| void | connectionAdded (pqPipelineSource *source, pqPipelineSource *consumer, int srcOutputPort) |
| | fired when a connection is created between two pqPipelineSources. More...
| void | preConnectionAdded (pqPipelineSource *source, pqPipelineSource *consumer, int srcOutputPort) |
| void | connectionRemoved (pqPipelineSource *source, pqPipelineSource *consumer, int srcOutputPort) |
| | fired when a connection is broken between two pqPipelineSources. More...
| void | preConnectionRemoved (pqPipelineSource *source, pqPipelineSource *consumer, int srcOutputPort) |
| void | representationAdded (pqPipelineSource *source, pqDataRepresentation *repr, int srcOutputPort) |
| | fired when a representation is added. More...
| void | representationRemoved (pqPipelineSource *source, pqDataRepresentation *repr, int srcOutputPort) |
| | fired when a representation is removed. More...
| void | visibilityChanged (pqPipelineSource *source, pqDataRepresentation *repr) |
| | Fired when the visbility of a representation for the source changes. More...
| void | dataUpdated (pqPipelineSource *source) |
| | Fired right after the underlying algorithm updates (executes). More...
| void | selectionChanged (pqOutputPort *port) |
| | Fired when the selection on a port has changed. More...
| void | nameChanged (pqServerManagerModelItem *) |
| | Fired when the name of the proxy is changed. More...
| void | modifiedStateChanged (pqServerManagerModelItem *) |
| | Fired when the modified status changes for the proxy. More...
| | pqPipelineSource (const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=NULL) |
| | ~pqPipelineSource () override |
| int | getNumberOfOutputPorts () const |
| | A source may have multiple output ports. More...
| pqOutputPort * | getOutputPort (int outputport) const |
| | Returns the pqOutputPort for the given output port. More...
| pqOutputPort * | getOutputPort (const QString &portName) const |
| | Returns the pqOutputPort given the name of the port. More...
| QList< pqOutputPort * > | getOutputPorts () const |
| | Returns all the output ports. More...
| int | getNumberOfConsumers (int outputport) const |
| | Returns the number of consumers connected to the given output port. More...
| int | getNumberOfConsumers () const |
| | Get the number of consumers connected to output port 0. More...
| pqPipelineSource * | getConsumer (int outputport, int index) const |
| | Get the consumer at a particulat index on a given output port. More...
| pqPipelineSource * | getConsumer (int index) const |
| | Get consumer at a particular index on output port 0. More...
| QList< pqPipelineSource * > | getAllConsumers () const |
| | Returns a list of consumers for all output ports. More...
| QList< pqDataRepresentation * > | getRepresentations (int outputport, pqView *view) const |
| | Returns a list of representations for this source in the given view. More...
| QList< pqDataRepresentation * > | getRepresentations (pqView *view) const |
| pqDataRepresentation * | getRepresentation (int outputport, pqView *view) const |
| | Returns the first representation for this source in the given view. More...
| pqDataRepresentation * | getRepresentation (pqView *view) const |
| QList< pqView * > | getViews () const |
| | Returns a list of render modules in which this source has representations added (the representations may not be visible). More...
| void | renderAllViews (bool force=false) |
| | This method updates all render modules to which all representations for this source belong, if force is true, it for an immediate render otherwise render on idle. More...
| void | updatePipeline () |
| | Update the pipeline with the current time. More...
| vtkSMSourceProxy * | getSourceProxy () |
| | Return the vtkSMSourceProxy instance corresponding to this pqPipelineSource. More...
| | pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=NULL) |
| | ~pqProxy () override |
| | Get the server on which this proxy exists. More...
| | This is a convenience method. More...
| | Get the name with which this proxy is registered on the server manager. More...
| | Get the vtkSMProxy this object stands for. More...
| | Gets whether or not the source has been modified. More...
| | Sets whether or not the source has been modified. More...
| | Returns the hints for this proxy, if any. More...
| | Returns a list of all helper proxies. More...
| | Returns a list of all the helper proxies added with a given key. More...
| | Returns the keys for helper proxies. More...
| | Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More...
| | Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More...
| | Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More...
| | Return whether or not the user has modified the GUI name of the source. More...
| | pqServerManagerModelItem (QObject *parent=NULL) |
| | ~pqServerManagerModelItem () override |
PQ representation for a vtkSMProxy that can be involved in a pipeline.
i.e that can have input and/or output. The public API is to observe the object, changes to the pipeline structure are only through protected function. These changes happen automatically as a reflection of the SM state.
Definition at line 60 of file pqPipelineSource.h.
