pqPipelineRepresentation.h
3  Program: ParaView
4  Module: pqPipelineRepresentation.h
5
6  Copyright (c) 2005-2008 Sandia Corporation, Kitware Inc.
7  All rights reserved.
11
14  Kitware Inc.
15  28 Corporate Drive
16  Clifton Park, NY 12065
17  USA
18
30
31 =========================================================================*/
32
38 #ifndef _pqPipelineRepresentation_h
39 #define _pqPipelineRepresentation_h
40
41 #include "pqDataRepresentation.h"
42 #include <QPair>
43
44 class pqPipelineSource;
45 class pqRenderViewModule;
46 class pqServer;
51
58 class PQCORE_EXPORT pqPipelineRepresentation : public pqDataRepresentation
59 {
60  Q_OBJECT
62
63 public:
64  // Constructor.
65  // \c group :- smgroup in which the proxy has been registered.
66  // \c name :- smname as which the proxy has been registered.
67  // \c repr :- the representation proxy.
68  // \c server:- server on which the proxy is created.
69  // \c parent:- QObject parent.
70  pqPipelineRepresentation(const QString& group, const QString& name, vtkSMProxy* repr,
71  pqServer* server, QObject* parent = NULL);
72  ~pqPipelineRepresentation() override;
73
74  // Get the internal display proxy.
75  vtkSMRepresentationProxy* getRepresentationProxy() const;
76
77 protected:
78  // Overridden to set up some additional Qt connections
79  void setView(pqView* view) override;
80
81 public Q_SLOTS:
82  // If lookuptable is set up and is used for coloring,
83  // then calling this method resets the table ranges to match the current
84  // range of the selected array.
85  void resetLookupTableScalarRange();
86
87  // If lookuptable is set up and is used for coloring,
88  // then calling this method resets the table ranges to match the
89  // range of the selected array over time. This can potentially be a slow
90  // processes hence use with caution!!!
91  void resetLookupTableScalarRangeOverTime();
92 };
93
94 #endif
Proxy for a representations.
pqDataRepresentation is the superclass for a display for a pqPipelineSource i.e.
This is PQ representation for a single representation.
This is PQ representation for a single display.
This is a PQ abstraction of a generic view module.
Definition: pqView.h:54
name
Definition: vtkSMProxy.h:152
Data array information like type.
PQ representation for a vtkSMProxy that can be involved in a pipeline.
virtual void setView(pqView *)
Called by pqView when this representation gets added to / removed from the view.
pqServer (should be renamed to pqSession) is a pqServerManagerModelItem subclass that represents a vt...
Definition: pqServer.h:64
