pqDataRepresentation is the superclass for a display for a pqPipelineSource i.e. More...
#include <pqDataRepresentation.h>
Public Slots | |
| virtual void | updateLookupTable () |
| Slot to update the lookup table if the application setting to reset it on visibility changes is on. More... | |
| virtual void | resetAllTransferFunctionRangesUsingCurrentData () |
| void | onVisibilityChanged () override |
| Overridden to set the VisibilityChangedSinceLastUpdate flag. More... | |
Public Slots inherited from pqRepresentation | |
| void | renderView (bool force) |
| Renders the view to which this representation has been added if any. More... | |
| void | renderViewEventually () |
| Simply calls renderView(false);. More... | |
Signals | |
| void | dataUpdated () |
| Fired when the representation proxy fires the vtkCommand::UpdateDataEvent. More... | |
| void | colorTransferFunctionModified () |
| Fired to indicate that the "LookupTable" property (if any) on the representation was modified. More... | |
| void | colorArrayNameModified () |
| Signal fired to indicate that the "ColorArrayName" property (if any) on the representation was modified. More... | |
| void | attrArrayNameModified () |
| Signal fired to indicate that the rendering attribute arrays properties (Normals, TCoords, Tangents) were modified. More... | |
Signals inherited from pqRepresentation | |
| void | visibilityChanged (bool visible) |
| Fired when the visibility property of the underlying display changes. More... | |
| void | updated () |
| Fired whenever Update() is called on the underlying display proxy. More... | |
Signals inherited from pqProxy | |
| void | nameChanged (pqServerManagerModelItem *) |
| Fired when the name of the proxy is changed. More... | |
| void | modifiedStateChanged (pqServerManagerModelItem *) |
| Fired when the modified status changes for the proxy. More... | |
| pqDataRepresentation (const QString &group, const QString &name, vtkSMProxy *display, pqServer *server, QObject *parent=0) | |
| ~pqDataRepresentation () override | |
| pqPipelineSource * | getInput () const |
| Get the source/filter of which this is a display. More... | |
| pqOutputPort * | getOutputPortFromInput () const |
| Returns the input pqPipelineSource's output port to which this representation is connected. More... | |
| vtkPVDataInformation * | getInputDataInformation () const |
| Returns the data information for the data coming into the representation as input. More... | |
| vtkPVTemporalDataInformation * | getInputTemporalDataInformation () const |
| Returns the temporal data information for the input. More... | |
| vtkPVDataInformation * | getRepresentedDataInformation (bool update=true) const |
| Returns the represented data information. More... | |
| bool | getDataBounds (double bounds[6]) |
| Get the data bounds for the input of this display. More... | |
| virtual vtkSMProxy * | getLookupTableProxy () |
| Returns the lookuptable proxy, if any. More... | |
| virtual pqScalarsToColors * | getLookupTable () |
| Returns the pqScalarsToColors object for the lookup table proxy if any. More... | |
| unsigned long | getFullResMemorySize () |
| Returns the data size for the full-res data. More... | |
| pqDataRepresentation * | getRepresentationForUpstreamSource () const |
| This is convenience method to return first representation for the upstream stream filter/source in the same view as this representation. More... | |
Public Member Functions inherited from pqRepresentation | |
| pqRepresentation (const QString &group, const QString &name, vtkSMProxy *repr, pqServer *server, QObject *parent=NULL) | |
| ~pqRepresentation () override | |
| virtual bool | isVisible () const |
| Returns if the status of the visbility property of this display. More... | |
| virtual void | setVisible (bool visible) |
| Set the visibility. More... | |
| pqView * | getView () const |
| Returns the view to which this representation has been added, if any. More... | |
| vtkSMViewProxy * | getViewProxy () const |
| Returns the view proxy to which this representation has been added, if any. More... | |
Public Member Functions inherited from pqProxy | |
| pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=NULL) | |
| ~pqProxy () override | |
| Get the server on which this proxy exists. More... | |
| This is a convenience method. More... | |
| Get the name with which this proxy is registered on the server manager. More... | |
| Get the vtkSMProxy this object stands for. More... | |
| Gets whether or not the source has been modified. More... | |
| Sets whether or not the source has been modified. More... | |
| Returns the hints for this proxy, if any. More... | |
| Returns a list of all helper proxies. More... | |
| Returns a list of all the helper proxies added with a given key. More... | |
| Returns the keys for helper proxies. More... | |
| Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More... | |
| Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More... | |
| Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More... | |
| Return whether or not the user has modified the GUI name of the source. More... | |
Public Member Functions inherited from pqServerManagerModelItem | |
| pqServerManagerModelItem (QObject *parent=NULL) | |
| ~pqServerManagerModelItem () override | |
Protected Slots | |
| virtual void | onInputChanged () |
| called when input property on display changes. More... | |
Protected Slots inherited from pqRepresentation | |
| virtual void | onVisibilityChanged () |
| called when the display visibility property changes. More... | |
Protected Slots inherited from pqProxy | |
| void | onProxyRegistered (const QString &, const QString &, vtkSMProxy *) |
| void | onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *) |
| void | initialize () override |
| Use this method to initialize the pqObject state using the underlying vtkSMProxy. More... | |
Protected Member Functions inherited from pqRepresentation | |
| Called by pqView when this representation gets added to / removed from the view. More... | |
Protected Member Functions inherited from pqProxy | |
| Make this pqProxy take on a new identity. More... | |
Protected Member Functions inherited from pqServerManagerModelItem | |
| All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More... | |
Public Types inherited from pqProxy | |
| enum | ModifiedState { UNINITIALIZED, MODIFIED, UNMODIFIED } |
| The modification state of this proxy. More... | |
Static Public Member Functions inherited from pqProxy | |
| static pqProxy * | findProxyWithHelper (vtkSMProxy *aproxy, QString &key) |
| Returns a pqProxy instance, of any, whose helper proxy is the aproxy. More... | |
| static std::string | rstToHtml (const char *rstStr) |
| convert proxy documentation from RST to HTML (so that it can be used in Qt) More... | |
| static QString | rstToHtml (const QString &rstStr) |
the input for this display proxy is a pqPiplineSource. This class manages the linking between the pqPiplineSource and pqDataRepresentation.
Definition at line 52 of file pqDataRepresentation.h.
| pqDataRepresentation::pqDataRepresentation | ( | const QString & | group, |
| const QString & | name, | ||
| vtkSMProxy * | display, | ||
| pqServer * | server, | ||
| QObject * | parent = 0 |
| pqPipelineSource* pqDataRepresentation::getInput | ( | ) | const |
| pqOutputPort* pqDataRepresentation::getOutputPortFromInput | ( | ) | const |
| vtkPVDataInformation* pqDataRepresentation::getInputDataInformation | ( | ) | const |
| vtkPVTemporalDataInformation* pqDataRepresentation::getInputTemporalDataInformation | ( | ) | const |
This can be a very slow process. Use with extreme caution!!!
| vtkPVDataInformation* pqDataRepresentation::getRepresentedDataInformation | ( | bool | update = true | ) | const |
Depending on the representation this may differ from the input data information eg. if the representation shows an outline of the data, the this method will return the information about the polydata forming the outline not the input dataset.
| bool pqDataRepresentation::getDataBounds | ( | double | bounds[6] | ) |
Returns if the operation was successful.
Most consumer displays take a lookup table. This method provides access to the Lookup table, if one exists.
| unsigned long pqDataRepresentation::getFullResMemorySize | ( | ) |
This may trigger a pipeline update to obtain correct data sizes.
| pqDataRepresentation* pqDataRepresentation::getRepresentationForUpstreamSource | ( | ) | const |
This is only applicable, if this representation is connected to a data-filter which has a valid input.
signal |
signal |
signal |
This property controls the scalar coloring settings on the representation.
signal |
These properties control the shading and texture mapping.
virtualslot |
virtualslot |
overrideslot |
protectedvirtualslot |
We must detect if (and when) the display is connected to a new proxy.
inlineoverrideprotectedvirtual |
This needs to be done only once, after the object has been created.
Reimplemented from pqProxy.
Definition at line 181 of file pqDataRepresentation.h.
