vtkPVTemporalDataInformation is used to gather data information over time. More...
#include <vtkPVTemporalDataInformation.h>
| typedef vtkPVInformation | Superclass |
Public Types inherited from vtkPVInformation | |
| void | CopyFromObject (vtkObject *object) override |
| Transfer information about a single object into this object. More... | |
| void | AddInformation (vtkPVInformation *info) override |
| Merge another information object. More... | |
| void | Initialize () |
| Initializes the information object. More... | |
| vtkPVDataSetAttributesInformation * | GetAttributeInformation (int attr) |
| Convenience method to get the attribute information given the attribute type. More... | |
| vtkPVArrayInformation * | GetArrayInformation (const char *arrayname, int fieldAssociation) |
| Method to find and return attribute array information for a particular array for the given attribute type if one exists. More... | |
| virtual void | SetPortNumber (int) |
| Port number controls which output port the information is gathered from. More... | |
| void | CopyToStream (vtkClientServerStream *) override |
| Manage a serialized version of the information. More... | |
| void | CopyFromStream (const vtkClientServerStream *) override |
| void | CopyParametersToStream (vtkMultiProcessStream &) override |
| Serialize/Deserialize the parameters that control how/what information is gathered. More... | |
| void | CopyParametersFromStream (vtkMultiProcessStream &) override |
| virtual int | GetNumberOfTimeSteps () |
| Returns the number of timesteps this information was gathered from. More... | |
| virtual double * | GetTimeRange () |
| Returns the time-range this information was gathered from. More... | |
| virtual void | GetTimeRange (double &, double &) |
| virtual void | GetTimeRange (double [2]) |
| virtual vtkPVDataSetAttributesInformation * | GetPointDataInformation () |
| Access to information about point/cell/vertex/edge/row data. More... | |
| virtual vtkPVDataSetAttributesInformation * | GetCellDataInformation () |
| virtual vtkPVDataSetAttributesInformation * | GetVertexDataInformation () |
| virtual vtkPVDataSetAttributesInformation * | GetEdgeDataInformation () |
| virtual vtkPVDataSetAttributesInformation * | GetRowDataInformation () |
| virtual vtkPVDataSetAttributesInformation * | GetFieldDataInformation () |
| Access to information about field data, if any. More... | |
Public Member Functions inherited from vtkPVInformation | |
| virtual int | GetRootOnly () |
| Set/get whether to gather information only from the root. More... | |
| static vtkPVTemporalDataInformation * | New () |
| static vtkPVTemporalDataInformation * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkPVInformation | |
| static vtkPVInformation * | SafeDownCast (vtkObject *o) |
Protected Attributes | |
| vtkPVDataSetAttributesInformation * | PointDataInformation |
| vtkPVDataSetAttributesInformation * | CellDataInformation |
| vtkPVDataSetAttributesInformation * | FieldDataInformation |
| vtkPVDataSetAttributesInformation * | VertexDataInformation |
| vtkPVDataSetAttributesInformation * | EdgeDataInformation |
| vtkPVDataSetAttributesInformation * | RowDataInformation |
| double | TimeRange [2] |
| int | NumberOfTimeSteps |
| int | PortNumber |
Protected Attributes inherited from vtkPVInformation | |
| int | RootOnly |
This information provided by this class is a sub-set of vtkPVDataInformation and hence this is not directly a subclass of vtkPVDataInformation. It internally uses vtkPVDataInformation to collect information about each timestep.
Definition at line 34 of file vtkPVTemporalDataInformation.h.
Definition at line 38 of file vtkPVTemporalDataInformation.h.
Reimplemented from vtkPVInformation.
This is only applicable when the vtkObject from which the information being gathered is a vtkAlgorithm. Set it to -1(default), to return the classname of the vtkAlgorithm itself. This is the only parameter that can be set on the client-side before gathering the information.
This expects the object to be a vtkAlgorithmOutput.
Calls AddInformation(info, 0).
Implements vtkPVInformation.
This are different from the ivars that constitute the gathered information itself. For example, PortNumber on vtkPVDataInformation controls what output port the data-information is gathered from.
| void vtkPVTemporalDataInformation::Initialize | ( | ) |
| vtkPVDataSetAttributesInformation* vtkPVTemporalDataInformation::GetAttributeInformation | ( | int | attr | ) |
attr can be vtkDataObject::FieldAssociations or vtkDataObject::AttributeTypes (since both are identical).
| vtkPVArrayInformation* vtkPVTemporalDataInformation::GetArrayInformation | ( | const char * | arrayname, |
| int | fieldAssociation | ||
Returns NULL if none is found. fieldAssociation can be vtkDataObject::FIELD_ASSOCIATION_POINTS, vtkDataObject::FIELD_ASSOCIATION_CELLS etc. (use vtkDataObject::FIELD_ASSOCIATION_NONE for field data) (or vtkDataObject::POINT, vtkDataObject::CELL, vtkDataObject::FIELD).
Definition at line 142 of file vtkPVTemporalDataInformation.h.
Definition at line 143 of file vtkPVTemporalDataInformation.h.
Definition at line 144 of file vtkPVTemporalDataInformation.h.
Definition at line 145 of file vtkPVTemporalDataInformation.h.
Definition at line 146 of file vtkPVTemporalDataInformation.h.
Definition at line 147 of file vtkPVTemporalDataInformation.h.
Definition at line 149 of file vtkPVTemporalDataInformation.h.
Definition at line 150 of file vtkPVTemporalDataInformation.h.
Definition at line 151 of file vtkPVTemporalDataInformation.h.
