| | pqPipelineRepresentation (const QString &group, const QString &name, vtkSMProxy *repr, pqServer *server, QObject *parent=NULL) |
| | ~pqPipelineRepresentation () override |
| vtkSMRepresentationProxy * | getRepresentationProxy () const |
| | pqDataRepresentation (const QString &group, const QString &name, vtkSMProxy *display, pqServer *server, QObject *parent=0) |
| | ~pqDataRepresentation () override |
| pqPipelineSource * | getInput () const |
| | Get the source/filter of which this is a display. More...
| pqOutputPort * | getOutputPortFromInput () const |
| | Returns the input pqPipelineSource's output port to which this representation is connected. More...
| vtkPVDataInformation * | getInputDataInformation () const |
| | Returns the data information for the data coming into the representation as input. More...
| vtkPVTemporalDataInformation * | getInputTemporalDataInformation () const |
| | Returns the temporal data information for the input. More...
| vtkPVDataInformation * | getRepresentedDataInformation (bool update=true) const |
| | Returns the represented data information. More...
| bool | getDataBounds (double bounds[6]) |
| | Get the data bounds for the input of this display. More...
| virtual vtkSMProxy * | getLookupTableProxy () |
| | Returns the lookuptable proxy, if any. More...
| virtual pqScalarsToColors * | getLookupTable () |
| | Returns the pqScalarsToColors object for the lookup table proxy if any. More...
| unsigned long | getFullResMemorySize () |
| | Returns the data size for the full-res data. More...
| pqDataRepresentation * | getRepresentationForUpstreamSource () const |
| | This is convenience method to return first representation for the upstream stream filter/source in the same view as this representation. More...
| | pqRepresentation (const QString &group, const QString &name, vtkSMProxy *repr, pqServer *server, QObject *parent=NULL) |
| | ~pqRepresentation () override |
| virtual bool | isVisible () const |
| | Returns if the status of the visbility property of this display. More...
| virtual void | setVisible (bool visible) |
| | Set the visibility. More...
| pqView * | getView () const |
| | Returns the view to which this representation has been added, if any. More...
| vtkSMViewProxy * | getViewProxy () const |
| | Returns the view proxy to which this representation has been added, if any. More...
| | pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=NULL) |
| | ~pqProxy () override |
| | Get the server on which this proxy exists. More...
| | This is a convenience method. More...
| | Get the name with which this proxy is registered on the server manager. More...
| | Get the vtkSMProxy this object stands for. More...
| | Gets whether or not the source has been modified. More...
| | Sets whether or not the source has been modified. More...
| | Returns the hints for this proxy, if any. More...
| | Returns a list of all helper proxies. More...
| | Returns a list of all the helper proxies added with a given key. More...
| | Returns the keys for helper proxies. More...
| | Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More...
| | Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More...
| | Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More...
| | Return whether or not the user has modified the GUI name of the source. More...
| | pqServerManagerModelItem (QObject *parent=NULL) |
| | ~pqServerManagerModelItem () override |
| enum | ModifiedState { UNINITIALIZED,
MODIFIED,
UNMODIFIED
| | The modification state of this proxy. More...
| void | dataUpdated () |
| | Fired when the representation proxy fires the vtkCommand::UpdateDataEvent. More...
| void | colorTransferFunctionModified () |
| | Fired to indicate that the "LookupTable" property (if any) on the representation was modified. More...
| void | colorArrayNameModified () |
| | Signal fired to indicate that the "ColorArrayName" property (if any) on the representation was modified. More...
| void | attrArrayNameModified () |
| | Signal fired to indicate that the rendering attribute arrays properties (Normals, TCoords, Tangents) were modified. More...
| void | visibilityChanged (bool visible) |
| | Fired when the visibility property of the underlying display changes. More...
| void | updated () |
| | Fired whenever Update() is called on the underlying display proxy. More...
| void | nameChanged (pqServerManagerModelItem *) |
| | Fired when the name of the proxy is changed. More...
| void | modifiedStateChanged (pqServerManagerModelItem *) |
| | Fired when the modified status changes for the proxy. More...
| static pqProxy * | findProxyWithHelper (vtkSMProxy *aproxy, QString &key) |
| | Returns a pqProxy instance, of any, whose helper proxy is the aproxy. More...
| static std::string | rstToHtml (const char *rstStr) |
| | convert proxy documentation from RST to HTML (so that it can be used in Qt) More...
| static QString | rstToHtml (const QString &rstStr) |
| virtual void | onInputChanged () |
| | called when input property on display changes. More...
| virtual void | onVisibilityChanged () |
| | called when the display visibility property changes. More...
| void | onProxyRegistered (const QString &, const QString &, vtkSMProxy *) |
| void | onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *) |
This is PQ representation for a single display.
A pqRepresentation represents a single vtkSMRepresentationProxy. The display can be added to only one render module or more (ofcouse on the same server, this class doesn't worry about that.
Definition at line 58 of file pqPipelineRepresentation.h.
