Public Slots | Signals | Public Member Functions | Properties | List of all members
pqArraySelectorPropertyWidget Class Reference
pqPropertyWidget subclass for properties with vtkSMArrayListDomain. More...
#include <pqArraySelectorPropertyWidget.h>
Inheritance diagram for pqArraySelectorPropertyWidget:
Collaboration diagram for pqArraySelectorPropertyWidget:
Public Slots
void setArray (int assoc, const QString &val)
 Set the chosen array name and association. More...
void setArray (const QList< QVariant > &val)
 A setArray overload useful to expose the setArray using Qt's property system. More...
void setArrayName (const QString &name)
 Set the array name without caring for the array association. More...
Signals
void arrayChanged ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqArraySelectorPropertyWidget (vtkSMProperty *smproperty, vtkSMProxy *smproxy, QWidget *parent=nullptr)
 pqArraySelectorPropertyWidget (vtkSMProperty *smproperty, vtkSMProxy *smproxy, std::initializer_list< QPair< int, QString >> knownArrays, QWidget *parent=nullptr)
 ~pqArraySelectorPropertyWidget () override
QString arrayName () const
 Returns the chosen array name. More...
int arrayAssociation () const
 Returns the chosen array association. More...
QList< QVariant > array () const
 Returns the {association, name} for the chosen array. More...
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Properties
QString arrayName
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
pqArraySelectorPropertyWidget is intended to be used for vtkSMStringVectorProperty instances that have a vtkSMArrayListDomain domain and want to show a single combo-box to allow the user to choose the array to use.
We support non-repeatable string-vector property with a 1, 2, or 5 elements. When 1 element is present, we interpret the property value as the name of chosen array, thus the user won't be able to pick array association. While for 2 and 5 element properties the array association and name can be picked.
The list of available arrays is built using the vtkSMArrayListDomain and updated anytime the domain is updated. If the currently chosen value is no longer in the domain, we will preserve it and flag it by adding a (?) suffix to the displayed label.
pqStringVectorPropertyWidget::createWidget instantiates this for any string vector property with a vtkSMArrayListDomain that is not repeatable.
Pre-defined entries can be provided with the KnownArrays argument when constructing the widget.
Definition at line 38 of file pqArraySelectorPropertyWidget.h.
◆ pqArraySelectorPropertyWidget() [1/2]
pqArraySelectorPropertyWidget::pqArraySelectorPropertyWidget ( vtkSMProperty *  smproperty,
vtkSMProxy *  smproxy,
QWidget *  parent = nullptr
◆ pqArraySelectorPropertyWidget() [2/2]
◆ ~pqArraySelectorPropertyWidget()
pqArraySelectorPropertyWidget::~pqArraySelectorPropertyWidget ( )
override
◆ arrayName()
QString pqArraySelectorPropertyWidget::arrayName ( ) const
◆ arrayAssociation()
int pqArraySelectorPropertyWidget::arrayAssociation ( ) const
◆ array()
QList<QVariant> pqArraySelectorPropertyWidget::array ( ) const
◆ setArray [1/2]
void pqArraySelectorPropertyWidget::setArray ( int  assoc,
const QString &  val
slot
◆ setArray [2/2]
void pqArraySelectorPropertyWidget::setArray ( const QList< QVariant > &  val)
slot
val must be a two-tuple.
◆ setArrayName
void pqArraySelectorPropertyWidget::setArrayName ( const QString &  name)
slot
In general, this is only meant to be used for connecting to a SMProperty which only lets the user choose the array name and not the association.
◆ arrayChanged
void pqArraySelectorPropertyWidget::arrayChanged ( )
signal
Property Documentation
◆ array
readwrite
Definition at line 43 of file pqArraySelectorPropertyWidget.h.
◆ arrayName
readwrite
