Data array information like type. More...
#include <vtkPVArrayInformation.h>
| typedef vtkPVInformation | Superclass |
Public Types inherited from vtkPVInformation | |
| void | SetComponentName (vtkIdType component, const char *name) |
| Set the name for a component. More... | |
| const char * | GetComponentName (vtkIdType component) |
| Get the component name for a given component. More... | |
| void | GetDataTypeRange (double range[2]) |
| This method return the Min and Max possible range of the native data type. More... | |
| int | Compare (vtkPVArrayInformation *info) |
| Returns 1 if the array can be combined. More... | |
| void | DeepCopy (vtkPVArrayInformation *info) |
| void | CopyFromObject (vtkObject *) override |
| Transfer information about a single object into this object. More... | |
| void | AddInformation (vtkPVInformation *) override |
| Merge another information object. More... | |
| void | Initialize () |
| Remove all infommation. More... | |
| virtual void | SetDataType (int) |
| DataType is the string name of the data type: VTK_FLOAT ... More... | |
| virtual int | GetDataType () |
| virtual void | SetName (const char *) |
| Set/get array's name. More... | |
| virtual char * | GetName () |
| void | SetNumberOfComponents (int numComps) |
| Changing the number of components clears the ranges back to the default. More... | |
| virtual int | GetNumberOfComponents () |
| virtual void | SetNumberOfTuples (vtkTypeInt64) |
| Set/get the array's length. More... | |
| virtual vtkTypeInt64 | GetNumberOfTuples () |
| void | SetComponentRange (int comp, double min, double max) |
| There is a range for each component. More... | |
| void | SetComponentRange (int comp, double *range) |
| double * | GetComponentRange (int component) VTK_SIZEHINT(2) |
| void | GetComponentRange (int comp, double range[2]) |
| void | SetComponentFiniteRange (int comp, double min, double max) |
| void | SetComponentFiniteRange (int comp, double *range) |
| double * | GetComponentFiniteRange (int component) |
| void | GetComponentFiniteRange (int comp, double range[2]) |
| void | CopyToStream (vtkClientServerStream *) override |
| Manage a serialized version of the information. More... | |
| void | CopyFromStream (const vtkClientServerStream *) override |
| virtual void | SetIsPartial (int) |
| If IsPartial is true, this array is in only some of the parts of a multi-block dataset. More... | |
| virtual int | GetIsPartial () |
| void | AddInformationKeys (vtkPVArrayInformation *info) |
| Merge (union) keys into this object. More... | |
| void | AddInformationKey (const char *location, const char *name) |
| void | AddUniqueInformationKey (const char *location, const char *name) |
| int | GetNumberOfInformationKeys () |
| Get information on the InformationKeys of this array. More... | |
| const char * | GetInformationKeyLocation (int) |
| const char * | GetInformationKeyName (int) |
| int | HasInformationKey (const char *location, const char *name) |
| int | GetNumberOfStringValues () |
| For string arrays, this returns first few non-empty values. More... | |
| const char * | GetStringValue (int) |
Public Member Functions inherited from vtkPVInformation | |
| virtual void | CopyParametersToStream (vtkMultiProcessStream &) |
| Serialize/Deserialize the parameters that control how/what information is gathered. More... | |
| virtual void | CopyParametersFromStream (vtkMultiProcessStream &) |
| virtual int | GetRootOnly () |
| Set/get whether to gather information only from the root. More... | |
| static vtkPVArrayInformation * | New () |
| static vtkPVArrayInformation * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkPVInformation | |
| static vtkPVInformation * | SafeDownCast (vtkObject *o) |
Protected Attributes | |
| int | IsPartial |
| int | DataType |
| int | NumberOfComponents |
| vtkTypeInt64 | NumberOfTuples |
| char * | Name |
| double * | Ranges |
| double * | FiniteRanges |
| std::vector< std::string > | StringValues |
| vtkInternalInformationKeys * | InformationKeys |
| std::string * | DefaultComponentName |
| vtkInternalComponentNames * | ComponentNames |
Protected Attributes inherited from vtkPVInformation | |
| int | RootOnly |
This objects is for eliminating direct access to vtkDataObjects by the "client". Only vtkPVPart and vtkPVProcessModule should access the data directly. At the moment, this object is only a container and has no useful methods for operating on data. Note: I could just use vtkDataArray objects and store the range as values in the array. This would eliminate this object.
Definition at line 40 of file vtkPVArrayInformation.h.
Definition at line 44 of file vtkPVArrayInformation.h.
protecteddelete |
Reimplemented from vtkPVInformation.
Reimplemented in vtkPVGenericAttributeInformation.
the value "VTK_VOID" means that different processes have different types.
| void vtkPVArrayInformation::SetNumberOfComponents | ( | int | numComps | ) |
Must be >= 1.
Note: the const char* that is returned is only valid intill the next call to this method!
Range for component -1 is the range of the vector magnitude. The number of components should be set before these ranges.
Definition at line 99 of file vtkPVArrayInformation.h.
Definition at line 114 of file vtkPVArrayInformation.h.
| void vtkPVArrayInformation::GetDataTypeRange | ( | double | range[2] | ) |
For example if a vtkScalars consists of unsigned char data these will return (0,255). Nothing particular for 12bits data is done
| int vtkPVArrayInformation::Compare | ( | vtkPVArrayInformation * | info | ) |
It must have the same name and number of components.
| void vtkPVArrayInformation::DeepCopy | ( | vtkPVArrayInformation * | info | ) |
Implements vtkPVInformation.
By default, IsPartial is set to 0.
| void vtkPVArrayInformation::Initialize | ( | ) |
Next add will be like a copy.
| void vtkPVArrayInformation::AddInformationKeys | ( | vtkPVArrayInformation * | info | ) |
| int vtkPVArrayInformation::GetNumberOfInformationKeys | ( | ) |
| int vtkPVArrayInformation::GetNumberOfStringValues | ( | ) |
Merge (union) ranges/values into this object.
assigns to a string to DefaultComponentName for this component
protecteddelete |
Definition at line 209 of file vtkPVArrayInformation.h.
Definition at line 210 of file vtkPVArrayInformation.h.
Definition at line 211 of file vtkPVArrayInformation.h.
Definition at line 212 of file vtkPVArrayInformation.h.
Definition at line 213 of file vtkPVArrayInformation.h.
Definition at line 214 of file vtkPVArrayInformation.h.
Definition at line 215 of file vtkPVArrayInformation.h.
Definition at line 216 of file vtkPVArrayInformation.h.
Definition at line 220 of file vtkPVArrayInformation.h.
Definition at line 225 of file vtkPVArrayInformation.h.
Definition at line 230 of file vtkPVArrayInformation.h.
