Public Member Functions | Static Public Member Functions | List of all members
pqStringVectorPropertyWidget Class Reference
#include <pqStringVectorPropertyWidget.h>
Inheritance diagram for pqStringVectorPropertyWidget:
Collaboration diagram for pqStringVectorPropertyWidget:
 pqStringVectorPropertyWidget (vtkSMProperty *property, vtkSMProxy *proxy, QWidget *parent=nullptr)
 ~pqStringVectorPropertyWidget () override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
static pqPropertyWidget * createWidget (vtkSMStringVectorProperty *smproperty, vtkSMProxy *smproxy, QWidget *parent=nullptr)
 Factory method to instantiate a hard-coded type of pqPropertyWidget subclass for t he vtkSMStringVectorProperty. More...
static void processFileChooserHints (vtkPVXMLElement *hints, bool &directoryMode, bool &anyFile, QString &filter, bool &browseLocalFileSystem)
 Method to process file-choice related hints. More...
template<class T >
void changeAvailable ()
void changeFinished ()
void restartRequired ()
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
Definition at line 12 of file pqStringVectorPropertyWidget.h.
◆ pqStringVectorPropertyWidget()
pqStringVectorPropertyWidget::pqStringVectorPropertyWidget ( vtkSMProperty *  property,
vtkSMProxy *  proxy,
QWidget *  parent = nullptr
◆ ~pqStringVectorPropertyWidget()
pqStringVectorPropertyWidget::~pqStringVectorPropertyWidget ( )
override
◆ createWidget()
static pqPropertyWidget* pqStringVectorPropertyWidget::createWidget ( vtkSMStringVectorProperty *  smproperty,
vtkSMProxy *  smproxy,
◆ processFileChooserHints()
static void pqStringVectorPropertyWidget::processFileChooserHints ( vtkPVXMLElement *  hints,
bool &  directoryMode,
bool &  anyFile,
QString &  filter,
bool &  browseLocalFileSystem
