Public Slots | Signals | Public Member Functions | Protected Slots | Protected Member Functions | Properties | List of all members
pqCoordinateFramePropertyWidget Class Reference
pqCoordinateFramePropertyWidget is a custom property widget that uses "CoordinateFrameWidgetRepresentation" to help users interactively set the origin and normal for a plane. More...
#include <pqCoordinateFramePropertyWidget.h>
Inheritance diagram for pqCoordinateFramePropertyWidget:
Collaboration diagram for pqCoordinateFramePropertyWidget:
Public Slots
void useXNormal ()
 Set the widget normal to be along the X axis. More...
void useYNormal ()
 Set the widget normal to be along the Y axis. More...
void useZNormal ()
 Set the widget normal to be along the Z axis. More...
void resetToWorldXYZ ()
 Reset the axes to align with world coordinate axes. More...
void resetToDataBounds ()
 Update the widget's origin and bounds using current data bounds. More...
void resetCameraToNormal ()
 Reset the camera to be down the locked (or nearest) coordinate-frame axis. More...
void useCameraNormal ()
 Set the locked (or nearest) coordinate frame axis to be along the camera view direction. More...
void setUserXAxis ()
 Set the X-,Y-, or Z-axis with user-specified values and update the other axes accordingly. More...
void setUserYAxis ()
void setUserZAxis ()
- Public Slots inherited from pqInteractivePropertyWidgetAbstract
virtual void setWidgetVisible (bool val)
 Toggle the interactive widget's visibility. More...
void setDataSource (vtkSMProxy *dataSource)
 DataSource is used by interactive widgets to determine now to place the widget in the view e.g. More...
Signals
void lockedAxisChangedByUser (int)
- Signals inherited from pqInteractivePropertyWidgetAbstract
void widgetVisibilityToggled (bool)
 Fired whenever setWidgetVisible() changes the widget's visibility. More...
void widgetVisibilityUpdated (bool)
 Fired whenever the widgets visibility is updated for whatever reason, be it because the panel was selected/deselected or the view changed, etc. More...
void startInteraction ()
 Fired by the underlying interactive widget representation proxy, for each respective events. More...
void interaction ()
void endInteraction ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqCoordinateFramePropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqCoordinateFramePropertyWidget () override
int getLockedAxis () const
 Set/get which axis is locked. More...
void setLockedAxis (int lockedAxis)
- Public Member Functions inherited from pqInteractivePropertyWidget
 pqInteractivePropertyWidget (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqInteractivePropertyWidget () override
vtkSMNewWidgetRepresentationProxy * widgetProxy () const
 Returns the proxy for the 3D interactive widget. More...
- Public Member Functions inherited from pqInteractivePropertyWidgetAbstract
 pqInteractivePropertyWidgetAbstract (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqInteractivePropertyWidgetAbstract () override
void reset () override
 Overridden to call this->render() to ensure that the widget is redrawn. More...
void setView (pqView *view) override
 Overridden to show the widget proxy in the new view. More...
bool isWidgetVisible () const
 Returns the interactive widget's visibility. More...
vtkSMProxy * dataSource () const
 Returns the data source. More...
vtkBoundingBox dataBounds (bool visibleOnly=false) const
 Returns bounds from the dataSource, if possible. More...
vtkSMPropertyGroup * propertyGroup () const
 Returns the vtkSMPropertyGroup pass to the constructor. More...
void hideEvent (QHideEvent *) override
 Overriden in order to hide the VTK widget. More...
void showEvent (QShowEvent *) override
 Overriden in order to show the VTK widget. More...
void select () override
 In these methods, we show/hide the widget since the interactive widget is not supposed to be visible except when the panel is "active" or "selected". More...
void deselect () override
void selectPort (int portIndex) final
 ~pqPropertyWidget () override
virtual void apply ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
bool isSelected () const
Protected Slots
void placeWidget () override
 Places the interactive widget using current data source information. More...
- Protected Slots inherited from pqInteractivePropertyWidgetAbstract
virtual void placeWidget ()=0
void render ()
 Safe call render on the view. More...
virtual void updateWidgetVisibility ()
 This method is called to update the state of Visibility and Enabled properties on the widget based on the state of isWidgetVisible(), isSelected() and the active view. More...
void setUserAxis (int axis)
- Protected Member Functions inherited from pqInteractivePropertyWidget
vtkSMNewWidgetRepresentationProxyAbstract * internalWidgetProxy () final
 Get the internal instance of the widget proxy. More...
- Protected Member Functions inherited from pqInteractivePropertyWidgetAbstract
void setupConnections (vtkSMNewWidgetRepresentationProxyAbstract *widget, vtkSMPropertyGroup *smgroup, vtkSMProxy *smproxy)
 Setup all the links and events for the given widget and SM property group. More...
void setupUserObserver (vtkSMProxy *smproxy)
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
Properties
int lockedAxis
- Properties inherited from pqInteractivePropertyWidgetAbstract
pqSMProxy dataSource
template<class T >
- Protected Attributes inherited from pqInteractivePropertyWidgetAbstract
bool VisibleState = true
bool WidgetVisibility = false
int LinkedPortIndex = -1
To use this widget for a property group (vtkSMPropertyGroup), use "InteractiveFrame" as the "panel_widget" in the XML configuration for the proxy. The property group should have properties for following functions:
Definition at line 27 of file pqCoordinateFramePropertyWidget.h.
◆ pqCoordinateFramePropertyWidget()
pqCoordinateFramePropertyWidget::pqCoordinateFramePropertyWidget ( vtkSMProxy *  proxy,
QWidget *  parent = nullptr
◆ ~pqCoordinateFramePropertyWidget()
pqCoordinateFramePropertyWidget::~pqCoordinateFramePropertyWidget ( )
override
◆ getLockedAxis()
int pqCoordinateFramePropertyWidget::getLockedAxis ( ) const
(-1 indicates no axis is locked.)
◆ setLockedAxis()
void pqCoordinateFramePropertyWidget::setLockedAxis ( int  lockedAxis)
◆ useXNormal
void pqCoordinateFramePropertyWidget::useXNormal ( )
inlineslot
Definition at line 49 of file pqCoordinateFramePropertyWidget.h.
◆ useYNormal
void pqCoordinateFramePropertyWidget::useYNormal ( )
inlineslot
Definition at line 54 of file pqCoordinateFramePropertyWidget.h.
◆ useZNormal
void pqCoordinateFramePropertyWidget::useZNormal ( )
inlineslot
Definition at line 59 of file pqCoordinateFramePropertyWidget.h.
◆ resetToWorldXYZ
void pqCoordinateFramePropertyWidget::resetToWorldXYZ ( )
slot
◆ resetToDataBounds
void pqCoordinateFramePropertyWidget::resetToDataBounds ( )
slot
◆ resetCameraToNormal
void pqCoordinateFramePropertyWidget::resetCameraToNormal ( )
slot
◆ useCameraNormal
void pqCoordinateFramePropertyWidget::useCameraNormal ( )
slot
◆ setUserXAxis
void pqCoordinateFramePropertyWidget::setUserXAxis ( )
slot
◆ setUserYAxis
void pqCoordinateFramePropertyWidget::setUserYAxis ( )
slot
◆ setUserZAxis
void pqCoordinateFramePropertyWidget::setUserZAxis ( )
slot
◆ placeWidget
void pqCoordinateFramePropertyWidget::placeWidget ( )
overrideprotectedslot
◆ setUserAxis()
void pqCoordinateFramePropertyWidget::setUserAxis ( int  axis)
◆ lockedAxisChangedByUser
void pqCoordinateFramePropertyWidget::lockedAxisChangedByUser ( int  )
signal
Property Documentation
◆ lockedAxis
int pqCoordinateFramePropertyWidget::lockedAxis
readwrite
Definition at line 31 of file pqCoordinateFramePropertyWidget.h.
