Signals | Public Member Functions | Protected Slots | Properties | List of all members
pqAnglePropertyWidget Class Reference
pqAnglePropertyWidget is a custom property widget that uses "PolyLineWidgetRepresentation" to help users interactively set points that form an angle defined by 3 point. More...
#include <pqAnglePropertyWidget.h>
Inheritance diagram for pqAnglePropertyWidget:
Collaboration diagram for pqAnglePropertyWidget:
Signals
void pointsChanged ()
 Signal fired whenever the points are changed. More...
- Signals inherited from pqInteractivePropertyWidgetAbstract
void widgetVisibilityToggled (bool)
 Fired whenever setWidgetVisible() changes the widget's visibility. More...
void widgetVisibilityUpdated (bool)
 Fired whenever the widgets visibility is updated for whatever reason, be it because the panel was selected/deselected or the view changed, etc. More...
void startInteraction ()
 Fired by the underlying interactive widget representation proxy, for each respective events. More...
void interaction ()
void endInteraction ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqAnglePropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqAnglePropertyWidget () override
QList< QVariant > points () const
 Get/Set the points that form the angle. More...
void setPoints (const QList< QVariant > &points)
- Public Member Functions inherited from pqInteractivePropertyWidget
 pqInteractivePropertyWidget (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqInteractivePropertyWidget () override
vtkSMNewWidgetRepresentationProxy * widgetProxy () const
 Returns the proxy for the 3D interactive widget. More...
- Public Member Functions inherited from pqInteractivePropertyWidgetAbstract
 pqInteractivePropertyWidgetAbstract (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqInteractivePropertyWidgetAbstract () override
void reset () override
 Overridden to call this->render() to ensure that the widget is redrawn. More...
void setView (pqView *view) override
 Overridden to show the widget proxy in the new view. More...
bool isWidgetVisible () const
 Returns the interactive widget's visibility. More...
vtkSMProxy * dataSource () const
 Returns the data source. More...
vtkBoundingBox dataBounds (bool visibleOnly=false) const
 Returns bounds from the dataSource, if possible. More...
vtkSMPropertyGroup * propertyGroup () const
 Returns the vtkSMPropertyGroup pass to the constructor. More...
void hideEvent (QHideEvent *) override
 Overriden in order to hide the VTK widget. More...
void showEvent (QShowEvent *) override
 Overriden in order to show the VTK widget. More...
void select () override
 In these methods, we show/hide the widget since the interactive widget is not supposed to be visible except when the panel is "active" or "selected". More...
void deselect () override
void selectPort (int portIndex) final
 ~pqPropertyWidget () override
virtual void apply ()
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
bool isSelected () const
Protected Slots
void placeWidget () override
void updateLabels ()
- Protected Slots inherited from pqInteractivePropertyWidgetAbstract
virtual void placeWidget ()=0
 Places the interactive widget using current data source information. More...
void render ()
 Safe call render on the view. More...
virtual void updateWidgetVisibility ()
 This method is called to update the state of Visibility and Enabled properties on the widget based on the state of isWidgetVisible(), isSelected() and the active view. More...
Properties
- Properties inherited from pqInteractivePropertyWidgetAbstract
pqSMProxy dataSource
- Public Slots inherited from pqInteractivePropertyWidgetAbstract
virtual void setWidgetVisible (bool val)
 Toggle the interactive widget's visibility. More...
void setDataSource (vtkSMProxy *dataSource)
 DataSource is used by interactive widgets to determine now to place the widget in the view e.g. More...
template<class T >
- Protected Member Functions inherited from pqInteractivePropertyWidget
vtkSMNewWidgetRepresentationProxyAbstract * internalWidgetProxy () final
 Get the internal instance of the widget proxy. More...
- Protected Member Functions inherited from pqInteractivePropertyWidgetAbstract
void setupConnections (vtkSMNewWidgetRepresentationProxyAbstract *widget, vtkSMPropertyGroup *smgroup, vtkSMProxy *smproxy)
 Setup all the links and events for the given widget and SM property group. More...
void setupUserObserver (vtkSMProxy *smproxy)
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
- Protected Attributes inherited from pqInteractivePropertyWidgetAbstract
bool VisibleState = true
bool WidgetVisibility = false
int LinkedPortIndex = -1
To use this widget for a property group (vtkSMPropertyGroup), use "InteractiveAngle" as the "panel_widget" in the XML configuration. The property group can have properties for following functions:
Definition at line 22 of file pqAnglePropertyWidget.h.
◆ pqAnglePropertyWidget()
pqAnglePropertyWidget::pqAnglePropertyWidget ( vtkSMProxy *  proxy,
QWidget *  parent = nullptr
◆ ~pqAnglePropertyWidget()
pqAnglePropertyWidget::~pqAnglePropertyWidget ( )
override
◆ points()
QList<QVariant> pqAnglePropertyWidget::points ( ) const
Size should always be 9.
◆ setPoints()
void pqAnglePropertyWidget::setPoints ( const QList< QVariant > &  points)
◆ pointsChanged
void pqAnglePropertyWidget::pointsChanged ( )
signal
◆ placeWidget
void pqAnglePropertyWidget::placeWidget ( )
overrideprotectedslot
◆ updateLabels
void pqAnglePropertyWidget::updateLabels ( )
protectedslot
Property Documentation
◆ points
readwrite
Definition at line 24 of file pqAnglePropertyWidget.h.
