObserver > Observer
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMNew2DWidgetRepresentationProxy is a proxy for 2D widgets and their representations.
Definition at line 20 of file vtkSMNew2DWidgetRepresentationProxy.h.
Definition at line 25 of file vtkSMNew2DWidgetRepresentationProxy.h.
◆ vtkSMNew2DWidgetRepresentationProxy()
vtkSMNew2DWidgetRepresentationProxy::vtkSMNew2DWidgetRepresentationProxy ( )
◆ ~vtkSMNew2DWidgetRepresentationProxy()
vtkSMNew2DWidgetRepresentationProxy::~vtkSMNew2DWidgetRepresentationProxy ( )
static vtkSMNew2DWidgetRepresentationProxy* vtkSMNew2DWidgetRepresentationProxy::New ( )
virtual const char* vtkSMNew2DWidgetRepresentationProxy::GetClassName ( )
static int vtkSMNew2DWidgetRepresentationProxy::IsTypeOf ( const char *  type)
virtual int vtkSMNew2DWidgetRepresentationProxy::IsA ( const char *  type)
static vtkSMNew2DWidgetRepresentationProxy* vtkSMNew2DWidgetRepresentationProxy::SafeDownCast ( vtkObject *  o)
void vtkSMNew2DWidgetRepresentationProxy::PrintSelf ( ostream &  os,
◆ GetContextItemProxy()
virtual vtkSMProxy* vtkSMNew2DWidgetRepresentationProxy::GetContextItemProxy ( )
◆ ExecuteEvent()
void vtkSMNew2DWidgetRepresentationProxy::ExecuteEvent ( unsigned long  event)
overrideprotectedvirtual
Implements vtkSMNewWidgetRepresentationProxyAbstract.
◆ CreateVTKObjects()
void vtkSMNew2DWidgetRepresentationProxy::CreateVTKObjects ( )
◆ ContextItem
vtkWeakPointer<vtkContextItem> vtkSMNew2DWidgetRepresentationProxy::ContextItem
Definition at line 48 of file vtkSMNew2DWidgetRepresentationProxy.h.
◆ ContextItemProxy
vtkSMProxy* vtkSMNew2DWidgetRepresentationProxy::ContextItemProxy = nullptr
Definition at line 49 of file vtkSMNew2DWidgetRepresentationProxy.h.
