| void | CopyFromFieldData (vtkFieldData *data) |
| void | CopyFromGenericAttributesOnPoints (vtkGenericAttributeCollection *data) |
| void | CopyFromGenericAttributesOnCells (vtkGenericAttributeCollection *data) |
| void | CopyFromGenericAttributes (vtkGenericAttributeCollection *data, int centering) |
| void | Initialize () |
| | Remove all infommation. More...
| vtkPVArrayInformation * | GetAttributeInformation (int attributeType) |
| | For getting default scalars ... More...
| int | IsArrayAnAttribute (int arrayIndex) |
| | Mimics data set attribute call. More...
| virtual int | GetFieldAssociation () |
| | Returns the field association to which the instance corresponds to. More...
| virtual void | SetFieldAssociation (int) |
| void | CopyFromDataSetAttributes (vtkDataSetAttributes *data) |
| | Transfer information about a single vtk data object into this object. More...
| void | DeepCopy (vtkPVDataSetAttributesInformation *info) |
| void | AddInformation (vtkPVDataSetAttributesInformation *info) |
| | Intersect information of argument with information currently in this object. More...
| void | AddInformation (vtkPVInformation *info) override |
| int | GetNumberOfArrays () const |
| | Access to information. More...
| int | GetMaximumNumberOfTuples () const |
| vtkPVArrayInformation * | GetArrayInformation (int idx) const |
| vtkPVArrayInformation * | GetArrayInformation (const char *name) const |
| void | CopyToStream (vtkClientServerStream *) override |
| | Manage a serialized version of the information. More...
| void | CopyFromStream (const vtkClientServerStream *) override |
| virtual void | CopyFromObject (vtkObject *) |
| | Transfer information about a single object into this object. More...
| virtual void | CopyParametersToStream (vtkMultiProcessStream &) |
| | Serialize/Deserialize the parameters that control how/what information is gathered. More...
| virtual void | CopyParametersFromStream (vtkMultiProcessStream &) |
| virtual int | GetRootOnly () |
| | Set/get whether to gather information only from the root. More...
List of array info.
Information associated with vtkDataSetAttributes object (i.e point data). This object does not have any user interface. It is created and destroyed on the fly as needed. It may be possible to add features of this object to vtkDataSetAttributes. That would eliminate all of the "Information" in ParaView.
Definition at line 38 of file vtkPVDataSetAttributesInformation.h.
